  • unknown
  • unknown
17 Feb 2025 11:04
Replied by unknown on topic (solved) Documentation Hobbing
A lil off topic, but that explains why the images are missing from the wiki.
I too had a look at hobbing a month or 2 ago......but Newstart doesn't allow for that.
  • tftmarco0
  • tftmarco0's Avatar
17 Feb 2025 10:54
Tried every net solution for days to install linuxcnc
Category: Installing LinuxCNC
I totally understand and agree. I didn't know debian13 was out of Bata and now an alpha release. It is good to know that Trixie/Debian13 has Linuxcnc as part of its repos. Also "XFCE or mate is that these are Xorg based desktops which Linuxcnc requires" is very helpful knowledge. Your comments about Realtek makes a lot of sense.
The installation of Trixie/Debian13 was also successful but would not reboot, But I now think you are right about my HDD being the problem all along. It did not pass the "short test" and I found this on the net, "Yes, a faulty disk drive could potentially install a complete operating system but then not be found on reboot" It seemed to weird that all the ISOs I tried would have the same error once they were successfully installed. I am now swapping out the HDD with another one I have, so I can hopefully get Trixie/Debian13/Linuxcnc on the main internal hard drive. I was going to do a bootable USB drive and run it in live mode set to "persist" the settings I made, but that would be slower with the USB bottleneck. Thanks again for everyone's help, I feel this action will solve the mystery issue. I will get back to you all with the conformation if or when it works.
  • haasme
  • haasme
17 Feb 2025 10:28
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Sorry, you are right, the original image is clean. :( my mistake!
  • Mr. Mass
  • Mr. Mass's Avatar
17 Feb 2025 09:36
Replied by Mr. Mass on topic Matrix Keyboard controlling LinuxCNC
Category: Show Your Stuff
Trying to figure out a similar industrial keyboard from SYNTEC. The upper part is a regular PS/2 keyboard, and the lower part is a matrix keyboard with combined LEDs. The buttons on the matrix worked fine, only they are rotated 90 degrees. But there is a strange problem with the LEDs. They are shifted and some of them double. For example, button 0 and LED also 0, work normally. But if we try to light up LED 6, it lights up again 0. And to light up the LED on button 6, it is 12. I checked the wiring several times, everything seems to be correct. Maybe someone can see with fresh eyes what I'm wrong because I'm out of ideas.
  • HalaszAttila
  • HalaszAttila
17 Feb 2025 09:32
Replied by HalaszAttila on topic DMG DMU 50 Retroftiing(?) help
Category: CNC Machines
Hello,
do you have maybe photos of servo motor mounting on X, Y axis? I am interesting in max length of servo motor?
  • Aciera
  • Aciera's Avatar
17 Feb 2025 09:28
Replied by Aciera on topic CoreXY for plasma table.
I'm not familiar with compiling custom kinematics.
There already is a corexy kinematics installed called 'corexykins'
As an alternative there also is a corexy hal component that lets you use trivkins:
forum.linuxcnc.org/10-advanced-configura...kins?start=10#203954
  • unknown
  • unknown
17 Feb 2025 09:22
I don't know why you think you need to update repos. They are setup by the installer to point to the correct repos. I have never seen this mentioned nor have I ever had to do this. The only time you may have to do is when installing a distro that is EOL. That will need to done after booting into the system for the first time.
No I know that grub has not been "left out" I've installed the Linuxcnc iso a number of times. Rod & the guys do a very good & thorough job on, and the guy that does the RPi images has half a brain as well.
From a simple 2 minute search, it would appear HP uefi boot files that uses bootfile names that are tied to some microsoft naming convention. This is not the generally excepted method. There are some guides, search hp whateverhpmodelimusing linux install issues or something along those lines.
To correct the issue you will have to do a complete install, boot with systemrescue cd open a terminal and make the changes. I'd urge you to read the docs relating to the systemrescue cd.
