  • matasbuk
  • matasbuk
20 Mar 2025 06:11
Replied by matasbuk on topic Blown 7i84
Blown 7i84
Category: Driver Boards
3 phase CB should be 3 pole, not 3 individual 1 pole breakers, to prevent single phasing. I would also recommend installing a phase monitor and connecting to the main contactor to cut power if one phase is lost from the power grid.
  • rodw
  • rodw's Avatar
20 Mar 2025 06:09
2.9.3 - Stuck in wrong state and stops
Category: Plasmac
Reported by a customer. Sometimes, QTP freezes. Moving the float switch by hand seems to clear the error and the cut proceeds.
Any ideas or feedback? I have never experienced this.
I wanted to write a script that updates APT to look at the new Buildbot for 2.10 instead of the Linuxcnc.org 2.94  repo so it looks like I need to do that now....
  • besriworld
  • besriworld
20 Mar 2025 04:36
Replied by besriworld on topic Blown 7i84
Blown 7i84
Yes, I would cut off the pins of the IC too. Even if you have hot air, you can fry the connector.
I think these are reverse diodes. Remove the chip, check with a multimeter for a short, and power up the board.
  • D Jensen
  • D Jensen
20 Mar 2025 04:22
Replied by D Jensen on topic Retrofitting a 1986 Maho MH400E
Category: Milling Machines
Hi Chris,
I've opened mine and I can see how it works. I suspect the vertical and horizontal quills are identical enough that we could swap them.
The bolt with the sleeve is item 2 on the drawing. If you replaced the head of the bolt with a Kipps handle it would work like the vertical clamping handle. So that sleeve will push on the 2 arced pieces like in my photos on page 171, and clamp around the quill.
You have to remove the cover plug to get to the bolt head. Take out the 5mm grub screw and use a normal 5mm bolt to pull it out.Once loose, the quill should be free. Remember to disconnect the hydraulic elbow item 5 at the rear and the feather key underneath the slide item 6. I would think that the quill would slide without removing the front seal system item 4, but it may be full of dirt like mine.
If you look closely you can see the type of markings on the spline they talk about for reassembly. That's on a different spline though.
Looks pretty easy.
Good luck with it,
David
  • unknown
  • unknown
20 Mar 2025 02:35
Replied by unknown on topic Beckhoff KL4032 VFD Spindle speed control
Category: EtherCAT
My old T530 has FireWire, the only thing that'll connect to that I have is a camera.
Interfaces come and go, it's the nature of the beast, think coax for networking, ega,CGA, VGA still seems to be hanging in there, IDE, Floppy, old school wide SCSI.
Tho the industrial serial stuff seems to last, thanks to it being electrically robust.
  • UrKibin
  • UrKibin
20 Mar 2025 01:47
CINCINATTI MILACRON ARROW 500 (BDS4 + VFS5) WITH MESA 7i77 + 6i25 WITH LINUXCNC
Hi PCW,
Noted on this. Ill first wire the enable of mesa 7i77 to the enable of the servo drive bds4 since I found out that there is a difference in bias/balance (adjustment for zero movement upon drive enablement) if I force enable (jumping the enable of the servo drive (Daredevil)) instead of the mesa board.
I'll first connect the ENAn of the 7i77 to the servo drives so that once the drives are enabled, there will be no movement.
After that, will follow your instructions and use 4096 as a scale starting point to fine tune one axis.
Thank you for your advise.
Regards,
Kelvin
20 Mar 2025 01:46
Replied by tommylight on topic Beckhoff KL4032 VFD Spindle speed control
Category: EtherCAT
Eventually they gave up and adopted USB-C. (Oh well..., so much for all that work)
nope, they did not "adopt" it, they were forced by Europe.
20 Mar 2025 01:44
Replied by tommylight on topic halui toggle button
halui toggle button
Category: Basic Configuration
You can do it like this.
loadrt toggle count=5
addf toggle.0 servo-thread
setp toggle.0.debounce 50
net flood-toggle toggle.0.in <= hm2_5i25.0.7i77.0.0.input-29
net flood-control toggle.0.out => hm2_5i25.0.7i77.0.0.output-02
If you need only one toggle, do not use "count=5" as that creates 5 toggles, so that would also need all the addf and setp and inputs and outputs in hal, for all 5, from 0 to 4.
  • bevins
  • bevins's Avatar
20 Mar 2025 00:24
Replied by bevins on topic halui toggle button
halui toggle button
  • gwond
  • gwond
19 Mar 2025 23:51
Koike Aronson Plasma Conversion - sanity check on Mesa board selection?
Thanks for the replies, I should have noted the inhibit logic on the drive itself in my earlier post, but from my interpretation of the datasheet for the 12A8, GND at the input would disable the drive.  Is that correct?
11 INHIBIT IN TTL level (+5 V) inhibit/enable input. Leave open to enable drive. Pull to ground to inhibit drive. Inhibit turns off all power devices.
