  • stirra
  • stirra
24 Apr 2026 17:30
Replied by stirra on topic 4 axis foam cutter configuration
Category: AXIS
I ended up using a bottle of water as a weight, with the wire fixed at one end and a pulley arrangement for the moving end. I used polished wire nozzles used for wire winding machines to guide the wire without fatiguing it. Do not try to use MIG welder wire nozzles, as they will break the wire very quickly.  I built the machine for a university lab, but I don't think they have used it very much since, so long term reliability is untested.-- Ralph
  • COFHAL
  • COFHAL
24 Apr 2026 16:56
Replied by COFHAL on topic Qtvcp GUI and hal pins
Category: Qtvcp
Thanks for you support.
I've already installed the python3-zmq package, but it's not clear to me how to include a macro. Could you help me with an example to complete it?
MACRO=
MACRO=
And how to connect these macros to an external button
24 Apr 2026 15:13
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Seems like encoder failing to count at higher speeds, might be interference, or encoder slotted wheel dirt/rust, or encoder input lagging, or encoder outputs marginally low output.
I have also seen a perfectly good encoder counting on one direction, and one channel going all wonky on the other direction, it was new so i returned it without the chance of figuring out what was wrong with it.
  • Dudelbert
  • Dudelbert
24 Apr 2026 14:44 - 24 Apr 2026 14:53
Category: Turning
I had time to test some more today.
Let me start with a big thanks for the great, helpful feedback.
I started trying some runs with G33. Multiple runs with the same settings resulted in only one tool mark.
Increasing the RPM did in fact result in a slightly lagging toolpath (cutting on the right side of the insert).
This was not very pronounced, even between 100 and 900 RPM the difference was visible, but not more than a few tenths of a mm.
At 2000 RPM, the new tool marks were close to the middle between the earlier ones. But I don’t really intend to thread at 2000 RPM anyway.
Going back to G76, but with Q, H, E, and L all set to 0, gave me my first nice thread.
Reintroducing Q29 still gives a nice thread and cuts on the left of the insert, as one would expect.
H2 also still worked, and after that E0.75 but L0 gave the same good result.
So only L2 was left, and I am now using the same G76 line as before, so this has to be the problem.
But no it also cuts fine.
At this point, I am uncertain if I should be happy that I can cut threads now or worried that I have no idea what was wrong until now.
I cannot think of anything I changed in between.The only thing is, I had a look at the belt connecting the spindle to the encoder.
I had this apart and inspected, checked the belt (nothing notable to see), and put it back together. I don’t think that should have changed anything, maybe slightly different belt tension?
  • smc.collins
  • smc.collins
24 Apr 2026 13:18
Replied by smc.collins on topic Schaublin 125-CNC retrofit.
Category: Turning
check the angle on the bar, and be sure of your tip height, both will break most threading insert, been there got the t shirt
  • rodw
  • rodw's Avatar
24 Apr 2026 11:59
Replied by rodw on topic HAL component for tangential knife
Category: HAL
This appeares to be working now
checkout  the state-tags-arc from my repo to test
github.com/rodw-au/linuxcnc/tree/state-tags-arcs
There is some house keeping to sort out. I need to work out how to use equate G_1,G_2  etc in motion (control.c) I remember the devs last time I tried, they did not like this  but I have not got a solution yet. Its just housekeeping and will only be an issue ig the equates for gcodes are ever changed.
  • cmorley
  • cmorley
24 Apr 2026 04:14
Replied by cmorley on topic Qtvcp GUI and hal pins
Category: Qtvcp
Have you run linuxcnc from a terminal so you can see any errors?
you need python3-zmq package on the system.
macros are defined under heading:
[DISPLAY]
MACRO=
MACRO=
I'll have to check later to confirm all work properly.
  • Metalurgent
  • Metalurgent
23 Apr 2026 22:12
Replied by Metalurgent on topic Adding additional i/o beyond default
Thank you, Peter.
I did as you suggested and I was able to see the dio listed in halshow.
I spent all day trying to understand how to access and setup the inputs and outputs using the M64+ commands.
I think I figured it out after hours of frustration.
My issue was understanding the syntax of how the actual screw terminals of the 7I77 connected to the input of an MDI command of say M64 P4.
I needed to get my head around the random name that I had assigned to an output [ say Digital out 4], the terminal on the 7i77 ( that could be terminal 8..) and the call sign [say M64 P3] that i put into MDI . Understanding how to link them all together in hal to get a predictable result was a head-wreck.
Watching that single halshow dot finally turn from brown to yellow made my day.
Easy once you know.....as usual.
Thanks.
  • rodw
  • rodw's Avatar
23 Apr 2026 21:09
Category: HAL
Having looked at this a few times, I think that the best place to do it is actually in a G-code filter. ie calculate the heading from the G-code and insert / append C axis moves as appropriate.
Actually, there is a use case that needs motion pins. A plasma cutter cutting bevels. An additional joint is needed to tilt the torch and there are complicated tilting torch holders that keep the torch tip axial to the Z axis (single axis bevel head). I was just chatting to a user with one who uses the post processor approach.
But picture a simpler torch holder design where the torch tip position moves when tilted. A component could take the bevel angle and calculate the offset x,y,z positions of the tilted torch tip and then apply external offsets to locate the torch on the cut path in real time. This way, the machine could consume simple 2D x,y gcode (which is the norm for plasma cutters) and enter plasma cutting nirvana with bevelled holes.
23 Apr 2026 20:37
23 Apr 2026 20:33
Replied by tommylight on topic Mesa 7IA0 inputs threshold
Category: Driver Boards
Yes using level shifters, but if it works properly with the resistor just use that, it is OK.
www.google.com/search?num=10&client=fire...286&bih=974&dpr=1.33
23 Apr 2026 20:28
New Youtube chanel for CNC .... anything ! toma cnc
Category: Show Your Stuff
I do know the password - i just cannot type it in.
Can you elaborate on this?
  • Glite
  • Glite
23 Apr 2026 19:25
Mesa 7IA0 inputs threshold was created by Glite
I found a situation with inductive sensors where default input threshold of 3.5 V is to low, as those sensors are 4.5-5.5 V in OFF state.
For one sensor I mitigated it with adding 10K pulldown resistor. Is there any better way to do that?
  • emresensoy
  • emresensoy
23 Apr 2026 18:51 - 23 Apr 2026 19:20
 CAM232 - 2.5 Axis CAM Software (First 2 Code Free, than 1$ for each)
A 1-month free Pro membership will be automatically added to any account upon first login.
If you experience any problems, please write here.
  • smcivor
  • smcivor
23 Apr 2026 18:25
Tom I came across your videos looking for information on a Messer plasma table. I have an older machine year 2000 that I bought from a John Deere factory in Iowa that was running the day that I purchased it, I am trying to get it up and running but don't have software or the computer cables etc to fire it up. Everything is hooked up but its looking for a password. Has an older Navigator control that looks good but I cannot get past the password as I cannot type it in. I do know the password - i just cannot type it in. Messer is no help, they just keep saying it is obsolete. If you could point me in the right direction or be of any help I would greatly appreciate it. Thanks Sean
614 309 6854
Displaying 2656 - 2670 out of 13997 results.
Time to create page: 0.216 seconds
