  • timo
  • timo
19 Jan 2026 21:52 - 19 Jan 2026 21:53
Replied by timo on topic G Codes not working
G Codes not working
Category: G&M Codes
Isn't it the point of CNC that every program can be different?
Joking aside:
I guess if you post the two codes, you might have more replies quicker.
  • spumco
  • spumco
19 Jan 2026 18:43
Replied by spumco on topic ARE YOU KIDDING ME YOUTUBE !!!
Can i renounce my US citizenship? Granted i never went there, but still i feel ashamed about what is going on there as i have two brothers living there.
Understandable, but keep in mind this is a Washington state bill, not federal.
Depending on how it plays out I'd be surprised if federal reps from similarly-leaning states don't introduce similar legislation at the federal level.
  • Davidson55
  • Davidson55
19 Jan 2026 16:24
G Codes not working was created by Davidson55
G Codes not working
Category: G&M Codes
Good day. I am new to Linux CNC. I have been working with the owner of Sherline. Great guy but he's too busy to help me on every issue I have. So, I am coming to the Linux CNC community for help.
I am using BobCAD-CAM for my CAD/CAM. After I complete my drawing and create my G-Code, I then transfer it to my Sherline program. I have a Sherline 4400 lathe. I am using version LinuxCNC/Axis 2.9.0. I was given a sample program from Sherline. I ran the program with no issues.
I am looking at the g-codes I created and the sample code, they're totally different.
If someone has the time to give help would be much appreciated. If I need to post the g-codes, let me know. Thanks in advance.
  • juliankoenig87
  • juliankoenig87
19 Jan 2026 16:03 - 19 Jan 2026 16:10
Mesa 7i96S step ausgangsignal =5V , Schrittmotortriber eingang 12V was nun?
Category: Deutsch
Er meint denke ich diese hier(Anhang).
Jedenfalls bei meinem sind 74hc245d drauf. Die können keine 12V. Aber who knows. Vielleicht gibt es breakout boards (bob) die das können. Würde mich interessieren.
Hab dein pdf überflogen. Nochmal anders als in deinem vorherigen Bild. Genau wie bei meinen Endstufen. 12V hochohmiger Pullup an Schmitt Trigger.
Kannst du dann plug n play mit dem Darlington Array auf Masse ziehen.
Kann dir morgen mal den Schaltplan schicken. Hab die Platinen unbestückt hier liegen oder eine noch teilbestückt (ohne Relais). Bauteilkosten und was für die Kaffeekasse reicht mir, falls wir nicht noch andere Lösungen hier genannt bekommen.
  • meister
  • meister
19 Jan 2026 15:41
Category: Deutsch
Nimm doch einfach ein 5achs Bob und steck es an den pfostenstecker. Das Teil kostet 8euro auf Amazon. Dort sind die uln drauf, damit kannst du deine 12v Signale erzeugen.
  • Studi
  • Studi's Avatar
19 Jan 2026 15:14 - 19 Jan 2026 15:26
Category: Deutsch
Wow, von Printdesign bin ich noch ein gutes Stück entfernt..
Meine Fräse ist ein Kumpel Projekt.
Er macht auch Elektronik und ich eher das mechanische.
Jedenfalls sieht dein Lösungsansatz echt professionell aus.
(Ich sage frech einfach Du, bin 65, darf ich das?)
Zum Thema krumme Beinchen, würde ich sagen: Viel besser dies , als vulkanähnliche Erhebungen auf dem Chip!
Ja, der Bedarf besteht durchaus! Ich werde das meiner Kumpel zeigen, und abfragen, welche Meinung er dazu hat.
Ich selber bin von einer Kauflösung ausgegangen und habe verzweifelt ein Pegelwandlerbord gesucht.
Hab aber nur von höher nach tiefer gefunden. Nix würde passen.
Wie würde das ablaufen?
Ich bin gern bereit dafür was zu bezahlen.
