  • amitsa
  • amitsa's Avatar
14 Aug 2024 19:30
Replied by amitsa on topic Jogging not working on basic setup
Category: Basic Configuration
I posted the original hal and INI files.  But I'm not sure if there are other files you were referring to.
Right now the files are for a 2 AXIS setup with a pair of Y joints.  I'm just trying to get jogging to work for these axis' before adding the Z axis.
  • PCW
  • PCW's Avatar
14 Aug 2024 19:27
qtplasmac (Operation Error: hm2/hm2_7i76e.0:) in middle of cut
Category: Plasmac
This brings up the question is why in the world is ethtool not included in the
LinuxCNC distribution (plus the RT8168 DKMS driver should be as well)
These affect all LinuxCNC Ethernet connected motion devices, not just Mesa
14 Aug 2024 19:16
Category: Plasmac
Find a USB-wireless dongle and connect to internet.
14 Aug 2024 19:15
Replied by tommylight on topic Jogging not working on basic setup
Attach the proper files, what are we supposed to do with crippled files?
  • RMJ fabrication
  • RMJ fabrication
  • amitsa
  • amitsa's Avatar
14 Aug 2024 19:08
Jogging not working on basic setup was created by amitsa
I'm new to LinuxCNC and hobbyist machining.  For some reason, jogging isn't working on my 3 Axis setup. I feel like I'm just missing one critical configuration but can't figure it out.  I got homing to work from the Axis GUI, but jogging doesn't work.
I've posted my INI files and HAL files.  I've only included X axis configurations for brevity.  Any tips ?
System Details
* Raspberry Pi 5
* LinuxCNC 2.9.3
  • dave.franchino@gmail.com
14 Aug 2024 18:55
configuring GPIO for a Raspberry Pi 4B was created by dave.franchino@gmail.com
Category: Configuration Tools
Hey kind folks,
I am working to configure a Raspberry pi 4B to run LinuxCNC for a two-axis machine I'm building.  I am using the HAL driver for Raspberrry PI GPIO pins (hal_pi_gpio).
I am proposing to use the following pins:
net Xdir => hal_pi_gpio.pin-15-out
net Xstep => hal_pi_gpio.pin-16-out
net Ydir => hal_pi_gpio.pin-18-out
net Ystep => hal_pi_gpio.pin-22-out
When I start LinuxCNC the HAL file appears to be loading properly.
But if I go to a terminal and say Halcmd show pins  - it appears to be showing my pins configured as INPUTS - not outputs?
(I'm assuming that's what the direction column in the show pins command means).
nc@raspberrypi:~/Desktop$ halcmd show pin
Component Pins:
Owner   Type  Dir         Value  Name
    28  bit   IN          FALSE  hal_pi_gpio.pin-15-out <== Xdir
    28  bit   IN          FALSE  hal_pi_gpio.pin-16-out <== Xstep
    28  bit   IN          FALSE  hal_pi_gpio.pin-18-out <== Ydir
    28  bit   IN          FALSE  hal_pi_gpio.pin-22-out <== Ystep
I'm pretty sure I did the math on the mask right although I could be wrong. To confirm, I just tried masking for one output and it still shows up as IN.
The documentation says I should add up the hex values for all pins that should be configured as an output which I think is what I've done.
Anyone see what I'm missing?  Thanks!!!!
my full .hal file follows:
# Generated by stepconf 1.1 at Fri Nov 17 17:18:50 2023
# overwritten when you run stepconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
# Load the Raspberry Pi GPIO driver
loadrt hal_pi_gpio dir=0x00F00040
loadrt stepgen step_type=0,0
# Add to the base thread
addf hal_pi_gpio.read base-thread
addf hal_pi_gpio.write base-thread
addf stepgen.update-freq servo-thread
# Configure output pins
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 35000
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable joint.1.amp-enable-out => stepgen.1.enable
net estop-out => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
  • blazedforever
  • blazedforever
14 Aug 2024 18:51 - 14 Aug 2024 19:31
Replied by blazedforever on topic Configuring a dual stage axis
Hey thanks for that information! I think it will probably be fine for my needs, mostly light duty stuff and the stage I have planned seems rigid enough. I kind of want to give it a go and see the results. If anybody has more information or examples on how this configuration might work that would be appreciated. I'm digging into the manual , still at a bit of a loss on where to start.
  • RMJ fabrication
  • RMJ fabrication
14 Aug 2024 18:27 - 14 Aug 2024 18:29
Category: Plasmac
My computer is not connected to the internet and has no wifi should I connect to the internet and try again? I used a cable to do the installation and then I disconnected it to connect the 7i76e.
  • Hauligali22
  • Hauligali22
14 Aug 2024 18:06
Replied by Hauligali22 on topic Linuxcnc with Computer Vision …
Hi Hamel2020,
I am currently attempting to integrate computer vision in a cnc machine to develop a closed-loop system. My idea was also to hopefully update the original g-code in real-time but I have been also recommended to use external offsets instead. What progress have you made? Thanks!
  • PCW
  • PCW's Avatar
14 Aug 2024 17:58
Category: Plasmac
Yes, looks like you have no network connectivity.
What does
ip a
report
14 Aug 2024 17:49
Replied by tommylight on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
Sorry but i can not help you with stuff i have no clue about, the bash is trying to run an executable file that i do not know what it contains, etc, etc.
I do admire your will to try and fix it and you being hell bent on learning new stuff, but at some point you have to cut the losses and move on.
Find another hard drive, cheap used one, install everything you need, and if this succeeds, then get rid of the old one. This way you still have a backup.
14 Aug 2024 17:45
Category: Plasmac
On your screenshot, it clearly states to do
sudo apt-get update
and try again
Although, this being a networking issue, i have to ask:
-how is the PC wired to internet?
-If wired through cable, did you revert back the network settings?
  • Muftijaja
  • Muftijaja
14 Aug 2024 17:17
Replied by Muftijaja on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
Hello tommylight! I know, you said this somewhere at the beginning of this thread. I must say, I did not know anything about the fickleness of this theme. I am (now as before) absolute newbie to Linux and Linuxcnc, I made my config with the wizard and afaik, I did not touch the /etc/network files at any time until someone in this thread told me to do this. I did not play around with settings but tried to consolidate the network with the help of the guys here. If I have done sth. wrong, I apologize.
Any help with my latest questions (bash) is welcome.
Cheers, Hanno
  • RMJ fabrication
  • RMJ fabrication
Displaying 23896 - 23910 out of 24447 results.
Time to create page: 1.442 seconds