This page may shed some light
moderndevice.com/blogs/documentation/deb...B1VB_YVs8xKHMTlPVRQW
  • rodw
  • rodw's Avatar
17 Feb 2025 09:20
EtherCAT IO and frequency counter for plasma cutter
Yes, it was weird because I have already built a machine with ECT86 drives so knew what was needed.
I have used a few more sdos for homing parameters (5 sdos) and also to configure inputs for homing and estop
  • Aciera
  • Aciera's Avatar
17 Feb 2025 08:52
Replied by Aciera on topic Mill ATC Help needed.
Category: Basic Configuration
I'm not really familiar with ATC remaps but maybe try adding this loop to your hal:
net tool-prep-loop iocontrol.0.tool-prepare iocontrol.0.tool-prepared
  • rodw
  • rodw's Avatar
17 Feb 2025 08:42
Replied by rodw on topic StepperOnline A6 Servo
Category: EtherCAT
I have not yet got a working custom homing component but I am back working on it. Basically over the weekend I threw in a bunch of pins with a view to eliminating the cia402 component. I think I will modify that so it has a parameter that bypasses all homing features of cia402.comp. I have not connected anything to hal.
github.com/rodw-au/cia402_homecomp
  • rodw
  • rodw's Avatar
17 Feb 2025 08:29
To say Trixie is unreliable is untrue, particularly when it now an alpha release. The reason why Trixie was recommended is that it has a current version of Linuxcnc in its repos and you may have needed later drivers. The reason why I said to use XFCE or mate is that these are Xorg  based desktops which Linuxcnc requires. Wayland desktops are problematic for Linuxcnc.
But when you see the messages about Realtek, this is because you do not have a useable HDD and the system is looking to boot off the network somewhere through the Realtek network interface. You don't wnt this.
The sad part about your issues is that it is due to you not having a suitable HDD/SSD installed on your system, My recommendation would be to go and buy a new SSD and install that in your PC as clearly something is wrong.
  • MTTI
  • MTTI's Avatar
17 Feb 2025 08:16
Replied by MTTI on topic New and Working RTAI debs for 2.9
Thanks for this answer.
I would like to install RTAI due to the jitter in my setup, which is around 70k.
I'm using 4 stepper motors with encoders (closed loop) and a USC board from PICO.
Sometimes, though not very often, I get an "Unexpected realtime delay" message.
Do you think this could be related to the jitter amount?
I've tried every optimization I could find in the BIOS...
Just having a look at the PICO config, is the base thread used ? From a quick look nothing appears to attach to the base thread. Which would lead me to think that a simple RT_PREEMPT kernel would be suffice. The PICO board would seem to operate in a simialr way to a mesa 7i90 using the EPP protocol. IE using the parallel port to send timing info to a FPGA.
You're right, into the HAL file, there is only mention of servo-thread:
