  • Jens23
  • Jens23
17 Feb 2025 06:59
Replied by Jens23 on topic 3D plot: Cannot probe with zero feedrate
Thanks for the answer!
The M600 calls this macro: github.com/TooTall18T/tool_length_probe/...n/tool_touch_off.ngc
As this macro uses the "normal" M6, I remapped M6 to my own macro "manuell_atc" (github.com/GameOEver/LinuxCNC/blob/main/manuell_atc.ngc).
M300 and M500 basically add an M64Px to M3/M5 to have a vavle for the ATC spindle turn on and off for the air seal.
I am currently working on an ATC carousel, but it will probably take a few months to get it working. In the meantime I have made a very simple macro that basically turns valves on and off when you press cycle start for release or clamping tools.
If I understand your comment correctly, I would only call my "manuell_atc" macro when #<_task> EQ 1?
  • tftmarco0
  • tftmarco0's Avatar
17 Feb 2025 06:33
Tried every net solution for days to install linuxcnc
Category: Installing LinuxCNC
I am currently trying “rodw” suggestion, I understand that the bata versions or in this case debian13 tend to be less stable than ones like 12 that have been out for awhile. They use them to have a larger sampling of users to identify bugs. It is an old tradition. However, I am trying all suggestions from more experienced linux users and sometimes the next release has fixed the bugs identified in earlier versions.
I did just check HP compatibility. I did not think it could be the problem but it is a good suggestion. My results were
"Linux will work on just about any PC. I mean that literally
It is totally possible to install Linux onto any HP laptop. Try going to the BIOS, by entering the F10 when booting up. In their, try disabling secure boot and switching from UEFI to Legacy BIOS then save your changes"
I will try the BIOS suggestions here but I do believe I have already done that a few times.
The latency test in live mode I will look into but I can't stress it out my system because I don't have it connected to a CNC system yet. I think my dedicated computer is at the high end of the linuxcnc requirements. Also this seem unlikely to be the cause of the issue of the system not finding an install on ether hard drive.
Please be respectful. I am new to Linux but as I understand from the last few days of learning Linux.. The "sudo commands" are used in a live or successfully installed version of Linux software. They are entered in what is called a terminal as a command prompt. User “rodw” would be better to ask about that he recommended I use some. The sudo commands I used in live mode seemed to be related to updating a repository of needed files that were not in the ISO install. Basic system queries like a file search.
Your last remarks were not clear, "buggy uefi and having to rename some boot files." If you have any question I can answer or if you have a suggestion to help solve my issue, I am happy to answer any question or try any possible solution. as always I do appreciate any useful comments.
  • Nserega.90
  • Nserega.90
17 Feb 2025 06:33
Replied by Nserega.90 on topic Flexible GUI
Flexible GUI
Category: Flex GUI
Thanks John, that's what I thought. Yes, I noticed that the top menu items are the same on all tabs. That’s why I decided to ask you, since I wasn’t completely sure myself))))
  • Hakan
  • Hakan
17 Feb 2025 06:20 - 17 Feb 2025 08:17
Replied by Hakan on topic Fusion 360 post processor file for Plamac
Category: Plasmac
Have to correct myself after reading through the QtPlasmaC documentation.
Centerpunch uses the spotter tool, which is the torch firing short enough to only make an indentation. Very clever. Has its own setting on the Parameter page, firing time most notably. So let the M3 $2 S1 stay.
Actually, when I think of it. I think its a bug/feature of PlasmaC that M3 won't allow a line above with only coordinates, but must include also the move command.
Not ok
G0 X5 Y5
X100.0 Y100.0
M3 $2 S1
Ok
G0 X5 Y5
G0 X100 Y100
M3 $2 S1
  • Hakan
  • Hakan
17 Feb 2025 06:05
THC with Beckhoff EL5101 and THCAD2 => encoder signal loss
Category: Plasmac
I think one can not take for granted that EL3061's signal ground is the same potential as the workpiece ground. If you are lucky it might work, but to be on the safe side the torch signals should be isolated and free to float.
  • unknown
  • unknown
17 Feb 2025 05:32
No the selection of the type of desktop has absolutely nothing to do with your issue. It only selects what kind of Desktop environment you will have once booted.
Grub is the boot loader, this is where your issue is.
Due to HP being in bed with MS they chose "Microsoft's way" on naming the boot files for uefi.
If you turn on legacy boot and disable secure boot, as tommy mentioned a while back this may resolve your problem.
  • unknown
  • unknown
17 Feb 2025 05:26
Replied by unknown on topic New and Working RTAI debs for 2.9
Thanks for this answer.
I would like to install RTAI due to the jitter in my setup, which is around 70k.
I'm using 4 stepper motors with encoders (closed loop) and a USC board from PICO.
Sometimes, though not very often, I get an "Unexpected realtime delay" message.
Do you think this could be related to the jitter amount?
I've tried every optimization I could find in the BIOS...
