  • PCW
  • PCW's Avatar
25 Feb 2026 17:24
hm2_modbus pktuart, probably a firmware request?
Category: Driver Boards
This should be close
File Name: 7i96d_7i85p_pktv3.zip
File Size:128 KB
Note that I had to reduce the number of sserial channels to 3 to fit
(the are also renumbered so channels 0,1,2 are on 7i85 channels 0,1,2)
  • ikkuh
  • ikkuh's Avatar
25 Feb 2026 17:14
qtdragon - new tool length after a manual tool change
Category: Qtvcp
Most info will still work. The problem is that there is not really consensus about what automatic toolbit offset en height settings must do.
I had mine working for a while. I switched to 3d printing and will pick up later this spring.
  • tightmopedman9
  • tightmopedman9
25 Feb 2026 17:08
qtDragon: Auto Return to Manual Mode After an MDI Command so MPG works
Category: Qtvcp
Are there any potential drawbacks of this? I've wondered why this wasn't the standard implementation - I figured it was for good reason, so never asked. I ended up dedicating a physical button to activate MDI mode instead, but it feels like a waste of a button...
Will this modification switch back to MDI mode after a python based probing cycle (successful or failed)? I find that's the most frequent time I need to switch back to MDI mode.
  • Konstantin
  • Konstantin
25 Feb 2026 17:08
Replied by Konstantin on topic CiA 402 Folder Missing
Category: EtherCAT
Hello,
attached are the requested outputs and I added PDOs and SDOs outputs as well.
  • MaHa
  • MaHa
25 Feb 2026 16:45
Replied by MaHa on topic REMAP Mcode seemingly ignored
Category: AXIS
When working with multiple m codes, i always use Queue Buster before each m-code.
eg.
M66 E0 L0
M169 P9
M66 E0 L0
M169 P6
  • rhscdn
  • rhscdn
25 Feb 2026 16:31
Category: Qtvcp
Is the info in this thread still relevant to QtDragon shipped with 2.9.7? I have a 3-axis cnc router with a manual change spindle and I'm looking to automate bit offset/height setting with a tool setter input on my 7i96s.
  • Dudelbert
  • Dudelbert
25 Feb 2026 16:22
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Don’t worry, I don’t know how often I intended to attach something and then just didn’t. I asked when I was still having problems with the PnCconf setup, so it is not relevant anymore. But thanks.
  • DerKlotz
  • DerKlotz
25 Feb 2026 16:16
Replied by DerKlotz on topic Add Buttons in Probe Basic
Category: QtPyVCP
Yes, probably you are right... tomorrow next try
  • Lcvette
  • Lcvette's Avatar
25 Feb 2026 16:11
Replied by Lcvette on topic Add Buttons in Probe Basic
Category: QtPyVCP
without knowing how and what you did its nearly impossible to guess, you appear to have been using multiple different old version to test or try things, so i would almost say for someone at your level your best bet is a clean build fro the ground up to ensure you don't have any remnants remaining that could muck up future progress.
  • DerKlotz
  • DerKlotz
25 Feb 2026 16:08 - 25 Feb 2026 16:09
Category: QtPyVCP
Pretty sure yes... i got it to work now. But the latency of my new system is really really slow. I switch back to the old one.
Last question for today...
" i would remove everything and reinstall from scratch using apt only, be sure to purge all installations"
what exactly i need to deinstall and which commands in the terminal?
  • PCW
  • PCW's Avatar
25 Feb 2026 15:37
Replied by PCW on topic 7i92TM defect? How to verify?
If you measure the voltage across C36 I expect you will find a low voltage
instead of the expected 4.2V. What this likely means is that one or both
bus switch parts (74CBT16211) have been damaged by either ESD
or by being connected live to the G540 with no common ground
existing between the G540 and 7I92T before they were connected,
exposing the bus switches to a transient high voltage.
  • NT4Boy
  • NT4Boy
25 Feb 2026 15:32
REMAP Mcode seemingly ignored was created by NT4Boy
Category: AXIS
Hi.
I've added a custom M199 code to enable my  spindle-index-enable signal, and this runs fine. (Can see the LED light up in halshow when run.)
So now I'd like to build it into my M19, so the M99 runs just before the M19 is called.
In the [RS274NGC] section of my INI, I have put
REMAP=M19  modalgroup=7  argspec=RQP ngc=custom_M19
my custom_R19.ngc file contains:-
( Custom spindle orientation ngc file)
( M199 raise spindle-index-enable signal)
o<pre_M19>sub
M5
M199
G4 P2
M19 R#<r> Q#<q> P#<p>
o<pre_M19>endsub
The G4 pause is just so I can be sure that the signal is enabled in halshow gui.
I'm pretty sure the file is being read at Linuxcnc fire up, as when I remove the file from the macros folder, the startup parser errors with missing file.
After I home the machine and run the MDI command say M19 R20, the M199 and the pause are not being executed.
I feel I have missed something really obvious..  be grateful for a steer. Thanks
25 Feb 2026 15:14
Replied by tommylight on topic Add Buttons in Probe Basic
Category: QtPyVCP
Did you do a
sudo apt update
before
sudo dpkg -i linuxcnc-uspace_2.9.8_amd64.deb
  • Finngineering
  • Finngineering
25 Feb 2026 14:49
Replied by Finngineering on topic Schaublin 125-CNC retrofit.
