13 Aug 2024 08:09
Replied by Cant do this anymore bye all on topic Computer crashing
Computer crashing
Category: Installing LinuxCNC
I've given up on the core machines, personally not worth the time or effort mucking around with.
One thing that may help is taking the PC apart and cleaning it.
  • Sami
  • Sami
13 Aug 2024 05:16
Replied by Sami on topic Pc reboot / 5i25(6i25) & 7i77
Tested with LMDE 6 with lastest updates and still reboot issue when starting linuxcnc with 6i25 + 7i77 & lathe hw attached.
No error messages, kernel log just show normal messages and then booting up information. What to do next?
  • cakeslob
  • cakeslob
13 Aug 2024 03:54
Sorry if wrong topic but would this be possible with pokeys57cnc?
It is great controller card but I would prefer not to use mach3/4
Short answer is no,
long answer, you can modify the SKR1.4 firmware to work with the RPi/SPI, but there is no ethernet version
  • cmorley
  • cmorley
13 Aug 2024 03:31
Replied by cmorley on topic Probe Basic in QTDragon
Category: Qtvcp
In your configuration folder, you should see a 'qtvcp' folder.
In that folder add 'images' and 'widgets_ui' folders.
for versa:
in the images folder copy 'probe_icons' from share/qtvcp/images/probe_icons
In the folder widgets_ui copy anything with versa in the name from share/qtvcp/widgets_ui
for basic_probe same idea
in the images folder copy widgets/basic_probe_help and widgets/basic_probe_icons
In the folder widgets_ui copy anything with basic in the name from share/qtvcp/widgets_ui
if you run qtdragon with the - i or -d debugging on you should see text like this in terminal:
[QTvcp.QTVCP.QT_PSTAT][INFO] Using LOCAL widget file from: /home/chris/emc/configs/sim/qtdragon/qtdragon_tool_probe/qtvcp/widgets_ui/ (qt_pstat.py:329)
[QTvcp.QTVCP.QT_PSTAT][INFO] Using LOCAL images path from: /home/chris/emc/configs/sim/qtdragon/qtdragon_tool_probe/qtvcp/images/ (qt_pstat.py:346)
Now you can modify those files in your configuration folder and qtdragon will use them instead.
Chris
  • Bari
  • Bari's Avatar
13 Aug 2024 02:59
Replied by Bari on topic Cylindrical mapping
Cylindrical mapping
Category: Show Your Stuff
Just FYI if you just want to wrap G-code to a cylinder
www.scorchworks.com/Gcoderipper/gcoderipper.html
  • PCW
  • PCW's Avatar
13 Aug 2024 02:56
Replied by PCW on topic 7i77 watch dog catch 22
Category: Driver Boards
A 7I77 watchdog fault occurs when communication with LinuxCNC is lost.
This is not something you typically recover from without restarting
LinuxCNC, that is, it usually means LinuxCNC or the host PC has crashed.
or host communication to the FPGA card has been lost or serial communications
have been lost
  • Benb
  • Benb's Avatar
13 Aug 2024 01:50
7i77 watch dog catch 22 was created by Benb
Question 1:
Is there an output pin for an external Estop/reset safety circuit to read the status of 7i77 WDT? If not, would it be feasible to use one of the existing pin outputs by Keeping this output pin ON while the watchdog timer has NOT bit. Here where the catch 22 comes into play, when the WDT bites, the hostmot2 driver disables the digital outputs therefore my external hardwired circuit will not be able to determine the WDT output pin status (see diagram Highlighted in RED). One way I can think of to solve this puzzle is to restrict the WDT from internally disabling the digital outputs, and have WDT just set a flag and let the hardwired safety circuit take care of disabling the power to the digital outputs.       Or I am out to lunch?Question 2:
7i77 field terminal block has several terminals I am hoping to be able to keep the field power OFF to the digital outputs until the safety lockout circuit is reset and the field digital inputs and VIN powered while the ESTOP circuit is active. If you look at the wiring diagram, I need the numbers of the terminal blocks marked with question mark (highlited in green). Nomenclature:
CR# – CONTROL RELAY
MCR - MASTER CONTROL RELAY
F# - FUSE
DI – DIGITAL INPUT
DO – DIGITAL OUTPUT
PB – PUSH BUTTON
WDT – WATCH DOG TIMER
L1 - MAIN SUPPLY LINE 120 VAC
N - MAIN SUPPLY NEUTRAL
PL- Pilot Light
A brief explanation to what this hardwired circuit does follows this diagram.
