New and Working RTAI debs for 2.9
- Onrddd
20 Dec 2024 12:59 #317039
by Onrddd
Replied by Onrddd on topic New and Working RTAI debs for 2.9
Hi everyone, total noob here. I'm experinenting the linuxcnc. I have an asrock j3355b board. I'm planning to use it with parallel port. I tried to install debian and linux cnc 2.9.2 but I cannot solve the kernel issue. When I install debian 12 it comes with kernel 6.x.x and all the RTAI kernel and other stuff is for kernel 5.4. as I understand that kernel and RTAI packages needs to be same. How do you install debian 12 RTAI, please help or direct me to correct direction.
- Elco
- Thank you received: 3
20 Dec 2024 15:43 #317044
by Elco
Replied by Elco on topic New and Working RTAI debs for 2.9
I assume that this procedure does not work when starting with a clean version of LMDE6? I tried on several systems, but I get long lists with missing python modules and the grub menu does not work.
Regards, Rob
Regards, Rob
- Elco
24 Dec 2024 14:48 - 25 Dec 2024 08:52 #317285
by Elco
After installation of the 5.4.279 rtai kernel + the matching Lcnc version and a reboot, applying rt_setup and rebooting again,
starting a the axis demo for the first time often causes the system to hang or the run to abort with errors.
This happened with about 7 tries on two different systems (a 4 core Intel - isolcpu=3 and a 6 core AMD - isolcpu=2,3,5).
Info attached, as well as a run of the RTAI testsuite (odt file).
The second start of the axis demo gives an RTAI warning, but ignoring that the demo works perfectly to the end.
Running the latency test for the first time usually shows permanent 0's for both fast clock and servo.
Starting the second time it works, but the servo thread is always 999725 at start, but clearing that both values stay below 10000 with multiple gears and browsing.
Edit: Any suggestions what is wrong here?
Thanks.
Robert
Thanks.
Robert
Last edit: 25 Dec 2024 08:52 by Elco.
- MTTI
- Thank you received: 6
16 Feb 2025 21:18 - 16 Feb 2025 21:19 #321772
by MTTI
Replied by MTTI on topic New and Working RTAI debs for 2.9
Hello,
I installed the debs in the pinned link (5.4.279) on fresh Debian 12 and booted on this kernel but when I launch LinuxCNC or even Latency test, the computer freeze...
I tried to disable many things in the BIOS...
I tried on another computer and it works, so I think this is hardware related...
sudo lscpu:
sudo lscpu:
Architecture : x86_64
Mode(s) opératoire(s) des processeurs : 32-bit, 64-bit
Tailles des adresses: 39 bits physical, 48 bits virtual
Boutisme : Little Endian
Processeur(s) : 4
Liste de processeur(s) en ligne : 0-3
Identifiant constructeur : GenuineIntel
Identifiant constructeur du BIOS : Intel(R) Corporation
Nom de modèle : Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
Nom de modèle BIOS : Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz To Be Filled By O.E.M. CPU @ 1.7GHz
Famille de processeur BIOS : 198
Famille de processeur : 6
Modèle : 142
Thread(s) par cœur : 1
Cœur(s) par socket : 4
Socket(s) : 1
Révision : 10
multiplication des MHz du/des CPU(s) : 99%
Vitesse maximale du processeur en MHz : 1800,0000
Vitesse minimale du processeur en MHz : 400,0000
BogoMIPS : 3999,93
Drapeaux : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp
lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl est tm2 ssse3 s
dbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb i
nvpcid_single pti ssbd ibrs ibpb stibp fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsave
c xgetbv1 xsaves dtherm arat pln pts hwp hwp_notify hwp_act_window hwp_epp md_clear flush_l1d arch_capabilities
Caches (somme de toutes) :
L1d : 128 KiB (4 instances)
L1i : 128 KiB (4 instances)
L2 : 1 MiB (4 instances)
L3 : 8 MiB (1 instance)
NUMA :
Nœud(s) NUMA : 1
Nœud NUMA 0 de processeur(s) : 0-3
Vulnérabilités :
Gather data sampling : Mitigation; Microcode
Itlb multihit : KVM: Mitigation: VMX unsupported
L1tf : Mitigation; PTE Inversion
Mds : Mitigation; Clear CPU buffers; SMT disabled
Meltdown : Mitigation; PTI
Mmio stale data : Mitigation; Clear CPU buffers; SMT disabled
Reg file data sampling : Not affected
Retbleed : Mitigation; IBRS
Spec rstack overflow : Not affected
Spec store bypass : Mitigation; Speculative Store Bypass disabled via prctl
Spectre v1 : Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Spectre v2 : Mitigation; IBRS; IBPB conditional; RSB filling; PBRSB-eIBRS Not affected; BHI Not affected
Srbds : Mitigation; Microcode
Tsx async abort : Not affected
Do you have any suggestion?
