  • Muecke
  • Muecke's Avatar
17 Oct 2024 18:59
Unterstützung bei der Automatisierung einer Simulation
Category: Deutsch
Da Bilder etwas Totes sind und ich wirklich dankbar für dein Tool bin.
Ich möchte dir zeigen, was dabei herausgekommen ist, das war mein erster richtiger Test, denn ich konnte.
DANKE NOCH MAL !!! an der Stelle für das Tool.
VG Mücke
  • gardenweazel
  • gardenweazel's Avatar
17 Oct 2024 18:05
Inconsistent values from Versaprobe was created by gardenweazel
Category: Qtvcp
I'm using QTDragon HD and having issues when probing.
I am using the steps as outlined in the qt_auto_probe_tool.ngc file start off with.
From machine_log.dat (VIM line numbers precede each line)
 17 17:11:22 Loaded tool 0
  18 17:11:22 Tool 0: PROBE
  19 17:11:28 Cannot switch pages while in AUTO mode
  20 17:11:39 Versa Probe: Start Cycle: Go to Tool Setter
  21 17:12:08 Versa Probe: Start Cycle: Probe Tool Setter Z Height
  22 17:12:17 HISTORY Tool Setter height Z[-148.426]
  23 17:13:17 Versa Probe: Start Cycle: Probe Z Height of material
  24 17:13:27 HISTORY Probe Material Top Z[-115.031]
  25 17:14:47 Cannot switch pages while in AUTO mode
  26 17:14:52 Versa Probe: Start Cycle: Probe Outside Edges, Finish At Corner
  27 17:15:17 HISTORY Outside XPYP  Xp[0.302] Lx[0.000] Yp[0.027] Ly[0.000]
  28 17:15:56 Started program from line 1
  29 17:17:30 Tool 16: whiteside router bits - whiteside rd210
  30 17:17:47 Tool 16: whiteside router bits - whiteside rd210
  31 17:17:47  Probe Height: -148.4200
  32 17:17:47 Run timer stopped at 00:01:50
  33 17:17:47 Loaded file /home/andy/uploads/Large-Serving-Tray-REVISED-V2-POCKET-2.ngc
  34 17:17:47  Block Height: -115.0300
  35 17:17:47  Probe Result: 229.0947
  36 17:17:47  Calculated Offset: 262.4847
  37 17:17:47 Linear move on line 231 would exceed Z's positive limit
  38 17:17:47 Linear move on line 231 would exceed joint 3's positive limit
  39 17:17:47 invalid params in linear command
  40 17:17:47 Abort Parameter is [3]
  41 17:17:55 Started program from line 1
  42 17:18:17 Tool 16: whiteside router bits - whiteside rd210
  43 17:18:17  Probe Height: -148.4200
  44 17:18:17  Block Height: -115.0300
  45 17:18:17  Probe Result: 229.0912
  46 17:18:17  Calculated Offset: 262.4812
  47 17:43:20 Run timer stopped at 00:25:24
Here's the popup message:  NOTE the MDI line number 231 has no Z axis movement and the program file has not even started to execute. At this point the new tool change has already taken place and the new tool is being measured.
Not sure what is causing this but, after I "Clear all" the and restart the file from the beginning it runs as expected without the error.
Finally, worth noting is that I noticed my tool table appears to have been altered and is NOT from previous runs. Has many missing columns.
It appears as if something has written to the tool table when it should have not.
Here's a couple of lines in my current tool table that reflects this issue, note that tool 16 has the Z set.
T15  P15  D+6.350000 ;whiteside router bits - whiteside ru210
T16  P16  D+6.350000 Z+258.012190 ;whiteside router bits - whiteside rd210
T17  P17  D+6.350000 ;whiteside router bits - whiteside rd207
And here is a backup that I took a week or so ago:
T15 P15 X0 Y0 Z0 A0 B0 C0 U0 V0 W0 D6.35000 I0 J0 Q0 ;whiteside router bits - whiteside ru2100 -- 1/4 inch upcut spiral- solid carbide
T16 P16 X0 Y0 Z0 A0 B0 C0 U0 V0 W0 D6.35000 I0 J0 Q0 ;whiteside router bits - whiteside rd2100 -- 1/4 inch downcut spiral- solid carbide
T17 P17 X0 Y0 Z0 A0 B0 C0 U0 V0 W0 D6.35000 I0 J0 Q0 ;whiteside router bits - whiteside rd2074a --o-flute 1/4 inch downcut spiral - solid carbide
Any ideas?
  • btvpimill
  • btvpimill
17 Oct 2024 18:02
Machine moves when you stop program in the middle
Not sure what infor to provide. My machine has suddenly decided to move a seems like random amount if I hit stop during a run. It did not use to do this. and sometimes it just stops where it is. But now I can't trust it. So for instance lets say it has moved to the first cut location and is spooling up the spindle. If I hit the stop button or esc button, it will slowly move in x/y/z. During the move the disp[lay will not update. Buit when it stops the DRO will update to correct position.
