  • roland100
  • roland100
19 Jul 2025 14:39
Replied by roland100 on topic Mesa 7i96S MPG encoder on P1
Category: Driver Boards
Hello PCW,
I found a solution:
I flashed my 7i96s with the 7i96sd_mpgp1.bi file from the mesa homepage. Now everything works as expected.
My goal is to wire my MPG to P1, I think, this bin-file is for realizing this too.
Thanks a lot
  • jochen91
  • jochen91
19 Jul 2025 14:28 - 19 Jul 2025 14:55
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
Update:
So i took the machine mostly apart.
It is really dirty. I don't know what the pre-owners did with it, but dried up coolant is basically everywhere. Its yukky. It takes a lot of time to clean everything.
Linear guide rails on the Z Axis -> Scrap ( 2 out of 5 blocks are wiggling in the Rail) The rail is some special THK rail and is only sold as a set by Mazak. I requested a counter offer from a THK dealer... even more expensive.
The Y axis box ways are done. The lubrication system malfunctioned and the way wipers failed over the years. Already brought it in for regrinding. After that it needs to be scraped, which i am able to do. I lack a lot of experience in scrapping but its a "simple" box way and no dove tail ways.
Same goes basically for the X axis. Lube system got plugged up by failing way wipers and even the hardened ways got damaged. -> Regrinding.
Ballscrews:
Z Axis ballscrew is in good condition, but has no preload anymore.
X Axis ballscrew is in good condition, and still has preload.
Y Axis ballscrew feels a little bit crunchy... the balls need the be replaced and checked again.
Milling spindle:
The taper is shot and needs to be reground. I assume the bearings are also in no good condition. This repair also needs the be done professionally.
The good news:
I fixed my temporary encoder capacitor solution with a proper super cap. I even upgraded it to a 1.5F :)
  • Sbvr4
  • Sbvr4
19 Jul 2025 14:10
Probe_Basic Not Writing Parameter Variables
Category: QtPyVCP
Good Morning,
I've installed Probe Basic and continue to have an issue with parameters not being written to the .var file. Anytime a value is updated via Probe_basic ui, a "File not Open" error shows and no changes are made to the .var file. Parameters entered via Gcodes work fine. For instance, SET TOOL TOUCH OFF POS generates "File Not Open" error, but MDI g30.1 works fine. The sim version works fine.
Terminal shows: emctask.cc 68: interp_error
I am running:
Debian 12 Bookworm
LCNC v2.10
Current version of Probe_basic and QtPyVCP
installed sable APT version
Any help would be greatly appreciated.
Thank you,
Sean
File Name: main_2025-07-19.hal
File Size:8 KB
File Name: 1610L_Prob...7-19.ini
File Size:6 KB
File Name: probe_basi...19-2.hal
File Size:4 KB
  • roland100
  • roland100
19 Jul 2025 14:04
Hello PCW,
A few days ago i flashed my 7i96s with the 7i96sd_inmp1v2.bin file. Flashing was without error.
Since then, the X-axis-homing does not work anymore.
Homing of y-axis and z-axis works fine, as expected.
I would be glad to get your help to solve this issue
Is there a way to get the 7i96s in the state before flashing ?
Tanks a lot
  • roland100
  • roland100
19 Jul 2025 13:55
7i96S Referenzfahrt X-Achse funktioniert nach mesaflash nicht mehr
Hallo Zusammen,
Ich bin neu im Forum und wende mich an euch, da ich den Fehler beim Referenzieren der X-Achse nicht finde.
Meine LinuxCNC miz 7i96S hat wunderbar funktioniert, bis ich die Karte mit dem file 7i96sd_inmp1v2.bin geflasht habe.
Ich habe nur den flash gemacht, an der pncconf usw nichts geändert.
Die Y-&Z-Achse referenzieren nach wie vor wie erwartet, die X-Achse fährt in die falsche Richtung los, d.h. vom Referenzschalter weg,
wenn ich den Schalter von Hand betätige fährt X einfach weiter, der Positionswert ändert sich nicht auf 0, zählt einfach weiter.
Bei 2 Punkten bitte ich um eure Hilfe:
- Welche Ursache kann dieses Verhalten auslösen ?
- Wie schaffe ich es die 7i96s in den vorigen Zustand zu flashen ?
Über jeden Input freue ich mich, den bin-, hal- und ini-file habe ich abgeängt.
19 Jul 2025 13:29
Replied by tommylight on topic Mesa Auswahl für größeres Projekt
Category: Deutsch
1 encoder, nur ein.
7i83 hat kein encoder eingange, 7i85 oder 7i85S soll 4 encoder eingange habben.
Ich wurde die 7i95T mit 7i83 nemen, fuhr mehr IO noch ein 7i84 nemen, oder 7i73 fuhr die konzole ...
