  • Nathan40
  • Nathan40
10 Mar 2025 07:03
7i95t pin and firmware files with Stepgens and Inputs 5Axis BoB
Category: Driver Boards
Hi
thanks for your response. The input pin if the 5A BOB has to be inverted. It is giving an error that pin cannot be inverted. Please help.
  • meister
  • meister
10 Mar 2025 06:43
The wiring will work for 3-4Axis mill and for Lathe.
For Lathe you need to set 'LinuxCNC->Machinetype' to lathe
and maybe remove 2 stepdir plugins.
If you need a Spindle-Encoder, you can add it freely to the other free ports.
  • timo
  • timo
10 Mar 2025 05:56
Unable to loop more than 25 times using M98 and L
Category: G&M Codes
It worked here. Running 40 times.
  • PCW
  • PCW's Avatar
10 Mar 2025 02:23
Replied by PCW on topic mesa 7i33 7i37
mesa 7i33 7i37
Pullups and pulldowns are possible on both but only after configuration
Xilinx chips have the added option of pullups before being configured
  • Khan
  • Khan
10 Mar 2025 02:08
Delta VFD-B Modbus with QtDragon_hd
Hello,
i would like to run delta vfd-b over rs485 modbus and integrate with qtdragon hd GUI, can somebody please point me in the right direction i am completely new to linuxcnc,
thanks
  • Lcvette
  • Lcvette's Avatar
10 Mar 2025 01:59
Replied by Lcvette on topic Problems with vcp-template
Category: QtPyVCP
Glad you got a handle on it!
  • vre
  • vre
10 Mar 2025 01:56
halui toggle button was created by vre
halui toggle button
Category: Basic Configuration
I have an external momentary button and i want to toggle between halui.flood.on and halui.flood.off
How can do this config ?
Also i have an output pin that activates lubrication pump and an output pin that activates a solenoid hydraulic valve that releases spindle tool clamp
where in hal must connect it in iocontrol v2 ?
  • vre
  • vre
10 Mar 2025 01:49
Replied by vre on topic mesa 7i33 7i37
mesa 7i33 7i37
7i80hdt that is not xilinx fpga has the pullup only limitation
or can configured both pullup and pulldown with weak internal resistors ?
  • Nserega.90
  • Nserega.90
10 Mar 2025 01:47
Replied by Nserega.90 on topic Problems with vcp-template
Category: QtPyVCP
Thank you! Yes, everything worked out! Your instructions were easier. I'm trying to design)))
10 Mar 2025 01:13
Replied by tommylight on topic Trouble getting a new configuration running.
In the ini file, this:
[TRAJ]
COORDINATES = XYZ
Should be
[TRAJ]
COORDINATES = XXYZ
  • Lik2waterski
  • Lik2waterski
10 Mar 2025 00:56
Trouble getting a new configuration running. was created by Lik2waterski
My old system that my machine works on is axis 2.8.0 running on linux mint 19.3 xfce with linux 4.19.106-rt46-lcnc.
My new system LMDE 6 Faye,
LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7.
I am trying to move a current working configuration to the new computer. My main goal is to add a carousel tool changer. I have deleted all "A axis" stuff just to get the machine working before adding the new configs. My machine has tandem Xaxis for the gantry then Y,Z. but the errors I keep getting are like this
check_config: [JOINT_2]MIN_LIMIT > [AXIS_Z]MIN_LIMIT (-0.001 > -8.0) but Joint 2 isn't Axis Z. My system was set
up X1,joint 0, X2 Joint 1, Y Joint 2, Z joint 3. I will try to attach my ini, file and my Hal. If anyone could help me, I sure would appreciate it. Thank you. Travis
  • unknown
  • unknown
10 Mar 2025 00:54
Custom "MESA 7c81 Clone" PCB featuring a Raspberry Pi Compute Module 5
Funny thing is, the Mesa 7c81 and a stacked RPi look like a more compact solution.
NVME would be nice, the RPi5 with a NVME drive is blazingly fast.
Did you stick with the Mesa fpga pin to 7c81 layout ? Or did you change it to make routing easier ?
If you change things around, especially the clock signal, the SPI_CLK for comms is a little tricky to work out to begin with.
Sorry don't mean to add feature creep, man I wish I could design a simple board for the KSZ8851 Ethernet chip for my mesa clone thingy. So hats off to you Old Chap.
  • REAL ELETRIC
  • REAL ELETRIC
10 Mar 2025 00:47
Replied by REAL ELETRIC on topic MECHATROLINK-II interface
I sent a message to your email to purchase one of these boards.
my email - This email address is being protected from spambots. You need JavaScript enabled to view it.
  • Lcvette
  • Lcvette's Avatar
10 Mar 2025 00:45
Can't succesfully release Tool (according to Probe Basic GUI)
Category: QtPyVCP
changing LT is incorrect. you should instead rewrite the portion of the macro to correctly wait for the available signal. ie use the correct M66 Pn input so the macro verifies the drawbar is in fact in the correct position.
  • unknown
  • unknown
10 Mar 2025 00:42
Raspi 5 touchscreen experience - recommendation
I have this one, used on my mill with a PC platform: Expensive
Planar Pct 2235 22" 1920X1080 Full HD Touch Screen VGA HDMI DISPLAY PORT USB
For the RPi5: Cheap
www.ebay.com.au/itm/225953008741
I would assume if the touchscreen interface is USB you should be fine. Tho the raspberry pi forums maybe a better resource, just look\ask for usb hid compatible touchscreen, stipulate USB HID is the only option.
Displaying 17986 - 18000 out of 18523 results.
Time to create page: 3.780 seconds
