  • esmurf
  • esmurf
22 Jul 2025 09:28 - 22 Jul 2025 09:59
Replied by esmurf on topic Trying to get my OMC A6 Servos homing
Category: EtherCAT
How did you wire your home and limit switches?
If you push the siwtches by hand, do you see the "pins" change in halshow?
I would recommend to wire the limit and home switches to the servo drives DI inputs.
Then you can see the signals in PDO 60FD.
e.g. add this to your ethercat-conf.xml for each A6 servo:
<pdoEntry idx="60FD" subIdx="00" bitLen="32" halType="complex">
<complexEntry bitLen="1" halPin="limit-neg" halType="bit"/>
<complexEntry bitLen="1" halPin="limit-pos" halType="bit"/>
<complexEntry bitLen="1" halPin="home-switch" halType="bit"/>
<complexEntry bitLen="13" />
<complexEntry bitLen="1" halPin="din1" halType="bit"/>
<complexEntry bitLen="1" halPin="din2" halType="bit"/>
<complexEntry bitLen="1" halPin="din3" halType="bit"/>
<complexEntry bitLen="1" halPin="din4" halType="bit"/>
<complexEntry bitLen="1" halPin="din5" halType="bit"/>
<complexEntry bitLen="1" halPin="din6" halType="bit"/>
<complexEntry bitLen="1" halPin="din7" halType="bit"/>
<complexEntry bitLen="1" halPin="din8" halType="bit"/>
<complexEntry bitLen="1" halPin="din9" halType="bit"/>
<complexEntry bitLen="7" />
</pdoEntry>
I use negative logic. You have to configure this on your drive to match the limit/home switches. This is permanently saved in the drive.
e.g.
# set operating mode
ethercat upload -p 2 --type int8 0x6060 0x00
ethercat download -p 2 --type int8 0x6060 0x00 8
# set "active low" DI input logic
ethercat upload -p 2 --type uint16 0x2004 0x02
ethercat download -p 2 --type uint16 0x2004 0x02 1
ethercat upload -p 2 --type uint16 0x2004 0x06
ethercat download -p 2 --type uint16 0x2004 0x06 1
ethercat upload -p 2 --type uint16 0x2004 0x0A
ethercat download -p 2 --type uint16 0x2004 0x0A 1
You also have to set homing mode  (PDO 0x6098) - see manual
  • rodw
  • rodw's Avatar
22 Jul 2025 06:57
Replied by rodw on topic QTplasmac material database enhancement
Category: Plasmac
Have a look at monokrom. it might do this already as the designer did the ramp piercing and pushed to qtp. It has a proper SQL database
  • peterdownunder
  • peterdownunder
22 Jul 2025 06:44
Replied by peterdownunder on topic (solved) python error on startup
as an aside, how do i mark this as answered ??
  • peterdownunder
  • peterdownunder
22 Jul 2025 06:41
Thanks that fixed it. Unsure what exactly happened, but happy to have it fixed
  • rodw
  • rodw's Avatar
22 Jul 2025 06:35
We need to purge raspi-firmware packages in LinuxCNC ISO (AMD64 version)
Category: Installing LinuxCNC
What about removing the package from the image file?
The installer supresses it and its not installed but as soon as there is an apt update, it comes back. Very annoying. This was present in the original release of Debian Bookworm and it was fixed in the first update but the update were never pushed to the Debian Builder we use to make the iso (which is what we should use to follow the Deban way)
  • Luc1luc
  • Luc1luc
22 Jul 2025 06:31 - 22 Jul 2025 06:34
Trying to get my OMC A6 Servos homing was created by Luc1luc
Category: EtherCAT
Hey there,
im hare to look for some help on getting my Servos to work. Which currently ignore my endstops and would "crash" into them if i wouldnt stop
The Servos are Stepperonline A6 400W Ethercat ones, combined with an Beckhoff EK1100 and some IO Modules.
I also got the absolute encoder cables, but so far thought to just use them like a "stepper drop-in" and then if working, to go the next step and do the "integrated homing" way.
I just setup everything i think i will need:
- installing the Ethercat
- installing the cia402 driver
So hopefully theres people here who might be able to "get me on the right way" with my Servo setup and explain me my mistakes.
