  • NWE
  • NWE's Avatar
19 Dec 2025 22:13 - 20 Dec 2025 06:41
Ursviken Pullmax Optima 130 press brake retrofit with 4 axis backgage
Category: Show Your Stuff
Y1 and Y2 are not reading any index for me. I better bring my oscilloscope next time to check what, if anything, is coming in those z and /z wires from the linear scales. Latching hal logic connected to [HMOT](CARD0).encoder.04.input-index and [HMOT](CARD0).encoder.05.input-index does not catch any pulse.
Y1 and Y2 also has reference sensors near the bottom, it'll never reach that position after he installs the punch and the die. I see the book calls them Max Down Left, and Max Down Right. So they are bottom limits. Maybe to avoid overextending the cylinders when no tooling is installed.
edit:
Finally got R1 axis (joint 6) homing to index.
When all else fails, read the instructions! Here is the magic that makes home-to-index work:
net    j6-index-enable        [HMOT](CARD0).encoder.00.index-enable
net    j6-index-enable        joint.6.index-enable
19 Dec 2025 21:31
  • kello711
  • kello711's Avatar
19 Dec 2025 21:26
Replied by kello711 on topic 7i96S card arrived what setup is recomended
Category: Driver Boards
the ALM signal is just an OPTO output
The ALM is an OPTO output from the CL57T right? According to the manual section 6, it shows that I need to supply 5-24v DC to that circuit. Can I just use my 24v field power for this? Doesn't it matter that I have the driver setting S3 set to 5v (due to STEP/DIR 5v signals)? I don't want to fry this thing before I get going.
Note that you could parallel the ALM outputs to save inputs
This was the plan.Also, how do I use a spare STEP/DIR for ENA? Is that in my HAL settings? The manual mentions:
ENA must be ahead of DIR by at least 200ms
  • Nator
  • Nator
19 Dec 2025 21:19
PicoBOB-DLX was created by Nator
PicoBOB-DLX
Hello everybody,
I do have a self build portal CNC machine with LinuxCNC and LPT running. Never really disappointed me, well maybe it could be a little less noisy (more microsteps). Now a WABECO F1210 found its way into my workshop. I would like to convert the whole system to LinuxCNC since I got the whole "chain" for this running. When I started LPT was the choice of the time. Now I read about MESA and stuff. ChatGPT brought me to the PicoBOB-DLX. This thing looks quite like a smart "simple" solution. Does someone has this running? Since I got some kids since my last build the "free" time did not get more... So I am really interested in a quite simple solution.
regards Han
  • PCW
  • PCW's Avatar
19 Dec 2025 21:00 - 19 Dec 2025 21:09
PNP for mixed voltages...
But I don't think you really need mixed input voltages, as the Enable is an output
and the ALM signal is just an OPTO output
For 24V NPN proximity switches:
+24V --> 7I96S input common
NPN proximity switch 0utputs --> 7I96S isolated inputs
ALM+  --> 7i96S isolated input
COM- 24V COMMOM
  • kello711
  • kello711's Avatar
19 Dec 2025 20:42
You can mix  7I96/7I96S input voltages if the inputs are wired in sinking mode,
that is if the input common (TB3 pin 12)  is wired to ground and the sources
(switches, alarm signals etc) supply a positive voltage relative to this ground,
in this case, the input will respond to positive voltages between 5V and 36V
so
Home/limit switch:
+24V  --> SWITCH COM  --> SWITCH NC --> 7I96S isolated input
 5V alarm signal:
 +5V alarm signal --> 7I96S isolated input
7I96/7i96S input common --> 24V GND and 5V GND
Note the the enable signal is a 7I96S output so can either be driven from a free step/dir output
or an isolated output
Yeah I realized what I said about ENA after I posted. Thanks for the clarification. So, should my prox sensors be NPN or PNP in this case? Crossing fingers for NPN.
  • PCW
  • PCW's Avatar
19 Dec 2025 20:27 - 19 Dec 2025 20:29
so
Home/limit switch:
 5V alarm signal:
  • kello711
  • kello711's Avatar
19 Dec 2025 19:53
I would use all 5V signals for the step motor drive interface
and possibly 24V for limit switches .