# Generated by stepconf 1.1 at Tue Jan 28 10:21:07 2025
# Si vous modifiez ce fichier, il sera
# écrasé quand vous relancerez Stepconf
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[TRAJ]SPINDLES
# next load the PID module, for four PID loops
loadrt pid num_chan=4
loadrt  plasmac
loadrt hal_ppmc epp_dir=1
# make some signals for the scope for tuning.
loadrt ddt count=4
# add components for E-stop logic
loadrt estop_latch count=1
loadrt and2 count=1
# set up the realtime thread
# read inputs first
addf ppmc.0.read servo-thread
# then run the motion controller
addf and2.0 servo-thread
addf estop-latch.0 servo-thread
# then the PID loops
addf pid.0.do-pid-calcs servo-thread
addf pid.1.do-pid-calcs servo-thread
addf pid.2.do-pid-calcs servo-thread
addf pid.3.do-pid-calcs servo-thread
# write outputs last
addf ppmc.0.write servo-thread
# ---PLASMA INPUT DEBOUNCE---
loadrt dbounce names=db_breakaway,db_float,db_ohmic,db_arc-ok
addf db_float     servo-thread
addf db_ohmic     servo-thread
addf db_breakaway servo-thread
addf db_arc-ok    servo-thread
# ---JOINT ASSOCIATED WITH THE Z AXIS---
net plasmac:axis-position joint.2.pos-fb => plasmac.axis-z-position
# ---PLASMA INPUTS---
# ---all modes---
net plasmac:float-switch   => db_float.in
net plasmac:breakaway      => db_breakaway.in
net plasmac:ohmic-probe    => db_ohmic.in
net plasmac:ohmic-sense-in   => plasmac.ohmic-sense-in
# ---modes 0 & 1
net plasmac:arc-voltage-in => plasmac.arc-voltage-in
# ---modes 1 & 2
net plasmac:arc-ok-in      => db_arc-ok.in
# ---mode 2
net plasmac:move-up        => plasmac.move-up
net plasmac:move-down      => plasmac.move-down
# ---PLASMA OUTPUTS---
# ---all modes---
net plasmac:ohmic-enable   <= plasmac.ohmic-enable
net plasmac:scribe-arm     <= plasmac.scribe-arm
net plasmac:scribe-on      <= plasmac.scribe-on
# connect limit/home switch outputs to motion controller
net Xminlim <= ppmc.0.din.01.in
net Xminlim => joint.0.neg-lim-sw-in
net Xmaxlim <= ppmc.0.din.02.in
net Xmaxlim => joint.0.pos-lim-sw-in
net Xhome <= ppmc.0.din.00.in
net Xhome => joint.0.home-sw-in
net Yminlim <= ppmc.0.din.05.in
net Yminlim => joint.1.neg-lim-sw-in
net Ymaxlim <= ppmc.0.din.06.in
net Ymaxlim => joint.1.pos-lim-sw-in
net Yhome <= ppmc.0.din.04.in
net Yhome => joint.1.home-sw-in
net Zminlim <= ppmc.0.din.09.in
net Zminlim => joint.2.neg-lim-sw-in
net Zmaxlim <= ppmc.0.din.10.in
net Zmaxlim => joint.2.pos-lim-sw-in
net Zhome <= ppmc.0.din.08.in
net Zhome => joint.2.home-sw-in
net Aminlim <= ppmc.0.din.12.in
net Aminlim => joint.3.neg-lim-sw-in
net Amaxlim <= ppmc.0.din.13.in
net Amaxlim => joint.3.pos-lim-sw-in
net Ahome <= ppmc.0.din.11.in
net Ahome => joint.3.home-sw-in
# connect index pulses to motion controller
# uncomment these lines only if you have a Rev 2 USC board
# newsig Xindex bit
# newsig Yindex  bit
# newsig Zindex bit
# newsig Aindex bit
# linksp Xindex <= ppmc.0.encoder.00.index-enable
# linksp Xindex => joint.0.index-enable
# linksp Yindex <= ppmc.0.encoder.01.index-enable
# linksp Yindex => joint.1.index-enable
# linksp Zindex <= ppmc.0.encoder.02.index-enable
# linksp Zindex => joint.2.index-enable
# linksp Aindex <= ppmc.0.encoder.03.index-enable
# linksp Aindex => joint.3.index-enable
# Connect I/O controller I/Os
# connect e-stop write/sense to I/O controller
# and univstep's fault with estop's output, so  estop FF is reset, but
#      prevent continued estop signal from univstep from holding FF cleared
net ppmcEstop ppmc.0.din.15.in-not
