- tnl1
- tnl1
12 Sep 2025 22:01
Replied by tnl1 on topic AMSAMOTION IO module
Category: EtherCAT
Start with the configuration with the lpt port, then make changes to the *.hal file linuxcnc, if there is no physical lpt, then just comment out the lines using it... Attached is xml for 1631 and aq0810 from amsamotion
- scotta
12 Sep 2025 21:57 - 12 Sep 2025 21:57
Replied by scotta on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
I've tried to run your config. Firstly corrected
BASE_PERIOD = 1000000
SERVO_PERIOD = 5000000
to
BASE_PERIOD = 0
SERVO_PERIOD = 1000000
You config also seems to be setup for imperial yet using mm?
I can jog with that above correction without following errors.
For your DRV8825 have you added the micro stepping jumpers? The DRV8825 wont enable without this, which I tried on my SKR3EZ. I unfortunately killed my normal SKR3 so cannot test with that board.
to
BASE_PERIOD = 0
12 Sep 2025 20:26
Replied by PCW on topic Probing routines changing mode from G90 to G91
Category: QtPyVCP
This may sound dumb as I am no gcode expert, but is there a way to "push" the current gcode settings
and restore them later?
12 Sep 2025 19:46
Replied by Aciera on topic Re:ini. changes while EMC2 running?
ini values can be changed using the 'ini.*' hal pins. Changes can be made while a program is running but will only become active after a queue buster command (eg M66 E0 L0) which will restart the motion planner with the updated ini values.
- scsmith1451
12 Sep 2025 19:21
Save Post Reference to User List was created by scsmith1451
Category: Forum Questions
I have found that I often stumble across interesting topics while searching for info on the forum site that I would like to go back to at a future date. It would be awesome if posts could be tagged and saved to a user's account list for easy retrieval in the future. The list should be editable to remove old links that are no longer needed.
Kind Regard,
Kind Regard,
- Unlogic
- Unlogic
12 Sep 2025 19:04 - 12 Sep 2025 19:11
Replied by Unlogic on topic Probing routines changing mode from G90 to G91
Category: QtPyVCP
Big thanks Chris, that was a really quick fix from you!
Fixing the bug in the normal uses cases is what's most important as probing errors are not that common once you get used to the various probing functions.
The abort handling seems tricky to solve indeed. I went through the documentation in search for a solution. I was looking for a hook to detect when a program has been halted but I came up with nothing.
Maybe some of the more experienced LinuxCNC gurus here on the forum has some input on how this could be solved.
- grijalvap
12 Sep 2025 18:59
Replied by grijalvap on topic Re:ini. changes while EMC2 running?
Any update?
- ccc774
- ccc774
12 Sep 2025 17:30 - 14 Sep 2025 09:28
Replied by ccc774 on topic Can the OPI5 be Configured to Run LCNC?
thanks Royka for the kernel.
I rebuilt the system today with Armbian Trixie and rt-kernel 6.1.115. I couldn't get the 3D accelerator to work. I think something was not set when the kernel was created.
OpenGL vendor string: Mesa
OpenGL renderer string: llvmpipe (LLVM 19.1.7, 128 bits)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 25.0.7-2
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 4.5 (Compatibility Profile) Mesa 25.0.7-2
OpenGL shading language version string: 4.50
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 25.0.7-2
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
Linuxcnc 2.10 won't start.
~$ linuxcnc
LINUXCNC - 2.10.0~pre0
Machine configuration file is 'gmoccapy.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./core_sim.hal
rtapi_task_start(): Operation not permitted
HAL_LIB: could not start task for thread base-thread: -1
MOTION: failed to create 100000 nsec base thread
MOTION: init_threads() failed
motmod: rtapi_app_main: Operation not permitted (-1)
./core_sim.hal:7: waitpid failed /usr/bin/rtapi_app motmod
./core_sim.hal:7: /usr/bin/rtapi_app exited without becoming ready
./core_sim.hal:7: insmod for motmod failed, returned -1
USRMOT: ERROR: command 30 timeout (seq: 1)
emcMotionInit: emcTrajInit failed
USRMOT: ERROR: command 3 timeout (seq: 2)
LinuxCNC terminated with an error.
