  • cadcam
  • cadcam
06 Sep 2025 05:03
Replied by cadcam on topic problems with Verser Probe Screen 2.9
Category: Basic Configuration
Have you made any further progress with this?
  • amanker
  • amanker
06 Sep 2025 04:17 - 06 Sep 2025 04:18
If someone can give me example config.txt and config files hal and ini for skr3 board, it would be really helpful. Or look at my config files for skr3.
  • cadcam
  • cadcam
06 Sep 2025 03:45
  • Gusgus
  • Gusgus
06 Sep 2025 01:37
Hi tommylight!
We have tested the spinndle idea but the error happens regardless of if its on or off. We use and unshielded cable, let me test that out.
06 Sep 2025 01:33
Most probably interference on the SPI wiring, so the first thing would be to make those wires very short, like 10cm short, or use shielded cable.
I would also not bother with the power supply as Octopus has pretty good regulators.
If the machine has a spindle, notice if the error occurs when the spindle is turned on.
  • Gusgus
  • Gusgus
06 Sep 2025 01:25
we turn on the machine, and all normal
## Entering IDLE state
we open linux cnc and enable the machine
## Entering RUNNING state
x ammount of time passes and this happens
## Entering RESET state
Resetting rxBuffer
disable and we then get this printout
after that we can enable the machine but the time it takes for it to enter the reset state is much much shorter, like milliseconds
  • Gusgus
  • Gusgus
06 Sep 2025 01:23
Hello again Scotta!
We've continued testing on the octopus board, we have gotten movement but it seems that the SPI communication with the board seems to keep dying. We got the serial output:
Creating a std module
Remora PRU - Programmable Realtime Unit
 Mbed-OS6
 Remora-spi Driver
## Entering SETUP state
1. Reading json configuration file
Mounting the filesystem... OK
Opening "/fs/config.txt"... OK
Json config file lenght = 1996
Closing "/fs/config.txt"...
2. Setting up DMA and threads
Initialising SPI1 slave
Initialising DMA for SPI
3. Parsing json configuration file
Config deserialisation - Deserialization succeeded
4. Config threads
Creating thread 40000
Creating thread 1000
Creating thread 57600
5. Loading modules
Servo thread object
Reset pin
Make Reset Pin at pin PC_15
Creating Pin @
  port = GPIOC
  pin = 15
Servo thread object
eStop
Make eStop at pin PG_12
Creating Pin @
  port = GPIOG
  pin = 12
Servo thread object
Spindle
Make PWM at pin PB_0
Creating variable frequency Hardware PWM at pin PB_0
Creating Pin @
  port = GPIOB
  pin = 0
Base thread object
X - Joint 0 step generator
Creating Pin @
  port = GPIOG
  pin = 2
Creating Pin @
  port = GPIOF
  pin = 9
Creating Pin @
  port = GPIOF
  pin = 10
Base thread object
Y1 - Joint 1 step generator
Creating Pin @
  port = GPIOF
  pin = 1
Creating Pin @
  port = GPIOC
  pin = 13
Creating Pin @
  port = GPIOF
  pin = 0
Base thread object
Y2 - Joint 1 step generator
Creating Pin @
  port = GPIOD
  pin = 4
Creating Pin @
  port = GPIOE
  pin = 2
Creating Pin @
  port = GPIOE
  pin = 3
Base thread object
Z - Joint 2 step generator
Creating Pin @
  port = GPIOE
  pin = 0
Creating Pin @
  port = GPIOE
  pin = 6
Creating Pin @
  port = GPIOA
  pin = 14
Servo thread object
X min
Make Digital Input at pin PG_6
  Setting pin as No Pull
Creating Pin @
  port = GPIOG
  pin = 6
Servo thread object
Y min
Make Digital Input at pin PG_9
Creating Pin @
  port = GPIOG
  pin = 9
Servo thread object
Z min
Make Digital Input at pin PG_10
Creating Pin @
  port = GPIOG
  pin = 10
Servo thread object
Probe
Make Digital Input at pin PG_11
Creating Pin @
  port = GPIOG
  pin = 11
## Entering START state
Starting the BASE thread
Registering interrupt for interrupt number = 24
    power on Timer 9
Starting the SERVO thread
Registering interrupt for interrupt number = 25
    power on Timer 10
   Resetting rxBuffer
This last bit is where we are running into a wall, we are not sure what is causing this.
