  • Lcvette
  • Lcvette's Avatar
23 Jan 2026 16:27
Probe Basic Documentation and Installation... Start Here!!!
Category: QtPyVCP
The Docs have been updated again so please be sure to review and check for any changes if you are updating your installation!
kcjengr.github.io/probe_basic/
  • ihavenofish
  • ihavenofish
23 Jan 2026 16:26
Replied by ihavenofish on topic ARE YOU KIDDING ME YOUTUBE !!!
Well, that's the question... There's a few ideas floating around I've seen.
  • ok
  • ok
23 Jan 2026 16:00
Replied by ok on topic ARE YOU KIDDING ME YOUTUBE !!!
If you think this is on one hand not real and unworkable, but one the other hand suspect that they are "hiding something else" - What do you have in mind that they (whoever that is) want to achieve?
  • ihavenofish
  • ihavenofish
23 Jan 2026 15:50
Important to remember this is JUST rage bait, and not real.
They literally aren't banning anything, they are proposing a restriction that is not workable even if it got passed, which it won't.
Should you be concerned at their lack of knowledge to understand their own laws? Yes. Should you be concern this will somehow impact your printers or CNC's? No. Should you be concerned this will make linuxcnc disappear? No. That's literally not even possible.
You need educate your local government if you see bills pop up like this, they are clearly clueless. Responding as if this is an existential threat though is just being as silly as they are and not in the least bit helpful.
My opinion is that this proposed law is SO dumb that it is hiding something else. Follow the money as they say. Who benefits from this? It's not gun safety advocates.
  • ihavenofish
  • ihavenofish
23 Jan 2026 15:40
Replied by ihavenofish on topic LinuxCNC S-Curve Accelerations
 we are limited to what we can do.
This statement does no compute.
  • PCW
  • PCW's Avatar
23 Jan 2026 15:31
Bitfile or help – Mesa 6i25 + 7i74 (BiSS-C) + 8i20 + 7i70/7i87
Category: Driver Boards
There are no constraints on HostMot2 FPGA pins, any pin can be any function
so a 7I74 ( 8 channel RS-422/-RS-485 interface) can have any mix of functions
that physically match the 7I74 pinout. That is, for example, you could have
SSI,BISS,Fanuc absolute encoders are sserial mixed on the same 7I74.
You could even have Step/Dir outputs on output channels and say period
measurement on input channels.
  • my1987toyota
  • my1987toyota's Avatar
23 Jan 2026 15:13
Replied by my1987toyota on topic I got a medal!
I got a medal!
A well deserved award. And thank you as well for what you do for this community.
  • my1987toyota
23 Jan 2026 14:40 - 23 Jan 2026 14:42
Replied by my1987toyota on topic ARE YOU KIDDING ME YOUTUBE !!!
And yet more. call it rage bait if you want. Remember this isn't just about 3D printers  it concerns ANY machine Additive
or Subtractive.
  • Mark Kraus
  • Mark Kraus
23 Jan 2026 13:49
Trying to move from UCCNC to Linuxcnc and using 7i96s but having trouble
Category: StepConf Wizard
I was not getting anything on halshow and then I used a multimeter on the encoder and did not get anything. I thought it may have been damaged so I ordered another and hope to install it Sat or Monday.
23 Jan 2026 13:12
... i wanted to know if it is possible to have both a biss signal on a port and a normal serial on the other port on a single 7i74?
I would venture a guess at Yes it is as i have something similar in use for many years, details here
forum.linuxcnc.org/30-cnc-machines/31792...-01-retrofit?start=0
There should be attached two firmwares for 5i25/7i77/7i74, one with 4 SSI and 4 SSerial, and another for 6 SSI and 2 SSerial, look for posts made by PCW if you think any of that is helpful.
23 Jan 2026 13:03
Replied by tommylight on topic Best controll board for LinuxCNC
If you can justify it, Mesa 7i96S.
For very cheap use an old PC with a parallel port, or a new-ish PC with a parallel port add on card.
Both versions are extremely reliable, proven by many machines in daily use.
Depending on requirements, parallel port might limit the maximum speed, still very usable always.
  • Murphy
  • Murphy
23 Jan 2026 12:23
I finally got CSS working on the lathe. I ditched the vevor vfd and bought a Huang yang vfd. It had way more features. I connected it through modbus instead of the EC500. It works perfectly now in CSS
  • sataran
  • sataran
23 Jan 2026 10:29
alright i got my encoder biss running! i started to assemble all cards and i wanted to know if it is possible to have both a biss signal on a port and a normal serial on the other port on a single 7i74?
if it is not possible i will use another solution but if it is a possibility I'll need a different bitfile.
my configuration is :
6i25
P3 =>7i76
->spindle -> variator - > motor
->field out 0 7 -> 4contactor
->field in 0 15
P2 =>7i74
-> biss
-> 7i87
-> 8i20
  • grandixximo
  • grandixximo's Avatar
23 Jan 2026 10:24 - 23 Jan 2026 12:20
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
The jerk limits are being respected on the tangent trajectory, the jerk limit works on segments due to the tp architecture, you see jerk spikes because when you look at the joints indipendently, the jerk they experience is completely different from planned jerk, there is cartesian rotation jerk, there are kinematics transitions, the spikes being reported are due to the fact that how the jerk is implemented and the architecture of the tp, we are limited to what we can do. When users report spike and we try to fix them, we find that the problem is not our jerk limiting, it's everything around it that is not made with jerk limit in mind...
The reasoning behind "augmenting" the path, is that we don't like to see the machine ondulate, on something like a multi axis cloud point, we can do it very smoothly but not at constant velocity, look at the actual machine and you'd want to fix it too. Do you want to see nice curves in the scope. Or you want to see the machine behave like it's following a smooth path?  Swift motion requires a swift path, they go together.
  • Demunkies
  • Demunkies
23 Jan 2026 10:22
Best controll board for LinuxCNC was created by Demunkies
Which controller board is best to use with LinuxCNC? I have a 3-axis router. DM542 stepper drivers and Nema 23HS9430B motors
Displaying 6556 - 6570 out of 14038 results.
Time to create page: 0.314 seconds
