- Moutomation
- Moutomation
08 Aug 2024 19:26
Replied by Moutomation on topic Ethercat installation from repositories - how to step by step
Category: EtherCAT
Hello,
Is it possible to install ethernet for raspbery pi? Are the iso files up to date ?
08 Aug 2024 19:18
Replied by rodw on topic Installing Linuxcnc on Debian Bookworm
Category: Installing LinuxCNC
Yes its pretty easy to give a user sudo access. I think from memory using sudo then requires root's password.
You just need to add your user to the sudoers user group when signed in as root
usermod -aG sudo newuser
- papaathome
- papaathome
08 Aug 2024 19:09
I want to mention a few points I ran into. Maybe others can do there advanage with it.
First: There is a warining not to supply a root password when installing Debian. If you do give a root password then sudo is disabled.
Of cause I had supplied a root password (old habits dont die easily!)
I had two options, reinstall and don't supply a password or find out how to enable sudo. I opted for the second one.
If you search the internet then you can find several sites with advice how to do it.
In the instructions I used the command `adduser username sudo` is used. That command could not be found.
Solution: use `whereis adduser` then use the command with the full path.
The rest is just read first, check and check again then do exact what you are told to do. No further problems.
Now running kernel Linux 6.1.0-23-rt-amd64 with LinuxCNC installed.
Latency tests are a factor 2 better compared to running LinuxCNC life.
I have made some changes in the bios between testing with LinuxCNC life and the current situation but have not (yet) fully tuned this installation.
I want to try the next step, using the RTAI kernel.
Kind regards.
Replied by papaathome on topic Installing Linuxcnc on Debian Bookworm
Just followed the procedure, it was a doddle.Installing linuxcnc on a standard Debian instance is described in the docs here
linuxcnc.org/docs/stable/html/getting-st...th_preempt_rt_kernel
Kind regards.
- anfänger
08 Aug 2024 18:10
Replied by anfänger on topic Fehlmann Picomax 100 Retrofit
Category: Milling Machines
- anfänger
08 Aug 2024 18:02 - 08 Aug 2024 19:35
Replied by anfänger on topic Py3 - Probe Basic Config Conversion Doc Lcnc 2.9+
Category: QtPyVCP
Hi I installed the development system with 2.9.3 and the deb files like in the tutorial described.
kcjengr.github.io/probe_basic/development_quick_start_apt.html
Then I tried to open my config I used with probe_basic under 2.8.2. Fixed the python3 issues with my own Hal components.
now it ts trying to start an I am expecting to fail due to missing Hal pins from qtpyvcp, cause I heavyly modified the ui file to match my machine.
but I get this error:
I guess try coming from my custom_config.yml
ad related files.
and when I emote the custom widget (its for setup sheets)
I come to the point where it fails due to missing pins.
copying my ui file over the one in the deb package let it fail again.
I guesss there were some changes which make it fail.
I'll made all ma chalets just to one tab I added.
So I did edit this section in the ui file. and still run into errors.
I am afraid I need to redo all ma work. maybe its faster since I've done it before
will there be a better option in the future keep custom tabs?
for more complex machines this might help a lot.
Thanks Patrick[/code]
[qtpyvcp.app.launcher][CRITICAL] Unhandled exception in probe_basic line 8 (launcher.py:37)
File "/usr/bin/probe_basic", line 8, in <module>
sys.exit(main())
File "/usr/lib/python3/dist-packages/probe_basic/__init__.py", line 20, in main
qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)
File "/usr/lib/python3/dist-packages/qtpyvcp/__init__.py", line 26, in run_vcp
run(*args, **kwargs)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/__init__.py", line 129, in run
launch_application(opts, config)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 78, in launch_application
loadWindows(config['windows'])
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 228, in loadWindows
window = _initialize_object_from_dict(window_dict)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 208, in _initialize_object_from_dict
return obj(*args, **kwargs)
File "/home/wully/linuxcnc/configs/wully/custom_probebasic.py", line 15, in __init__
super(CustomProbeBasic, self).__init__(*args, **kwargs)
File "/usr/lib/python3/dist-packages/probe_basic/probe_basic.py", line 35, in __init__
super(ProbeBasic, self).__init__(*args, **kwargs)
File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 47, in __init__
self.loadUi(ui_file)
File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 106, in loadUi
uic.loadUi(ui_file, self)
File "/usr/lib/python3/dist-packages/PyQt5/uic/__init__.py", line 241, in loadUi
return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)
File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/loader.py", line 66, in loadUi
return self.parse(filename, resource_suffix)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 1037, in parse
actor(elem)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 828, in createUserInterface
self.traverseWidgetTree(elem)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 806, in traverseWidgetTree
handler(self, child)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 273, in createWidget
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 503, in createLayout
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 546, in handleItem
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 264, in createWidget
self.stack.push(self.setupObject(widget_class, parent, elem))
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 228, in setupObject
obj = self.factory.createQObject(clsname, name, args, is_attribute)
File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 118, in createQObject
return self._cpolicy.instantiate(factory, *args, **kwargs)
File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 137, in instantiate
return clsObject(*ctor_args)
File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/display_widgets/vtk_backplot/vtk_backplot.py", line 179, in __init__
self.default_view = view_options[view_default_setting]
ad related files.
