27 Nov 2025 20:28
Replied by tommylight on topic Mesa 7I96s - 5 AXIS
Mesa 7I96s - 5 AXIS
Category: Installing LinuxCNC
Did you by any chance edit the hal and ini files on a windows PC, or maybe using Libreoffice?
  • Ul
  • Ul
27 Nov 2025 20:05 - 27 Nov 2025 20:08
Replied by Ul on topic Chinese Mesa 7I92 from aliexpress NEW
Category: Driver Boards
Thank you for the reply, but I just flashed at least the 3.3V power regulator with 24V on the still working 7i98 instead, so it will take some time for me to do the repair. Maybe I can even program it using raspberry GPIOs then.
By that coincidence I had an EEPROM with a working firmware, which I just soldered it on the bricked card. Now it works again, but the other one doesn't.
  • PCW
  • PCW's Avatar
27 Nov 2025 19:47 - 27 Nov 2025 19:49
Replied by PCW on topic Chinese Mesa 7I92 from aliexpress NEW
On Xilinx based cards you can use any working bitfile for fallback.
It wont have the blinking INIT LED indicator but otherwise the same.
This will protect against things like a power failure during flash update
It will not protect against writing firmware that does not work but has a
valid chip type and CRC (like firmware for a different card)
If you do have working fallback and a bad primary (Good CRC but does not work),
it is possible to recover without JTAG by intentionally causing an error in the primary
flash file load (say by shorting out the flash chip SDO pin briefly at power up)
  • Ul
  • Ul
27 Nov 2025 19:23
If they did supply firmware, I would try re-writing it with:
mesaflash --device 7i92 --addr 10.10.10.10 --write  vendor_supplied_firmware_file_name.bit --reload
My Chinese 7i98 doesn't seem to have a fallback area, so I bricked one of mine by flashing a corrupted Chinese firmware. I wouldn't try again to flash it this way.
Since then I am doing it the Chinese way:
sudo mesaflash --device 7i92 --addr 192.168.1.121 --write 7i92.bit --fix --fallback
sudo mesaflash --device 7i92 --addr 192.168.1.121 --write 7i92.bit --fallback
sudo mesaflash --device 7i92 --addr 192.168.1.121 --reload --fallback
If the firmware doesn't work, it says: "No 7I98 board found" and only one LED is on.  So I know if the firmware is bad and I don't go further. After power cycling it, the previous firmware is loaded and it works again.
If it works (and only if it works), i continue with:
Then I power cycle it and check the pins:
sudo mesaflash --device 7i92 --addr 192.168.1.121 --readhmid
I've tested some original 7i92 and 7i98 bitfiles and they all work perfectly, so there is no point in using Chinese bitfiles except if the "7i92" card doesn't even look like a Mesa card and really needs a Chinese custom file. I believe, even the files supplied by the Chinese are mostly original files.
I also could flash a Chinese 7i98 fallback firmware called "7i92_fallback.bit" on a Chinese 7i92, so the 7i92 had 50 pins.
But it didn't brick, so I could flash the right firmware afterwards.
  • Dudelbert
  • Dudelbert
27 Nov 2025 18:16
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
So, I did think a bit and decided to actually go on with a change to LinuxCNC. Thanks for the replies helping me to decide in that way.
I think I will try to leave the cabling in the machine mostly untouched, but completely remake everything in the electrical cabinet.
For many of the open questions I will probably stick closely to what Rotary did, as most of the design decisions were considered by this whole forum, and the pros and cons have been carefully considered. With that, I don’t see much of a point in redoing this myself.
I will update here now and again, but only with stuff specific to my project.
With this I will definitely change the Z-axis motor and driver. I do have a Chinese AASD driver from an old project that never happened.
It’s a 1 kW motor, so definitely overkill — but it is already there, so it will work.
One other thing: in the toolholders I got with the machine there was one that does not fit the machine. See picture.
If anyone has a machine that needs this style of toolholder, or knows someone who does, I would be happy to give it away.
  • MTTI
  • MTTI's Avatar
27 Nov 2025 18:11
QtPlasmaC – Magic Comments not creating materials from G-code
Category: Plasmac
Hi
This morning I was running v2.9-238.315 and later tested with v2.10-009.072. The issue was present on both versions.
I continued testing and the problem only occurs with o=1 and o=2 magic comments.
o=0 was always working correctly and did not cause any issue.
With o=1 and o=2, the material was written to the *_material.cfg* file, but QtPlasmaC showed a parameter error and did not update the material list. A restart of QtPlasmaC was required for the new material to appear.
I found the cause inside the function rewrite_material_file() in qtplasmac_gcode.
The code checks material_reload like this:
response = RUN(['halcmd', 'getp', self.matReloadPin], capture_output=True)
if not int(response.stdout.decode()):
    break
But on my installation, this command returns:
halcmd getp qtplasmac.material_reload = TRUE
Since TRUE cannot be converted to int(), a ValueError exception is raised.