It does not loose its place, if I hit run it will go right back to the correct start position.
It will also do this if the spindle is up to speed and cutting. If I hit stop it will move.
If it was only X and Y, I could hobble through the job, but it may take a dive with Z which could plunge through my part.
The only changes I have made are I tried to install easy probe a few weeks ago. But seems like I have not had this issue until today.
BTW, running Axis.
  • PCW
  • PCW's Avatar
17 Oct 2024 17:48
Replied by PCW on topic Getting started with 6i25+7i75+7i85s
Category: PnCConf Wizard
If the index had a high enough duty cycle that you could use the software encoder
you could use a little hal magic to switch the RPM source from hardware encoder to
index only software encoder at some specific commanded RPM.
17 Oct 2024 17:19
Replied by tommylight on topic IP Blocked
IP Blocked
Category: Forum Questions
No idea if i can do anything about it, but i can try.
There is no direct messaging here, so report this post and write it there ... although secrecy might be a bit much for a public IP address, sill less exposure.
  • Aciera
  • Aciera's Avatar
17 Oct 2024 17:03
Replied by Aciera on topic Welche Tasten haben die Achsen?
Category: Deutsch
Du kannst die Tasten auch selber zuordnen:
forum.linuxcnc.org/21-axis/46689-how-to-...on-keys-on-ui#250075
Hab ich aber auch noch nie gemacht, weil ich keine Tastatur Shortcuts nutze.
  • spontarelliam
  • spontarelliam
17 Oct 2024 16:57
Replied by spontarelliam on topic IP Blocked
IP Blocked
Virginia. Can I send you my ip by direct message?
17 Oct 2024 16:56
IP Blocked
Where are you located?
17 Oct 2024 16:52
Replied by tommylight on topic Welche Tasten haben die Achsen?
Category: Deutsch
Did you try to add the standard USA keymap?
No idea how to do that so use google, please.
17 Oct 2024 16:51
Replied by tommylight on topic Can the OPI5 be Configured to Run LCNC?
Try this
lsblk -o UUID,VENDOR,ID
Then try open FSTAB if possible and edit it by replacing the UUID of your drive from the resulting list
sudo nano /etc/fstab
  • Lcvette
  • Lcvette's Avatar
17 Oct 2024 16:49
Replied by Lcvette on topic KeyError vtk_backplot
Category: QtPyVCP
i don't get that on the latest release so its difficult to say what is causing it on your setup unfortunately, could be a yaml setting perhaps, that is where i would start looking first.
  • Krister
  • Krister's Avatar
17 Oct 2024 16:44
Replied by Krister on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
Hi One problem solved and one remain ,I replaced the analog optical sensor to a "digital" one and the revolution meter start to work . the reading is ok and the reading is controled with a speedometer. the other problem is the red and green LED weryfing to start the process from the G-code program  G97 S600 M3 The program start at 150 rpm and the red LED starts at 350 rev, it is mirror action , it should start at ca 450 and stopp at ca 700 revs ,it is programd with 150 % tolerans .
17 Oct 2024 16:42
Replied by tommylight on topic Does this CNC machine price makes any sense?
Category: Milling Machines
That's prepayment, but even the full payment seems too cheap
+1
US $3,595.50 is still way to low, but i have seen this before, price is low but the shipping is sky high, something like 936$ shipping for a 350$ machine.
From experience of some of my clients, they ordered a 9000$ machine with this size with no ATC, payed, then got another invoice for shipping and customs for 4500$, then had to pay nearly 5000$ our tax and our customs, despite the invoice of 4500$ from them stating that our customs are included there! ~19000$ all in, several of them, not just one.
Our country often gives grants for such equipment, so people keep buying them, leaving them collect dust for some time then sell them on. Disgraceful! Some do use them, those that work, that is, as the failure rate is way to high for a new type of Ethernet controller they use lately.
  • spontarelliam
  • spontarelliam
17 Oct 2024 16:40
IP Blocked
My ip has been blocked for at least a week. I use a password manager, so maybe that has something to do with it?
I don't see from the other posters what the procedure is for getting unblocked. It's a business static ip, so I can't just reboot the router.
Thanks for your help, I'd love to get back on the forums on a real computer.
  • jmelson
  • jmelson
17 Oct 2024 16:10
Replied by jmelson on topic Does this CNC machine price makes any sense?
The only way they can do this for under $1K delivered is to ship it in a rather small box, with LOTS of small parts, and you have to put it together and get it all aligned.
Even still, I can't figure out how they can do it this cheap. Buyer beware!
Jon
Displaying 22561 - 22575 out of 22868 results.
Time to create page: 2.098 seconds
