  • MaHa
  • MaHa
13 Dec 2025 18:52 - 13 Dec 2025 20:07
freelancer needed to create a routine for ATC tool change (rackchange)
I modified the routine for unload and load, o315 and o 316 used. In .ini file the value for 'y_gap' should be 206, not 317 The diff shows the modification
File Name: rack_change.txt
File Size:3 KB
  • Hakan
  • Hakan
13 Dec 2025 17:49
Ethercat compatible Encoder board tentative STM32F4 + LAN9252
Category: EtherCAT
Are you sure spi works?
Apart from that, make sure the stm32 and the eeprom are in sync, that is, they both come from the same saving of "Save all files"
and that the firmware is compiled and downloaded. It doesn't hurt to do it one more time.
Power cycle the board to make sure both stm32 and lan9252 read the most recent data.
Right-click the mouse on the marked item and remove it. Scan for new boxes to make it reappear.
Also quit Twincat and start it.
All a bit extra cautious to make sure any old data/cache is eliminated.
  • LCR
  • LCR
13 Dec 2025 17:14
Problems with Lichuan Ethercat servo drive
Category: EtherCAT
LinuxCNC must have timed out I'll attach again hopefully.
File Name: My_Etherca...2-13.zip
File Size:25 KB
  • LCR
  • LCR
13 Dec 2025 17:12 - 13 Dec 2025 17:15
Category: EtherCAT
So here is my setup directory. It has been 6 months since I've looked at this, also I'm not too proud, I just got it working.
It is for a gantry. Includes homing and compensates for the buildup of following error I see on all the axes.
The integration loop bit is at the bottom of cia402.comp.  It's more like a slow drift than hard integration. But it does the job of eliminating the buildup of position error.
Also make sure you are sending the target velocity 60B1 and adjust the velocity gains. I ran the machine back and forth and watched following error as I adjusted the various velocity gains. They matter.
Attachment not found
  • Masiwood123
  • Masiwood123's Avatar
13 Dec 2025 16:44 - 13 Dec 2025 16:52
.this does not work, maybe because you entered the parameters in the routine in the section of returning the current tool to its place, also o302 already exists, so I changed it to o303, but the same thing happens when selecting T4 M6(spindle goes 111mm from tool 3). you should somehow add it to the section of the file where it says ``POKUPI ALAT'',- means that is, ``selected tool'' down in routine, if you are able to edit that part. Thank you very much
  • spumco
  • spumco
13 Dec 2025 16:43
Replied by spumco on topic Clearpath HLFB amp.joint.delay
Category: HAL
 back when they were selling stepper motors and labeling them as "revolutionary servo motors" for a lot more $, and i think they still do, but now with encoder feedback.
Tommy,
They aren't steppers and I don't think they ever have been.  I haven't seen the internal windings, but they don't act like any steppers I've come across.  There is no perceptible rotor cogging when you spin them by hand.  Even the Berger-Lahr 5-phase steppers I have on my Emco lathe have a tiny bit of cogging feel.
The Nema 23/34's are BLDC's with an encoder, trajectory generator, and IO (not just some halls).  The AC-input versions are... maybe something else, don't know.
I've been using them off and on for automation equipment for about 7-8 years and they haven't changed, at least not the mechanical/electrical parts.  They've got upgraded IP67 connectors as an option now, as well as Ethercat models.
Best thing since sliced bread?  No.  There's an upper limit to the performance you can get with 75VDC and 16AWG(ish) cables.
But they are extremely useful in certain applications and no separate drive makes integrating them very easy.
  • cdamm11
  • cdamm11
13 Dec 2025 16:27
Replied by cdamm11 on topic 6i25 and 7i77 config
Category: Driver Boards
Yes the PC is in metal housing and right now it is outside the control cabinet. I am confident this is not a EMC issue.
i have bought a much older pc which i will test tommorow.
thanks so far.
  • PCW
  • PCW's Avatar
13 Dec 2025 16:15 - 14 Dec 2025 04:08
Ursviken Pullmax Optima 130 press brake retrofit with 4 axis backgage
Category: Show Your Stuff
is
hm2_7i80.0.pwmgen.00.enable <== j6-amp-enable
true when you expect PWM output?
Your firmware has PWMGEN 0 enabling all 7I54 PWMgens
If this is not desirable you leave the enables as GPIO
bits.
  • Ismacr63
  • Ismacr63
13 Dec 2025 16:05 - 13 Dec 2025 19:45
Replied by Ismacr63 on topic VFD configuration help
Category: Turning
Thanks for your reply. That works fine, except I can't use the three-position switch for forward and reverse.
I've also noticed that when I press the stop button, I have to hold it down until the motor stops completely. If I release it before the motor stops, it doesn't stop and the RPMs increase again.
I'll keep this VFD (A2 8015) for a belt sander I'm building.
I bought another VFD, a Suswe SU600, for the lathe, and I'd like to do the same as with the other one: add a three-position switch for forward and reverse, and a start/stop button.
  • NWE
  • NWE's Avatar
13 Dec 2025 15:22
Replied by NWE on topic 6i25 and 7i77 config
Does the pc have a metal housing (shielded), with the 6i25 inside? Or is it a motherboard mounted in a cabinet that also contains a VFD, relays, etc? If so, your motherboard will likely need additional shielding.
13 Dec 2025 15:18
Replied by tommylight on topic 6i25 and 7i77 config
Find or borrow a used PC.
  • cdamm11
  • cdamm11
13 Dec 2025 15:08
the pc only reboots when i try to run my configuration. i can run Sample configurations like "axis". But when i try to run the config i created using pncconf wizard the pc just reboots. i also does this if i try to Open Loop test or test / tune axis.
  • unknown
  • unknown
13 Dec 2025 14:40
Replied by unknown on topic Linuxcnc Rpi4/5 Images
Category: Installing LinuxCNC
langdons as these are release candidates I would prefer if these are only available from the links on my github page. If you have any images with rcX in the file name on your server could you please kindly remove them.
13 Dec 2025 14:40
No, not really, you will need another PC at least.
Lets clear something up first, does the PC reboot when turning ON the Mesa cards, or, when running LinuxCNC ?
13 Dec 2025 14:37
Replied by tommylight on topic Clearpath HLFB amp.joint.delay
Category: HAL
@Spumco,
Thank you for reminding me, now i know why i can not recall what was going on as i am used to ignoring everything having to do with clearpath since back when they were selling stepper motors and labeling them as "revolutionary servo motors" for a lot more $, and i think they still do, but now with encoder feedback.
Displaying 8161 - 8175 out of 14061 results.
Time to create page: 4.389 seconds