What do you think?
~$ linuxcnc
What do you think?
- scsmith1451
12 Sep 2025 16:21
AXIS Jog Rate display not updating after calling set_jograte() functions was created by scsmith1451
Category: GladeVCP
In my gladevcp panel I have configured two buttons to set the jog rate. One to set to the lowest value that I use for positioning my crosshair laser, the other to set to the max value that I use. I have tried both ACTION.SET_JOG_RATE(rate) and GSTAT.set_jog_rate(rate), but neither affect the jog rate display in AXIS. The documentation for GSTAT.set_jog_rate(rate) mentions that after setting the jog rate, the jograte-changed signal is emitted which I would expect to update the AXIS display but there is no feedback indicating that the rate has changed. Is this a known issue or am I doing something wrong?
FYI - I also have a combo box to select the current system offset system which does change the AXIS display after a new offset is selected, so I would expect these two functions to work the same.
Kind Regards,
Kind Regards,
12 Sep 2025 15:30
Replied by Aciera on topic Recompiling the motmod modules to expose pos-cmd pins
glad you got it working. If you feel like sharing you could go to your cloned folder and post the output of:
Might help somebody in the future.
git diff --minimal HEADMight help somebody in the future.
- hitchhiker
- hitchhiker
12 Sep 2025 15:25
Replied by hitchhiker on topic ECMO VMC100 Retrofit with Carousel/Toolchanger
Category: Milling Machines
Hi! And.. success!!!!!!
I found some issues in my ngc!
Later i make a video and upload! Then i show how to get a working toolchanger with the carousel.comp!
I made 3 failures...
Debounce-Modul wrong CAP!
Timing placing in the ngc
Order of handle stuff in the ngc
I collect later everything and show it.
Thanks to andypugh to show the right way.
Its not so fast like original Emco but its everytime done a correct Toolchange!
- Lcvette
12 Sep 2025 14:06
Replied by Lcvette on topic Carousel don t stop when estop is pushed
Category: QtPyVCP
As PCW mentioned those I/O should have some conditional motion safeties in hal, also anything critical that needs to stop immediately should also be wired to a power disconnect contactor to ensure absolute motion halting in the event of a estop. for mine my mushroom button halts both linuxcnc and all drives and motors. for the screen estop its just halting in software. this way i only press the danger mushroom if it is imperative everything must cease STAT!
- Lcvette
12 Sep 2025 13:59
Replied by Lcvette on topic Probing routines changing mode from G90 to G91
Category: QtPyVCP
You are right, i never ran into it because i almost always am running in auto mode but i found a handful of subroutines that fail to revert to G90 at the end of completion. i have corrected them and they will be up on on the next push for the development branch. for the stable branch you will need to manually copy over the edited files or make the same adjustments in your local subroutines if you have edited them. the list of affected subroutines are below:
probe_cal_round_pocket
probe_cal_square_pocket
probe_round_pocket
probe_valley_x
probe_valley_y
if you want to manually add in the return to G90 immediately you would add it after the end of the last move that is NOT in a confitional "if" statement o110 for example:
Regarding when a routine fails to complete from an motion internal abort scenario, that is an unfortunate situation where the G91 was active at the time of the routine abort failure typically in a G38.x move. I am not sure the best way to do anything about that so I am open to ideas, this abort comes from linuxcnc so i don't think i can add additional code to follow in the subroutine that would be executed. i could be wrong, but i'm simply unsure how i would do it, so if you know post up please and we can incorporate that safety!
Thanks,
Chris
probe_round_pocket
probe_valley_x
probe_valley_y
(Probe Completion Move to Z Clearance Plane, and X Zero)
G90
F[#<probe_traverse_fr>]
G38.3 Y[#<y_center_probed>]
G91
G38.3 Z[#<z_probe_stack>]
G90 <--------------------------------------------------- Add G90 here!
