  • endian
  • endian's Avatar
17 Jul 2025 10:35
Replied by endian on topic Reduce read-all timing 7i76e + 7i77
I did the
packet-read-timeout=500000
sserial_port_0=2000x to sserial_port_0=2000h
ping between mesa is less then 0,3ms and it is per to per connection
I did not try the custom firmware
./mesa-configtool --new-fpga 7i76e --no-sserial --optimize-read
goal is -
SERVO_PERIOD = 500000
resualt is no change at all ...
  • Yan_moto
  • Yan_moto
17 Jul 2025 10:16
Anyone figured out how to get Trinamic's TMC5160 drivers working with LinuxCNC?
Category: Driver Boards
I'm using those drivers currently. They are quite a beasty. It is possible to use them in standalone mode, but  i would advice against it if your motor is relatively low current (below 5A). I burnt one motor this way as setup of IRUN (with CFG pins) is half range up to full power - this is probably linear scale so 5 -10 A.
Best option is to have additional SPI capable device (arduino, rasperry pi, even 8081 probably would do) just to configure the driver(s).
Connect DIR/Step (and maybe DIAGs) to parallel/mesa card.
Quite important to supply all 3 power inputs (took me some time to get figure this out)
- main board HV (0-60)
- stepstick adapter VIO for logic (5V)
- stepstick adapter VM/ 24V (it can be lower - i'm  using 19.5V/4A now). As mentioned this input is exposed as VM on stepstick adapter - it should be used to  supply colling FAN but is also used to supply TMC internal voltage regulator and then some internal circuitry !!!
As a observation it looks like this input require some power too like few amps (my 24V/1.6A died when suppling 3 drivers- was good with one).
Next step is just to tune parameters and you are set.
I did manage to get these boards to work in the mode I needed through SPI programming.
NEMA23 - 48v 3A
I measured the current on the 24V branch - 20-30mA when the engine was running.
Programming via SPI from STM32 has its own tricks, but it was actually very interesting!
  • unknown
  • unknown
17 Jul 2025 10:15
Replied by unknown on topic Reduce read-all timing 7i76e + 7i77
So you tried stuff AI has, what have you tried and what were the exact results ? To save repeating stuff.
  • MaHa
  • MaHa
17 Jul 2025 10:05
Replied by MaHa on topic Flex Gui preset buttons
Category: Flex GUI
Just to check if i messed op the ui file, i made a new project, just with essential items to start. The behaviour is the same. When a running a program or mdi move, and press a button with feed_percent_, rapid_percent_ ,spindle_percent_ the display stops updating for about 5 seconds. When watching distance to go in hal, this keeps moving.
  • PedPEx
  • PedPEx
17 Jul 2025 10:02 - 18 Jul 2025 15:20
Replied by PedPEx on topic Un-lobotomizing a Maho MH600T
Category: CNC Machines
Hey Mark,
really nice work with your Maho retrofit. I'll certainly use your gearbox component in my conversion as well :)
I am actually using the original M23 connectors. The assembly concept is also shown on the Github page.
These are pictures of the very first test PCB, not the latest v0.9.5
  • RotarySMP
  • RotarySMP's Avatar
17 Jul 2025 09:45 - 23 Jul 2025 14:38
Replied by RotarySMP on topic Un-lobotomizing a Maho MH600T
Wow, nice work.
One aspect of the Heidenhain hardware which is outstanding is the quality of their cables (double shielded) and connectors (M23). Why downgrade to D-Sub rather than making your board compatible with M23, so you can plug the scales straight in?
Mark
  • endian
  • endian's Avatar
17 Jul 2025 09:37
Reduce read-all timing 7i76e + 7i77 was created by endian
Hello gentelmen,
How to reduce the read-all timig from 0,8ms to something below please? Ping I have beloe 0,3ms and latency at servothread below 800ns
I am using 7i76e+7i77 at P1 with 3 axis setup..
I have tried everything what AI told me but without any success ...
thanks
  • PedPEx
  • PedPEx
17 Jul 2025 09:28
Problems switching PDO assignments (EP5101-0011)
Category: EtherCAT
Thank you for your suggestions. I'll test them within the next two weeks and keep you updated – I'm currently in the middle of my exam period, so my rime for the retrofit is limited :/
  • PedPEx
  • PedPEx
17 Jul 2025 09:19
Hey folks,
i'm currently retrofitting my Maho MH400E and also needed a interpolator for my linear scales. I wanted to ditch the big clunky 3 channel board of Heidenhain and also avoid the EXEs with the same reason. Without knowing about your project i started my own interpolator also based on the iC-NV and reached out to the manufacturer iC-Haus. They kindly provided some more details and also the hint to have a look at the datasheet of the iC-NQC. In that datasheet, there is a analog frontend suggestion, that can be feed with 11µA, 1V and TTL signals (the NQC is a BiSS interpolator/converter). So i pretty much copied that input circuit (ditched the TTL input) and added some lowpass capacitors like they suggested in a other part of the datasheet. In case they don't work it's easy enough to just not populate them.
