18 Oct 2024 01:51
KERT mill and Hardinge lathe retrofitted with LinuxCNC
Category: Show Your Stuff
Been over 8 month since his last upload, i really hope he is OK.
18 Oct 2024 01:46
Yotube and InstaGram links to my channels, frequently updated
Added the old youtube channel on the first post, plenty of videos there.
Rod, i did check some stuff online, was quoted 3200-3800$ just to get a 110KG box sized 3.5x0.8x0.8 meters from the ship to a truck outside the port. Should be lower as there are no customs in USA for stuff made here, but that requires a lot of paperwork. And my brother is not interested at all in using it, to complicated for him.
18 Oct 2024 01:24
Replied by tommylight on topic Mazak Quickturn 10 x2 retrofit ideas!
Category: Turning
For me it is easy, although time consuming, and the fact that mice ate the cabling only pushed me to do the retrofit sooner as i already had all the hardware ready and waiting. This was a fully working machine before the mice incident.
As for step/dir vs analog, i used them both and it is the same for me, i like both.
Mine had some "backwards" resolvers so i had to switch to encoders, i would have liked to keep the resolvers for sure.
VFD was easy, after figuring out what pin/wire does what. The relay board with ... many relays was a pain to follow and test and wire in, but a quickly made magnetic phone holder helped a lot, stick it somewhere-set it to record the DVM-go chase cables around the machine-watch video! :) Nice physical workout, for sure.
I still have some stuff left to wire in as i need another Mesa 7i84 or i can replace the one in the control panel with a 7i73 as i have one and put the 7i84 from the control panel on the back.
Besides foot pedals, can not recall what else was left out, but the machine is fully functional...with a missing hydraulic chuck! :(
If you machine is similar to mine, there are a lot of IO there, so i am not sure Pico can handle that but i hope Jon sees this and he can confirm if that is OK.
Mesa also has some boards for resolvers, but first do check what you have to make sure they can work for you.
  • gardenweazel
  • gardenweazel's Avatar
18 Oct 2024 00:55
Replied by gardenweazel on topic Inconsistent values from Versaprobe
Category: Qtvcp
So, the call to save the tool offset is in the qt_auto_probe_tool.ngc on or around line 202-203 seems to be mangling the tool.tbl format.
203 G10 L1 P#<tool> Z[#<calculated_offset>]
Which occurs after the OKAY click of the tool change prompt. I've checked it before and after.
  • Appliedmarine
  • Appliedmarine
18 Oct 2024 00:55
Replied by Appliedmarine on topic Mazak Quickturn 10 x2 retrofit ideas!
Category: Turning
Thank you Tommylight,
I read that post last night! very interesting build you've done!
Looking back, would it have been worth changing to step/direction digital servos or worth the effort involved with the analogue gear?
Was the VFD hard to integrate into linux with the MESA system? I'm looking at using Pico systems, as they might have a converter for the resolvers.
18 Oct 2024 00:32
Replied by tommylight on topic Внешняя кнопка
Внешняя кнопка
We need the board type/make as it can not be seen good in the pictures, the green thing with lots of cables.
Also upload here the
TPS.hal
TPS.ini
files so we can have a look at them.
18 Oct 2024 00:28
  • PCW
  • PCW's Avatar
18 Oct 2024 00:22
Replied by PCW on topic 7I33TA Just plug it in?
Category: Driver Boards
If you spindle drive can use 5V PWM/DIR control
(and you are not using all 6 step/dir outputs on the 7I52S)
it might be easiest to use firmware that changes one of the 6
step/dir outputs on the 7I52S to PWM/DIR
18 Oct 2024 00:20
Replied by tommylight on topic Mesa 7i96s torch on/off connection
That would require opening the plasma source and wiring in the torch on, voltage, and optionally arc ok signals.
That is also very dangerous and requires some electrical experience, do you have anyone to help with that?
  • Deckerjwd
  • Deckerjwd's Avatar
18 Oct 2024 00:16
7I33TA Just plug it in? was created by Deckerjwd
retrofitting a mazak vtc-20b and it is going great, i have step and dir to all the servo drives. that is running off a 7i52s in first connecter P4, i have a 7i44 on p2, i would like to run a 7i33ta in the middle for the analog spindle. can i just plug it in or do i need a new firmware for the 5i24-24?
also seem like a lot to use a whole 7i33ta just for the spindle, maybe i could use pwm and dir with the gs2015 spindle drive?
18 Oct 2024 00:16
Replied by tommylight on topic PNCconfig error
PNCconfig error
After pressing start in PncConf, uncheck the "show advanced option pages" and continue on.
  • okielaxplyr
  • okielaxplyr
18 Oct 2024 00:10
Replied by okielaxplyr on topic PNCconfig error
PNCconfig error
hello Tommy,
PNCconfig will not continue past the External Controls after error.
Regards
  • ric812
  • ric812
17 Oct 2024 23:45
Mesa 7i96s torch on/off connection was created by ric812
I am building a CNC plasma table and I am going to use QtplasmaC. I am trying to find out the correct pin out for Torch on/off and Arc OK. I am using the Mesa 7i96S board with a THCAD - 10. I have attached the wiring diagram I am using but it is for a plasma cutter with external connectors. The plasma cutter I am using is older and does not have any of those.
  • Benb
  • Benb's Avatar
17 Oct 2024 23:25
Replied by Benb on topic linuxcnc-dev is missing?
Category: Installing LinuxCNC
It looks like you have debian in your e drive and its trying read files from it.
E: Unable to locate package libtool-bin
E: Package 'bison' has no installation candidate
E: Package 'flex' has no installation candidate
E: Unable to locate package libelf-dev
E: Unable to locate package libacl1-dev
  • ccc774
  • ccc774
17 Oct 2024 22:57 - 21 Oct 2024 22:07
Replied by ccc774 on topic Can the OPI5 be Configured to Run LCNC?
 The ID returned by blkid is the same that I have in armbianEnv and it is the same ID that it says it does not recognize when booting.
Displaying 22681 - 22695 out of 22719 results.
Time to create page: 0.504 seconds