PrintNC_LinuxCNC/EtherCAT at main · Luc1luc/PrintNC_LinuxCNC
  • rodw
  • rodw's Avatar
22 Jul 2025 06:24
Replied by rodw on topic Spindle Docs
Spindle Docs
Category: LinuxCNC Documents
2.9 pre is years old and buggy. You can't depend on it. You really should upgrade to 2.9.4 by following the steps in the Getting Linuxcnc docs or adopt Debian Trixie pre-release as it should be out as the official Debian release next month.
  • Kieran
  • Kieran
22 Jul 2025 05:29
Replied by Kieran on topic Rf45 clone glow up.
Rf45 clone glow up.
Category: Milling Machines
I've been busy on this machine. Got my B axis alive.
I will throw some pictures up of the other progress tomorrow.
youtube.com/shorts/gAclUIYUk1Y?si=PEWtBkNokJtn4JyQ
  • Kieran
  • Kieran
22 Jul 2025 05:18 - 22 Jul 2025 05:22
Replied by Kieran on topic Do I need a better PC?
Category: EtherCAT
In other news, my new pc build runs much better generally and I don't have the real-time delay error warnings anymore. And I've been busy making mechanical progress on my machine.
  • Kieran
  • Kieran
22 Jul 2025 05:16
Category: EtherCAT
I've been messing with this again. I have an intel 2 ports pcie lan card that I tried to use. I got the ip address from ip a command and put it in the etc/ethercat.config. for some reason only the lan on the motherboard works even with the address changed. But the servos were crunchy sounding and it was disconnecting randomly. I put it back to the correct address for the motherboard port and its smooth. I have not been able to run ethercats on the pci card.
  • tcbmetalworks
  • tcbmetalworks
22 Jul 2025 03:46
Replied by tcbmetalworks on topic Automatic band saw marvel v10a
Category: CNC Machines
Got the saw back home. She's definitely rough. Good news is it looks possible to make the saw miter in the opposite direction by removing one support bar. The way the shuttle seems to work is it has a ball screw with a limit switch on it to control the length that the hydraulic retracts. Once it hits the limit switch it stops the hydraulic from further feeding forward. I may rework the vices as they currently have a very shallow depth of hydraulic travel. The bearings in the saw wheels feel sloppy but smooth. In the morning I am pressure washing the whole machine and may try to put power to it to see if anything still works. If I can reuse hydraulic pump and band saw motor that would be awesome!
  • mBender
  • mBender
22 Jul 2025 02:18
Hi all,
JCLPCB delivered my self made PCB board. Testing ongoing. I had to order 5 boards. If anyone is interested in one, I have a few spares. Located in the Florida USA.
  • rubinstu
  • rubinstu
22 Jul 2025 00:56 - 22 Jul 2025 00:59
Weird G54 orientation was created by rubinstu
I'm having a weird issue with my programs, or maybe my setup when I generate the NC codes. For some reason, my program "starts" (G54 setting the origin) way outside of the boundary of my machine. You can see in the picture the "G54" is way out there. The default program ("LinuxCNC") puts the G54 right on the limits of the machine (at least per the drawings). Please see the attached screenshots. What could be causing this? I'm generating GCodes from Fusion 360.Thank you!
  • cakeslob
  • cakeslob
22 Jul 2025 00:11
Replied by cakeslob on topic Axis Modifications
Axis Modifications
Category: AXIS
yeah there are some file managers you can integrate into axis tab and use the way you describe. There are some TK alternatives file browsers I have yet to figure out how to use yet
  • cakeslob
  • cakeslob
22 Jul 2025 00:02
	"Thread": "Servo",
	"Type": "Digital Pin",
		"Comment":			"Index",
		"Pin":				"1.28",
		"Mode":				"Input",
		"Invert":			"True",
		"Data Bit":			6
	"Thread": "Servo",
	"Type": "QEI",
		"Comment":			"spindle-encoder",
		"Modifier":			"Pull Up",
		"PV[i]":			0,
		"Data Bit":			2,
		"Enable Index":		"True"
well, maybe you dont need to use the preassigned index, you will find out i guess
# Spindle QEI encoder
	setp encoder.0.position-scale 800.000000
	net encoder-count     <= remora.PV.0     => encoder.0.raw_count
	net encoder-phaseZ    <= remora.input.6  => encoder.0.phase-Z
#	setp encoder.0.index-enable true
i dont think you are connecting your spindle pins correctly thought. its waiting for the index enable probably
compare to this one
github.com/cakeslob/RRW_LAB/blob/inc/Lin.../remora-xyz.hal#L128
Displaying 13921 - 13935 out of 14619 results.
Time to create page: 0.422 seconds