(probe mode rules for WCO or probe position measuring only)
o110 if [#<probe_mode> EQ 0]
(Record X Zero in selected WCO)
G10 L2 P#5220 Y[#<y_center_probed> + #<workspace_y>]
o110 endif
(Reinstate Feedrate Override)
M50 P1
o<probe_valley_y> endsub
M2 (end program)Regarding when a routine fails to complete from an motion internal abort scenario, that is an unfortunate situation where the G91 was active at the time of the routine abort failure typically in a G38.x move. I am not sure the best way to do anything about that so I am open to ideas, this abort comes from linuxcnc so i don't think i can add additional code to follow in the subroutine that would be executed. i could be wrong, but i'm simply unsure how i would do it, so if you know post up please and we can incorporate that safety!
Thanks,
Chris
12 Sep 2025 13:44
Replied by tommylight on topic EL7342 Current Capacity
Category: EtherCAT
Normally you can safely use a higher rated motor on a lower rated drive, it just wont have the full torque/speed.
Except some really cheap China drives, all drives have current limiting, so they will output whatever that maximum is, and usually that can be set with DIP switches or software.
The problem arises when drive can provide more current than the motor attached can withstand, so limiting current is a must.
And just in case:
Voltage = speed = RPM
Current = torque
-you can drive a higher current rated motor with a lower current rated drive, it will limit torque
-you can NOT drive a lower current rated motor with a higher current rated drive without LIMITING current
-you can drive a higher voltage rated motor with a lower voltage rated drive, it will limit speed and sometimes torque
-you can NOT drive a lower voltage rated motor with a higher voltage rated drive without LIMITING output voltage and current, and even then some motors will overheat due to the PWM nature of the drive and spikes in output current/voltage.
And just in case:
Current = torque
- farmer_mike
- farmer_mike
12 Sep 2025 13:35 - 13 Sep 2025 01:36
Replied by farmer_mike on topic Getting (hopefully) close to an Rtelligent build
Category: EtherCAT
I have made some big progress lately. I have the limit switches and homing switches working. I also have the E stop working.
My issue is the RS750E AC servos shake quite a bit. Without the drive belts installed, the servos will sit and shake after completing a move. With the drive belts on, the system moves in the correct direction, but does so in a shaky manner.
My hypothesis is too much integral gain. I believe the problem is because I started with the stepper motor examples. Maybe there are some PID gains inside the drive that I need to configure.
I think what I need are the drive gains set with the SDO parameters inside the XML file.
Thanks for all the help
[/code]
[/code]
[/code]
# CIA 402 example snippet Hal
# Setup
loadrt [KINS]KINEMATICS
loadusr -W lcec_conf ethercat-conf.xml
#loadusr -W /home/cnc/linuxcnc/configs/linuxcnc-cia402-single/python_control.py
loadrt lcec
loadrt cia402 count=3
loadrt pid names=0-pid,1-pid,2-pid
loadrt bitslice count=6 personality=32,32,32,32,32,32
addf bitslice.0 servo-thread
addf bitslice.1 servo-thread
addf bitslice.2 servo-thread