This stops the reload process, which leads to the UI not updating and to the misleading “parameter missing” message.
I applied a workaround that accepts both 0/1 and TRUE/FALSE strings:
raw = response.stdout.decode().strip().upper()
if raw in ['0', 'FALSE']:
    break
else:
    continue
After this fix:
* o=1 and o=2 now correctly create or update materials
* the UI refreshes immediately
* no more incorrect popup message
* no restart of QtPlasmaC required
* o=0 continues to work as before
I also added a local improvement: after a new material is created, it is automatically selected as the current active material.
If needed, I can provide a clean patch and test G-code examples.
I am also available to run additional tests if required.
I have attached to this post the NGC file I have been using since this morning.
The temporary example file was not working either, except when using o=0
  • PCW
  • PCW's Avatar
27 Nov 2025 17:00 - 27 Nov 2025 17:08
Replied by PCW on topic Mesa 7I96s - 5 AXIS
Mesa 7I96s - 5 AXIS
So it's a mystery, Your hal/ini files work for me.
(after changing to 10.10.10.10 IP address because that's how my test PC is setup)
Do you always get this error:
hm2_eth: ERROR: Could not retrieve hardware address (MAC) of 192.168.1.121: Resource temporarily unavailable
That happens before any joint/axis ini settings are processed and is only related to low level communications.
You can sometimes get this error after power cycling if the network link is not established yet, so could happen in testing
but is not in anyway related to the number of axis.
  • jmelson
  • jmelson
27 Nov 2025 16:36
Replied by jmelson on topic Fanuc encoders
Fanuc encoders
That is just a list of error codes produced by the Fanuc control. I have a working converter for the 4-wire, low speed (1.024 mbit/second) encoders. I am now trying to decipher the 2-wire, 2.73 mbit/sec encoders. I have been able to trick an encoder to start responding by flipping switches on a pulse generator. But, I tried to set up an FPGA to get the encoder to respond, and I get NOTHING!
So, these encoders apparently need a different command to select the mode before it will respond.
Jon
  • snowgoer540
  • snowgoer540's Avatar
27 Nov 2025 16:22
Category: Plasmac
Can you post your actual gcode file?
What version of qtplasmac are you running? It’s in the header of the window.
There is a temporary example file for
both metric and imperial in the nc_files\plasmac folder…  here:
github.com/LinuxCNC/linuxcnc/blob/master...porary_materials.ngc
  • RotarySMP
  • RotarySMP's Avatar
27 Nov 2025 16:21
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Category: Turning
Those are the thermal overheat switch, which with that wiring will cut power to the main VFD in the case that the brake module overheats. To test it, that connection is not necessary.
  • spumco
  • spumco
27 Nov 2025 15:58
Replied by spumco on topic Schaublin 125-CNC retrofit.
Category: Turning
One thing I didn't notice in the vid or the thread discussion is that there is a separate manual for the braking module.  It's referenced on page viii (Part G - 11) of the VFD manual.
The braking module manual shows a "T1" and "T2" connection on the module.. but those aren't shown in the main VFD manual.
Based on the diagram, I suspect those need mains power to 'activate' the braking module.
I'm sure there are some parameters to change as well, but this might be a possibility.  Maybe have a look?
And yes...dogshit manuals.
  • Z3n
  • Z3n
27 Nov 2025 15:42
Replied by Z3n on topic Converting a Brother TC215 to LinuxCNC
Category: Milling Machines
You can direct connect to via the AC Servos via a special cable through USB and their software: www.dmm-tech.com/resource-center
The 7I92 does connect via eithernet. I believe the reason for purchasing the dual board setup was to make sure there were enough axis controllers available for eventual expansion via rotary tables and things like that, as well as the appropriate spindle control for the mill.
  • Z3n
  • Z3n
27 Nov 2025 15:40 - 27 Nov 2025 15:44
Replied by Z3n on topic Red Init & Done Lights on 7i92M
It is a 7I92M as per the screen printing on the board and the sticker on the back.
I did check the 5v power and it appears to be getting a very solid 5v, but I will power it independently to double check in case there is some form of low voltage immediately at power on.
Appreciate the help, I'll start the RMA process with Mesa.
Edit: Oh, and I'm assuming I should be able to configure the 7I76 / 7I77D appropriately to be powered via direct 5v and look at the lights to confirm those boards function as well? The manual is a little sparse on what the different LED patterns indicate.
  • jmp97
  • jmp97
27 Nov 2025 15:39
Replied by jmp97 on topic Mesa 7I96s - 5 AXIS
Mesa 7I96s - 5 AXIS
Not, it's the same
  • PCW
  • PCW's Avatar
27 Nov 2025 15:24
Mesa 7I96s - 5 AXIS
Is the card IP address different in the 5 Axis configuration?
Displaying 10336 - 10350 out of 12721 results.
Time to create page: 0.490 seconds
