  • Hakan
  • Hakan
04 Mar 2025 23:30
Replied by Hakan on topic Ethercat linuxcnc not seeing any slaves
Category: EtherCAT
Mac address and generic driver.
Two network interfaces and you picked the wrong one? Has never happened to anyone...
Ethercat master prints in /var/log/messages. Have a look there or at the end of the huge output of "sudo dmesg" for signs of why it won't use the network interface
  • ihavenofish
  • ihavenofish
04 Mar 2025 23:13 - 04 Mar 2025 23:22
Replied by ihavenofish on topic Ethercat linuxcnc not seeing any slaves
Category: EtherCAT
so yes, that would have included typing in the MAC in that file per instructions
checked that file again. seems fine. reran enable, start, status... nothing changes.
  • ihavenofish
  • ihavenofish
04 Mar 2025 23:11
Category: EtherCAT
I did only what the instructions said up to the point of typing ethercat slaves.
  • bigmactx
  • bigmactx's Avatar
04 Mar 2025 22:55
Replied by bigmactx on topic LinuxCNC 2.10 build
LinuxCNC 2.10 build
Category: Installing LinuxCNC
Quick update and correction.
It seems that changing the Makefile.inc isn't necessary as it gets rebuilt as part of the run.
So looking at ./debian/configure I see the option for no documents is 'no-docs' and this works.
./debian/configure no-docs
dpkg-buildpackage -b -uc
-b option doesn't seem to matter.
I'll do some more digging into the fortify issue to see if I can find a better solution and to understand the DEBUG question lingering in my miind.
Cheers
  • Hakan
  • Hakan
04 Mar 2025 22:49 - 04 Mar 2025 22:50
Category: EtherCAT
Link down. Did you customize /etc/ethercat.conf ?
  • ihavenofish
  • ihavenofish
04 Mar 2025 22:46 - 04 Mar 2025 22:48
Category: EtherCAT
from ethercat master.... seems maybe its not working at the network card level. What did i break? haha
Master0
Phase: Waiting for device(s)...
Active: no
Slaves: 0
Ethernet devices:
Main: 00:23:24:3e:1b:ba (waiting...)
Link: DOWN
Tx frames: 0
Tx bytes: 0
Rx frames: 0
Rx bytes: 0
Tx errors: 0
Tx frame rate [1/s]: 0 0 0
Tx rate [KByte/s]: 0.0 0.0 0.0
Rx frame rate [1/s]: 0 0 0
Rx rate [KByte/s]: 0.0 0.0 0.0
Common:
Tx frames: 0
Tx bytes: 0
Rx frames: 0
Rx bytes: 0
Lost frames: 0
Loss rate [1/s]: 0 0 0
Frame loss [%]: 0.0 0.0 0.0
Distributed clocks:
Reference clock: None
DC reference time: 0
Application time: 0
2000-01-01 00:00:00.000000000
  • Hakan
  • Hakan
04 Mar 2025 22:39
Category: EtherCAT
Try
ethercat master
ethercat slaves
sudo dmesg
  • ihavenofish
  • ihavenofish
04 Mar 2025 22:37
Ethercat linuxcnc not seeing any slaves was created by ihavenofish
Category: EtherCAT
So, I installed linuxcnc fresh, then began the ethercat install per instruction thread. It *seems* to have worked, but there are no slaves displayed when I type ethercat slaves...
So, for sanity I went into twincat, and it DOES scan the servo drives, however it triggers a communication error of wrong data type. I wonder if the 2 are related and something is set wrong on the drives.
Servos drives are omron R88D
Any thoughts on what may be wrong here?
  • JohnnyCNC
  • JohnnyCNC's Avatar
04 Mar 2025 22:29
Replied by JohnnyCNC on topic Work with probe
Work with probe
Category: Basic Configuration
Glad you got it. I'm using Basic Probe with QTDragon_HD. There is also Probe_Basic and Versa Probe which I think is what you are using. It looks like you are using the GMOCCAPY UI.
  • PCW
  • PCW's Avatar
04 Mar 2025 22:05
Should I just suck it up and buy a good stepper driver?
Category: Driver Boards
All standard MOSFETs have inherent "body" diodes which will function as flybacks
though typically Schottky diodes are added to reduce voltage drop and hence power
dissipation.
  • Daz
  • Daz
04 Mar 2025 22:04 - 04 Mar 2025 22:17
Replied by Daz on topic Work with probe
Work with probe
Found it! And at the end, it was a simple option to tick.
While I was analysing the macro, I came across this lovely if statement:
;Check for refinement measurement
O7 if [#<_hal[probe.chk_use_fine]> GT 0]
And after checking the screen, here it is: "Use refinement measurement". After checking the option, there is a second probing action at probing velocity. Problem solved!
  • Bjornstabo
  • Bjornstabo
04 Mar 2025 22:04
Replied by Bjornstabo on topic Plasmac Post Processors
Category: Plasmac
I am having the same problem with "Radius to end of arc differs from radius to start" with a +90% error rate, using the fusion 360 post. I am able to post out some parts that will run and some that dont. All of theese have previosly been run with no issues on a Mach3 plasma with the same cut settings. Files 1001 and 1005 runs fine. But not 1002 and 1006? Any idea on how to fix this?
  • Daz
  • Daz
04 Mar 2025 21:46
Work with probe
OK, I think I now understand how the macros are structured. Here is the main macro responsible for probing. I am now trying to understand it and debug it. Any help is much appreciated :)
File Name: _psng_probe.ngc
File Size:5 KB
  • bigmactx
  • bigmactx's Avatar
04 Mar 2025 21:36
LinuxCNC 2.10 build
So I found a quick fix for the _FORTIFY_SOURCE errors which is ok specifically for me at least to now but not a good fix for the project.
In the src directory is Makefile line 255:
original line DEBUG := $(DEBUG) -g -Wall -D_FORTIFY_SOURCE=2
modified line DEBUG := $(DEBUG) -g -Wall
in the Makefile.inc file line 114:
original line CPPFLAGS = -Wdate-time -D_FORTIFY_SOURCE=3
modified line CPPFLAGS = -Wdate-time
As I mentioned, this would not be an acceptable fix for generalized distribution as buffer overruns and other security features provided by _FORTIFY_SOURCE are important. It does however get me going for now just fine.
Now I'll dig into the manpage issue with "\S" and see if I can find a workaround for that. Documentation is always a good thing to have.
Thanks to all for help and suggestions.
  • ErwinCNC
  • ErwinCNC
04 Mar 2025 21:23
Installation 2.9.4 Debian Bookworm Preempt-RT ISO // Probleme
Category: Deutsch
Hallo Fraes Paul,
zu 2
bin ebenfalls nur Anfänger in dem Thema habe die letzten Wochen aber einige Zeit mit dem Thema Latenz verbracht.
Vermutlich kennst du die Latenz Videos von TooTall18T?
Hast du deinen Latenz Test unter Last gemacht? Video im Hintergrund, ein paar drehende Zahnräder (glxgears), Fenstergröße mit der Maus langsam ändern, ...
das hatte bei mir einen relativ großen Einfluss im Sinne von schlechteren Latenzwerten.
Mit den Hinweisen aus den Videos habe ich die Latenz deutlich verbessern können aber leider kommt immer noch ab und an die Watchdog Meldung
Grüße Erwin
Displaying 18331 - 18345 out of 18527 results.
Time to create page: 0.529 seconds
