  • ihavenofish
  • ihavenofish
28 Oct 2025 03:59
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Category: CNC Machines
I found a hal and ini for a parker drive and commented out errors until it made it through and booted linuxcnc and had flashing lights on tx and rx. So we now have communication. Of course its all wrong cause its for a different VFD, but the communication is actually working.
Woo.
  • heaven
  • heaven
28 Oct 2025 03:29
Need Help in Kinamatics of Small DIY 6dof robotic arm.
Maybe you are in singularities, try another homing position
  • richcolvin
  • richcolvin's Avatar
28 Oct 2025 02:05
Replied by richcolvin on topic M19 for Indexing a Spindle using Stepper Motors
Jean Philippe,
Thank you for sharing these. I greatly appreciate your generosity.
Am I correct I. My thinking that the magic for this is in the spindle.hal file?
Rich
  • ihavenofish
  • ihavenofish
28 Oct 2025 00:27
Inching my way foreward.
Have a hal and ini for modbus now, and im getting an "out of range" error.
This happens if the drive in on or off, and im seeing no leds on the adapter. so perhaps the adapter is not enabled? Does it require a driver?
The chip on the adapter is CH340
  • boksi
  • boksi
28 Oct 2025 00:25
Mesa smart serial or PktUART or serial over RS232 or udp for robot joints
Great, in meantime I am wondering, rough estimation could it be all logic (6x uart + quadrature logic + 6 to 8 stepgens + 1 smart serial) packed to 6i25 or 7i92?
I think that I don't need C signal from encoder to count full revolutions.
Yes uart parameters are fixed.
I am seeing the next sequence, LinuxCNC will issue power up of servo drivers and encoders would be connected both to drivers and RS422 to TTL converters (encoders are RS422), so there would be 2 listeners per encoder on RS422 network (think this should not be a problem for RS422).
Drivers will issue power on for encoders and this is trigger for them to send data.
After RS422 -> TTL conversion then will be signal isolation and then fpga.
  • Lcvette
  • Lcvette's Avatar
28 Oct 2025 00:01
User Install for Probe Basic Py3 (For Machine Control)
Category: QtPyVCP
Review the config in settings section to make sure everything is there that needs to be. 30-40 seconds means something is wrong in the config most likely. Just go through line by line and read everything carefully to make sure you didn't overlook anything. Should fix your issue. When in doubt compare to the SIM config. If it works as expected then go through your machine config again and find the error or missing item.
  • ihavenofish
  • ihavenofish
27 Oct 2025 22:02
Thanks. Problem is I don't really know what to do with this.
  • Hakan
  • Hakan
27 Oct 2025 21:02
  • ihavenofish
  • ihavenofish
27 Oct 2025 20:39
can someone walk me through the setup on linuxcnc for this? i am seeing so many conflicting and incomplete instructions and components that are no longer supported or redundant (like vfdmod).
  • PCW
  • PCW's Avatar
27 Oct 2025 19:46 - 27 Oct 2025 19:49
Replied by PCW on topic USB activity causes network error
Category: Plasmac
Also what USB dongle?
I have a rtl8192cu based USB WIFI dongle on this test machine
and it seem to have no effect on latency when plugged/unplugged
Have you done the usual optimizations?
DKMS driver for RealTek Ethernet chips
Turn off IRQ coalescing on Intel Ethernet chips
in grub file isolcpus = last processor
pin Ethernet IRQ to last processor
 It means that the network message could not be compete in one cycle.
Actually it's worse than that, with default settings, it means 5 read requests in a row timed out
so usually means multi-ms latency...
  • ihavenofish
  • ihavenofish
27 Oct 2025 19:31
So, its definitely doing something different when the drive is on vs off. So that's a start. It does show exception 1 a fair bit.
[27/10/2025 15:29:13]
Modbus Response (COM5)
Address: 1
Function: 4 (0x04) - Read Input Registers
Exception Code: 1
Checksum: 0x82c0 - OK
Modbus Request (COM5)
Address: 1
Function: 1 (0x01) - Read Coils
Starting Address: 773
Quantity: 0
Checksum: 0x2c4f - OK
Address: 1
Starting Address: 779
Quantity: 0
Checksum: 0x4d8c - OK
Address: 1
Starting Address: 912
Quantity: 0
Checksum: 0x3c63 - OK
27 Oct 2025 19:23
Replied by tommylight on topic USB activity causes network error
Category: Plasmac
How is the network for Mesa card set up, using network manager or by editing the /etc/network/interfaces file?
  • PCW
  • PCW's Avatar
27 Oct 2025 19:20
Replied by PCW on topic LinuxCNC installation + 7I96S
Category: Installing LinuxCNC
isolcpus=5
would be correct for a 6 core CPU
  • ihavenofish
  • ihavenofish
27 Oct 2025 19:19
Hmmm. that's helpful thanks. its doing... something in both directions. so maybe the issue is the spindle talker 2 software.
Any advise on another way to check functions?
27 Oct 2025 19:19
Replied by tommylight on topic Festo CMMT-ST
Festo CMMT-ST
Category: EtherCAT
cia402.4.xxxxx
That is in your hal file for the X axis, it should be
cia402.0.xxxxx
if you want X to be the first joint/axis.
Same for other joints and axis, and there are multiple instances for each joint to be changed.
Displaying 11986 - 12000 out of 12802 results.
Time to create page: 1.002 seconds
