  • ajanfahri
  • ajanfahri's Avatar
22 Oct 2026 09:56
Replied by ajanfahri on topic Show Your Stuff: My Custom CNC Controller
Category: Show Your Stuff
Thanks for checking it out!
The source code isn't publicly available, so I'm afraid I can't share it. The page isn't actually a login screen; the frontend is built with React, and the backend is written in C/C++.
However, I'd be happy to explain how it works or help in any other way if you're interested.
Thanks again for your interest!
  • ajanfahri
22 Oct 2026 09:49
Advice on Designing a GUI for a Custom C-Based EtherCAT CNC Controller on Linux
You're absolutely right, trajectory planning is a challenging task.
Our journey started about 20 years ago with milling and EDM machines. Back then, we were developing our software in C/C++ on DOS 6.22. I still remember spending days debugging our milling and EDM applications.
You can take a look at some of our old DOS applications here:
doscapture.fahriworks.com/
Later, we moved on to plasma cutting machines, and now I'm working on a laser cutting machine using Linux, Xenomai, and EtherCAT.
Your points about reliability and keeping the GUI separate from real-time motion control are very valuable. Thank you for sharing your experience and advice!
  • ajanfahri
22 Oct 2026 09:44
The project is still under development. The CNC software I have worked with is proprietary, so I cannot share its source code.
My current project is a separate development using Linux, Xenomai for real-time capabilities, and EtherCAT for motion control. I'm still working on the architecture and exploring the HMI approach.
  • NWE
  • NWE's Avatar
22 Oct 2026 09:42
Seems to be gated behind account login. Is the source code available?
  • automata
  • automata
22 Oct 2026 09:22
New LinuxCNC Multi-Channel System – Looking for Testers & Feedback
I registered on the site for trying the community edition.
But could not download the deb or the src to be able to try anything.
Even the link to the manual gives a 404 error.
I would appreciate a heads-up on this thread once you get a chance to get the site working.
Thanks,
-automata
22 Oct 2026 08:49
Trajectory planner is not an easy task, so i would stick with LinuxCNC for that (as do most companies using it) and do your HMI/GUI for it.
C/C++ is fine, React i have no clue (is that a version of Java script?), but whatever you end up using, make sure that if it crashes, it does not take the trajectory planner and real time stuff with it.
For me reliability is paramount, so i stick with Axis GUI mostly, i distinctly recall some 10 years back messing with Linux deleting stuff while the machine was working, i broke something, screen went black, keyboard was not doing anything, but the machine went on to finish the part over two hours after blacking out!
Having industrial machines With LinuxCNC running 24/7 for nearly 15 years without ever having any issues is something big companies can not do, of course as most of those still use windoze! :)
  • ajanfahri
22 Oct 2026 06:40 - 22 Oct 2026 06:54
Since you asked me to show my work, I'm developing my own CNC controller using C, Ubuntu Linux with real-time capabilities, and EtherCAT.You can find more about my software development work at https://www.fahriworks.com.I'll share more technical details about the CNC project as development progresses.Wishing everyone the best with their projects!
  • ajanfahri
22 Oct 2026 06:26
Thanks for your suggestions! I'll look into your recommendations.(FlexGUI and QtPyVCP.)
However, I'm developing my own CNC controller from scratch rather than using LinuxCNC. The real-time control core is written in C, and I'm integrating EtherCAT for servo communication.
I'm mainly trying to decide on the best HMI architecture for my own system: a native C/C++ GUI or a modern React-based web interface communicating with the C control core through a separate backend.
I'd be interested in your thoughts on this architecture, particularly regarding reliability, real-time performance, and communication between the HMI and the control core.
  • stefan63
  • stefan63's Avatar
22 Oct 2026 05:51
Replied by stefan63 on topic Yaskawa servo options
How do i buy this card an how much does it cost?
yurtaev.com/yssc3p.html
  • andrey.pawl
  • andrey.pawl
22 Oct 2026 04:59
Replied by andrey.pawl on topic Cannot access main website linuxcnc.org
Thank you. It turned out that my internet provider was having problems accessing your website. The provider has already resolved the issue. Access to your site has been restored.
22 Oct 2026 04:10
Replied by tommylight on topic Cannot access main website linuxcnc.org
It is working, but there are issues for sure, probably due to panic caused by some news yesterday and may server getting shut down completely.
Both our servers are working, but i could not access the forum from yesterday afternoon till today morning, but i could access the website just fine.
In the meantime, use a free proxy located in USA, it will work fine for browsing etc, but i would not use it to login anywhere.
  • andrey.pawl
  • andrey.pawl
22 Oct 2026 03:20
Cannot access main website linuxcnc.org was created by andrey.pawl
Hello,I can open the forum (forum.linuxcnc.org) without any problems from my home computer, but the main website linuxcnc.org does not load at all (even when using a VPN). From mobile data the main site works fine.It looks like my home IP might be blocked on the main site. Is this possible? What could be the reason, and what is the recommended way to resolve such an issue?Thank you.
22 Oct 2026 02:27
Replied by tommylight on topic Sudden lost of Y2 slave control
Category: Driver Boards
This looks a lot like a wiring issue, at an educated guess, one of the Mesa outputs to Y2 is tied to 5V.
Displaying 271 - 285 out of 11392 results.
Time to create page: 0.381 seconds
