  • La Pendule
  • La Pendule
08 Jan 2025 13:40 - 09 Jan 2025 08:35
bookworm/master-uspace/binary-amd64 was created by La Pendule
Category: Installing LinuxCNC
Hi all,
Just one question: On buildbot2.highlab the bookworm/master-uspace/binary-amd64 has not been updated since 2024 October 24th.
The source is now version 2.10.0-pre0-3979-gbc86e90f8b from  January 7th. 2025
LinuxCNC can so not more be updated via synaptic or apt install.
Is there a chance that the binary-amd64 will be updated soon ?
Thanks a lot for help
Regards
PW
Update 2025.01.09:
This morning the
binary-amd64 was updated. Thanks a lot to all contributors.
PW
  • slowpoke
  • slowpoke
08 Jan 2025 13:31 - 08 Jan 2025 13:52
7i96s Questions was created by slowpoke
7i96s Questions
Category: Driver Boards
Google search led me to this "Driver Boards" section of the forum, I had no idea it existed I was posting related question under General etc, apologies for my past transgressions.
My understanding is that some Mesa boards load their FPGA firmware every time they power up and others are non-volatile.So I guess:
1) If you have the former, you can just provide a different file in the correct location and change the boards functionality?
2) if you have the latter you need to re-flash the FPGA?
3) I'm using a 7196S for my lathe (WIP), so is the 7i96S volatile or non-volatile?
4) I have a quadrature encoding glass scale on my Z-axis connected to isolated inputs 0&1 (TB3-1&2), and this works fine unless I move quickly, apparently the inm's (I'm assuming this means input mux) scan rate can be increased. Not sure where the scan rate is changed, is that a HAL type parameter or do I need to reprogram the FPGA?  And how do I increase the scan rate?
5) If after maximizing the mux scan rate I find it's still too slow for fast moves and I instead connect the scales to the P1 expansion port, do I need to re-flash the FPGA, or is it already configured for quadrature encoder inputs? In total I will need to connect two scales and one MPG. Not counting the spindle encoder connections to TB2. Where do I find documentation on the expansion port and mapping of quadrature inputs to those P1 pins?
your help is much appreciated.
  • Beovoxo
  • Beovoxo
08 Jan 2025 13:22
Replied by Beovoxo on topic Deckel FP4A Retrofit
Category: Milling Machines
Godt the first pack of IO Boards today :) and waiting for the rest plus the controller.
  • JT
  • JT's Avatar
08 Jan 2025 13:13
Replied by JT on topic Flexible GUI
Flexible GUI
Category: Flex GUI
Kind of a bummer about the bold text thing
What bold text thing?
JT
  • pob2
  • pob2
08 Jan 2025 12:41
Replied by pob2 on topic mesa 5i20 and DAC
mesa 5i20 and DAC
Hi All,
I realise this is a very old thread - but I have a maho 400p too that is dead, as well and am looking to update the control (mine was a  Heidenhain TNC 135).  I don't hold much hope in getting the EPROM programs even if I did find a new heidenhain controller, so was thinking of a very similar approach to you stormpetrel.
I have no experience in CNC  refitting whatsoever but I hope to dust off some experience in PID controllers and power electronics from a very very long time ago, so I think I can manage the learning curve and I plan to take a lot of time to work out what to do with my machine.
I don't want to convert to three axis cnc or to replace trapezoidal with ballscrews, I want to get the machine back to a manual mill with a 'smart DRO', intact EMO chain and hydraulic functions etc, and hopefully keep the point -to point control function as it used to have, so I am thinking of one axis cnc and selecting each axis at atime in code.
So, to my question :  (I hope someone reads this given the original thread was 15 years ago!)
- the 5i20 and DAC approach was the way you suggested PCW back in 2010,  but given the time elapsed between now and then, what would you recommend now?
-stormpetrel, how did your project go, did you find it worked out, and where would you do things differently?
- as a starting point, and to see the complexity of all this would it be possible for you to send me  the design that you settled on back then?
I'm new to this forum and it was not apparent how private messages are sent. if this post doesn't find any replies I might repost it as a separate thread with reference to this one.