If so, I would just connect direct to each servo drive with a ground wire connected to the following pins below on the mesa board and then the other side of the floating switch would also go to GND:
net joint-0-enable joint.0.amp-enable-out => hm2_7i97.0.ssr.00.out-00
net joint-1-enable joint.1.amp-enable-out => hm2_7i97.0.ssr.00.out-01
Alternatively, if I could figure out how to make those into one signal with OR'ed logic for turning ON and AND logic for turning off, I would just drive the 12V relay on the board with one output, however, the Estop approach may be the simplest one to implement when reusing the existing PCB.
I'm assuming the Mesa board / LCNC don't care if anything is connected to servo enable as long as the motors move when commanded?  Meaning if the servos were enabled externally via Estop for example, the motion control would still work just fine and I could leave out the above two net commands from the HAL file?
19 Mar 2025 23:26
Category: EtherCAT
No it is not.
FireWire was a very good standard that got killed by corporate greed.
It was also used for networking mainly as interconnect between switches due to it's full duplex speed, besides all DV cameras having it at one point in time.
I liked it and used it plenty, and still have some add on cards rusting away in the shop.
  • tsaG
  • tsaG
19 Mar 2025 22:50
Getting iocontrol.0.tool-prep-pocket to work
I am currently implementing a rack tool changer. My problem is that the Hal Pin "iocontrol.0.tool-prep-pocket" is always Zero. Do I need to activate it in my HAL File? Its currently initialized as following:
net tool-prep-pocket iocontrol.0.tool-prep-pocket
My Tool Table looks as follows:
T1   P1   D+36.000000  Z+7.170534   ; tornado
T2   P2   D+6.000000  Z+22.944468   ; 2F 6*15*50 END Mill Carbide
T4   P3   Z+7.119867   ; 2F 3*12*39 VHM wood (sorotec)
T7   P4   D+4.000000  Z+21.747800   ; 1F 4*15*45 End Mill CARBIDE
T9   P5   D+7.000000  Z+22.959800   ; 3F 4*60 fase
T10  P6   D+4.000000  Z+20.327467   ; 3F 4*90° Fase
T13  P7   D+6.000000  Z+37.369466   ; 2F 6*21*50 VHM wood (sorotec)
T17  P8   Z+24.565134  ; graierer 0.2
T15  P9   D+6.000000  Z+27.896133   ; 2F 6*6*18*50 BB
However, even when inserting Tool1 prep-pocket is always 0. Is there something I am missing?
  • Tntmold
  • Tntmold
19 Mar 2025 22:28
Replied by Tntmold on topic General Questions about using ethercat
Category: EtherCAT
Thank you for the reply. Following the video on this thread, I installed the xml provided by the manufacturer but when I try to run linuxcnc I get the error:
~/linuxcnc/configs/sim.axis$ linuxcnc lathe.ini
LINUXCNC - 2.9.3
Machine configuration directory is '/home/phil/linuxcnc/configs/sim.axis'
Machine configuration file is 'lathe.ini'
Starting LinuxCNC...
libnml/buffer/shmem.cc 320: Shared memory buffers toolCmd and toolCmd may conflict. (key=1004(0x3EC))
libnml/buffer/shmem.cc 320: Shared memory buffers toolSts and toolSts may conflict. (key=1005(0x3ED))
libnml/buffer/shmem.cc 320: Shared memory buffers emcError and emcError may conflict. (key=1003(0x3EB))
Note: Using POSIX realtime
Found file(LIB): /usr/share/linuxcnc/hallib/basic_sim.tcl
setup_kins: cmd=loadrt trivkins coordinates=xz
Found file(REL): ./ethercat.hal
./ethercat.hal:1: lcec_conf exited without becoming ready
LinuxCNC terminated with an error. You can find more information in the log:
/home/phil/linuxcnc_debug.txt
and
/home/phil/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
linuxcnc_debug.txt contains:
13223
Stopping realtime threads
Unloading hal components
Linuxcnc_print.txt contains:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
INIFILE=/home/phil/linuxcnc/configs/sim.axis/lathe.ini
VERSION=1.1
PARAMETER_FILE=sim-lathe.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Z
KINEMATICS=trivkins coordinates=xz
Please help, where do I go from here?
19 Mar 2025 22:02
Replied by tommylight on topic BRIX i7-7557, unexpected guts.
Rod, repeat after me:
latency-histogram --nobase --sbinsize 1000 --show
Always use --show, it is disheartening seeing people here get happy looking at results and totally missing the striped columns on both sides of the graph.
  • rodw
  • rodw's Avatar
19 Mar 2025 21:41
Replied by rodw on topic BRIX i7-7557, unexpected guts.
where you are not using a parallel port run:
latency-histogram --nobase --sbins 1000
for Mesa, the real test is the network latency.
Displaying 17341 - 17355 out of 18507 results.
Time to create page: 0.439 seconds
