  • Jensner
  • Jensner
24 Oct 2024 15:10 - 24 Oct 2024 15:18
Unexpected realtime delay on task 0 with period 1000000
Category: QtPyVCP
rtt min/avg/max/mdev = 0.044/0.061/9.253/0.062 ms
The 9.253 ms is the issue
I suspect you have Realtek Ethernet hardware so need to install the DKMS driverAh
Ah... OK.
So I will try it..
Give you some feedback
I Think Your right...
  • Grotius
  • Grotius's Avatar
24 Oct 2024 15:08
Replied by Grotius on topic linuxcnc trajectory planner
Hi Arciera,
Thanks.
I repaired a mistake. The tpmod.so was pointing to the ~/rtlib instead of ~/lib path for finding liblinuxcnchal.so
However my 2 tests worked:
Removed the ~/lib & ~/rtlib content, removed all build dirs. And did ./installer
It just worked.
Then i cloned a new linuxcnc_trajectory_planner into a testdir. Then ./installer.
I worked.
If above isnt working, curious what happens if:
Me thinking your pc is not searching the ~/lib dir.
if you are in the ~/lib dir and do : sudo ldconfig .
The same in the ~/rtlib dir and do : sudo ldconfig .
  • Micro2000
  • Micro2000
24 Oct 2024 15:04
Replied by Micro2000 on topic Base Thread Over 100k
Do you know of an older model that will work? The reason why I ask is I was having screen resolution errors come up when I would use the built in graphics.
  • ric812
  • ric812
24 Oct 2024 14:58
  • tcbmetalworks
  • tcbmetalworks
24 Oct 2024 14:57
Replied by tcbmetalworks on topic Building new plasma table
I understand that any computer will do but with my previous set up I've ran into issues with the actual computer being unstable. Halfway threw cutting the thing crashes complete freeze up. I am looking for a computer that is able to handle being left on for days on end no instability.
  • PCW
  • PCW's Avatar
24 Oct 2024 14:22
Replied by PCW on topic About lathe spindle encoder
How do you intend to send the count and control signals to the PC?
24 Oct 2024 14:13
Replied by tommylight on topic Base Thread Over 100k
What about redeon/amd
Hit and miss, some work nicely, some do not.
  • Micro2000
  • Micro2000
24 Oct 2024 14:10
  • btvpimill
  • btvpimill
24 Oct 2024 14:01
Machine moves when you stop program in the middle
Awesome thank you!! So If I want to use easy probe I need to upgrade my version of LinuxCNC?
  • MennilTossFlykune
  • MennilTossFlykune
24 Oct 2024 14:01
Replied by MennilTossFlykune on topic Gmoccapy - spindle restarts at program stop
Category: Gmoccapy
I'm still not sure exactly how to describe this issue, I can only demonstrate it.
You can see here how G61/G64 are related to this:
The larger the P value the further into the program the interpreter will be able to read.
If the interpreter has reached a queuebuster when the program is aborted, the interpreter state and machine state will be synched properly(?)
  • The Egyptian
  • The Egyptian
24 Oct 2024 13:55
Replied by The Egyptian on topic About lathe spindle encoder
My problem is how to write hal configuration for this operation i'm fimilier with arduino code but i'm new to linuxcnc can you help me with hal config
  • PCW
  • PCW's Avatar
24 Oct 2024 13:51
Category: QtPyVCP
24 Oct 2024 13:46 - 24 Oct 2024 13:47
You mean the RTAI kernel?
It should be on our server as it also goes with the RTAI version of LinuxCNC.
See the documentation on how to proceed for 2.8.4
Edit
That does not mean you keep the 1050, it has to go out, NVIDIA cards cause latency issues, so should not be used.
Displaying 22306 - 22320 out of 22555 results.
Time to create page: 0.636 seconds