net ppmcEstop and2.0.in0
net EstopOkIn estop-latch.0.fault-in
net EstopOkIn and2.0.out
net EstopOkOut <= ppmc.0.dout.07.out
net EstopOkOut iocontrol.0.emc-enable-in
net EstopOkOut estop-latch.0.ok-out
net EstopOkOut and2.0.in1
net emc-estop-out iocontrol.0.user-enable-out
net emc-estop-out estop-latch.0.ok-in
net emc-estop-reset iocontrol.0.user-request-enable
net emc-estop-reset estop-latch.0.reset
# connect spindle fwd/rev to I/O controller
net SpindleFwd <= ppmc.0.dout.00.out
net SpindleFwd => spindle.0.forward
net SpindleRev <= ppmc.0.dout.01.out
net SpindleRev => spindle.0.reverse
# connect spindle brake to I/O controller
net SpindleBrakeOn <= ppmc.0.dout.02.out
net SpindleBrakeOn => spindle.0.brake
# connect mist/flood coolant to I/O controller
net MistOn <= ppmc.0.dout.03.out
net MistOn => iocontrol.0.coolant-mist
net FloodOn <= ppmc.0.dout.04.out
net FloodOn => iocontrol.0.coolant-flood
# connect position feedback signals to encoders
net Xpos-fb <= ppmc.0.encoder.00.position
net Ypos-fb <= ppmc.0.encoder.01.position
net Zpos-fb <= ppmc.0.encoder.02.position
net Apos-fb <= ppmc.0.encoder.03.position
# get feedback scaling from ini file
setp ppmc.0.encoder.00.scale [JOINT_0]INPUT_SCALE
setp ppmc.0.encoder.01.scale [JOINT_1]INPUT_SCALE
setp ppmc.0.encoder.02.scale [JOINT_2]INPUT_SCALE
setp ppmc.0.encoder.03.scale [JOINT_3]INPUT_SCALE
# connect PID output signals to step generators
net Xoutput => ppmc.0.stepgen.00.velocity
net Youtput => ppmc.0.stepgen.01.velocity
net Zoutput => ppmc.0.stepgen.02.velocity
net Aoutput => ppmc.0.stepgen.03.velocity
# connect axis enables to step generators
net Xenable => ppmc.0.stepgen.00.enable
net Yenable => ppmc.0.stepgen.01.enable
net Zenable => ppmc.0.stepgen.02.enable
net Aenable => ppmc.0.stepgen.03.enable
# set output scaling from ini file
# input and output scales should (normally) be the same for a USC
setp ppmc.0.stepgen.00.scale [JOINT_0]OUTPUT_SCALE
setp ppmc.0.stepgen.01.scale [JOINT_1]OUTPUT_SCALE
setp ppmc.0.stepgen.02.scale [JOINT_2]OUTPUT_SCALE
setp ppmc.0.stepgen.03.scale [JOINT_3]OUTPUT_SCALE
# add a couple of tuning test links
# if these are useful will want to add them to the other axes as well
# or make these setup with the tuning script
# net Xoutput ddt.0.in
# net Xpos-fb ddt.1.in
# HAL config file for servos -- expanded from core_servo.hal
# for a full four axis setup
# create four position feedback signals
# connect position feedback to PID loop
net Xpos-fb => pid.0.feedback
net Ypos-fb => pid.1.feedback
net Zpos-fb => pid.2.feedback
net Apos-fb => pid.3.feedback
# connect position feedback to motion module
net Xpos-fb => joint.0.motor-pos-fb
net Ypos-fb => joint.1.motor-pos-fb
net Zpos-fb => joint.2.motor-pos-fb
net Apos-fb => joint.3.motor-pos-fb
# create PID to DAC output signals
# connect output signals to output of PID loops
net Xoutput <= pid.0.output
net Youtput <= pid.1.output
net Zoutput <= pid.2.output
net Aoutput <= pid.3.output
# set PID loop output limits to +/-1.00
setp pid.0.maxoutput [JOINT_0]PID_MAX_VEL
setp pid.1.maxoutput [JOINT_1]PID_MAX_VEL
setp pid.2.maxoutput [JOINT_2]PID_MAX_VEL
setp pid.3.maxoutput [JOINT_3]PID_MAX_VEL
# set PID loop gains
setp pid.0.Pgain [JOINT_0]P
setp pid.0.Igain [JOINT_0]I
setp pid.0.Dgain [JOINT_0]D
setp pid.0.bias [JOINT_0]BIAS
setp pid.0.FF0 [JOINT_0]FF0
setp pid.0.FF1 [JOINT_0]FF1
setp pid.0.FF2 [JOINT_0]FF2
setp pid.0.deadband [JOINT_0]DEADBAND