  The wiring circuit diagram below  is a hardwired circuit that will allow power to be removed from digital outputs, servos and spindle. The circuit achieves the following:
  • If power is lost during operation the machine will not restart when power is re-established.
  • If an Estop is activated or a fault occurs during operation, the circuit will inhibit (prevent) power to digital outputs, servos and spindle. The rest of the machine control circuit will stay in the ON state; this will enable you to troubleshoot and resume operation without major reinitialization of the machine.
  • Machine will not restart until all faults are corrected and operator presses reset button.
This hardwired circuit is the equivalent of safety relay without guided contacts.
  • PCW
  • PCW's Avatar
13 Aug 2024 01:23 - 13 Aug 2024 01:59
Replied by PCW on topic RCpwmgen
RCpwmgen
I would expect you use a scale of 180
and get 90 degrees for a value of 90 (2 ms width)
and -90 degrees for a value of -90  (1 ms width)
You could also set the offset to 1 and then use a 0..180 value
to get 1 to 2 ms
  • Project_Hopeless
  • Project_Hopeless's Avatar
13 Aug 2024 01:10
Replied by Project_Hopeless on topic RCpwmgen
RCpwmgen
After some time away I got this working with the 7i96_5abobrcd firmware.  The physical pins DB25 vs. HAL pins had me twisted around.
setp hm2_[MESA](BOARD).0.rcpwmgen.rate 50setp hm2_[MESA](BOARD).0.rcpwmgen.00.width 1
setp hm2_[MESA](BOARD).0.rcpwmgen.00.offset 1.5
setp hm2_[MESA](BOARD).0.rcpwmgen.00.scale 180
Just a general question, on this function.  To get the servo to physically rotate 180 degrees (+-90) I need a scale of 95.  180 gave ~90degrees, and 90 gave ~190-200 degrees. Is this just the variability of the servo potentiometer?
13 Aug 2024 00:56
Replied by tommylight on topic OLD Lathe conversion to a CNC
Category: Turning
Whatever size you can put the cable through and do at least 1 or 2 windings.
13 Aug 2024 00:53
Replied by tommylight on topic Joint Amplifier Fault on Non-Moving Axis
Category: Basic Configuration
I would venture a guess at interference and check that first with a scope or a DVM that has a min/max memory feature.
  • JamesHoward
  • JamesHoward
13 Aug 2024 00:48
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
I made a header board for 5A-75E8.2 and started testing the litexcnc firmware and encountered the following problems.
1- When I close the linuxcnc software or press the estop key, the motors start moving.
2- For homing using encoder z pulse, after receiving the z pulse instead of stopping, it makes a strange movement at full speed and then stops.
I posted this problem before but couldn't find a solution for it.
Does anyone have any suggestions for solving these problems?
I cant say anything to problem 2, but as for problem #1:
Are you trying to use software for an e-stop? This is a terrible idea! IMO anyways. An E-stop Should cut power to your drives AND send a stop signal to your software. (one exception is: sending an e-stop signal to your spindle. if you cut power it will spin down for a long time. if you send it an e-stop signal it should stop almost instantly)
  • Benb
  • Benb's Avatar
12 Aug 2024 22:52
Replied by Benb on topic MCG Server Controller for 4th axis
The dc servo motor you have is fine and can be used to operate with Linuxcnc. You need either an analog (+-10vdc) or digital (pul/dir) brushed dc servo drive. I use Copley Junus (analog drive) for digital drive Leadshine DC810 is a popular digital servo drive (I have no experience with these drives) both the Copley and the Leadshine require a dc servo power supply. I have seen on EBAY Advance Motion Control drives with built in dc power supply. Since your servo motor is low current and standard voltage you should be able to find what you need on EBAY.
In nut shell you need to match your current Mesa hardware with either analog or digital servo drive. Then start looking for the drive that match your servo motor.
Good luck Ben
  • cakeslob
  • cakeslob
12 Aug 2024 22:40
Replied by cakeslob on topic Remora for RP2040
Remora for RP2040
limo, I saw you in the discord the otherday I think, you arent using the rp2040 right?
Is remora capable of doing it? Most likely, so long as you stay within the parameters of the remora board you are using, by which I mean, if your stepgen steprate is too high, remora might not be able to accommodate. Otherwise it sounds like a standard affair, as just configuring a stepgen.
Do we know how to configure a spindle with step/dir with remora? I dont personally. The bulk of it will be linuxcnc, and we can help you with connecting to remora
  • rodw
  • rodw's Avatar
12 Aug 2024 21:23
Displaying 23986 - 24000 out of 24484 results.
Time to create page: 2.816 seconds