Sorry beim Thema Bitfile, muss ich noch passen, hab mich noch nicht damit beschäftigt.
PS: Hab noch die alte Anleitung zur Schrittmotorenkarte gefunden. Hänge diese auch noch an.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • juliankoenig87
  • juliankoenig87
19 Jan 2026 14:25
Category: Deutsch
Yes. Also necessary with my solution, because the ULN is also sinking.
  • ihavenofish
  • ihavenofish
19 Jan 2026 14:23
Replied by ihavenofish on topic ARE YOU KIDDING ME YOUTUBE !!!
Laws made by people that have near zero understanding of the things they are trying to make laws about... sounds about normal.
Given the DIY and open source nature of printers, this law (which wont likely pass) would do nothing to stop printed guns, and only serve to harass law abiding citizens.
It's just nonsense.
  • PCW
  • PCW's Avatar
19 Jan 2026 14:06
Category: Deutsch
Without  a fancy level shifter chip,  you could use a small MOSFET
(say an 2N7000) and a stiff pullup resistor (300 ohms 1W as suggested)
to do the level shifting.
+12V --> 300 Ohm resistor pin 1
MOSFET Drain  --> 300 Ohm resistor pin 2 --> motor drive input
MOSFET source --> GND
MOSFET Gate --> 7I96 output
19 Jan 2026 14:05
Replied by tommylight on topic ARE YOU KIDDING ME YOUTUBE !!!
  • juliankoenig87
  • juliankoenig87
19 Jan 2026 14:02
Category: Deutsch
Achso. Das Ganze per ULN2803. Und wenn man eh dabei ist nen paar Inputs über TLP292 Optokoppler...
  • juliankoenig87
  • juliankoenig87
19 Jan 2026 13:57 - 19 Jan 2026 14:00
Category: Deutsch
Moin,
hab das selbe Thema bei meinen Berger Lahr Endstufen. Die benötigen auch 12V. Hab mir für die 7i96(s) dafür eine Adapterplatine gemacht. Mit einem Darlington Array. Für die üblichen 100 bis 200kHz Takt jedenfalls schnell genug. Dazu weil noch Platz war 2 Relais und bissle Kleinkram. Modbus und 0-10V.
Steckt man auf den expansion port. Bin nur noch nicht dazu gekommen das Bitfile zu schreiben. Wenn du Bedarf hast gibt Bescheid. Allerdings hab ich das auf ner 7i96. Falls du zb. eine 7i96s nutzen willst müsste man nochmal ran dann was das Bitfile angeht.
Wie immer auch dort beim ersten Mal kleine Fehler (siehe schiefe Pins) ;-)
Grüße
Julian
  • PCW
  • PCW's Avatar
19 Jan 2026 13:41
Trying to move from UCCNC to Linuxcnc and using 7i96s but having trouble
Category: StepConf Wizard
Can you post your current hal/ini files?
There are basic steps to verify encoder operation
1. Run halshow
2. Select the watch tab and then the 7I96S  encoder position pin and verify that it
increments by 1 for each forward turn of the spindle
If not you need to check the scaling, encoder connections etc
  • Studi
  • Studi's Avatar
19 Jan 2026 13:19 - 19 Jan 2026 13:34
Category: Deutsch
Meister schrieb:
Du brauchst sowie dochso ein Breakout-Board, die in der Regel einfach den Pin auf Masse ziehen, daher kannst du die Spannung selbst festlegen.
Kannst Du mir das erklären?
Das Mesa-Bord ist der Takt- und Richtungsgeber, dessen Ausgänge sind TTL Pegel = 5V.  ( Ich denk, die gibt die Spannung vor, oder?)
Die Motorenkarte erfordert aber mindestens einen Pegel von 8-12V. (Die Spannung der Mesa liegt weit unter dem Pegel der von den Eingängen gefordert wird.)
Displaying 8551 - 8565 out of 11472 results.
Time to create page: 0.261 seconds