setp pid.1.Pgain [JOINT_1]P
setp pid.1.Igain [JOINT_1]I
setp pid.1.Dgain [JOINT_1]D
setp pid.1.bias [JOINT_1]BIAS
setp pid.1.FF0 [JOINT_1]FF0
setp pid.1.FF1 [JOINT_1]FF1
setp pid.1.FF2 [JOINT_1]FF2
setp pid.1.deadband [JOINT_1]DEADBAND
setp pid.2.Pgain [JOINT_2]P
setp pid.2.Igain [JOINT_2]I
setp pid.2.Dgain [JOINT_2]D
setp pid.2.bias [JOINT_2]BIAS
setp pid.2.FF0 [JOINT_2]FF0
setp pid.2.FF1 [JOINT_2]FF1
setp pid.2.FF2 [JOINT_2]FF2
setp pid.2.deadband [JOINT_2]DEADBAND
setp pid.3.Pgain [JOINT_3]P
setp pid.3.Igain [JOINT_3]I
setp pid.3.Dgain [JOINT_3]D
setp pid.3.bias [JOINT_3]BIAS
setp pid.3.FF0 [JOINT_3]FF0
setp pid.3.FF1 [JOINT_3]FF1
setp pid.3.FF2 [JOINT_3]FF2
setp pid.3.deadband [JOINT_3]DEADBAND
# create four position command signals
# connect position commands to motion controller
net Xpos-cmd <= joint.0.motor-pos-cmd
net Ypos-cmd <= joint.1.motor-pos-cmd
net Zpos-cmd <= joint.2.motor-pos-cmd
net Apos-cmd <= joint.3.motor-pos-cmd
# connect position commands to PID input
net Xpos-cmd => pid.0.command
net Ypos-cmd => pid.1.command
net Zpos-cmd => pid.2.command
net Apos-cmd => pid.3.command
# create bit signals to enable/disable the PID loops
# connect the signals to the motion controller
net Xenable <= joint.0.amp-enable-out
net Yenable <= joint.1.amp-enable-out
net Zenable <= joint.2.amp-enable-out
net Aenable <= joint.3.amp-enable-out
# connect the signals to the PID blocks
net Xenable => pid.0.enable
net Yenable => pid.1.enable
net Zenable => pid.2.enable
net Aenable => pid.3.enable
But i'm not an expert in this type of configuration...
  • Aciera
  • Aciera's Avatar
17 Feb 2025 08:01
Replied by Aciera on topic 3D plot: Cannot probe with zero feedrate
The issue is caused by the part with the g38 command as that is where the error message comes from. So you would only call 'tool_touch_off.ngc' when #<_task> EQ 1
  • MTTI
  • MTTI's Avatar
17 Feb 2025 07:51
Are you hitting 70K microseconds on RTAI or PREEMPT_RT?
Just in case, here are the options I've found to help:
github.com/NTULINUX/RTAI/blob/master/README.BIOS
I only hit 70k jitter occasionally and only when the CPU usage is high, for example when running multiples GLXGEARS, playing HD videos on YouTube... Otherwise, my jitter stays around 50k.
I'm using PREEMPT_RT because RTAI doesn't work at all, even the latency test freezes the computer.
Thanks for the link, I already found it along with many others.
  • tftmarco0
17 Feb 2025 07:00
I thought this install page was just for desktop cosmetic stuff, but it also has "standard system utilities" as a checked default. I am just trying to be sure how important these settings are.
"Grub is the boot loader, this is where your issue is." Do you think the Grub boot loader was not in any of the ISO installs I tried? If so, why would it be left out since it is required to to have a successful install? Are you saying that if the Grub boot loader was left out, it would prevent my system from detecting any hard drive with a successful installation?
Do you feel that HP is preventing Linux software from installing?
"If you turn on legacy boot and disable secure boot, as tommy mentioned a while back this may resolve your problem."
I did try this suggestion before I joined this forum. It is a good suggestion offered on the net. I will keep trying every setting because I get suggestions to try this setting in different ways,
Displaying 18901 - 18915 out of 19203 results.
Time to create page: 1.683 seconds