How does one go about mixing 24v limit switch inputs with the 5v ENA/ALM inputs?
  • masawee
  • masawee
19 Dec 2025 19:27
Replied by masawee on topic Linuxcnc Image for Raspberry Pi 3
what is kernel and what is compiler, how use or how install and use. what is repos and scratch. not understand code nerd super engineer language. (translator not help this)
  • masawee
  • masawee
19 Dec 2025 19:11
Installing on RPi with GPIO and software stepping
Category: Installing LinuxCNC
but were is rpi 3 and 4 linuxcnc os.
  • EdWorks
  • EdWorks's Avatar
19 Dec 2025 18:49 - 19 Dec 2025 18:58
Byte2Bot Daughter Board/ Raspberry Pi5 issue: creating a 0-10v Spindle Voltage
It appears to work fine. Any further suggestions would be appreciated.
Full HAL file attached.
  • EdWorks
  • EdWorks's Avatar
19 Dec 2025 18:48
And here is the Snippet:
# --- SPINDLE PWM CONFIGURATION ---
# Load and Add Functions
# (Ensure loadrt pwmgen and loadrt scale are at the top of your file)
addf pwmgen.make-pulses base-thread
# 3. Connect Spindle Enable
# This turns the PWM generator on only when the spindle is active and needs to be eliminated.
# (removed) net spindle-on spindle.0.on => pwmgen.0.enable
#Inverted Voltage Corrections
# First you need to add the next two lines above
# loadrt not count=1
# addf not.0 servo-thread
# set the Frequency
# first we need to set a frequency for the PWM in order for it to smooth the output
setp pwmgen.0.pwm-freq 100.0
# Calibration
# When using a 0-10v output signal, you may need to invert the PWM output
# so that the 5 axis breakout board will output 0V at spindle off,and
# 10v when the spindle is full on. The Negative sign before the 60000 usually does this.
# unfortunately the resting (spindle off) voltage is 10.0V - bad -very bad!
# rather we leave everything alone and creat a not.0 variable that reverses the values
setp pwmgen.0.scale 60000
setp pwmgen.0.offset 0.0
setp pwmgen.0.enable 1
# Connect Spindle Speed Command
# This signal carries the RPM requested by G-code (S command)
net spindle-speed-cmd spindle.0.speed-out => pwmgen.0.value
# Prepare to invert it
net spindle-pwm-raw pwmgen.0.pwm => not.0.in
# Connect and invert the PWM Output to Physical GPIO
# This is the "Writer" for GPIO18
net spindle-pwm-final not.0.out => hal_gpio.GPIO18-out
#End Spindle Code
  • EdWorks
  • EdWorks's Avatar
19 Dec 2025 18:34 - 19 Dec 2025 18:47
I wanted to create a control voltage for my spindle using a Raspberry Pi 5 connected to a Byte2Bot parallel daughter board (Misnomer Alert – it is actually a DB25 daughterboard and has little to do with a parallel port) connected to a parallel port breakout board provided by Byte2Bot.  The parallel port breakout board has a terminal for PWM that will produce a voltage. The question is how to do it. Here is what I discovered:
This issue continues in the attachments:
LinuxCNCQuestionA
LinuxCNCQuestionB
LinuxCNCQuestionC
  • PCW
  • PCW's Avatar
19 Dec 2025 18:13
Bitfile for Mesa 7i96s + 7i85 (+Modbus (PKT-Pin))
Yes, the sserial pinouts on the 7I85 and 7I96S are similar except the 7I85 uses 8 pins and the 7I96S uses 6
You can plug a 6 pin sserial connector into the 7I85 if you center it, that is with  a 1 pin gap in each side.
The 8 pin connection uses duplicated power and ground pins. On the 6 pin connector, you must terminate
2 wires in the single power and ground pins.
  • PCW
  • PCW's Avatar
19 Dec 2025 18:06
Displaying 9766 - 9780 out of 11521 results.
Time to create page: 0.313 seconds
