  • karlhe
  • karlhe
16 Aug 2024 09:40 - 22 Aug 2024 16:25
Replied by karlhe on topic easyprobe linuxcnc
easyprobe linuxcnc
Category: Installing LinuxCNC
Hallo, ich muß das später noch mal nachtragen.
Hat nicht geklappt..
bis später
karlhe
  • Plasmanfm
  • Plasmanfm
16 Aug 2024 09:34
Replied by Plasmanfm on topic QtPlasmaC 7i96s Mesa THC Carte
Category: Deutsch
Ok tommylight und danke….
Torch on und Ark ok sowie 0-10 V für den Strom habe ich im Standart-Anschluss Zwei hätte ich frei gehabt der Anschluss ist aber nicht geschirmte !
Nun gut wenn das Probleme macht das bekommt das Gerät ein weiteren Plug mit Cat-Kabel.
King regarde
Juergen
  • Moutomation
  • Moutomation
  • Aciera
  • Aciera's Avatar
16 Aug 2024 09:25 - 16 Aug 2024 09:26
Replied by Aciera on topic easyprobe linuxcnc
easyprobe linuxcnc
Anhang mit dem Fehler fehlt.
  • karlhe
  • karlhe
16 Aug 2024 09:22 - 22 Aug 2024 16:21
easyprobe linuxcnc was created by karlhe
easyprobe linuxcnc
  • Mecanix
  • Mecanix
16 Aug 2024 09:12 - 16 Aug 2024 09:16
thanks guys, you show me again that i'm on the right track :)
Yes. You are. Confirmed. 1000% spot on and a great visionary (imho).
If you don't mind/allow, let me know when you believe to have a semi-final stable solution of the Generator & Gui and I'll fork over. I'll bring in RIO for a "Gowin-Only Maintained Solution" and clean up the code of other toolchains, and everything else irrelevant to gowin. We can swap updates/features and ideas along. I'll point over to you for sources...
ps. great way to publish that 5ax board sources and offloading from you any potential support/requests relating to that board/solution.
  • rodw
  • rodw's Avatar
16 Aug 2024 08:59
Ethercat installation from repositories - how to step by step
Category: EtherCAT
You need to install the  linuxcnc image from the downloads page then follow the first post here
  • Aciera
  • Aciera's Avatar
16 Aug 2024 08:59
Replied by Aciera on topic How to setup gearbox/reducer
Category: Basic Configuration
Looking at my notes on my Melfa robot config using absolute encoders it seems that the value in [Joint_n] SCALE is
360/gearbox_ratio
So for my 80:1 geared J0 I have SCALE = -4.5
for my 120:1 J1 I have SCALE = -3
And so on.
I'm not sure how I came up with that idea but it certainly works for me.
  • meister
  • meister
16 Aug 2024 08:53
One of the reasons for RIO was the poor availability of mesa boards.
i will concentrate again on the ICE40 and epc5 in connection with yosys/nestpnr. There I have no stress with licences or availability.
with Kicat it works better and better (before i was very limited with eagle-cad), so i will probably build another board like the Tangoboard, but this time with ICE40 and with W5500 .
I might also pursue an old approach for a modular board,
I had already done some tests:
  • Moutomation
  • Moutomation
16 Aug 2024 08:46
Category: EtherCAT
thanks a lot
What steps should I follow to configure ethercat?
cnc@raspberrypi:~/Desktop$ ethercat slave
bash: ethercat: command not found
cnc@raspberrypi:~/Desktop$ sudo geany /etc/ethercat.conf
cnc@raspberrypi:~/Desktop$ sudo systemctl enable ethercat.service
Failed to enable unit: Unit file ethercat.service does not exist.
cnc@raspberrypi:~/Desktop$ sudo systemctl start ethercat.service
Failed to start ethercat.service: Unit ethercat.service not found.
cnc@raspberrypi:~/Desktop$ sudo systemctl status ethercat.service
Unit ethercat.service could not be found.
cnc@raspberrypi:~/Desktop$ sudo chmod 666 /dev/EtherCAT0
chmod: cannot access '/dev/EtherCAT0': No such file or directory
cnc@raspberrypi:~/Desktop$ ethercat slaves
  • Mecanix
  • Mecanix
16 Aug 2024 08:42
@rthorntn
Don't. Don't do it man lol You've been warned. We'll figure out a way to get this board made avail somehow, no choice (in my case anyway).
  • Mecanix
  • Mecanix
16 Aug 2024 08:32 - 16 Aug 2024 12:55
I give up
Magic words!! I just did too, gotta call it quit bcuz I honestly can't make this medieval decade old crap working half-reliably whatever I try. Spent most of today learning this analconda python env, the whole things randomly puts up missing headers although all deps are in, ISE freezes, throws million warnings for no valid reasons, let alone unable to flash a bin over using openfpga among several others I've tried. Just nothing at all works - utter thrash all around in a few words. 20+hrs I'll never have back lool Honestly not recommending anyone to jump in the same bunny hole as I did, annihilates the awesomeness and rep of RIO entirely.
Nuff ghetto. Back to Gowin's EDA. Epic simplicity, less than gig dwload high-performance eda, 15mhz bin flasher/debugger, flawless under linux, ultimate 2-clicks-max joy at a reasonable price. STRONGLY ADVISED.
  • DPFlex
  • DPFlex
16 Aug 2024 07:27
Replied by DPFlex on topic How to setup gearbox/reducer
Hello Todd,
I understand that you make example of "incremental encoder" with quadrature.
My encoder is 17 bit absolute multi-turn type, so the counts for one turn is huge value 131072.
I calculate: 131072*80/360 = 29127.111111. Is it still correct to apply ?.
I put ENCODER_SCALE = 29127.111111 to INI file, but nothing happen.
I understand need to revise HAL file to use ENCODER_SCALE, but it seem encoder component is only suitable to incremental encoder type.
linuxcnc.org/docs/devel/html/man/man9/encoder.9.html
Please advise :) Thank you.
  • DPFlex
  • DPFlex
16 Aug 2024 07:16
Hi Tommylight,
My system is:
- Drive: AC Servo EtherCAT drive
- Motor is installed in SCARA robot
- The encoder: 17 bit optical absolute multi-turn. Its resolution is 131072, so I understand it has 131072 counts for one turn.
- The mechanical gearbox ratio is 80:1, fixed with motor.
Hope it is all you need :) Thank you.
  • rodw
  • rodw's Avatar
16 Aug 2024 07:14
Category: EtherCAT
looks like you need you use sudo sudo su before running the script
Displaying 23866 - 23880 out of 24348 results.
Time to create page: 1.376 seconds
