  • Sirfrimfram
  • Sirfrimfram
23 Jan 2026 19:18
Replied by Sirfrimfram on topic M6 Remap Issues - Weird Queue Buster Problem
The issue indeed did turn out to be related to spindle-at-speed.
Was able to fix it by ensuring spindle-at-speed was set true during tool changes.
  • andypugh
  • andypugh's Avatar
23 Jan 2026 19:17
Replied by andypugh on topic Mesa Card Basics
Mesa Card Basics
Category: Driver Boards
You can't use names= and count= at the same time.
if using HAL_TWOPASS then they all need to use names=
In your example the correct syntax is:
loadrt and2 name=probe_and
addf probe_and servo-thread
loadrt and2 name=estop_and
addf estop_and servo-thread
  • andypugh
  • andypugh's Avatar
23 Jan 2026 19:14
Replied by andypugh on topic 1982 Matsuura MC-500v Retrofit
Category: CNC Machines
Home-made spindle encoders can be as simple as a slotted disc with 3 x opto sensors (like: www.amazon.co.uk/YOUMILE-Optocoupler-Sen...rduino/dp/B07TZ78N8W )
You need to make one slot a bit deeper so that only the index sees it, and arrange the others around the perimiter so that they are N + 0.25 apart. (not N + 0.5 as I once did when making an encoder)
  • andypugh
  • andypugh's Avatar
23 Jan 2026 18:45
Replied by andypugh on topic Lathe Macros
Lathe Macros
Category: Other User Interfaces
The "play" button, if visible, ought to come to life when the machine is on and homed.
  • andypugh
  • andypugh's Avatar
23 Jan 2026 18:43
Replied by andypugh on topic XHC-WHB04B-4 config difference
See the "buttons" section:
linuxcnc.org/docs/stable/html/man/man1/x...6.1.html#HAL%20USAGE
The default config is set up just to say "macroN" when you press a button.
If you want to do somethng when you press the button you need to change (debug, macro4) to a bit of G-code (or a call to a subroutine) that has the desired affect.
  • andypugh
  • andypugh's Avatar
23 Jan 2026 18:37
Replied by andypugh on topic Z axes reference gets "forgotten"
Does your G-code include a G43 after loading the tool? (do you use the tool table, and are there non-zero Z length entries in there?)
  • andrax
  • andrax's Avatar
23 Jan 2026 18:36
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
What did you use for noise filters on the servos?
I can't find any information anywhere.
  • andypugh
  • andypugh's Avatar
23 Jan 2026 18:25
Replied by andypugh on topic M6 Remap Issues - Weird Queue Buster Problem
Getting stuck on a G1 can often be related to spindle-at-speed being false. How is that driven?
  • andypugh
  • andypugh's Avatar
23 Jan 2026 18:15
Catch 22 - PP 2.0.0 thumbdrive does not support MESA 7i92T, PP update blocked
Category: PathPilot
You may be editing the correct files, but maybe you are not running the right files?
If you start from a desktop entry, what is the command-line that it runs?
  • my1987toyota
  • my1987toyota's Avatar
23 Jan 2026 17:48
Replied by my1987toyota on topic ARE YOU KIDDING ME YOUTUBE !!!
Time will tell.
  • Japoo_Ness
  • Japoo_Ness
23 Jan 2026 17:38
Replied by Japoo_Ness on topic Mesa Suppliers
Mesa Suppliers
I’m going to try that next. I’ve been avoiding it since my English isn't the best, but I've already sent a few emails and haven't received a response yet.
Does anyone know if Mesa is having trouble getting back to people lately?
  • PCW
  • PCW's Avatar
23 Jan 2026 17:31
Mesa 7i96S - Error finishing read! iter 8
The USB Ethernet adapter is likely the main issue here
Running:
sudo chrt 99 ping -i .001 -q -c 60000 10.10.10.10
in a terminal window will give you an idea of the latency of the hosts Ethernet interface
( The command will run for 1 minute and then print timing statistics )
  • slowpoke
  • slowpoke
23 Jan 2026 17:16
New installation using a Yoga C340 and Mesa 7i96s
I'm getting an error when I start LinuxCNC, "Error finishing read! iter 8 ?
Red LED on Mesa turns on when this ocuurs.
I'm using a USB-C to Ethernet adapter and my best hunch is that this might be the problem?
Connection information is as follows:
IPV4
IP address 10.10.10.100
Broadcast address 10.255.255.255
Subnet mask 255.0.0.0.
7i96s jumpers are down, up = EEPROM
Is there something incorrect with the settings above?
The adapter I'm using is this one:  www.amazon.ca/dp/B0BR3M8XHK?ref=ppx_yo2o..._fed_asin_title&th=1
I'm not sure what steps I should take to troubleshoot?
  • mariob
  • mariob
23 Jan 2026 16:38
Linuxcnc erste Schritte und erste Probleme, NVEM und Remora
Category: Deutsch
Hallo,
und danke für den Link / Hinweis. Ich habe den Rechner zur Zeit nicht in Betrieb, die bestellte Bios Batterie ist eingebaut, die neue Festplatte muß noch rein, alles wieder zusammengebaut und dann Linuxcnc nochmal neu aufgesetzt werden.
Ja, das mit den verschiedenen Hardwareversionen habe ich herausbekommen, ich schaue mir die Links noch einmal an. Ich habe hier den Controller mit dem STM32F207 Chip.
Wenn ich das richtig verstanden habe (ich bin im Thread bei Beitrag 80) hat der Controller nach dem Brennen der Firmware bereits eine einfache Konfiguration für 3 Achsen als Default, ich muß also keine config.txt zusätzlich laden?
Gruß
Mario
Displaying 6541 - 6555 out of 14040 results.
Time to create page: 0.319 seconds
