  • tokomak
  • tokomak
13 Jul 2025 19:41
Replied by tokomak on topic Xilinx Zynq 7010 fpga crypto windfall boards
Category: Driver Boards
github.com/machinekit/mksocfpga Hostmot2 FPGA code for SoC/FPGA Zynq platforms
  • ZXT
  • ZXT
13 Jul 2025 19:25 - 13 Jul 2025 19:32
Configuring LinuxCNC 2.9.4 Mesa 7i95t Newbie.
Category: Milling Machines
I’ve been trying to get some stuff working and it’s starting to get there,
 Added some stuff and mpgs are reading and moving X, Y, Z but it immediately throws an error of positioning error, tired to adjust max acceleration for all axis, and also asked AI to help me make filtering/limiting, worked a little bit, but it went slow and unresponsive,
picture explains more of what happened
sorry for all comments in the files being Swedish.
  • Aciera
  • Aciera's Avatar
13 Jul 2025 19:11
Replied by Aciera on topic Sometimes my tool unload code just…stops
Category: O Codes (subroutines) and NGCGUI
@Pipik and @SebastianM
No double posting please.
  • hitchhiker
  • hitchhiker
13 Jul 2025 19:10
Replied by hitchhiker on topic 7i92 pwm to 0-10v analog
i dont do it over a wizard.. only by hand... in the hal and ini.
  • Aciera
  • Aciera's Avatar
13 Jul 2025 17:53
Replied by Aciera on topic Gmoccapy 3.5.0 - opinions needed
Category: Gmoccapy
The issue with the error is being dealt with:
github.com/LinuxCNC/linuxcnc/issues/3510
13 Jul 2025 17:30
Replied by tommylight on topic Mesaflash not working on 7i96s but it pings
Andy, did you delete your post?
13 Jul 2025 17:28
Replied by tommylight on topic 7i92 pwm to 0-10v analog
9V is 90% of 10V, makes me think in the wizard the default values are 10%-90%, but not sure if on StepConf or PncConf.
Check the hal if that is the case, namely if the max PWM value is 90%.
  • hitchhiker
  • hitchhiker
13 Jul 2025 17:09
7i92 pwm to 0-10v analog was created by hitchhiker
Hi guys.
i am a little bit confused.
I get from amazon a pwm to 0-10v converter.
I try it out first on a arduino which has 5v outputs on the GPIOs. works fine.
then i switched to my 7i92 and 7i92t!
i reach only 9v -9.04v if i screw in the calibration cap.
In the hal i set different pwm base freq. from 1khz up to 30khz. nothing helps.
then i come to the point that the optocoupler on the converter isolate the circuit. this means for me it doesnt matter which voltage is coming from the mesa right?
what are the cause?
i dont search for circuit diagramms..
the idea what i have was to take a lm358 and make it on a breadboard..
but i ask here before waste my time.
thanks
  • ziggi
  • ziggi's Avatar
13 Jul 2025 17:09
Troubles to get started with SD240 Retrofit
Category: Turning
No unfortunately a new Config with a MPG already included did not do the trick.
Manual jogging the X and Z axes works, continuos and inkremental but not with the encoder I intend to use as MPG.
I once again ran the suggested command "halcmd show pin | grep jog" - report attached.
Did not imagine it would be this challenging to get a MPG connected...
Sigi
File Name: SD240_V4.ini
File Size:3 KB
File Name: SD240_V4.hal
File Size:10 KB
File Name: halcmnd_jog.txt
File Size:7 KB
  • PCW
  • PCW's Avatar
13 Jul 2025 15:57 - 13 Jul 2025 15:57
You have the host set to the same address as the 7I96 card
(so you are pinging your host PC)
For a 7I96S set to 192.168.1.121, use 192.168.1.100/24 for the host
For a 7I96S set to 10.10.10.10, use 10.10.10.100/24 for the host
( 10.10.10.10 is suggested rather than 192.168.1.121 as the 192.168.1.XX
range is often overlapped with local DHCP network addresses)
  • Cerezas
  • Cerezas
13 Jul 2025 15:39 - 13 Jul 2025 15:50
Replied by Cerezas on topic Mesaflash not working on 7i96s but it pings
Try:
mesaflash --device ethernet --addr 192.168.1.121 --readhmid
  • tokomak
  • tokomak
  • tokomak
  • tokomak
13 Jul 2025 14:46 - 13 Jul 2025 14:49
13 Jul 2025 14:40
Replied by tommylight on topic Fehler Upgrade
Fehler Upgrade
Category: Deutsch
Die ganze fehler?
Gibt "raspi" dabei?
  • Edi_48
  • Edi_48
13 Jul 2025 14:38
Fehler Upgrade was created by Edi_48
Fehler Upgrade
Category: Deutsch
Hallo
Ich habe  LinuxCNC 2.9.4 Debian 12 Buchwurm PREEMPT-RT ISO neu installiert
und bekomme von  Sudo apt Upgrade eine Fehlermeldung:
Fehler traten auf beim Bearbeiten von:
 linux-image-6.1.0-37-rt-amd64
 linux-image-rt-amd64
 initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
 Ich habe auf einen Zweiten Rechner Linuxcnc installiert  und bekomme die selbe Fehlermeldung
was soll ich tun
mfg
Hilton
Displaying 14266 - 14280 out of 14629 results.
Time to create page: 0.726 seconds