Category: Turning
I had a quick look at the config files in the first thread. However, I do think it would be good with the latest files, as well as the classicladder part.
In addition to what I mentioned in the last post, I would also say you should have a look at these signals when you issue an M3 command:
[HMOT](CARD0).7i83.0.1.analogena0
[HMOT](CARD0).7i83.0.1.analogout0
If the physical buttons are not connected to (only) LinuxCNC, then I guess it could very well be something on the hardware side as well. In that case some kind of schematic would also be needed for "remote" troubleshooting.
  • DerKlotz
  • DerKlotz
25 Feb 2026 14:41 - 25 Feb 2026 14:58
Category: QtPyVCP
Hello and sorry for the late reply. I got a new PC yesterday and i finished to do the Debian 12 installation right now.
I followed the Probe Basic Stable docs...
I stuck on step 3 now
cd ~
cd Downloads
These are my errors now... Python not installed? If yes how do i install it via Terminal?
Reading database ... 129701 files and directories currently installed.)
Preparing to unpack linuxcnc-uspace_2.9.8_amd64.deb ...
Unpacking linuxcnc-uspace (1:2.9.8) over (1:2.9.8) ...
dpkg: dependency problems prevent configuration of linuxcnc-uspace:
 linuxcnc-uspace depends on libboost-python1.74.0 (>= 1.74.0+ds1); however:
  Package libboost-python1.74.0 is not installed.
 linuxcnc-uspace depends on libboost-python1.74.0-py311; however:
  Package libboost-python1.74.0-py311 is not installed.
 linuxcnc-uspace depends on libgpiod2 (>= 1.5.1); however:
  Package libgpiod2 is not installed.
 linuxcnc-uspace depends on libmodbus5 (>= 3.1.4); however:
  Package libmodbus5 is not installed.
 linuxcnc-uspace depends on libtk8.6 (>= 8.6.0); however:
  Package libtk8.6 is not installed.
 linuxcnc-uspace depends on libudev-dev; however:
  Package libudev-dev is not installed.
 linuxcnc-uspace depends on iptables; however:
  Package iptables is not installed.
 linuxcnc-uspace depends on blt; however:
  Package blt is not installed.
 linuxcnc-uspace depends on mesa-utils; however:
  Package mesa-utils is not installed.
 linuxcnc-uspace depends on python3-tk; however:
  Package python3-tk is not installed.
 linuxcnc-uspace depends on python3-numpy; however:
  Package python3-numpy is not installed.
 linuxcnc-uspace depends on python3-opengl; however:
  Package python3-opengl is not installed.
 linuxcnc-uspace depends on python3-configobj; however:
  Package python3-configobj is not installed.
 linuxcnc-uspace depends on python3-xlib; however:
  Package python3-xlib is not installed.
 linuxcnc-uspace depends on libgtksourceview-4-dev; however:
  Package libgtksourceview-4-dev is not installed.
 linuxcnc-uspace depends on tcl8.6; however:
  Package tcl8.6 is not installed.
 linuxcnc-uspace depends on tk8.6; however:
  Package tk8.6 is not installed.
 linuxcnc-uspace depends on bwidget (>= 1.7); however:
  Package bwidget is not installed.
 linuxcnc-uspace depends on tclreadline; however:
  Package tclreadline is not installed.
 linuxcnc-uspace depends on tclx; however:
  Package tclx is not installed.
 linuxcnc-uspace depends on python3-pyqt5; however:
  Package python3-pyqt5 is not installed.
 linuxcnc-uspace depends on python3-pyqt5.qsci; however:
  Package python3-pyqt5.qsci is not installed.
 linuxcnc-uspace depends on python3-pyqt5.qtsvg; however:
  Package python3-pyqt5.qtsvg is not installed.
 linuxcnc-uspace depends on python3-pyqt5.qtopengl; however:
  Package python3-pyqt5.qtopengl is not installed.
 linuxcnc-uspace depends on python3-opencv; however:
  Package python3-opencv is not installed.
 linuxcnc-uspace depends on python3-espeak; however:
  Package python3-espeak is not installed.
 linuxcnc-uspace depends on python3-dbus.mainloop.pyqt5; however:
  Package python3-dbus.mainloop.pyqt5 is not installed.
 linuxcnc-uspace depends on python3-pyqt5.qtwebengine | python3-pyqt5.qtwebkit; however:
  Package python3-pyqt5.qtwebengine is not installed.
  Package python3-pyqt5.qtwebkit is not installed.
 linuxcnc-uspace depends on espeak-ng; however:
  Package espeak-ng is not installed.
 linuxcnc-uspace depends on pyqt5-dev-tools; however:
  Package pyqt5-dev-tools is not installed.
 linuxcnc-uspace depends on gstreamer1.0-tools; however:
  Package gstreamer1.0-tools is not installed.
 linuxcnc-uspace depends on espeak; however:
  Package espeak is not installed.
 linuxcnc-uspace depends on python3-poppler-qt5; however:
  Package python3-poppler-qt5 is not installed.
 linuxcnc-uspace depends on psmisc; however:
  Package psmisc is not installed.
dpkg: error processing package linuxcnc-uspace (--install):
 dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.36-9+deb12u13) ...
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for mailcap (3.70+nmu1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for shared-mime-info (2.2-1) ...
Errors were encountered while processing:
 linuxcnc-uspace
Displaying 4936 - 4950 out of 14029 results.
Time to create page: 5.900 seconds
