  • Lcvette
  • Lcvette's Avatar
25 May 2025 06:20
Replied by Lcvette on topic config tool setter
config tool setter
Category: QtPyVCP
i cannot replicate, i get the value stored in both the var and the ui even through multiple restarts it remains correct.
  • unknown
  • unknown
25 May 2025 04:53
Why does it seem like everyone here is Australian?
I blame things I can't say but also the things I can't say with their fascination with American culture.
If you can't laugh at yourself you're coward.
  • CORBETT
  • CORBETT's Avatar
25 May 2025 03:53
Replied by CORBETT on topic el5151 reseting counts
Category: EtherCAT
Okay, good deal.  Glad it's working for you.
  • CallumRD1
  • CallumRD1
25 May 2025 02:13
Replied by CallumRD1 on topic Keyboard shortcut rempaping
Category: Qtvcp
Thanks for the response. I am getting the line you asked about in the terminal. When I just tried using the space bar pause, it worked in all but one instance. I think you're right, it's a focus issue. In one instance, I had clicked the coolant button and then hit the space bar and the program failed to pause, but I was unable to replicate the behavior in the short session I had to test it this evening. I'll follow up if I'm able to reproduce the failure to pause.
But anyways, thanks for the help with this! I hadn't realized how much I use this feature until I didn't have it. When the tool is plunging rapidly, it's really nice being able to reflexively pause everything to check positions and the distance to go.
  • cmorley
  • cmorley
25 May 2025 00:44
Replied by cmorley on topic Keyboard shortcut rempaping
Category: Qtvcp
If you run linuxcnc from a terminal, do you see this text?
'Custom subclassed handler loaded for spacebar pause'
sometimes it's a focus problem, try pressing the 'G54' or 'ABS' button (after the program is started.). If that works I will look into why you need to do that.
  • PCW
  • PCW's Avatar
24 May 2025 23:36 - 24 May 2025 23:58
Replied by PCW on topic Threading Index Varies With Speed
I was able to reproduce this error with a simple test setup
with no mechanics and using g76. It also causes errors even
at a constant spindle speed, as the offset changes with thread
depth over the multiple threading passes which would cause
a  wider than expected cut.
To test this I setup a 7I96S with a stepgen spindle setup to
emulate a 8 count encoder with index (using the stepgen table mode)
I checked the offset by using the sum2 component to scale the spindle
rotations to the thread pitch and subtract the result. This offset
should be independent of spindle speed, X,Z motion constraints
and drive line distance to thread pass, but it is not.
Have you raised an issue on the LinuxCNC github page?
  • PCW
  • PCW's Avatar
24 May 2025 23:13 - 24 May 2025 23:14
AC Servo tuning - Joint 0 following error at high velocities
Category: Basic Configuration
I would check the encoder signals at the Mesa card
The way to check is disable the drives (I hope this can be done
in a way the encoders still work) and then measure the differential voltage
(from A to /A and B to /B ) with a voltmeter in all quadrature states.
(you can usually to this by wiggling the motor shaft a bit to get all 4 states)
The absolute value of the differential voltage should always be greater than 2V
(you should get a positive differential voltage in one state and a negative voltage in
the other state)
Another check is to enable quadrature error checking on the encoder and seeing if
you get errors, that is set
hm2_CARD.0.encoder.NN.quad-error-enable
 true in halshow
and monitor
(CARD is the mesa card name and NN is the encoder number)
  • CallumRD1
  • CallumRD1
24 May 2025 23:12
Category: Qtvcp
It doesn't seem to be working. Do I need to call that python file somewhere?
  • spincycle
  • spincycle
24 May 2025 22:44
Replied by spincycle on topic Weiler 160 CNC Retrofit
Category: Show Your Stuff
Hi Klopp,
That's a beautiful machine!
Looking forward to seeing the end result.
j
  • zz912
  • zz912's Avatar
24 May 2025 22:35
versa-probe vs probe_screen_v2.9 was created by zz912
Category: Gmoccapy
I dont have any experience with probe screen.
I don't know where to start. I found two sources:
1) Data in source codes:
lib/python/gladevcp/builtin-panels/versa-probe
github.com/LinuxCNC/linuxcnc/tree/master...n-panels/versa-probe
I don't know if it's possible to open it in Gmoccapy. And how?
2) Individual project:
github.com/verser-git/probe_screen_v2.9
What is better?
  • Philip Lydin
  • Philip Lydin
24 May 2025 22:20
Replied by Philip Lydin on topic el5151 reseting counts
Category: EtherCAT
Thank you! That fixed it:)
  • jimboh2
  • jimboh2
24 May 2025 21:30
Replied by jimboh2 on topic Linuxcnc wood lathe insufficient torque
Thanks rodw, I had ordered a DM542 from Steppersonline and it arrived today. Even with the 24v and 270OZ stepper and DM542 set at 3A I now have plenty of torque. Problem solved. I guess the TB6600s weren't up to the task.
  • pgf
  • pgf
24 May 2025 21:22
Pause the program and stop the spindle in the middle of the program.
slightly off topic but related, A fun addition I made to our Gui.
Added a button that when you pause a program it appears. Saves the current position, current spindle speed, does a safe z move, switches to manual mode so you can jog.
satiowadahc hasn't been on the forum in a couple of years.  Anyone know what UI they were talking about?
I'd love to have exactly that feature.  The other day I was pretty sure my vacuum had clogged, since the pockets I was carving were completely full of sawdust about 3/4 of the way through the job.  If I could have, I'd have paused, done some hand vacuuming, and then kept going.  Other times I've thought, "sure wish I could recheck the positioning of that clamp", sometime after the job has started.
24 May 2025 21:04
Replied by tommylight on topic Retrofit Gildemeister ct40
OUCH! 25KW DC motor... you win! :) I have a 11KW one on a Mazak lathe.
If the drive is working, i would not change it, well i did not change mine, so
-K332 is relay contact for enabling the drive
-Sollwert should be the analog +-10V input
There are other things there, but for now if the rest of the installation is OK, that should be it.
You would need an analog Mesa card like 7i97T or 7i92TM with 7i77, or some other combination.
In general, i use the old drives and motors whenever possible.
24 May 2025 20:56
Replied by tommylight on topic sanmotion rs2a03a0al0w00
Category: Driver Boards
I would try to use them for sure, they are very good quality drives and new cost an arm and a leg, so try finding some used motors that work with these drives, for a reasonable price if possible.
Mind the encoder type.
Displaying 15481 - 15495 out of 16340 results.
Time to create page: 0.315 seconds
