  • Clements
  • Clements
25 Oct 2025 06:13
Replied by Clements on topic gmoccapy probe
gmoccapy probe
Category: Basic Configuration
I had a pretty hard time finding a pc with a parallel port. I don’t use a mesa card
The new pc is a dell optiplex 980 That is a very compact unit. The old HDD doesn’t seem to fit in the housing.
I use pcloud for gcode synchronization and I just couldn’t open the site on 2.8. So I decided to install te latest version of LinuxCNC
  • boksi
  • boksi
25 Oct 2025 05:30
Mesa smart serial or PktUART or serial over RS232 or udp for robot joints
Yes that is right.
Interesting that you mentioned stmbl, I remember they were integrated with some robot (video of manutec carrying a coin).
Do they send its position over smart serial ?
I suppose when position is requested drives can’t replay all at same time because of other priorities, but stll they have to provide position.
I have custom drives build and they are reading encoders and do control but I am looking next part integrating with kinematics module.
  • thefabricator03
  • thefabricator03's Avatar
25 Oct 2025 04:48 - 25 Oct 2025 04:49
PlasmaC Fatal Error Message was created by thefabricator03
Category: Plasmac
Hi Guys,
A plasma machine I built that runs the original PlasmaC is having a fatal error message that is stopping the machine from operating.
The guys who run the machine tell me the machine ran fine last Friday and when they came to use it on Monday morning they got this error message not matter what gcode program they tried to run.
This same issue happened back in March, and the only way I could fix the issue was to reformat the machine to a default state. Since it is re-occuring, there must be something going on to cause the issue.
Ive attached the gcode file to this post.
  • bentiggin
  • bentiggin
25 Oct 2025 02:29
Replied by bentiggin on topic Hypertherm hsd130 interface
Category: Plasma & Laser
I finally got around to getting everything wired up enough to test.
At first, I couldn't get it to start using a relay and a power supply on a switch. I realized the manual says "or dry contact closer", so I wired the relay directly to start- pin 15 and start+ pin 34, which worked.
Now I can't get my arc ok signal. I followed the example wiring in the manual. I connected ark ok+ pin 23 to the relay. Then 24vdc+ pin 37 to the relay. Then ark ok- pin 4 to power ground pin 36.
Wired up like this, the arc will not start and the plasma cutter gives an error. If I disconnect the ground to ark ok- pin 4, the plasma will start without errors. I am getting 24 volts between power and ground, and the 2 ark ok pins will close the circuit when the arc starts.
I am attaching the examples from the manual plus diagram of how I wired the arc ok relay.
I may have wired it up like example 4(which it says don't use) a long time ago before I decided to remove the old interface connection on it, so maybe that messed it up.
Does my ark ok wiring seem right? Should I try wiring it differently or should I consider using a reed relay instead?
  • ihavenofish
  • ihavenofish
25 Oct 2025 02:16
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Category: CNC Machines
Poke. Figured I should stick this here.
Machine is back together with some new upgraded, ethercat is working for the xyz.
Now I'm on to making the spindle work with modbus.
Is there a simple step by step instruction to set this up? I got a usb adapter, and I'm running qtdragon. In addition to just tuning on and off, id like it to display the true spindle speed and the load.
  • Cooped-Up
  • Cooped-Up
25 Oct 2025 00:54
Replied by Cooped-Up on topic Maho MH800e Retrofit Project
Category: Milling Machines
I thought so but obviously something is wrong. I did post my ini file a post or so ago. I was trying to change the direction the axis moves after the index is seen. Nothing I change seems to do anything
  • PCW
  • PCW's Avatar
25 Oct 2025 00:30
Replied by PCW on topic Maho MH800e Retrofit Project
Do you ini file settings match the requirements for index only homing?
linuxcnc.org/docs/html/config/ini-homing.html#_configuration
  • andypugh
  • andypugh's Avatar
24 Oct 2025 22:49
The STMBL drives can work with Yaskawa encoders.
(But supply is an issue)
forum.linuxcnc.org/27-driver-boards/5375...tmbl?start=30#311767
I see that you already know about their existence, but it might be worth considering using them.
  • boksi
  • boksi
24 Oct 2025 22:32
as I see from list there is no support for this type of encoder.
It's yaskawa absolute 12bit encoders. After power up some mS and it sends its absolute position over UART, after that if it moves it starts to send only quadrature pulses A/B like normal incremental encoder.
  • mark-v-d
  • mark-v-d
24 Oct 2025 22:28
POSITION_FILE and index was created by mark-v-d
I would like to use the POSITION_FILE in combination with the index pulse
of the encoder to home my lathe. The idea is that you know approximately
where you are when starting up, and once you pass the first index pulse
you know the exact position. Has anyone done this... and if so can you
explain how?
  • SPH
  • SPH's Avatar
24 Oct 2025 22:22 - 24 Oct 2025 22:34
Help with Delta E3 Ethercat drives - hal and ethercat-conf.xml
Category: EtherCAT
That sorted it. Just #'d out the two PYVCP lines. Looking back over the build thread it was using probe basic so that's probably the issue.
I now have axis running with one encoder that's reading! Fantastic. Don't have any motor control though. I can move the motor shaft and get count and motion on the simulator display but with the machine enabled I can't jog. The sim shows movement but no shaft rotation.
I'm also getting a Linuxcnc notification "LCEC: Invalid appTimePeriod of 0 for master 0 (should be 1000000)."
A quick search on the forum suggests that relates to:
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
HOMEMOD=always_homed
in the ini file but it's set to 1000000 already.
  • Cooped-Up
  • Cooped-Up
24 Oct 2025 21:57
watching the "DRO" the z axis zeros then moves, hits the index, zeros, and then hits the estop. I have the offset set to 0 so it should just stop correct?
  • Cooped-Up
  • Cooped-Up
24 Oct 2025 21:51
in testing the "Z" axis right now I have it passing the index point, it turns off the enable signal, seems to hesitate for a split second before continuing to the estop hard limit
  • PCW
  • PCW's Avatar
24 Oct 2025 21:47
Is index-enable connected to both motion and the driver?
If the encoder index  (something like hm2_cardname.0.encoder.00.index-enable)
has been set but is not ever cleared when the index location has been passed,
that suggests a hardware issue with the index signal itself.
  • Unlogic
  • Unlogic
24 Oct 2025 21:14
Replied by Unlogic on topic Probe Basic backplot error when loading file
Category: QtPyVCP
After an impressively quick iterative process Lcvette and TurBoss managed to fix all the errors I encountered in this thread.
I'm sure they'll announce an updated development version shortly including these fixes.
Displaying 12166 - 12180 out of 12802 results.
Time to create page: 0.828 seconds
