28 Mar 2026 02:44
Replied by tommylight on topic Differential encoder hard crashes the PC MESA7i77
Category: Driver Boards
See if you can disable this in BIOS, it is usually enabled by default
www.google.com/search?client=firefox-b-l...ssive+power+managent
Also, if you are using any kind of PCI-E riser or cable, se the PCI-E speed/mode to GEN1
  • NWE
  • NWE's Avatar
28 Mar 2026 02:05
Replied by NWE on topic Ethercat boards and hardware
here is some info on a cheap ethercat stepper drive. But it is not as cheap as your A4988.
4 axis stepper drive
  • PCW
  • PCW's Avatar
28 Mar 2026 01:55 - 28 Mar 2026 02:09
You could try  setpci and verify if the [disabled] goes away from the lspci listing
  • grossm5000
  • grossm5000
28 Mar 2026 01:08
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
the options in my BIOS PCI Subsystem Settings are:
Above 4G Decoding (enable/disable)
SR-10V Support (enable/disable)
and in BIOS Onboard Device Configuration
PCIEX1_1 Mode (auto) <--but i think this only refers to speed. I have this selection/option for all the PCI slots on the board
I tinkered with all of these earlier today to no result. I do have an ASUS A520M motherboard...BIOS options seem pretty generic.
  • grossm5000
  • grossm5000
28 Mar 2026 00:53 - 28 Mar 2026 00:53
I do have access to some BIOS PCI settings, but not sure if I can screenshot them. I am afraid the best I can do is take a picture.
I did some searching...will this command do anything for me?
sudo setpci -s 04:00.0 COMMAND=0x02
supposedly enables the memory space, but I am certainly not a software wizard...
  • PCW
  • PCW's Avatar
28 Mar 2026 00:49
The problem is this:
Region 0: Memory at fce00000 (32-bit, non-prefetchable) [disabled] [size=64K]
Which is likely something the BIOS did so may be fixable if you have access to BIOS PCI settings
I will take a look into what is needed to get mesaflash to re-enable the memory region (lLinuxCNC does this)
  • rodw
  • rodw's Avatar
28 Mar 2026 00:44
Latency, error finishing read, and IRQ affinity
Ran into an issue with IRQ balance after updating to trixie
Late to the party but currently best practice is not to use irqbalance. the balancing is now managed internally in the kernel so adding a second balancer can confuse things.... but it worked here....
  • grossm5000
  • grossm5000
28 Mar 2026 00:41
Here we are! I super appreciate it...so does my wife   Ive been trying to make this work all day
  • rodw
  • rodw's Avatar
28 Mar 2026 00:35
Replied by rodw on topic Probe Active before non-probe move
I once set a digital input in my probing sequence that was and2'd to the probe signal to stop this.
I think a better way would be to use motion.motion-type = 5 to signify probing was in use and disable the signal if this is false.
  • rodw
  • rodw's Avatar
28 Mar 2026 00:24
Replied by rodw on topic Ethercat Setup help needed for beginner
Category: EtherCAT
and even professionals sometimes find it frustrating.
Sometimes????? More often than that!
  • rodw
  • rodw's Avatar
28 Mar 2026 00:18
Replied by rodw on topic Jog troubles
Jog troubles
Category: Flex GUI
why jog before homing? I always disable it.
  • PCW
  • PCW's Avatar
27 Mar 2026 23:59
Can you do a
lspci -vv  | grep -A 10 2718 > pci.txt
and post pci,txt here?
  • grandixximo
  • grandixximo's Avatar
27 Mar 2026 23:15
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
I tried to follow your instructions, and it works ok for me.
I suspect it maybe something with the custom tool table which is missing from default, could you share that?
  • grandixximo
27 Mar 2026 22:45
Replied by grandixximo on topic Probe Active before non-probe move
Linuxcnc Version?
IMO this is a bug in the source code, i have this error disabled in the codebase I use for work
Displaying 3646 - 3660 out of 14010 results.
Time to create page: 0.278 seconds