  • rocket6delta
  • rocket6delta
19 Jul 2025 13:16
Replied by rocket6delta on topic 7i76EU Hal and Ini File
Category: HAL
it's possible...i measured 24V on the output pins.....these lines look different then when the machine was last operational but i had ChatGPT produce these...they don't seem right to me but i don't know enough...my board is a 7i76EU so i was thinking of replacing 7i76 with 7i76EU......if i comment these lines out the z axis brake doesn't release...
therman@Debian-LinuxCNC:~$ halcmd getp hm2_7i76.0.7i76.0.0.output-01
TRUE
therman@Debian-LinuxCNC:~$ halcmd getp hm2_7i76.0.7i76.0.0.output-00
TRUE
therman@Debian-LinuxCNC:~$ halcmd getp hm2_7i76.0.7i76.0.0.output-02
TRUE
  • timo
  • timo
19 Jul 2025 12:50
Replied by timo on topic Y axis A slave help request
Is it just about homing sequences? Or do you need to keep a fixed ratio for the axis?
  • Franklin
  • Franklin
19 Jul 2025 10:55
Replied by Franklin on topic WHB02 remote control to QtPlasmac
Category: Plasmac
So, with the help of the AI assistant I found out that it is a HID device. I entered the command: sudo cat /dev/hidraw4
then when I press the keys, characters appear in the terminal.
  • Millimetergott
  • Millimetergott
19 Jul 2025 08:27
Replied by Millimetergott on topic Homing Stepperonline A6
Category: EtherCAT
Hello, are you still having problems with your homing? I use the El7 homecomp for my A6. If you're still interested, I can upload my config.
  • hitchhiker
  • hitchhiker
19 Jul 2025 07:14
Replied by hitchhiker on topic Rotary Encoder to adjust Jog-Speed?
halui.joint.jog-speed (float in) - pin for setting jog speed for plus/minus jogging.
i connect a potentiometer to it and bring it in the hal together...
i see that halui.joint.jog-speed changed when i look to the halpin.
but the jog speed doesnt change when i jog.
i jog with the pc keyboard!
is it possible that this is only working when you jog with like a joystick???
or a button on a pendant for plus and minus???
i use a handwheel... my target is to move from increment to increment with a selected speed.. like:
i select joint 0 and increment 0.1 with the rotary switches on my pendant, then i rotste the handwheel.. the jog speed is the same wich is selected with the jog speed bar in AXIS. now i want to adjust this Speed with another encoder or pot.
but i understand it works only with buttons for + - axis movement together.
and this is what i understand that it works like a joystick.
or i am complete wrong?
  • G0G53Z148
  • G0G53Z148's Avatar
19 Jul 2025 04:59 - 19 Jul 2025 05:14
Replied by G0G53Z148 on topic Mesa Auswahl für größeres Projekt
Category: Deutsch
Hallo @tommylight
Das ist ein schönes Retrofit "ich ziehe meinen hut"
Du verwendest da die 7i92 TM  ich war mir eben nicht sicher da die TH und TM doch unterschiedliche beschreibungen haben.
Die 7i76 gibts auch nur mehr als 7i76U deshalb tu ich mir so schwer bei dem vielen was ich gelesen habe weils eben die alten karten nicht mehr gibt.
Aber 7i92TH mit IDC26>DB25 und 7i76U und 7i83 an Serial EXP
oder 7i92TM direkt an 7i76U (spart Kabel) und die 7i83 an Serial EXP
Oder hast du eine bessere alternative als die 7i83 mit smart serial also momentan werden mindestens 3 Spindel Servos gebraucht
Hab ich das nun so richtig aufgedröselt
5 step Dir
6 -10 - +10V
7 Encoder
1 poti
32 ein
16 ausgänge
Mit deinem Okay hab ich entlich eine steuerung die Servos sind schon am weg
danke dir und einen schönen tag
  • beefy
  • beefy
19 Jul 2025 01:14 - 19 Jul 2025 02:20
XHC-WHB04B-6 not increasing MPG counts
Category: HAL
Used xhc-whb04b-6 -ue in a terminal window, and can see all buttons working.
However, in the line:
pndnt wheel total counts {counts=0 activeCounter=0 isLeadActive=0}
all the values remain at zero.
Thing is with every click of the MPG there are other digits in the terminal window that are doing something so it appears the MPG clicks are being noticed by the driver.
Watching these digits (which are either 0 or 1 or -1) the 0 digit appears to be incrementing with MPG clicks but immediately returning to 0
The digit which is either +1 or -1 seems to change when I rotate the MPG forward and revere respectively.
So overall it appears the xhc-whb04b-6 driver is actually recognising the MPG pulses but is not incrementing the total pulse count.
I can also use
xhc-whb04b-6 Ha and then start Halshow.
Once again, all button presses show up in Halshow but counts stays at zero when using the MPG.
My big question is: does the driver need some sort of feedback pins setting from Halui, in order to increment the pin:
whb.axis._<N>_.jog-counts
  • PCW
  • PCW's Avatar
18 Jul 2025 22:37 - 18 Jul 2025 22:58
Replied by PCW on topic 7i76EU Hal and Ini File
Category: HAL
You would not normally see much of a change in STEP
pin outputs as the STEP pulses are short and do not change
the average voltage ( what a voltmeter reads ) very much.
You should see a change in the voltage on the DIR
pins when jogging in different directions.
It this possibly an issue with the motor drive enables?
  • unknown
  • unknown
Displaying 14056 - 14070 out of 14621 results.
Time to create page: 0.858 seconds
