  • DonatasO
  • DonatasO
17 May 2025 12:21 - 17 May 2025 12:33
G53 not ignoring tool length offset after a Python M6 remap
I'm writing an M6 remap in Python and encountered strange and dangerous behavior. After the first M6 call, G53 G0 takes into account the tool length offset, which should not be happening.
I'm unsure if I'm doing something wrong or if this is a bug in LinuxCNC. I hope you can help me clarify and resolve it.
LinuxCNC version: 2.9.4
UI (probably irrelevant): qtdragon_hd
This is a minimal working code to reproduce the issue:
# REMAP=M6 modalgroup=6 prolog=change_prolog python=is_this_a_bug epilog=change_epilog
def is_this_a_bug(self):
    if self.task == 0:  # ignore the preview interpreter
        return INTERP_OK
    emccanon.CHANGE_TOOL_NUMBER(self.selected_pocket)
    yield INTERP_EXECUTE_FINISH
    pose = EmcPose()
    pose.z = -50
    emccanon.USE_TOOL_LENGTH_OFFSET(pose)
    yield INTERP_OK
Steps to reproduce the issue:
  • Turn on and home the machine
  • T6 M6: the tool is loaded and offsets are set correctly.
  • G53 G0 Z0: the spindle rapids down to -50mm. This is not expected.
  • G49: cancel tool length compensation.
  • G43: enable tool length compensation
  • G53 G0 Z: the spindle rapids back up to zero. This is expected.
The issue can no longer be reproduced by issuing T6 M6, everything works correctly.
Attaching debug logs for each command:
T6 M6
Warning: Spoiler!
G53 G0 Z0
Warning: Spoiler!
G49
Warning: Spoiler!
G43
Warning: Spoiler!
G53 G0 Z0
Warning: Spoiler!
  • JT
  • JT's Avatar
17 May 2025 11:54
linux cnc keeps bending shortcutting to the next line.
It's important to understand how Linuxcnc follows the programmed path.
linuxcnc.org/docs/stable/html/user/user-concepts.html
Note that G64 Blend Without Tolerance Mode is the default
A good preamble should always be the first line of any nc code program.
gnipsel.com/linuxcnc-old/g-code/gen01.html
JT
  • Sternfox
  • Sternfox
17 May 2025 11:38 - 17 May 2025 11:49
Mill as lathe with probebasic was created by Sternfox
Category: QtPyVCP
Hey peeps.
I have A couple of questions. I want to use my mill as a cnc lathe.
Can I have pb turn and mill on seperate profiles?
And can pb turn utilise 3 axis? I need the third to line up the work and to change tools which I will have in the vice.
The other option is using a custom post in fusion but im guessing thats way more complicated.
Thoughts?
Much appreciated
  • rodw
  • rodw's Avatar
17 May 2025 11:28
Replied by rodw on topic Linuxcnc wood lathe insufficient torque
48 volt power supply and DM542A stepper drivers would almost quadruple torque you have now with your same Nema 23's
  • Hakan
  • Hakan
17 May 2025 11:14
Replied by Hakan on topic el5151 reseting counts
Category: EtherCAT
Yes that would be a problem. Linuxcnc asks the encoder to reset the counter to zero and count continuously up/down from there. I don't know any details of this encoder so I guess it is reading the manual to find how that can be done. Luckily Beckhoff has ok manuals.
For velocity you can try the ddt hal function, generate velocity as the derivative of the position. Taking the encoder pin values is limited by the servo loop time and EtherCAT cycle time, anything faster than some hundred Hz will fail.
  • SanzuiWorks
  • SanzuiWorks's Avatar
17 May 2025 09:40 - 21 May 2025 03:45
Replied by SanzuiWorks on topic Manual Toolchange + Abs Z Probe (QtDragon)
Category: Qtvcp
This requires QtDragon to support parsing (MDI_COMMAND, Gxx) output from FILTERs and executing it as an MDI command.
load_wsc_from_ngc.py
import re
import linuxcnc
import os
def on_button_detect_wcs(self):
    filename = STATUS.file
    if not os.path.exists(filename):
        print("G-code file not found.")
        return
    try:
        with open(filename, 'r') as f:
            for line in f:
                m = re.search(r'\bG5(4|5|6|7|8|9)(\.\d)?\b', line.upper())
                if m:
                    g_code = m.group(0)
                    print(f"Detected WCS: {g_code}")
                    c = linuxcnc.command()
                    s = linuxcnc.stat()
                    s.poll()
                    if s.task_state == linuxcnc.STATE_ON and s.interp_state == linuxcnc.INTERP_IDLE:
                        c.mode(linuxcnc.MODE_MDI)
                        c.wait_complete()
                        c.mdi(g_code)
                    else:
                        print("Interpreter not idle. Cannot send MDI.")
                    return
        print("No WCS (G54~G59.3) found.")
    except Exception as e:
        print(f"Error: {e}")
.ini
[FILTER]
PROGRAM_EXTENSION = .ngc G-Code File
FILTER = load_wsc_from_ngc.py .ngc
When you run the program directly, you can obtain the WSC, but it does not run automatically during the NGC loading.
  • aleene
  • aleene
17 May 2025 09:18
Could this board be a contender for a cheap alternative for simple applications?
Category: Driver Boards
Hello
I'm using the same controller and I might be able to assist.
The attached PDF file is all the documentation I received / I could find online.
The board seems to use a custom protocol - not TCP/IP based, I can see the MAC of the controller board.
The current control software is ~ a pain - i need to keep a specific windows 10 virtual machine to run it.
There's no linux support.
I've been thinking for some time to rip it out and replace it with a MESA 7i96S or something similar.
If you think there might  be any interest in this controller, please point me to a list of thing to prepare - protocol capture via wireshark / data dumps between the CPU and the ethernet controller, etc.
  • SanzuiWorks
17 May 2025 09:14 - 17 May 2025 09:17
Category: Qtvcp
This is the first time I've seen the filter function. I need to learn about this first.
  • MarkoPolo
  • MarkoPolo
17 May 2025 09:00
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
Maybe leave it as it is now, but add so that radioButton also works with true/false string for backward compatibility ?
  • cmorley
  • cmorley
  • cmorley
  • cmorley
17 May 2025 06:24
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
I did update the docs but..
Maybe I should set true/false to be radio buttons too and add buttontrue/false.
  • cmorley
  • cmorley
17 May 2025 06:09
Replied by cmorley on topic QTDragon and DTG readout
Category: Qtvcp
You can use an MPG to scroll the gcode graphics and gcode editor and other widgets.
Set the button, touch the widget, the border should change, then it will scroll
You can check it out with the QtDragon_lathe sim
  • cakeslob
  • cakeslob
17 May 2025 04:39 - 17 May 2025 05:34
hey Scott, my homies and i have the environment switching working, but we did a messy job to support a different board we were testing
github.com/cakeslob/Remora-STM32H7xx-PIO/tree/h723
  • cmorley
  • cmorley
17 May 2025 04:09
Category: Qtvcp
overlay DRO can be selected from the options button
  • cmorley
  • cmorley
17 May 2025 04:09
Category: Qtvcp
As a quick solution pull again:
Displaying 15901 - 15915 out of 16345 results.
Time to create page: 0.349 seconds
