  • boksi
  • boksi
26 Oct 2025 19:47 - 26 Oct 2025 19:49
Mesa smart serial or PktUART or serial over RS232 or udp for robot joints
Thanks both on suggestions, I see, checked both links quickly.
Have a question on principal level.
I need to have in fpga both uart component and quadrature enc component.
In order to work enc reading, first enc input pins should be connected to fpga input uart pins and then via some logic/demux this pins needs to be routed to quadrature logic in order to get inc pulses and also there is need to issue select signals on this demux after uart transfer sequence is finished.
Or other way, enc pins are connected to both uart and quadrature module components inside fpga but enable signals of both components are separately controlled via some conditions/logic.
Is this working this way or?
  • scotta
  • scotta's Avatar
26 Oct 2025 19:39
Remora SPI: Bad SPI payload, estop won’t reset, SKR 1.4 + RPi4 – config below
The SKR1.4 and LPC1768 are legacy and not supported in the latest version of the Remora component. You could try to use an older version of the component that supports the LPC1768.
  • Aciera
  • Aciera's Avatar
26 Oct 2025 19:19
Replied by Aciera on topic Manual tool change + tool lengh touch off
Tool offset is set here:
  G43.1 Z[#<_ToolZ> - #<_ToolZRef>]            ( Apply offset to Z height after Modal reset )
If this is run at every tool change then there may be no need to write the offset to the tool table.
26 Oct 2025 19:10
Replied by tommylight on topic LinuxCNC installation + 7I96S
Category: Installing LinuxCNC
Does LinuxCNC complain about latency issues when running?
What does
ip a
in a terminal return?
Upload here the hal and ini files so we can have a look.
  • jmp97
  • jmp97
26 Oct 2025 18:43
Replied by jmp97 on topic LinuxCNC installation + 7I96S
I have a problem that I can't solve.
I replaced the Ethernet network card with an Intel one. At first everything seemed to be working fine, but then I started getting “joint tracking error” problems. LinuxCNC simply stops the machine.
I increased SERVO_PERIOD in the INI from 1000000 to 4000000 (I can't increase it any further, LinuxCNC won't let me exit emergency mode).
When I move the axes quickly with the arrow keys, it seems to respond better, but it still stops.
What could be the problem? The PC is new with an Intel I5. Only LinuxCNC is in use, nothing else is running. Everything is disabled in the BIOS.
It's causing me serious mental problems
  • andypugh
  • andypugh's Avatar
26 Oct 2025 18:41
Replied by andypugh on topic Subroutine error
Subroutine error
G53 G0 Z0
Is Z=0 in machine coordinates inside the axis limits? If your soft-limit is at zero then possibly going to exactly zero triggers the error (I have a vague memory that this was a fixed bug, though).
You could try setting max Z (or joint 2) to 0.01  (or whatever) then see if G53 Z0 still gives a fault.
  • andypugh
  • andypugh's Avatar
26 Oct 2025 18:32
5-axis Isel-based machine - Logosol to LinuxCNC?
Category: CNC Machines
My thought is to write HAL components to interface LinuxCNC pins to Logosol's LDCN protocol. The servo drives run a 51.2 microsecond update rate, so 20 servo ticks is 1.024 ms.
What bit rate is that at? 115200 bps is quite quick for RS485 (though the internet suggests that 42Mb/s is possible).
At 115200bps 51µs per packet only has space for 6 bits of data, so it either must be running unusually high bit rates or not updating as fast as suggested.
  • thanks for the help
26 Oct 2025 18:26
Replied by thanks for the help on topic Manual tool change + tool lengh touch off
Thank you,
That would make sense, the G10 would populate the tool table and the G43 would assign the tool length offset.  I guess the mystery is where to add it to this ngc file?  And how did others have success with this code without those commands?   As you can tell I am really new to all this.  Attached is the sub routine I have been trying if you feel like looking at it.
File Name: tool-chang...test.txt
File Size:11 KB
  • andypugh
  • andypugh's Avatar
26 Oct 2025 18:12
Replied by andypugh on topic Manual tool change + tool lengh touch off
You may need one of the G10 variants in your macro.
linuxcnc.org/docs/stable/html/gcode/g-code.html#gcode:g10-l0
Or possibly just a G43
  • lorenzing
  • lorenzing
26 Oct 2025 18:04
Replied by lorenzing on topic Festo CMMT-ST
Festo CMMT-ST
Category: EtherCAT
Hi andypugh, jc2ktr shared his working setup, but here is mine:
[KINS]
JOINTS = 5
KINEMATICS = trivkins coordinates=XYYZZ kinstype=BOTH
26 Oct 2025 17:47
Thank you for the response,
I am using Axis gui with version 2.9.4.  I was using this format (debug,#<5081>) which yielded ######.  Upon your suggestion I tried this format (debug, 5181) which yielded the number in the var file....a big thank you for that clarification!!!!
I think my main problem is that my tool table is not updated based on my 5063 variable.  When the probe trips the switch, I see the var file up updated, it stores tripped the z value in the 5063 variable, but that number is not populated in the tool table.  As a side note, I did have to add the 5063 variable manually to the var file.
Again, thank you for you time
  • Aciera
  • Aciera's Avatar
26 Oct 2025 17:42 - 26 Oct 2025 17:44
Replied by Aciera on topic VTK based version of Vismach
Category: Show Your Stuff
It's pretty much the same. It's actually fairly straight forward once you get the hang of it but I guess that's true for everything and I must have made a couple dozen sim models by now.
ProbeBasic has machine simulation that can be setup using a yaml file (similar to what some CAM systems have) but it is quite limited compared to vismach.
  • andypugh
  • andypugh's Avatar
26 Oct 2025 17:40
Replied by andypugh on topic Festo CMMT-ST
Festo CMMT-ST
Category: EtherCAT
Your kinematics setup seems to be wrong:
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
Should be 5 joints and probably XYYZZ
  • andypugh
  • andypugh's Avatar
26 Oct 2025 17:33
Proposal RPi Linuxcnc Image Based on Raspi OS All welcome/encoraged to comment
Just a reminder (it's way down the list of repos now) but we did previously use pi-gen to make LinuxCNC images.
github.com/LinuxCNC/pi-gen
Bitrot has probably set in, though.
  • andypugh
  • andypugh's Avatar
26 Oct 2025 17:22
how to get rid of the probed dumping non-probe mode error?
There is a motive. My 2.8.4 has a jitter in the range of 2000. It also uses the compiled module "curve geometry" (compensation of the position of the X coordinate depending on the position of the Y coordinate). There is no such module for 2.9.
I don't think that "curve geometery" was ever a built-in LinuxCNC component. Did you install it from a comp file?
If you have the .comp file then it will also work with 2.9.x once installed, but if you don't have the source file then you may be a bit stuck.
If you have 2000ns jitter then you may be using the RTAI kernel? It is possible to run LinuxCNC 2.9.x with RTAI, but it's been a while since I created an installer package. (they have to be built by hand, as the buildbot currently has no RTAI builders, and it needs modifications to the Makefile)
Having said that, I have a PC that gives 3-digit latency with both RTAI and Preempt-RT. it appears to be entirely random.
Displaying 12061 - 12075 out of 12802 results.
Time to create page: 3.216 seconds
