  • NWE
  • NWE's Avatar
30 Dec 2025 06:45 - 30 Dec 2025 07:02
Replied by NWE on topic Spindle Encoder: Float Precision Issues
Category: HAL
Maybe reset the encoder count on each index pulse? Then it would not count to such high numbers. But this will break the speed output of your ddt (I think). Does the EL5151 not have an encoder velocity output? I just used a similar Beckhoff part recently but can't remember, I don't think I used or needed velocity (speed) feedback in that project.
  • meister
  • meister
30 Dec 2025 06:10
there are an buildin watchdog, it will disable the pwm/stepdir output if the connection is lost.
you can also set a chain of 'modifiers' to each pin (plugin -> Pins -> Modifiers) like delay, debounce, ... and 'onerror'.
The 'onerror' modifier hold the pin to low or high if connection is lost.
You can also use the 'chargepump' hal-component (www.linuxcnc.org/docs/html/man/man9/charge_pump.9.html) to control a master power relay.
  • kello711
  • kello711's Avatar
30 Dec 2025 05:52
Replied by kello711 on topic 7i96S card arrived what setup is recomended
Category: Driver Boards
Ok, so I think I understand what I should do. Using the StepperOnline Motion Studio software, I change the ENA polarity from high to low so no input is disabled and 5V input enables the motors. Additionally, I can switch the ALM polarity from low (default) to high and take that input in as inverse. Basically like a NC estop. For the wiring on the ENA, can I daisy chain them together? Also for the ALM, can I run those in series with the GND coming into the first driver and the last driver returning the GND back to the controller, with 24V as the input common?
  • rodw
  • rodw's Avatar
30 Dec 2025 05:17
Replied by rodw on topic Python LinuxCNC module
yes this is a requirement now. nonstandard modules require a virtual environment (venv) in a folder. Google python venv
  • NWE
  • NWE's Avatar
30 Dec 2025 04:47
Replied by NWE on topic PID Windup on the way down
Category: HAL
Pid maxoutput limits in the positive and negative direction. So, you can set maxoutput to 1.0 and it will limit the output in the range of 1.0 to -1.0
I'm not sure what it would take to prevent windup below 0.
For what its worth, one thing that has bit me in the past in trying to tune PID and lots of troubles with windup: slow vfd accel/decel. If the PID is tuned to respond faster than the ramp time of the VFD, that'll wind it up.
Also, a hal limit1 component might be in order to prevent sending a negative voltage to the vfd analog input, some kinds smoke when they get negative signals.
  • Ozcnc
  • Ozcnc
30 Dec 2025 04:15
Linuxcnc 2.9.7 - Mesa 5i25 with HKD 5 AXIS MACH3 STEPPER I/FACE and 5i25_5ABOBx2
Bob has 5v using usb.
I'm only working with 5v now to get step/dir outputs working.
I will connect the 12v supply to run the spindle.
  • Dave3891
  • Dave3891
30 Dec 2025 04:08
I've started wiring and testing my custom RIO board and everything is looking good so far.
Is there any option to have a watchdog on the outputs? So if the computer crashes or loses connection the outputs will turn off?
Also are there any examples anywhere of controlling a spindle VFD over modbus with RIO?
  • PCW
  • PCW's Avatar
30 Dec 2025 03:27
Replied by PCW on topic 7I84U multiplex control panel switches
This can be done with 5 7I84U outputs and 6 7I84U inputs in conjunction
with the matrix_kb component
If you expect to press more than one switch at a time
you need to add one diode per switch
I'm pretty sure there are examples of this on the forum so a
search for "7i84" and "matrix" might find something...
  • rmavalente
  • rmavalente
30 Dec 2025 01:31
7I84U multiplex control panel switches was created by rmavalente
Hello Folks,
I searched, but not much came about multiplexing the IO on a 7I84U or other mesa card. My panel will have 28 push buttons, 3 pots and one MPG. I could wire everything to the 7I84U, but with a 5x6 matrix I can mux all the switches, saving IOs.
How can this be done? Examples would be much appreciated.
Greetings
  • PCW
  • PCW's Avatar
30 Dec 2025 01:30
Replied by PCW on topic 7i97t Mesaflash Problem
Also note that the pre-installed firmware on a 7I97T fully supports the standard analog and digital I/O
You typically only need different firmware if you have an added parallel daughtercard
Analog output problems are most likely a hal file or tuning/polarity issue
  • grandixximo
  • grandixximo's Avatar
30 Dec 2025 01:10 - 30 Dec 2025 01:10
  • grandixximo
30 Dec 2025 00:30
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
my s-curve blending is comparable to the current TP, there is some loss, but it is unavoidable, but not in mills or more range.
  • NWE
  • NWE's Avatar
30 Dec 2025 00:28
Ursviken Pullmax Optima 130 press brake retrofit with 4 axis backgage
Category: Show Your Stuff
I think a custom hal component will be the ticket for this ram control. I envision a glade user interface, separate reusable custom components for each backstop axis, and a custom component for the Y axis (upper beam height control.)
Different brands of press brakes would get their own  Y axis component, due to complicated variations in hydraulic configurations among the different makes and models.
Bend programs will be loaded in the python userspace gui app as a list of dictionaries containing positions for every single axis for the machine.
Stage two of my dream will be to write a python based app allowing the user to enter dimensions and angles, then create the bends file that the press gui can load.
Attached preliminary work, don't try running this one, it is incomplete yet.
  • hhscott
  • hhscott
29 Dec 2025 22:19 - 30 Dec 2025 07:07
Python LinuxCNC module was created by hhscott
I am wanting to write a couple of simple python3 scripts to automate some functions in LinuxCNC using the python linuxcnc module to send NML messages. I did this several years ago for another project and it was very successful. In this new application I am using a pi5 8GB with a Mesa 7i96s running Trixie 2.9.7. The basic installation is working well and the CNC is operating great so far (without any python automation).
I am a little confused about using python on Debian Trixie. When I try to install a package I get errors and the terminal prompts that I should use a virtual environment for python and packages. If I do this, will my python scripts still connect to the running instance of LinuxCNC? Please help me understand the basic structure for using python on the Trixie OS with LinuxCNC.
Thank you,
HH
  • endian
  • endian's Avatar
29 Dec 2025 21:55
Replied by endian on topic Ethercat random jitter fix
Category: EtherCAT
If you will test it .. please share some visual results before and after{for example scope printscreen) .. We are all interested in your pr I think !
thanks
Displaying 7591 - 7605 out of 14025 results.
Time to create page: 1.229 seconds