Last edit: 16 Feb 2025 21:19 by MTTI.
- NTULINUX
- Thank you received: 84
16 Feb 2025 23:15 #321781
by NTULINUX
Replied by NTULINUX on topic New and Working RTAI debs for 2.9
MTTI, some systems do not work on RTAI. I tried RTAI on my SO's laptop and it instantly kernel panicked each time.
- MTTI
16 Feb 2025 23:45 #321784
by MTTI
Thanks for this answer.
I would like to install RTAI due to the jitter in my setup, which is around 70k.
I'm using 4 stepper motors with encoders (closed loop) and a USC board from PICO.
Sometimes, though not very often, I get an "Unexpected realtime delay" message.
Do you think this could be related to the jitter amount?
I've tried every optimization I could find in the BIOS...
- NTULINUX
17 Feb 2025 01:32 #321792
by NTULINUX
Are you hitting 70K microseconds on RTAI or PREEMPT_RT?
Just in case, here are the options I've found to help:
github.com/NTULINUX/RTAI/blob/master/README.BIOS
- unknown
- Thank you received: 323
17 Feb 2025 05:26 #321798
by unknown
Replied by unknown on topic New and Working RTAI debs for 2.9
Just having a look at the PICO config, is the base thread used ? From a quick look nothing appears to attach to the base thread. Which would lead me to think that a simple RT_PREEMPT kernel would be suffice. The PICO board would seem to operate in a simialr way to a mesa 7i90 using the EPP protocol. IE using the parallel port to send timing info to a FPGA.Thanks for this answer.
- MTTI
17 Feb 2025 07:51 #321806
by MTTI
I'm using PREEMPT_RT because RTAI doesn't work at all, even the latency test freezes the computer.
Thanks for the link, I already found it along with many others.
I only hit 70k jitter occasionally and only when the CPU usage is high, for example when running multiples GLXGEARS, playing HD videos on YouTube... Otherwise, my jitter stays around 50k.Are you hitting 70K microseconds on RTAI or PREEMPT_RT?
- MTTI
17 Feb 2025 08:16 #321808
by MTTI
But i'm not an expert in this type of configuration...
You're right, into the HAL file, there is only mention of servo-thread:
# Generated by stepconf 1.1 at Tue Jan 28 10:21:07 2025
# Si vous modifiez ce fichier, il sera
# écrasé quand vous relancerez Stepconf
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[TRAJ]SPINDLES
# next load the PID module, for four PID loops
loadrt pid num_chan=4
loadrt plasmac
loadrt hal_ppmc epp_dir=1
# make some signals for the scope for tuning.
loadrt ddt count=4
# add components for E-stop logic
loadrt estop_latch count=1
loadrt and2 count=1
# set up the realtime thread
# read inputs first
addf ppmc.0.read servo-thread
# then run the motion controller
addf and2.0 servo-thread
addf estop-latch.0 servo-thread
# then the PID loops
addf pid.0.do-pid-calcs servo-thread
addf pid.1.do-pid-calcs servo-thread
addf pid.2.do-pid-calcs servo-thread
addf pid.3.do-pid-calcs servo-thread
# write outputs last
addf ppmc.0.write servo-thread
# ---PLASMA INPUT DEBOUNCE---
loadrt dbounce names=db_breakaway,db_float,db_ohmic,db_arc-ok
addf db_float servo-thread
addf db_ohmic servo-thread
addf db_breakaway servo-thread
addf db_arc-ok servo-thread
# ---JOINT ASSOCIATED WITH THE Z AXIS---
net plasmac:axis-position joint.2.pos-fb => plasmac.axis-z-position
# ---PLASMA INPUTS---
# ---all modes---
net plasmac:float-switch => db_float.in
net plasmac:breakaway => db_breakaway.in
net plasmac:ohmic-probe => db_ohmic.in
net plasmac:ohmic-sense-in => plasmac.ohmic-sense-in
# ---modes 0 & 1
net plasmac:arc-voltage-in => plasmac.arc-voltage-in