addf bitslice.3 servo-thread
addf bitslice.4 servo-thread
addf bitslice.5 servo-thread
loadrt conv_s32_u32 count=6
addf conv-s32-u32.0 servo-thread
addf conv-s32-u32.1 servo-thread
addf conv-s32-u32.2 servo-thread
addf conv-s32-u32.3 servo-thread
addf conv-s32-u32.4 servo-thread
addf conv-s32-u32.5 servo-thread
# Functions servo-thread
addf lcec.read-all servo-thread
addf cia402.0.read-all servo-thread
addf cia402.1.read-all servo-thread
addf cia402.2.read-all servo-thread
addf 0-pid.do-pid-calcs servo-thread
addf 1-pid.do-pid-calcs servo-thread
addf 2-pid.do-pid-calcs servo-thread
addf cia402.0.write-all servo-thread
addf cia402.1.write-all servo-thread
addf cia402.2.write-all servo-thread
addf lcec.write-all servo-thread
#nets
net emc-enable => iocontrol.0.emc-enable-in
sets emc-enable 1
#config
# Joint 0
setp cia402.0.csp-mode 1
setp cia402.0.pos-scale 786432
#from servo(ethercat) to cia402
net 0-statusword lcec.0.0.cia-statusword => cia402.0.statusword
net 0-opmode-display lcec.0.0.opmode-display => cia402.0.opmode-display
net 0-drv-act-pos lcec.0.0.actual-position => cia402.0.drv-actual-position
net 0-drv-act-velo lcec.0.0.actual-velocity => cia402.0.drv-actual-velocity
#from motion to cia
net 0-enable <= joint.0.amp-enable-out => cia402.0.enable
net 0-amp-fault => joint.0.amp-fault-in <= cia402.0.drv-fault
net 0-pos-cmd <= joint.0.motor-pos-cmd => cia402.0.pos-cmd
net 0-pos-fb => joint.0.motor-pos-fb <= cia402.0.pos-fb
#from cia402 to servo(ethercat)
net 0-controlword cia402.0.controlword => lcec.0.0.cia-controlword
net 0-modes-of-operation cia402.0.opmode => lcec.0.0.opmode
net 0-drv-target-pos cia402.0.drv-target-position => lcec.0.0.target-position
net 0-drv-target-velo cia402.0.drv-target-velocity => lcec.0.0.target-velocity
net my-out-0 conv-s32-u32.0.in <= lcec.0.0.digitalinputs
net my-in-0 conv-s32-u32.0.out => bitslice.0.in
net my-bit-0 bitslice.0.out-00 joint.0.neg-lim-sw-in
net my-out-0 conv-s32-u32.1.in <= lcec.0.0.digitalinputs
net my-in-1 conv-s32-u32.1.out => bitslice.1.in
net my-bit-1 bitslice.1.out-01 joint.0.pos-lim-sw-in
net my-out-0 conv-s32-u32.2.in <= lcec.0.0.digitalinputs
net my-in-2 conv-s32-u32.2.out => bitslice.2.in
net my-bit-2 bitslice.2.out-02 joint.0.home-sw-in
# Joint 1
setp cia402.1.csp-mode 1
setp cia402.1.pos-scale -786432
net 1-statusword lcec.0.1.cia-statusword => cia402.1.statusword
net 1-opmode-display lcec.0.1.opmode-display => cia402.1.opmode-display
net 1-drv-act-pos lcec.0.1.actual-position => cia402.1.drv-actual-position
net 1-drv-act-velo lcec.0.1.actual-velocity => cia402.1.drv-actual-velocity
net 1-controlword cia402.1.controlword => lcec.0.1.cia-controlword
net 1-modes-of-operation cia402.1.opmode => lcec.0.1.opmode
net 1-drv-target-pos cia402.1.drv-target-position => lcec.0.1.target-position
net 1-drv-target-velo cia402.1.drv-target-velocity => lcec.0.1.target-velocity
#from motion to cia
net 1-enable <= joint.1.amp-enable-out => cia402.1.enable
net 1-amp-fault => joint.1.amp-fault-in <= cia402.1.drv-fault
net 1-pos-cmd <= joint.1.motor-pos-cmd => cia402.1.pos-cmd
net 1-pos-fb => joint.1.motor-pos-fb <= cia402.1.pos-fb
net my-out-1 conv-s32-u32.3.in <= lcec.0.1.digitalinputs
net my-in-3 conv-s32-u32.3.out => bitslice.3.in