Just having a look at the PICO config, is the base thread used ? From a quick look nothing appears to attach to the base thread. Which would lead me to think that a simple RT_PREEMPT kernel would be suffice. The PICO board would seem to operate in a simialr way to a mesa 7i90 using the EPP protocol. IE using the parallel port to send timing info to a FPGA.
  • phillc54
  • phillc54's Avatar
17 Feb 2025 05:20
Replied by phillc54 on topic (solved) Documentation Hobbing
I think that there are issues with https on the wiki, try http:
wiki.linuxcnc.org/uploads/hobbing.zip
  • tftmarco0
17 Feb 2025 05:14
Rodw, you said "Be sure to select Mate or XFCE desktop" The defaults in your suggested ISO / Debian 13"are "Debian desktop environment", then "Gnome" and "standard system utilities". All preselected. Not selected are "Mate and Xfce" among others. Do you feel going with the preselected defaults will cause the "can not find a bootable drive" error problem? or should I just go with the defaults? If I don't select some of the unchecked software options on this install page, will it cause my system to not install or just not find the bootable OS on reboot? It does say "the core of the system is installed"
  • unknown
  • unknown
17 Feb 2025 05:02
Debian 13 is still in testing. Debian 12 is the current stable version. So no Debian 13 (Trixie) is not more stable than Debian 12 (Bookworm). Honestly I would stay away from Trixie based on your Linux experience. Stay with the version that actually has been released rather than a version that is still in testing.
I would also look for any HP forums that discuss your particular machine as it maybe a "HP issue" with some input from Microsoft that is causing the issue, not a "Linux issue".
But have you followed my advice regarding testing the latency of the computer ? If the latency is not suitable I wouldn't bother trying to install Linuxcnc on that machine.
You keep mentioning "sudo commands" but give no indication to what these areor what they are supposed to do, do you see this is another issue where you are not supplying information, do you need this information beaten out of you (this does not mean an actual beating, but this how frustrating you are being). Would these be related to HP's buggy uefi and having to rename some boot files.
  • tftmarco0
17 Feb 2025 04:32
I have a HP computer 110-210, The system info is in the first photo provided “Mysystem.jpg” I will send a photo of the label on the side of the box if you like, but it has less info than the detailed system info. Sorry to provide to much background info on me, but is was suggested that I did not try the obvious things first like using the default settings or installing to my main internal drive first.
"unknown" said “The reason for my troll comment was because you seemed to not want to give a lot of info, or it would seem directly reply to any suggestions.” I though with all the photos like “my detailed system info” I was providing too much info. If there is something missing from all the info and photos provided, I am happy to provide it.
I saw the latency test while in live mode. It asked to do things like stress my system that I could not do yet like running motors I think. But it did not seem like it would prevent my “successful installs” from being found on ether hard drive” Do you think they are related? Now that you have seen my system info, do you feel that my system is not capable of recognizing a successful install on ether of my hard drives?
Update… I thought trying installs without the Ethernet connected may help avoid the “UEFI: IPv4 Realtek PCIe FE family controller” coming back and interfering with something, but the install made it clear it wants to be connected to get all needed files. So I am starting over with it reconnected. I am currently trying “rodw” suggestion to see if this ISO “debian-trixie-DI-alpha1-amd64-netinst.iso” will be found after a successful install I hope. I did see it said Debian13, so maybe it is more stable than the others I have tried. Unless the problem is something else. I will post the results of this install attempt using the suggestions like “Be sure to select Mate or XFCE desktop “ but the sudo commands would need to be in a live mode terminal if the install fails.
17 Feb 2025 01:48
Replied by tommylight on topic MESA 7i96S and Input config
Category: Basic Configuration
NO = normally open switch
NC = normally closed switch
  • NTULINUX
  • NTULINUX's Avatar
17 Feb 2025 01:32
Replied by NTULINUX on topic New and Working RTAI debs for 2.9
Are you hitting 70K microseconds on RTAI or PREEMPT_RT?
Just in case, here are the options I've found to help:
github.com/NTULINUX/RTAI/blob/master/README.BIOS
  • aikiaviator
  • aikiaviator
17 Feb 2025 01:32
Replied by aikiaviator on topic MESA 7i96S and Input config
Sorry, I'm a bit stupid today, but when you say "you must use
the plain inputs pins for NO contacts and the -not pins for NC contacts."
On the 7i96S there are only input pins with a common, not listed particularly as NO (normal pins ref:inputs) or NC (i.e. -not pins).
Do you mean that the NO are set as normal with Common Ground, and when set to NC then the Inversion sets the logical pin "type" to -NOT?
I know I am being a bit anal, but just want to be clear.
Thanks.
  • Thayloreing
  • Thayloreing
17 Feb 2025 01:06
Replied by Thayloreing on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Good evening, I tried to follow this tutorial, but I couldn't find the stlink bin file, the DAPLink file no longer exists, I couldn't find it anywhere
Displaying 18916 - 18930 out of 19203 results.
Time to create page: 1.825 seconds