# ---modes 1 & 2
net plasmac:arc-ok-in => db_arc-ok.in
# ---mode 2
net plasmac:move-up => plasmac.move-up
net plasmac:move-down => plasmac.move-down
# ---PLASMA OUTPUTS---
# ---all modes---
net plasmac:ohmic-enable <= plasmac.ohmic-enable
net plasmac:scribe-arm <= plasmac.scribe-arm
net plasmac:scribe-on <= plasmac.scribe-on
# connect limit/home switch outputs to motion controller
net Xminlim <= ppmc.0.din.01.in
net Xminlim => joint.0.neg-lim-sw-in
net Xmaxlim <= ppmc.0.din.02.in
net Xmaxlim => joint.0.pos-lim-sw-in
net Xhome <= ppmc.0.din.00.in
net Xhome => joint.0.home-sw-in
net Yminlim <= ppmc.0.din.05.in
net Yminlim => joint.1.neg-lim-sw-in
net Ymaxlim <= ppmc.0.din.06.in
net Ymaxlim => joint.1.pos-lim-sw-in
net Yhome <= ppmc.0.din.04.in
net Yhome => joint.1.home-sw-in
net Zminlim <= ppmc.0.din.09.in
net Zminlim => joint.2.neg-lim-sw-in
net Zmaxlim <= ppmc.0.din.10.in
net Zmaxlim => joint.2.pos-lim-sw-in
net Zhome <= ppmc.0.din.08.in
net Zhome => joint.2.home-sw-in
net Aminlim <= ppmc.0.din.12.in
net Aminlim => joint.3.neg-lim-sw-in
net Amaxlim <= ppmc.0.din.13.in
net Amaxlim => joint.3.pos-lim-sw-in
net Ahome <= ppmc.0.din.11.in
net Ahome => joint.3.home-sw-in
# connect index pulses to motion controller
# uncomment these lines only if you have a Rev 2 USC board
# newsig Xindex bit
# newsig Yindex bit
# newsig Zindex bit
# newsig Aindex bit
# linksp Xindex <= ppmc.0.encoder.00.index-enable
# linksp Xindex => joint.0.index-enable
# linksp Yindex <= ppmc.0.encoder.01.index-enable
# linksp Yindex => joint.1.index-enable
# linksp Zindex <= ppmc.0.encoder.02.index-enable
# linksp Zindex => joint.2.index-enable
# linksp Aindex <= ppmc.0.encoder.03.index-enable
# linksp Aindex => joint.3.index-enable
# Connect I/O controller I/Os
# connect e-stop write/sense to I/O controller
# and univstep's fault with estop's output, so estop FF is reset, but
# prevent continued estop signal from univstep from holding FF cleared
net ppmcEstop ppmc.0.din.15.in-not
net ppmcEstop and2.0.in0
net EstopOkIn estop-latch.0.fault-in
net EstopOkIn and2.0.out
net EstopOkOut <= ppmc.0.dout.07.out
net EstopOkOut iocontrol.0.emc-enable-in
net EstopOkOut estop-latch.0.ok-out
net EstopOkOut and2.0.in1
net emc-estop-out iocontrol.0.user-enable-out
net emc-estop-out estop-latch.0.ok-in
net emc-estop-reset iocontrol.0.user-request-enable
net emc-estop-reset estop-latch.0.reset
# connect spindle fwd/rev to I/O controller
net SpindleFwd <= ppmc.0.dout.00.out
net SpindleFwd => spindle.0.forward
net SpindleRev <= ppmc.0.dout.01.out
net SpindleRev => spindle.0.reverse
# connect spindle brake to I/O controller
net SpindleBrakeOn <= ppmc.0.dout.02.out
net SpindleBrakeOn => spindle.0.brake
# connect mist/flood coolant to I/O controller
net MistOn <= ppmc.0.dout.03.out
net MistOn => iocontrol.0.coolant-mist
net FloodOn <= ppmc.0.dout.04.out
net FloodOn => iocontrol.0.coolant-flood
# connect position feedback signals to encoders
net Xpos-fb <= ppmc.0.encoder.00.position
net Ypos-fb <= ppmc.0.encoder.01.position
net Zpos-fb <= ppmc.0.encoder.02.position
net Apos-fb <= ppmc.0.encoder.03.position
# get feedback scaling from ini file
setp ppmc.0.encoder.00.scale [JOINT_0]INPUT_SCALE
setp ppmc.0.encoder.01.scale [JOINT_1]INPUT_SCALE
setp ppmc.0.encoder.02.scale [JOINT_2]INPUT_SCALE
setp ppmc.0.encoder.03.scale [JOINT_3]INPUT_SCALE
# connect PID output signals to step generators
net Xoutput => ppmc.0.stepgen.00.velocity
net Youtput => ppmc.0.stepgen.01.velocity