Thanks in advance,
Pat
08 Jan 2025 12:34
Replied by tommylight on topic pncconf Clearpath SDSK settings
The maximum acceleration I calculated as 49800 mm/sec^2 is WORLDS away from the default 750, and pncconf doesn't allow more than 10000.
Unless that is a very small 3D printer, 49800 mm/sec^2 is way, way, way to high.
  • rodw
  • rodw's Avatar
08 Jan 2025 12:28
Strange error after stopping file and adjusting part zero
Sometime this happens if your gcode is written to use absolute IJK coordinates on arcs but you are using relative coordinates or vice versa.
  • JT
  • JT's Avatar
08 Jan 2025 12:25
Flexible GUI
Category: Flex GUI
Looking good!
JT
  • rodw
  • rodw's Avatar
08 Jan 2025 12:23
RPi 5 with 6.12 PREEMPT_RT = Using POSIX non-realtime
Allan, I have not quite got to 6.12 on my installer but I did  merge ther upstream to my master branch to get 6.12 support
github.com/rodw-au/rpi-img-builder-lcnc
This runs on a normal PC and cross compiles.
The main branch did compile 6.12
It would need cloning my 2.9.3 branch to a new branch and merging the master branch into it
Then a bit of massaging to remove the existing RT patch and configuring a few config files in the top level folder.
I remember seeing someone here saying you needed to set a few more config settings that used to be set in the patch. They also included a script to set it up. Perhaps that is your issue.
  • blazini36
  • blazini36
08 Jan 2025 12:10 - 08 Jan 2025 12:11
Replied by blazini36 on topic Flexible GUI
Flexible GUI
Category: Flex GUI
Lol yeah, I noticed them in the docs and started adding them before updating the debs.....
Kinda tedious but it's getting there...
  • Aciera
  • Aciera's Avatar
08 Jan 2025 12:08
That is a valid error. Why you are getting it is impossible to say without at least seeing the gcode program.
  • JT
  • JT's Avatar
08 Jan 2025 11:54
Flexible GUI
Category: Flex GUI
I also noticed there's no good binary indicators in qt5's standard set of widgets, like LEDs or even a button that changes appearance on input. The only thing I've found is hal labels, but even then I think they are only actually good for displaying numeric values. If set to "bit" type input, they just display true or false. I don't see any way to make a text string appear or disappear at least. Looking for something that can just indicate a fault.
If something like this is already there just point it out, I'm good at missing things.
You didn't miss anything unless you looked in the last few minutes lol. I just added that feature.
gnipsel.com/linuxcnc/flexgui/hal.html#bool-label
JT
  • alangibson
  • alangibson
08 Jan 2025 11:38
Hello all. I'm trying out LinuxCNC 2.9.3 on the 6.12 kernel running on a Raspberry Pi 5. Installation goes fine, but LinuxCNC refuses to acknowledge I'm running a realtime kernel. On startup, it spits out the message: "Note: Using POSIX non-realtime"
However, `uname-a` shows:
Linux plasma 6.12.8-v8-16k+ #1 SMP PREEMPT_RT Tue Jan  7 22:00:59 CET 2025 aarch64 GNU/Linux
My installations script is here:
gist.github.com/alangibson/12700b72f737889536565896143eefe0
Can anyone make out my mistake? Or is there a known issue? I've searched but found nothing applicable.
  • rodw
  • rodw's Avatar
08 Jan 2025 10:58
Replied by rodw on topic pncconf Clearpath SDSK settings
You can edit the ini file directly to set the accelleration.
Read the docs on ini file configuration
But I think you will find more than 3000-5000 will shake your machine apart,
  • JT
  • JT's Avatar
08 Jan 2025 10:33
Flexible GUI
Category: Flex GUI
All the menu items have push buttons as well.
gnipsel.com/linuxcnc/flexgui/controls.html#push-buttons
Let me look into adding user text to a bit type hal label.
JT
Displaying 20371 - 20385 out of 21722 results.
Time to create page: 0.404 seconds