net my-bit-3 bitslice.3.out-00 joint.1.pos-lim-sw-in
net my-out-1 conv-s32-u32.4.in <= lcec.0.1.digitalinputs
net my-in-4 conv-s32-u32.4.out => bitslice.4.in
net my-bit-4 bitslice.4.out-01 joint.1.neg-lim-sw-in
net my-out-1 conv-s32-u32.5.in <= lcec.0.1.digitalinputs
net my-in-5 conv-s32-u32.5.out => bitslice.5.in
net my-bit-5 bitslice.5.out-02 joint.1.home-sw-in
# Joint 2
setp cia402.2.csp-mode 1
setp cia402.2.pos-scale 96000
net 2-statusword lcec.0.2.cia-statusword => cia402.2.statusword
net 2-opmode-display lcec.0.2.opmode-display => cia402.2.opmode-display
net 2-drv-act-pos lcec.0.2.actual-position => cia402.2.drv-actual-position
net 2-drv-act-velo lcec.0.2.actual-velocity => cia402.2.drv-actual-velocity
net 2-controlword cia402.2.controlword => lcec.0.2.cia-controlword
net 2-modes-of-operation cia402.2.opmode => lcec.0.2.opmode
net 2-drv-target-pos cia402.2.drv-target-position => lcec.0.2.target-position
net 2-drv-target-velo cia402.2.drv-target-velocity => lcec.0.2.target-velocity
#from motion to cia
net 2-enable <= joint.2.amp-enable-out => cia402.2.enable
net 2-amp-fault => joint.2.amp-fault-in <= cia402.2.drv-fault
net 2-pos-cmd <= joint.2.motor-pos-cmd => cia402.2.pos-cmd
net 2-pos-fb => joint.2.motor-pos-fb <= cia402.2.pos-fb
net 2-CCW-limit lcec.0.2.in-3 => joint.2.neg-lim-sw-in
net 2-CW-limit lcec.0.2.in-4 => joint.2.pos-lim-sw-in
net 2-in-home lcec.0.2.in-5 => joint.2.home-sw-in
net 2-in-6 lcec.0.2.in-6 => halui.estop.activate
#net spindle_speed spindle.0.speed-out => python_control.rpm_in
[code]# This config file was created 2020-08-14 17:19:37.621705 by the update_ini script
# The original config files may be found in the /home/demo/linuxcnc/configs/et-3ax/et_3ax_CIA402.old directory
[EMC]
# The version string for this INI file.
VERSION = 1.1
MACHINE = EtherCAT Machine
DEBUG = 1
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
#PYVCP = pyvcp_panel.xml
# places the pyvcp panel at the bottom of the Axis window
PYVCP_POSITION = RIGHT
# Cycle time, in seconds, that display will sleep between polls
CYCLE_TIME = 0.100
# Path to help file
HELP_FILE = doc/help.txt
# Initial display setting for position, RELATIVE or MACHINE
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1
# Prefix to be used
PROGRAM_PREFIX = /home/demo/linuxcnc/nc_files
INTRO_TIME = 0
INCREMENTS = 1in .5in .25in .125in .0625in .025in .05in
#INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
nc = /usr/bin/axis
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 0
[TASK]
TASK = milltask
CYCLE_TIME = 0.005
[HAL]
HALFILE = cia402.hal
#SHUTDOWN = shutdown.hal
HALUI = halui
[HALUI]
[TRAJ]
HOME = 16 12 7
COORDINATES = XYZ
LINEAR_UNITS = in
ANGULAR_UNITS = deg
DEFAULT_LINEAR_VELOCITY = .25
MAX_LINEAR_VELOCITY = .5
MIN_LINEAR_VELOCITY = .01
DEFAULT_ANGULAR_VELOCITY = 360
MAX_ANGULAR_VELOCITY = 720
POSITION_FILE = position.txt
[EMCIO]
# Name of IO controller program, e.g., iov2 has tool changer stuff
EMCIO = iov2
CYCLE_TIME = 0.100
# tool table file
TOOL_TABLE = cia402.tbl
TOOL_CHANGE_POSITION = 0 0 50.8
#RANDOM_TOOLCHANGER = 1
[KINS]
JOINTS = 3
KINEMATICS = trivkins kinstype=both coordinates=xyz
[AXIS_X]
MIN_LIMIT = 0.1
MAX_LIMIT = 17.9
MAX_VELOCITY = .5
MAX_ACCELERATION = 10
BACKLASH = 0.0000
[JOINT_0]