# example of a machine specific settings
windows:
mainwindow:
provider: custom_probebasic:CustomProbeBasic
#windows:
# mainwindow:
# kwargs:
# confirm_exit: false
settings:
# VTK backplot view settings
backplot.show-grid:
default_value: false
backplot.show-program-bounds:
backplot.show-program-labels:
backplot.show-program-ticks:
backplot.show-machine-bounds:
backplot.show-machine-labels:
backplot.show-machine-ticks:
backplot.perspective-view:
backplot.view:
default_value: P
options: ["X: Front View", "XZ: Lathe View", "XZ2: Lathe View", "Y: Front View", "Z: Top View", "Z2: Bottom View", "P: Isometric"]
backplot.multitool-colors:
default_value: True
sys.exit(main())
actor(elem)
File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 100, in createQObject
factory = self.findQObjectType(classname)
File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 125, in findQObjectType
w = module.search(classname)
File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 113, in search
module = __import__(mname, {}, {}, (cls,))
ModuleNotFoundError: No module named 'qtpyvcp_conversational_gcode'
sys.exit(main())
actor(elem)
File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 116, in createQObject
raise NoSuchWidgetError(classname)
PyQt5.uic.exceptions.NoSuchWidgetError: Unknown Qt widget: HalLCDNumber
- Lpkkk
- Lpkkk
08 Aug 2024 17:30
Replied by Lpkkk on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I will try your settings. So far the best settings I could find were :
DEADBAND = -0.0002
FF1_GAIN = 1
P_GAIN = 1
I put negative deadband because it seems to work better than positive. I've tried many di settings in last few days. A lot of testing.
DEADBAND = -0.0002
FF1_GAIN = 1
P_GAIN = 1
- anfänger
08 Aug 2024 17:04 - 08 Sep 2024 15:23
Replied by anfänger on topic Mesa Analog Vs Step Dir
Category: Driver Boards
thanks again.
Update is running...
And home with index is working!
many thanks!
many thanks!
- Moutomation
- Moutomation
08 Aug 2024 17:03 - 08 Aug 2024 17:09
Replied by Moutomation on topic classic ladder input and output added
Category: ClassicLadder
I appreciate your contribution to this forum and to us. Thank you very much,
- meister
- meister
08 Aug 2024 16:25
Replied by meister on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
sooo, small WARNING, I have now tidied up the boards and configs.
renamed a lot of things and removed all my test files.
if you are missing something, please let me know, i still have everything
i will shortly merge the dev branch into the main and then also remove the riogui repository (everything is in the riocore)
- jossen
- jossen
08 Aug 2024 15:28
Replied by jossen on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
Category: HAL
Someone got the Vfdmod package for RaspberryPi? (arm)
08 Aug 2024 13:43
Replied by PCW on topic Mesa Analog Vs Step Dir
Stepgen index requires 2.9 or later
08 Aug 2024 13:36
Replied by tommylight on topic Pc reboot / 5i25(6i25) & 7i77
Download and install Linux Mint Debian Edition 6, after reboot in a terminal do
sudo apt update
sudo apt upgrade
sudo apt install linuxcnc-uspace
Test on all PC's as this seems to be the first thing to try.
I had 2 of Zen 3 5600G and they ran perfectly, several 3600 and 3700X and 3900X also run perfectly, so must be something else...
sudo apt update
sudo apt upgrade
08 Aug 2024 13:31
Replied by tommylight on topic I found old PC in the dumpster with parallel port
That might very well be usable, so start one of the included parallel port configurations and leave it running for a while, see if it shows latency warnings.
- spumco
- spumco
08 Aug 2024 12:28
Replied by spumco on topic Spindle.0.at-speed False not inhibiting motion
Category: HAL
Just speculating, but I wonder if there's a timing issue.
According to the manual, motion will be paused "before the first feed move after each spindle start or speed change"
Perhaps motion isn't being halted if a feed move is underway (even by 2ms) when the at-speed signal goes false.
Just to test, I'd throw a short G4 pause in the program right before the speed change and see if that corrects the behavior.
- spumco
- spumco
08 Aug 2024 12:11
Replied by spumco on topic Homing with detached 4th axis
Not sure if this is helpful , but here's my 4th scheme:
My 4th is set up with manual homing for a few reasons. First, I may have a fixture or trunnion table attached and I don't want to blindly let it rotate without checking clearances.
Second, my particular setup uses the servo drive's internal home-to-switch, back-to-index feature. (LCNC is running open-loop).
Third - and this is probably the most important reason - I had no clue how to modify/create a custom-homing routine which automatically detected the 4th axis and homed it (or not) depending on whether it was connected.
When I command the 'home 4th' function, LCNC immediately zeros the DRO, the drive does it's homing routine, and then signals LCNC the drive 'is-homed'. In the case of a power off, estop, or drive disable LCNC is set up to unhome all axes.
Like you, I have a 'connected' signal (using the servo cable) that controls both the drive contactor as well as informing LCNC that the 4th axis is attached/detached.
Time to create page: 0.415 seconds
