  • slowpoke
  • slowpoke
13 Aug 2024 22:50
Replied by slowpoke on topic Jogging from Mesa input (Axis version 2.9.2)
Category: HAL Examples
In this case this was just a proof of concept test. Now that I understand how it works, I will expand. I'm probably not going to use the actual Mesa inputs, I have a SAMD21 on my custom control board that if all goes to plan will emulate the ArduinoConnector project sending button presses to halui and also receive data back from halui. I have this working now for a few points on a little nano board. Next step is to port that nano code to the SAMD21 and then expand for all required points.
  • waukeenahBob
  • waukeenahBob
13 Aug 2024 22:49
Replied by waukeenahBob on topic MESA 7c81 HELP!
MESA 7c81 HELP!
Category: Driver Boards
Ok I changed the "actual servo period" to 1000000 in pncconf
Feeling not to smart at the moment... where do I find "step pulse width" in pncconf and I have searched the file system and do not see any files starting with 7c81
Sorry for the dumb questions... my google foo needs some help for this kind of stuff
  • PCW
  • PCW's Avatar
13 Aug 2024 22:48
Replied by PCW on topic 7i97t with 7i84d connection problem
There is information in the 7I97T manual (page 13)
for making a cable for any Sserial device (like the 7I84)
The 7I97T has a single RS-422 interface so can only connect
to a single 7I84 unless you add and additional expansion daughter
card (or simple 1 chip RS-422 interface) to the 7I97Ts P1 expansion
connector.
Do you have the drive and encoder pinouts?
  • PCW
  • PCW's Avatar
13 Aug 2024 22:30
qtplasmac (Operation Error: hm2/hm2_7i76e.0:) in middle of cut
Category: Plasmac
OK that's Intel so needs IRQ coalescing disabled
Before messing with the network setup its possible
to do this from the command line:
sudo ethtool -C [device] rx-usecs 0
where [device] is the name of the Ethernet device connected
to the Mesa card (usually something like eno1 or enp2s5 or similar)
You can determine this name with the command:
ip a
  • RMJ fabrication
  • RMJ fabrication
  • PCW
  • PCW's Avatar
13 Aug 2024 22:04 - 13 Aug 2024 22:04
Replied by PCW on topic Mesa 7I92TM Parallel port pin mapping
Category: PnCConf Wizard
7i92t_5abobx2d.bin should work with:
Stepgen0 --> Y axis
Stepgen1 --> X axis
Stepgen2 --> Z axis
Also in pncconf, set the number of stepgens to 3,
and the number of pwmgens and encoders to 0 to
free up the other pins so they can be used as
GPIO if needed.
  • PCW
  • PCW's Avatar
13 Aug 2024 21:56
Category: Plasmac
lspci  | grep -i eth
The character after lspci is a vertical bar
( usually shift \ ), not an 'L'
  • DougM
  • DougM
13 Aug 2024 21:55 - 13 Aug 2024 22:02
Replied by DougM on topic Mesa 7I92TM Parallel port pin mapping
Yes, I do.
X Step 4
X Dir 5
Y Step 2
Y Dir 3
Z Step 6
Z Dir 7
X Home 12
Y Home 11
Z Home 13
E-stop 10
Is the next step finding firmware that happens to match the above?  Or can I use the tool to poke the values into the right place, maybe using
--wpo     address value          Write hostmot2 variable directly at 'address' with 'value'.
Thanks so much for your guidance!
  • fons
  • fons's Avatar
13 Aug 2024 21:44 - 13 Aug 2024 21:45
Replied by fons on topic 7i97t with 7i84d connection problem
maybe not on the right place  but ...
i just get one 7i97t and also  two 7i84 card from eusurplus
where can i find a wire diagrama how to conect the two 7i84 to the 7i97 and also  where and how to conect the shaftencoders and driver inputsignals
thx in advance
  • AlessandroEmm
  • AlessandroEmm
13 Aug 2024 21:43
Replied by AlessandroEmm on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Can confirm this portion actually controlled voltage up to 10v on NVEMs (MX1052) output
net spindle-cw remora.output.09
loadrt pwmgen output_type=1
loadrt scale count=1
loadrt lowpass count=1
loadrt abs count=1
addf scale.0 servo-thread
addf lowpass.0 servo-thread
addf abs.0 servo-thread
setp scale.0.gain 0.00416666667
net spindle-cmd-rpm spindle.0.speed-out => scale.0.in
net spindle-cmd-rpm-abs scale.0.out => abs.0.in
net spindle-speed-DAC abs.0.out => remora.SP.0
net spindle-cw <= spindle.0.forward
  • RMJ fabrication
  • RMJ fabrication
  • rthorntn
  • rthorntn
13 Aug 2024 21:35 - 13 Aug 2024 21:36
Awesome, did you use any opto-couplers/digital isolators, are the nine 16-pin IC's only level-shifters?
  • PCW
  • PCW's Avatar
13 Aug 2024 21:29
  • RMJ fabrication
  • RMJ fabrication
13 Aug 2024 21:04
Category: Plasmac
My problem is not being caused by low latency due to overheating here is the temperature at the time of the error. Mach 3 would never do this using this same PC I cant get a full cut and it is very frustrating. please tell me what PCs you guys are using to not have these problems please let me know where to find instructions on how to start a cut in the middle of the file so at least cut recovery is simpler.
  • rodw
  • rodw's Avatar
13 Aug 2024 20:57
no increment minus?
I agree this is complicated. Recently I got this hardwired pendant going.
The MPG, axis select and scale selectors are well described in the docs (requires small mods for a mesa MPG) linuxcnc.org/docs/stable/html/examples/mpg.html
Getting high and low speed button jogging working (selected by holding the ~  button down) proved so complicated, I resorted to writing a custom component
Displaying 23956 - 23970 out of 24438 results.
Time to create page: 0.613 seconds
