  • PCW
  • PCW's Avatar
18 Aug 2024 15:20
Replied by PCW on topic Getting an error on starting a machine
Could be cabling problem but the "ip a" report shows
the link as up,  could also a be a host PC issue, or be a
7I76E issue.
What do the LEDs on the 7I76E RJ45 connector show?
18 Aug 2024 15:05
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
From memory the TXS level shifters are not really designed for driving a cable of any length, ie they are more for component to component on the same board.
The fet bus switches I use with pull-up resistors on the high side will easily drive a generic breakout board on the end of a 1.8m Parallel Port cable. TBH I copied this method from the Mesa 7i92 or 7c81 schematics, so I don’t claim any originality just can confirm that it is reliable. The only issue being that a buffer is required to drive any load, but 99% of breakout boards use them anyways.
On the other hand if you want to set 8 pins aside for dedicated inputs that are 5v tolerant via a 3.3v device a 74lvc245 is the part you want.
  • __Tom
  • __Tom
18 Aug 2024 14:58
Replied by __Tom on topic Getting an error on starting a machine
Oh yes my fault, 10.10.10.10 returns nothing.
So I suppose the mesa is gone.
  • PCW
  • PCW's Avatar
18 Aug 2024 14:44
You would need to
ping 10.10.10.10
To check connectivity to the 7I76E
  • __Tom
  • __Tom
18 Aug 2024 14:39
the output from command "ip a" and "ping 10.0.0.10"
  • meister
  • meister
18 Aug 2024 14:36
TangNano9K + W5500 to 2xBOB-IO
W5500
Level-Shifter (TXS0108E)
RGB-LED
Modbus
I2C - 5V (hope this will work via the level-shifter)
Maybe a good and cheap universal-board
  • JT
  • JT's Avatar
18 Aug 2024 14:22
Replied by JT on topic Flexible GUI
Flexible GUI
Category: Other User Interfaces
I added a drill speed and feed calculator.
JT
  • Kittifix
  • Kittifix
18 Aug 2024 13:49
Replied by Kittifix on topic HP EliteDesk 800 G2 VGA Scrambled
Category: Installing LinuxCNC
Same Problems here ,791,798 and .... no Way
Solved - navigate to Install -- press Tab and change "vga=788" to "vga=normal"
Enter and go ...
für die Suchmaschine : Installation Pixelbrei Klötzchen Grafikfehler verstümmelt
  • PCW
  • PCW's Avatar
18 Aug 2024 13:39
That error means there is no communication with the 7I76E
what does the command
ip a
report?
  • PhilipME
  • PhilipME's Avatar
18 Aug 2024 13:15
Replied by PhilipME on topic very basic mdi call
very basic mdi call
Category: O Codes (subroutines) and NGCGUI
I'm sorry, looking at your initial post again I'm not sure where this comes from:
[RS274NGC]
I'm not aware of a '[MACROS]' entry in the ini file.
So try this:
It is working now
I removed the entry [MACROS], it does not make any differance.
my next step is to tie the subroutine file to a soft button in the extended panel. And I think I know how to do that by now.
The step after that is to understand the full z-probe subroutine.
Have a good day
Philip
  • __Tom
  • __Tom
18 Aug 2024 13:01
Hello, hope someone of you can help me.I have 2 machines defined on one mesa 7i76e card a mill and a plasma cutter. Both was working well until an error came up. In the most cases an reboot of hard and software fixed all the troubles I had so far. But this one seams to be different. On rebooting on both of the machines I get the same error (please see the attached file) Hopefully I have no hardware damage.Thanks for your afford in advance. BR. Tom
  • JT
  • JT's Avatar
18 Aug 2024 11:58
Replied by JT on topic Mesa Configuration Tool
Category: Configuration Tools
Thanks PCW this has been fixed.
JT
18 Aug 2024 11:57 - 18 Aug 2024 11:58
Replied by Cant do this anymore bye all on topic SmartSerial Master for Arduino - exist? Possible?
Category: Driver Boards
That's the thing about Arduino, it's made people lazy and think everything can be solved via an arduino sketch.
It's like the guy that only owns a hammer, he thinks it can fix everything.
It's not just the programming you may want a good idea of how the hardware is connected. You'd need to know which pins go where.
  • anfänger
  • anfänger's Avatar
18 Aug 2024 11:55
probe_basic read jog increments was created by anfänger
Category: QtPyVCP
is there a way to read what jog increments are active? I want to use this buttons to scale ma jog wheels.
Thanks Patrick
Displaying 23746 - 23760 out of 24349 results.
Time to create page: 0.640 seconds
