New and Working RTAI debs for 2.9
- JT
- Thank you received: 593
08 Jul 2024 16:15 #304677
by JT
Replied by JT on topic New and Working RTAI debs for 2.9
I left the PC running and when I came back I lost menu, mouse and LinuxCNC. I installed Debian 12 and used the Mate desktop if that makes any difference.
This is what Tom got.
paste.debian.net/1322599/
paste.debian.net/1322600/
paste.debian.net/1322601/
- JT
08 Jul 2024 16:26 #304678
by JT
I just rebooted and no menu or panel, I can get a terminal using Ctrl Alt t and LinuxCNC from the terminal.
- NTULINUX
- Thank you received: 84
08 Jul 2024 16:39 #304680
by NTULINUX
Replied by NTULINUX on topic New and Working RTAI debs for 2.9
Sometimes it takes a few minutes for the panel and menu to load, I'm not sure why but I've noticed this with custom kernels on Debian.
As for the segfaults, I have an idea but it'd require new kernel debs..
- JT
08 Jul 2024 16:44 - 08 Jul 2024 20:51 #304682
by JT
Well I booted to the other HD running uspace and no menu or panel there.
I turned it off and walked away and now both RTAI and Uspace "seem" normal.
JT
JT
Last edit: 08 Jul 2024 20:51 by JT.
- Mecanix
- Thank you received: 229
08 Jul 2024 23:57 #304712
by Mecanix
I'm going to upgrade to latest in that case. Are we good to use the OP/Bari's release? ( onelaboratories.us/rtai_lcnc/ ). Or these needs to be dwloaded from somewhere else?
Replied by Mecanix on topic New and Working RTAI debs for 2.9
That's awesome to hear. Couldn't have hope more for you to recompile RTAI with the latest commits... was shy to ask as this is voluntary based. And so thanks again x1000 for that. ps. few bugs from the initial 2.9 release that were annoying in that Dec '23, although nothing that can't be easily managed. Pretty epic and low latency controller regardless!The LinuxCNC debs are the latest git checkout of the 2.9 branch as of a few days ago with some minor modifications.
List of changes:
github.com/NTULINUX/linuxcnc-rtai/commits/ntulinux/2.9-rtai/
Hey, I just wanted to say thanks to everyone testing these out and being part of the RTAI project. I spent a lot of time on RTAI and making improvements over the years and it's great to see that it's still very much alive and kicking in LinuxCNC.
- NTULINUX
09 Jul 2024 01:08 - 09 Jul 2024 01:27 #304716
by NTULINUX
There seems to be an issue with segfaults that are popping up with these debs. I want to try and fix these, and I'll be bumping the 5.4 kernel patch series to the latest from kernel.org as well. You're free to try the debs posted but they might be updated again soon.
Last edit: 09 Jul 2024 01:27 by NTULINUX.
The following user(s) said Thank You: tommylight, JT, Mecanix
- Mecanix
09 Jul 2024 03:35 - 09 Jul 2024 03:37 #304721
by Mecanix
Standby and awaiting your go ahead. Too kind man.
I really hope I'd have your knowledge and be able to help in any way. If testing is required, shout out and hopefully I'll be able to help out that way.
Last edit: 09 Jul 2024 03:37 by Mecanix.
- Bari
- Thank you received: 234
10 Jul 2024 03:03 #304785
by Bari
Replied by Bari on topic New and Working RTAI debs for 2.9
Added another RTAI set to the original post
forum.linuxcnc.org/9-installing-linuxcnc...-debs-for-2-9#304599
The following user(s) said Thank You: NickH
- tlightus
- Thank you received: 19
10 Jul 2024 03:14 - 10 Jul 2024 03:16 #304786
by tlightus
Replied by tlightus on topic New and Working RTAI debs for 2.9
The biggest issue I've found is segfaults when using PYQT (flex) without isolcpus set. Set it and things run smoothly so far with both 5.4.258 and 5.4.279. Still trying to break it...
Last edit: 10 Jul 2024 03:16 by tlightus.
- NTULINUX
10 Jul 2024 03:21 #304787
by NTULINUX
Tom is still having segfaults on his system with the 5.4.279 kernel but this only happens when he doesn't use `isoclpus=n` on the kernel cli. I'm not sure what's triggering it at this point but at least the 5.4 kernel patch series is up to date again.
I also forcibly enabled some basic memory debugging to try and catch some errors there too.
If everything goes OK for the majority of LinuxCNC RTAI users with the 5.4.279 kernel, I'll finally mark a new RTAI stable release.
The following user(s) said Thank You: tlightus, JT, NickH
Time to create page: 0.131 seconds