The current list of features are:
- DB15 plug matches pinout of Beckhoffs EP5101-0011
- In case somebody doesn't use it with a EP5101 it also supports reverse voltage protection
- All inputs and outputs are ESD safe
- Current limiter for sensor supply (currently set to 120 mA - can be bridged if not needed)
- Differential and single ended output possible (manually selectable via solder jumpers or by 0 ohm resistors)
- All signal lines are length matched to all other encoder channels
- Sensor can be plugged in via pin header or RJ45 (different pinout than yours - pin matched with Heidenhain)
- Board is meant as eval board as well as "finished product". Every input can be changed via a switch or the provided potentiometer
At the moment i'm at version 0.9.2, that's the first "finished" pcb layout, the texts for the switches, testpoints, ... are missing. I'll get to these in around 2 weeks, when my exams are over.
You can find the project here on Github: github.com/PedPEx/SinCosEnc-Conv_EP5101
When you have any inputs on that project, just let me know :)
  • Hakan
  • Hakan
17 Jul 2025 08:44
About G83 Deep drilling variable peck depth
linuxcnc.org/docs/2.6/html/gcode/gcode.h...ec:G83-Drilling-Peck
Doesn't seem to be supported. I also checked the code, interp_cycles.cc (always learn something new)
but no IJK.
  • meister
  • meister
17 Jul 2025 07:43
thanks, but still a lot of work to do (At the moment it is still a proof of concept):
here is the latest source file:
 www.multixmedia.org/testme-graph.py
# python3 testme-graph.py riocore/configs/Tangbob/config.json
  • kzali
  • kzali
17 Jul 2025 06:59
  • G0G53Z148
  • G0G53Z148's Avatar
17 Jul 2025 06:19
Replied by G0G53Z148 on topic Mesa Auswahl für größeres Projekt
Category: Deutsch
guten morgen,
danke für deinen denkanstoss
die kombi glaub ich wird es werden
7i95T + 7i83 + 7i73
Dann bringe ich das Vorschub Potentiometer auch noch unter auf der 7i73
in summe wären das dann
Step/Dir Ausgänge    6 (differenziell oder single-ended)                        7I95T
Encoder Eingänge    6 (A/B/Z, TTL oder differenziell, ~3 MHz)             7I95T
Digitale Eingänge    24 isolierte Inputs (4–36 V DC)                              7I95T
Digitale Ausgänge    6 isolierte Open-Drain-Ausgänge (bis 36 V/2 A)    7I95T
Analoge Ausgänge (±10 V)    6 DAC-Kanäle, 13 Bit Auflösung                7I83
Digitale Eingänge (GPIO)    16 (für Taster/Schalter oder Matrix-Keys)    7I73
Analoge Eingänge (0–5 V)    4 (für Potentiometer etc.)                            7I73
Drehgeber / Handrad    1 Inkremental-Encoder-Eingang (MPG)               7I73
und angeschlossen an die 7i95T über die beiden Serial mit RJ45 Open end kabeln
wo wir aber schon beim nächsten problempunkt wären.
Wie weiß PNC conf das wir an der 95T auf eine 73 und 83 angeschlossen haben
eine spezielle firmware auf mesa habe ich nicht gefunden. Das sind viele fragen
Danke und alles gute
  • atrex77
  • atrex77's Avatar
17 Jul 2025 06:13
W5100S-EVB-PICO stepgenerator and encoder driver
Probably in the next month second half.
  • atrex77
  • atrex77's Avatar
17 Jul 2025 06:04
in the io-samurai project you find example, in the main.c line #88 (detection & init) and line #172 is the draw process, i not used in the stepper-ninja project because its limiting the refresh speed of the inputs/outputs (~60/sec), but if you are want to use to inputs and outputs for control panel, its probably not a problem. If you want to participate the project please use the test branch.
Displaying 14131 - 14145 out of 14628 results.
Time to create page: 0.728 seconds