TYPE = LINEAR
MAX_VELOCITY = .5
DEADBAND = 0.01
P=1
I=0
D=0
# is this applicable for ethercat????
#STEPGEN_MAXVEL = 1.25
#STEPGEN_MAXACCEL = 1.25
SCALE = 1
FERROR = 200
MIN_FERROR = 50
MIN_LIMIT = 0
MAX_LIMIT = 18
HOME = 16
HOME_OFFSET = 16
HOME_SEQUENCE = 0
HOME_SEARCH_VEL = -.125
HOME_LATCH_VEL = -.125
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = NO
[AXIS_Y]
MIN_LIMIT = 0.1
MAX_LIMIT = 12.9
MAX_VELOCITY = .5
BACKLASH = 0.0000
[JOINT_1]
TYPE = LINEAR
MAX_VELOCITY = .5
DEADBAND = 0.01
P=1
I=0
D=0
STEP_SCALE = 1
FERROR = 2
MIN_FERROR = 20
MIN_LIMIT = 0
MAX_LIMIT = 13
HOME = 12
HOME_OFFSET = 12
HOME_SEQUENCE = 1
HOME_SEARCH_VEL = .125
HOME_LATCH_VEL = .125
HOME_USE_INDEX = NO
[JOINT_2]
TYPE = LINEAR
MAX_VELOCITY = .5
STEP_SCALE = 1
FERROR = 200
MIN_FERROR = 20
MIN_LIMIT = 3.4
MAX_LIMIT = 8.1
HOME = 7
HOME_OFFSET = 7
HOME_SEQUENCE = 2
HOME_USE_INDEX = NO
[AXIS_Z]
MIN_LIMIT = 3.5
MAX_LIMIT = 8
MAX_VELOCITY = .5
BACKLASH = 0.0000[/code]
[code][code]<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
<slave idx="0" type="generic" vid="00000A88" pid="0a880013" configPdos="true">
<!-- Joint 0 -->
<syncManager idx="0" dir="out"> </syncManager>
<syncManager idx="1" dir="out"> </syncManager>
<syncManager idx="2" dir="out">
<pdo idx="1600">
<pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="cia-controlword" halType="u32"/>
<pdoEntry idx="607a" subIdx="00" bitLen="32" halPin="target-position" halType="s32"/>
<pdoEntry idx="60b8" subIdx="00" bitLen="16" halPin="touchprobefunction0" halType="bit"/>
</pdo>
<pdo idx="1601">
<pdoEntry idx="6081" subIdx="00" bitLen="32" halPin="profile-velocity" halType="u32"/>
<pdoEntry idx="6083" subIdx="00" bitLen="32" halPin="target-accel" halType="u32"/>
<pdoEntry idx="6084" subIdx="00" bitLen="32" halPin="target-decel" halType="u32"/>
<pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="opmode" halType="s32"/>
</pdo>
<pdo idx="1602">
<pdoEntry idx="60ff" subIdx="00" bitLen="32" halPin="target-velocity" halType="s32"/>
</pdo>
</syncManager>
<syncManager idx="3" dir="in">
<pdo idx="1a00">
<pdoEntry idx="603f" subIdx="00" bitLen="16" halPin="errorcode" halType="bit"/>
<pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="cia-statusword" halType="u32"/>
<pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="opmode-display" halType="s32"/>
<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="actual-position" halType="s32"/>
<pdoEntry idx="60b9" subIdx="00" bitLen="16" halPin="touchprobestat" halType="bit"/>
<pdoEntry idx="60ba" subIdx="00" bitLen="32" halPin="touchprobe1pos" halType="s32"/>
<pdoEntry idx="60fd" subIdx="00" bitLen="32" halPin="digitalinputs" halType="s32"/>
</pdo>
<pdo idx="1a01">
<pdoEntry idx="606c" subIdx="00" bitLen="32" halPin="actual-velocity" halType="s32"/>
</pdo>
</syncManager>
<dcConf assignActivate="300" sync0Cycle="1000000"/>
</slave>
<slave idx="1" type="generic" vid="00000A88" pid="0a880013" configPdos="true">