  • PCW
  • PCW's Avatar
05 Sep 2025 23:35
Machine off at the end of the programm. Repeatable!
Category: Milling Machines
Consistent position errors after a long program could indicate a step timing
or polarity issue. Too low direction setup or hold times could cause a lost step
at reversals. Wrong step polarity can also cause this issue as stepping on the
trailing edge of the step pulse (rather then the expected leading edge) will
decrease the expected hold time.
It might be worth either inverting the step polarity or increasing the setup/hold times,
at least to see if it changes anything.
  • unknown
  • unknown
05 Sep 2025 23:20
Some of the cheaper fixed bearing blocks are sold with non angular contact bearings, this is something to check.
Until you perform a backlash test, and yes this can manifest as repeatable, you can not rule out a mechanical issue.
  • JohnnyCNC
  • JohnnyCNC's Avatar
05 Sep 2025 23:10
Questions about "Auto Zero" in QT_Dragon_HD probe tab.
Thanks Rod. I'll look into upgrading to 2.10.
  • scotta
  • scotta's Avatar
05 Sep 2025 21:26
Good to hear. I'd suggest slowing down the SPI comms like in the discussion above.
hal
loadrt remora-spi SPI_num=0 CS_num=0 SPI_freq=2000000
ini
#SERVO_PERIOD = 1000000
SERVO_PERIOD = 5000000
  • PCW
  • PCW's Avatar
05 Sep 2025 21:17
Replied by PCW on topic M100 on subroutine hangs
Category: HAL
Did the subroutine execute?
You could run
halcmd show signal s-index-zero-for-ATC
From the command line to check
  • PCW
  • PCW's Avatar
05 Sep 2025 20:44
Troubles to get started with SD240 Retrofit
Category: Turning
No, the actual index pin is not typically used by LinuxCNC
What interface card are you using for the encoder interface?
Is the encoder single ended or differential?
Is  the interface card jumpered to match the encoder type?
Another way to check the low level hardware is to set the index input to
single ended mode, and then watch hm2_7i80.0.encoder.00.input-index
in halshow as you ground the index input on the interface card.
hm2_7i80.0.encoder.00.input-index  should change state when you ground
the +index input pin
(with the encoder unplugged of course)
  • PCW
  • PCW's Avatar
05 Sep 2025 20:36 - 05 Sep 2025 20:37
Replied by PCW on topic orient spindle with ethercat EL5101
Category: EtherCAT
FF0,FF1,FF2 are feed forward terms
FF0 adds a proportion of the PID command to the PID output
FF1 adds a proportion of the PID commands first derivative to the PID output
FF2 adds a proportion of the PID commands second derivative to the PID output
For a simple example imagine a spindle control PID loop
This would have a PID loop with velocity command and velocity output.
Setting FF0 to 1 means that at a say commanded RPM of 3000,  means
that the PID output would be 3000 without any correction from the PID error
term. You can think of the FF terms as a way of centering the operating
point of the PID loop around the current state (rather than having
feedback have to do all the heavy lifting)
  • ziggi
  • ziggi's Avatar
05 Sep 2025 20:34 - 05 Sep 2025 20:36
Category: Turning
No, it does not.
I scrolled through the HAl and could not find the hm2_7i80.0.encoder.00.input-index pin linked anywhere. So I assume Linuxcnc does not get this signal- can this be the reason?
Displaying 13291 - 13305 out of 13750 results.
Time to create page: 0.467 seconds