net Zoutput => ppmc.0.stepgen.02.velocity
net Aoutput => ppmc.0.stepgen.03.velocity
# connect axis enables to step generators
net Xenable => ppmc.0.stepgen.00.enable
net Yenable => ppmc.0.stepgen.01.enable
net Zenable => ppmc.0.stepgen.02.enable
net Aenable => ppmc.0.stepgen.03.enable
# set output scaling from ini file
# input and output scales should (normally) be the same for a USC
setp ppmc.0.stepgen.00.scale [JOINT_0]OUTPUT_SCALE
setp ppmc.0.stepgen.01.scale [JOINT_1]OUTPUT_SCALE
setp ppmc.0.stepgen.02.scale [JOINT_2]OUTPUT_SCALE
setp ppmc.0.stepgen.03.scale [JOINT_3]OUTPUT_SCALE
# add a couple of tuning test links
# if these are useful will want to add them to the other axes as well
# or make these setup with the tuning script
# net Xoutput ddt.0.in
# net Xpos-fb ddt.1.in
# HAL config file for servos -- expanded from core_servo.hal
# for a full four axis setup
# create four position feedback signals
# connect position feedback to PID loop
net Xpos-fb => pid.0.feedback
net Ypos-fb => pid.1.feedback
net Zpos-fb => pid.2.feedback
net Apos-fb => pid.3.feedback
# connect position feedback to motion module
net Xpos-fb => joint.0.motor-pos-fb
net Ypos-fb => joint.1.motor-pos-fb
net Zpos-fb => joint.2.motor-pos-fb
net Apos-fb => joint.3.motor-pos-fb
# create PID to DAC output signals
# connect output signals to output of PID loops
net Xoutput <= pid.0.output
net Youtput <= pid.1.output
net Zoutput <= pid.2.output
net Aoutput <= pid.3.output
# set PID loop output limits to +/-1.00
setp pid.0.maxoutput [JOINT_0]PID_MAX_VEL
setp pid.1.maxoutput [JOINT_1]PID_MAX_VEL
setp pid.2.maxoutput [JOINT_2]PID_MAX_VEL
setp pid.3.maxoutput [JOINT_3]PID_MAX_VEL
# set PID loop gains
setp pid.0.Pgain [JOINT_0]P
setp pid.0.Igain [JOINT_0]I
setp pid.0.Dgain [JOINT_0]D
setp pid.0.bias [JOINT_0]BIAS
setp pid.0.FF0 [JOINT_0]FF0
setp pid.0.FF1 [JOINT_0]FF1
setp pid.0.FF2 [JOINT_0]FF2
setp pid.0.deadband [JOINT_0]DEADBAND
setp pid.1.Pgain [JOINT_1]P
setp pid.1.Igain [JOINT_1]I
setp pid.1.Dgain [JOINT_1]D
setp pid.1.bias [JOINT_1]BIAS
setp pid.1.FF0 [JOINT_1]FF0
setp pid.1.FF1 [JOINT_1]FF1
setp pid.1.FF2 [JOINT_1]FF2
setp pid.1.deadband [JOINT_1]DEADBAND
setp pid.2.Pgain [JOINT_2]P
setp pid.2.Igain [JOINT_2]I
setp pid.2.Dgain [JOINT_2]D
setp pid.2.bias [JOINT_2]BIAS
setp pid.2.FF0 [JOINT_2]FF0
setp pid.2.FF1 [JOINT_2]FF1
setp pid.2.FF2 [JOINT_2]FF2
setp pid.2.deadband [JOINT_2]DEADBAND
setp pid.3.Pgain [JOINT_3]P
setp pid.3.Igain [JOINT_3]I
setp pid.3.Dgain [JOINT_3]D
setp pid.3.bias [JOINT_3]BIAS
setp pid.3.FF0 [JOINT_3]FF0
setp pid.3.FF1 [JOINT_3]FF1
setp pid.3.FF2 [JOINT_3]FF2
setp pid.3.deadband [JOINT_3]DEADBAND
# create four position command signals
# connect position commands to motion controller
net Xpos-cmd <= joint.0.motor-pos-cmd
net Ypos-cmd <= joint.1.motor-pos-cmd
net Zpos-cmd <= joint.2.motor-pos-cmd
net Apos-cmd <= joint.3.motor-pos-cmd
# connect position commands to PID input
net Xpos-cmd => pid.0.command
net Ypos-cmd => pid.1.command
net Zpos-cmd => pid.2.command
net Apos-cmd => pid.3.command
# create bit signals to enable/disable the PID loops
# connect the signals to the motion controller
net Xenable <= joint.0.amp-enable-out
net Yenable <= joint.1.amp-enable-out
net Zenable <= joint.2.amp-enable-out
net Aenable <= joint.3.amp-enable-out
# connect the signals to the PID blocks
net Xenable => pid.0.enable
net Yenable => pid.1.enable
net Zenable => pid.2.enable
net Aenable => pid.3.enable
Time to create page: 0.251 seconds
