  • djdock99
  • djdock99
08 Feb 2026 09:11 - 08 Feb 2026 09:21
Replied by djdock99 on topic Maho mh800w retrofit
Category: Milling Machines
The area im stuck on is the latching of 19k1 relay. I cannot keep the relay latched because the axis keeps running away. I’ve tried swapping the wires and changing the signs for output scale and encoder scale multiple times different combinations and still run away just in opposite directions when I swap the E1 and e2 wires. So that leads me to say what I have done is not correct. When I try to latch 19k1 from f2 it drops constantly back to estopTo tackle it from a different angle I reduced the p value in the ini from 50 to 5 and manually latched 19k1 by pushing on the contactor with Linuxcnc started but without f2 pressed. The error indicator at the rear of the machine reset, and was happy with no errors but very very slow run away. Estop, door switch’s, tool clamp etc all work as before the retrofit and the axis limit switches all trip the estop. SoOn my machine when 19k1 is latched it fires the coil on 7k1
  • besriworld
  • besriworld
08 Feb 2026 09:04
Replied by besriworld on topic Mini wannabe datron build
Category: CNC Machines
Good job! Works well at high speed. Little beast :)
  • Stephan@work
  • Stephan@work
08 Feb 2026 08:40
Configure Mesa 7i96s and pktuart with Omron MX2 (wj200)
this hm2_modbus.0.last-error-code ?
it looks like:
• 110, 0x6e (ETIMEDOUT): The command received no reply and timed out.
But I 'm not sure if this was some consequential error.
I compared the running wj200.comp example of my USB-Dongle
but i can´t see any difference. Do I need some delay somewhere .
I added some interval="1000" like you did in your gs10. but no success.
  • PCW
  • PCW's Avatar
08 Feb 2026 06:12
Mesa 6i25 - Mesa 7i76U - Omron MX2 wiring
Category: Basic Configuration
Here is 5I25/6I25 firmware for a 7I76U with the PKTUART
File Name: 5i25_7i76x1pktd.zip
File Size:124 KB
I can try to help more later, but note there is another user trying to get a Omron MX2
working with a Mesa card and having issues. I suspect I may have to acquire a MX2
to try and get this going.
The 7I76U manual has the RS-485 wiring information (and you must use RS-485 mode with the 7I76U
so you lose on estep/dir output)
  • VRNF
  • VRNF
08 Feb 2026 03:40
Replied by VRNF on topic Maho mh800w retrofit
Sounds like you have two separate errors.to clarify, when you try to start the machine contactors are closing? If so, which?
For the servos, can you post how you connected the indramat +/- 10V wires to 7i97T terminal block?
  • Ozcnc
  • Ozcnc
08 Feb 2026 03:21 - 08 Feb 2026 05:26
Hello,Im using LinuxCNC 2.9Can I please get some assistance with wiring of the mesa 7i76U to an omron mx2 VFD and the HAL and INI file and the correct firmware recommendation. files.omron.eu/downloads/latest/manual/e...rs_manual_en.pdf?v=1
You do not have permissions to access this page.
  • rodw
  • rodw's Avatar
08 Feb 2026 02:22
Replied by rodw on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
37 m/min! Wow! I was starting to worry these motors will look tiny on such a big printer maybe I should look at bigger motors haha.
I will plan on using these motors with 2:1 reduction and 60mm dia. drum. 3 axis plus I can use the 4th output from this Lichuan driver for the small extruder motor.
My Elegoo Neptune 3 Max has a max rated speed of 6.4 m/min and they recommend printing at 3.6 m/min. The guy running the fast little FLSUN printer will probably share with me what the slicer settings look like for such high speed printing. The FLSUN S1 does 72 m/min. but I'm not interested in trying to match that any time soon. That printer has even less build volume than my elegoo.
The extruder - I will probably start with the spare head I think I got for my other printer, but I read recently about a new printer model, can't recall what it was called. It used high frequency induction heat to heat the nozzle, allowing the heater in the print head to heat up and cool off in seconds because the mass of the heater was reduced to pretty much just the nozzle. I might try that later.
I hope I'm not hijacking your thread here, maybe I should start a separate thread in hardware or builds related category when I start building this 3d printer.
There  are some pretty cool 5 way print heads I've seen recently. www.aliexpress.com/item/1005007430584580.html
  • NWE
  • NWE's Avatar
08 Feb 2026 01:54
Lenovo T14 Gen2 AMD - CRAZY High Latency - Am I screwed?
Not being able to access the bios seems quite a handicap. Lenovo says replace the motherboard. I found some possibilities otherwise:
www.ebay.com/itm/204768580473
and
www.reddit.com/r/thinkpad/comments/13wwp..._reset_for_t14_gen2/
Hope that helps.
08 Feb 2026 01:35
Replied by tommylight on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
This would be the right place for it:
forum.linuxcnc.org/additive-manufacturing
08 Feb 2026 01:23
Probably...
But, do download and test from USB the 2.8.4 version of LinuxCNC in a live session, report back how that looks.
And from experience with many, many laptops, they either work or they do not, so tweaking might just improve things a bit, but going from 3 million to 25-50K is never going to happen.
Also, disable TPM or whatever Lenovo is calling the Trusted Platform and anything related to virtualisation.
Some ideas here:
forum.linuxcnc.org/18-computer/54369-use...mesa-ethernet-boards
  • MaHa
  • MaHa
08 Feb 2026 01:17
Adding Feed Rate (IPM or IPR) to the lathe screen
Category: AXIS
With 2.7 i have used this pin. It needs multiply by 60 for feed per minute
motion.current-vel
current velocity in user units per second
example HAL:
setp   mult2.0.in0   60
net velcalc   mult2.0.in1   motion.current-vel
net cur-vel   mult2.0.out   pyvcp.feed
actual linuxcnc stable has pin
motion.feed-inches-per-minute
  • NWE
  • NWE's Avatar
08 Feb 2026 01:00
Replied by NWE on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
  • ihavenofish
  • ihavenofish
08 Feb 2026 01:00
Replied by ihavenofish on topic Mini wannabe datron build
Neeeed that jerk controllll.....
haha. :)
  • NT4Boy
  • NT4Boy
08 Feb 2026 00:23
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Thanks Andy. In fact I amusing Open Loop control fo this spindle. its a 2hp three phase device and seems pretty stable as is. Tried the improive it with pid tuning but only made things worse.
Still not got the orient to work. Swiching pids ok, but somewhere the orient count, angle and units screwed up and not reseting on the index.
might take a while longer.
Displaying 5716 - 5730 out of 14030 results.
Time to create page: 2.345 seconds
