  • TomAlborough
  • TomAlborough's Avatar
13 Jan 2025 21:42
RPi 5 with 6.12 PREEMPT_RT = Using POSIX non-realtime
Category: Installing LinuxCNC
Hello @cornholio:
I do understand some of the things you are saying.
I'm not a LinuxCNC'er so please bear with me.
A start might be to enumerate types of users as I see them:
Gold users just want to get something done (say make parts for a space station). Their CNC machines are already supported by LinuxCNC. They would appreciate a working version of LinuxCNC. Once they get it they probably will not change it over time unless they need to support new devices or new features.
The key here is that installing and getting LinuxCNC running should be as easy as it is to get Raspberry Pi 5 or Ubuntu up in the first place. (I'm not sure if my experience getting RPi5 up is similar to getting RPi4 up but more on that later).
If a newcomer can not get a version going enough to run say a "Maslow" machine (please Google "maslow cnc kit") then work still needs to be done.
Silver users/developers know and contribute to the LinuxCNC GitHub repo. The users have absolute control of the repo and the CNC, sysgen and testing features merged into it.
Bronze users/developers know and contribute to the Linux GitHub repo. The users have absolute control of the repo and the OS, sysgen and testing features merged into it.
The question comes: How to manage the need for support between Gold, Silver and Bronze users. I'm not sure of a solution here but I believe some solution will arise.
Tests should exist that (all) developers can run and get understandable results from. The only issue should be coverage at a given point in time. Hopefully the more tests you develop and manage the better off everyone should be.
I realize some of the above exists. It just needs to be pulled together.
An observation about configuration files: I think they may have gotten a bit out of hand.
I believe plain text files are easier for users to work with than XML but, a coherent "system build, installation and configuration" facility may be easier to develop and maintain if the configuration is rationally represented by some data handling facility (not a DBMS).
Please let me know your thoughts up to this point.
Many thanks,
Tom
  • MWalz
  • MWalz
13 Jan 2025 21:26
Replied by MWalz on topic StepperOnline A6 Servo
Category: EtherCAT
Thanks a lot, I can confirm your configuration works.
These are my first steps using ethercat. My mistake was that I added sdoConfig commands in the ethercat.xml to configure the PDO mapping like described in the servos manual.
Seems like it's sufficient to just add the pdoEntry's for the desired PDO mapping group and somehow it's configured automatically. By linuxcnc or the ethercat subsystem?
Maybe someone can comment/confirm this to avoid others making the same mistake.
  • RotarySMP
  • RotarySMP's Avatar
13 Jan 2025 21:20
Replied by RotarySMP on topic Gmoccapy 3.5.0 - opinions needed
Category: Gmoccapy
Thanks for adding the progress bar Norbert. I often wonder roughly how much longer a program will take.
  • chrischan
  • chrischan
13 Jan 2025 21:19
Replied by chrischan on topic Maus funktioniert nicht bei Spindel Start
Category: Deutsch
I'm using this one:
www.fif.com.pl/pl/przekazniki-elektromag..._query=Pk%202p%2012v
Can't find any information about a diode in it. So I try it tomorrow.
13 Jan 2025 21:11
Replied by tommylight on topic Maus funktioniert nicht bei Spindel Start
Category: Deutsch
Yes.
Do check if the ralay has one already, some do but mostly do not have it.
  • PCW
  • PCW's Avatar
13 Jan 2025 21:11 - 14 Jan 2025 00:47
7i95t firmware brick because i flashed a 7i95 bitfile in the fallback
Category: Driver Boards
freeby.mesanet.com/95tinit.tgz
Not sure about the executables (might be too old a libc version),
but you can get by by just programming the FPGA via JTAG
and running the two mesaflash commands.
Here is the FTDI4232 --> 10 pin header connection:
freeby.mesanet.com/pdf/parallel/4232efin.pdf
  • chrischan
  • chrischan
13 Jan 2025 20:48 - 13 Jan 2025 20:49
Category: Deutsch
That way, correct?
  • dschultz
  • dschultz
13 Jan 2025 18:28
Replied by dschultz on topic StepperOnline A6 Servo
Category: EtherCAT
These are basic with just the X axis.
  • Aciera
  • Aciera's Avatar
13 Jan 2025 17:52
Replied by Aciera on topic LinuxCNC with OKUMA OSP MX-55VA
Category: Basic Configuration
First thing you want to find out is what kind of signal interface the axes and spindle drives use (ie analog +-10V, step/direction, serial interface) that will then largely dictate the options to go forward.
  • Lcvette
  • Lcvette's Avatar
13 Jan 2025 17:23
Replied by Lcvette on topic Installation links failing
Category: QtPyVCP
links are now fixed!
  • zz912
  • zz912's Avatar
13 Jan 2025 16:57
Replied by zz912 on topic LCNC 2.10 - Ask for AUTOMATIC_G43
Category: Gmoccapy
"Should I move this thread over to the Gmoccapy section?"
Yes
  • PCW
  • PCW's Avatar
13 Jan 2025 16:32
Replied by PCW on topic 7I96S setup issue
7I96S setup issue
Category: PnCConf Wizard
I think that's a locale bug on pncconf:
forum.linuxcnc.org/27-driver-boards/5145...ettings-issue#291810
  • Jdolecki
  • Jdolecki
13 Jan 2025 16:13
7I96S setup issue was created by Jdolecki
7I96S setup issue
As I wait for my 7I96s to arrive I’m playing with the PcConfing trying to set it up and I keep getting stopped at this point.
im using a Rasberry pi 4
XY lathe
Gmoccapy
7i96s -internal data
Firmware 7i96s_7i74
When I go to apply the stepper config I get this error.
what am I entering wrong or missing?
  • etoimene
  • etoimene
13 Jan 2025 16:02
LinuxCNC with OKUMA OSP MX-55VA was created by etoimene
Hi all!
I was asked by friend to help him modernize the above mentioned machine.
It is still fully operational but programming it is PITA.
We would like to use something modern and not break the bank.
That's what got me here.
I am IT guy with some basic CNC understanding.
I also have available Advantech PPC-L106 R70-XE industrial panel PC we could use but that might be an overkill.
Laptop on the side would be perfectly acceptable.
I am 100% confident I could install LinuxCNC but configuring it to work safely with that machine might be a steep learning curve.
Any pointers in ht right direction are highly appreciated.
And now excuse me, I have reading to do.
linuxcnc.org/docs/stable/html/getting-st...#sec:config-launcher
Best regards from Croatia!
Displaying 19936 - 19950 out of 21716 results.
Time to create page: 0.489 seconds
