  • SOLD
  • SOLD
05 Dec 2024 06:54
Replied by SOLD on topic AX58100
AX58100
Category: EtherCAT
I understand the speed, it's hard to see the index pulse.
What I don't understand is when an index is detected, how does your encoder command element change the state?
For example:
Obj.IndexStatus = Encoder1.indexHappened();
Checks if an index pulse has occurred (uses the indexPulseFired variable).
If it has, it returns 1 and resets the state.
Obj.IndexByte = Encoder1.getIndexState();
Reads the digital value of the index pin directly (0 or 1).
Used to check the current state of the index signal.
This information, even monitoring with Twincat, does not detect any.
I am now starting to practice debugging and serial monitoring.
And next I think I will try EaserCAT-2000 with AX58100, but it is still difficult to change from LAN9295 to AX58100 with the original firmware of EaserCAT-2000.
  • Hakan
  • Hakan
05 Dec 2024 06:13 - 05 Dec 2024 06:16
Replied by Hakan on topic AX58100
AX58100
Category: EtherCAT
The Index signal is short, in EtherCAT it is only one servo cycle long so you will most likely miss it, or the linuxcnc tools will miss it. Unless you happen to position the encoder exactly where the index signal is, then you can see it on the IndexByte.
Use halscope to watch the index signal in linuxcnc. Set sample time short enough to capture all data.
  • Cj.tns60
  • Cj.tns60
05 Dec 2024 03:47
Retrofit torno CNC traub TNS 60 was created by Cj.tns60
Category: CNC Machines
Estou realizando um projeto de modernização da minha máquina não nem por onde começar. Gostaria de ajuda.Abaixo os detalhes da máquina Torno CNC traub modelo TNS/60 com 4 eixosFUSO PRINCIPAL 34.5 Kw c.c independente Eixo z servo 10n.m Bem antigo( irei pegar as configurações)Eixo x 8n.m Torre de ferramentas 12 posições Máquina toda hidráulica Eixo x 10n.m.
Comecei este tópico somente para darmos um kickoff no projeto, qualquer pergunta com relação ao projeto posso responder.
Ps. O comando é um tx8d
Obrigado
05 Dec 2024 03:18
Replied by tommylight on topic EtherCAT Servo Tuning and LinuxCNC PID Tuning
Are you using only EtherCAT drives?
Do you have any Mesa card or use parallel port?
Are the encoders in any way talking back to LinuxCNC, be it through Mesa or Pico or parallel port or any other interface?
If using EtherCAT with no feedback to LinuxCNC, no tuning in LinuxCNC.
05 Dec 2024 03:13
EMC_JOG_CONT cannot be executed unitl the machine is out of E-stop and turned on
Most probably from interference on the inputs, caused by spindle or drives motors, subsequent to using unshielded cables or no grounding.
First check if the power supplies and machine is grounded.
05 Dec 2024 03:09
Replied by tommylight on topic Verifying LinuxCNC ISO download.
Category: Installing LinuxCNC
Give it a try, it might just work ! :)
Jokes aside, been many, many years since i had a bad ISO download, so if your internet provider has not throttled downloads, all should be fine.
  • COFHAL
  • COFHAL
05 Dec 2024 00:37
Replied by COFHAL on topic AX58100
AX58100
Category: EtherCAT
I connected an encoder that has index, but I don't see any activity regarding that pin.
  • Benb
  • Benb's Avatar
04 Dec 2024 23:50 - 04 Dec 2024 23:54
Replied by Benb on topic Servo drive or some kind of problem
Category: HAL
I could not find online your servo drive manual. But found CMC manual for brushed DC motor with tachometer input.
ttps://www.artisantg.com/info/Cleveland_Motion_Controls_SDB_Series_Manual.pdf?srsltid=AfmBOorzCltvtjGyzWiOyaa6-XFNoLaBcmwPmFUnsA8L5EootgrmcSKG I am assuming this manual is similar to yours. If it is than you need to set the four digital inputs  SBY, OSW, SW1 AND SW2,  for the motor to spin in both direction  the inputs must be set to satisfy the operational conditions of the drive (digital inputs require 24vdc power)
  • Rkatts
  • Rkatts
04 Dec 2024 23:02
Replied by Rkatts on topic LCEC creating Danfoss VFD config
Category: EtherCAT
Did you find a solution?  What version of LinuxCNC are you running?
I have a similar issue.  It was running fine with LinuxCNC version 2.8, but after upgrading to 2.9.3 I get "PREOP E" errors and the drives won't enable.  It seems to be random which drives go to PREOP E and which ones go to OP.  Restarting LinuxCNC multiple times gives random results.
I get sync manager timeouts and failures to write SDO's.
  • Ekholm
  • Ekholm
04 Dec 2024 21:40
Replied by Ekholm on topic Get wifi working?
Get wifi working?
Hi! I had a friend over who tried to help me but with no success. Do you recomend some working usb wifi-card. The ax200 Intel chip was not so good :D
  • Mitch66
  • Mitch66
04 Dec 2024 19:41
Verifying LinuxCNC ISO download. was created by Mitch66
I am just getting started and have been working through the excellent series of videos by Joe Hildreth.  These videos are now 6 years old and so I think things may have moved on.  When it comes to downloading the latest version from the Downloads page, Joe recommends checking the download with a check sum using md5sum or sha256sum.  On the video the checksum is on the download page, as is a link to zsync - the method of downloading he recommends.  This is not on the current downloads page.  Do I still need to check my download (to a flash drive) before i install it on my new control computer?  If this has been covered elsewhere I am sorry but I have tried searching and cannot find an answer.
  • stonebite
  • stonebite
04 Dec 2024 18:59 - 04 Dec 2024 19:00
Replied by stonebite on topic Probe Basic "Einstellung metrisch oder imperial"
Category: Deutsch
forum.linuxcnc.org/qtpyvcp/48401-py3-pro...-doc-lcnc-2-9#287437
it might be a good idea to update the first post in this thread with a comment after the following the line mentioning that metric users need to change from G20 to G21.
[RS274NGC]
RS274NGC_STARTUP_CODE = F10 S300 G20 G17 G40 G49 G54 G64 P0.001 G80 G90 G91.1 G92.1 G94 G97 G98
  • mjones@welfab.ca
  • mjones@welfab.ca
04 Dec 2024 18:27
Electronic Gear Ratio on survo drive and setting pulses in ini
Problem solved.
Nothing to do with the drive and your setting were right on.
I was reading another thread about 'Whitch mode is best for new setups' it has alot of interesting stuff. still ready it as I'm hoping to see how they resolve tying the encoder feedback into linuxcnc.
Any ways in that thread they were talking about missed steps due to step and direction times being to small. I seen the number they were talking about ( in the thousands) and mine are just 400 and 800. Mine was a bit jerky and i figured maybe a bearing I would have to replace later, but suddenly made sense if its missing steps then it would be jerky as it missed and picked up again. I must have been loosing massive amounts of steps.. I changed my numbers to the below and now it moves smooth and the right distance.
Step Time=2000
Step Space=2000
Dir Hold=50000
Dir Setup=2000
I am so happy to me past this hurdle. Now on to the next.
I thank you so much for the help and efforts. unfortunately I am sure you will hear from me again when I hit the next wall.
I'm So thankful you guys are here for us that are struggling.
Displaying 22096 - 22110 out of 22275 results.
Time to create page: 0.483 seconds