<!-- Joint 1 -->
<pdo idx="1600">
</pdo>
<pdo idx="1601">
</pdo>
<pdo idx="1602">
</pdo>
</syncManager>
<pdo idx="1a00">
</pdo>
<pdo idx="1a01">
</pdo>
</syncManager>
</slave>
<!-- Joint 2 -->
<slave idx="2" type="generic" vid="00000a88" pid="0a880002" configPdos="true">
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
<sdoConfig idx="2000" subIdx="0"><sdoDataRaw data ="88 13"/></sdoConfig> <!-- Max motor current (5.0) -->
<sdoConfig idx="2007" subIdx="3"><sdoDataRaw data ="01"/></sdoConfig> <!-- Input 3 - CCW Limit -->
<sdoConfig idx="2007" subIdx="4"><sdoDataRaw data ="02"/></sdoConfig> <!-- Input 4 - CW Limit -->
<sdoConfig idx="2007" subIdx="5"><sdoDataRaw data ="03"/></sdoConfig> <!-- Input 5 - Home Function -->
<sdoConfig idx="2007" subIdx="6"><sdoDataRaw data ="05"/></sdoConfig> <!-- Input 6 - Emergency Stop -->
<sdoConfig idx="2011" subIdx="0"><sdoDataRaw data ="01 00"/></sdoConfig> <!-- Closed loop -->
<sdoConfig idx="6098" subIdx="0"><sdoDataRaw data ="11 00"/></sdoConfig> <!-- Home mode 17 -->
<sdoConfig idx="607C" subIdx="0"><sdoDataRaw data ="00 00"/></sdoConfig> <!-- Home offset 0 -->
<sdoConfig idx="609A" subIdx="0"><sdoDataRaw data ="F4 01"/></sdoConfig> <!-- Home accelleration 500 -->
<sdoConfig idx="6099" subIdx="01"><sdoDataRaw data ="C4 09"/></sdoConfig> <!-- Home fast speed 2500-->
<sdoConfig idx="6099" subIdx="02"><sdoDataRaw data ="F4 01"/></sdoConfig> <!-- Home slow speed 500 -->
<pdo idx="1600">
<!-- Target Position -->
<pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="target-position" halType="s32"/>
<!-- Target Velocity -->
<pdoEntry idx="60FF" subIdx="00" bitLen="32" halPin="target-velocity" halType="s32"/>
<!-- Digtial Outputs (manufacturer's extension ECT86/ECT60)-->
<pdoEntry idx="204A" subIdx="0" bitLen="16" halType="complex">
<complexEntry bitLen="1" halPin="out-1" halType="bit"/>
<complexEntry bitLen="1" halPin="out-2" halType="bit"/>
<complexEntry bitLen="14"/>
</pdoEntry>
</pdo>
</syncManager>
<pdo idx="1a00">
<pdoEntry idx="606C" subIdx="00" bitLen="32" halPin="actual-velocity" halType="s32"/>
<pdoEntry idx="6077" subIdx="00" bitLen="32" halPin="actual-torque" halType="s32"/>
<!-- Digtial_inputs (cia402 compatible) -->
<pdoEntry idx="60FD" subIdx="0" bitLen="32" halType="complex">
<complexEntry bitLen="1" halPin="CW-limit" halType="bit"/>
<complexEntry bitLen="1" halPin="CCW-limit" halType="bit"/>
<complexEntry bitLen="1" halPin="in-home" halType="bit"/>
<complexEntry bitLen="13"/>
<complexEntry bitLen="1" halPin="in-1" halType="bit"/>
<complexEntry bitLen="1" halPin="in-2" halType="bit"/>
<complexEntry bitLen="1" halPin="in-3" halType="bit"/>
<complexEntry bitLen="1" halPin="in-4" halType="bit"/>
<complexEntry bitLen="1" halPin="in-5" halType="bit"/>
<complexEntry bitLen="1" halPin="in-6" halType="bit"/>
<complexEntry bitLen="10"/>
</pdoEntry>
</pdo>
</syncManager>
</slave>
</master>
</masters>[/code]
Time to create page: 0.601 seconds
