15 Oct 2026 04:52
Replied by tommylight on topic I think the forum needs some TLC
Category: Forum Questions
Last two days it's been much better, thank you SGD.
15 Oct 2026 04:51
Replied by tommylight on topic Lathe Chuck Table
Lathe Chuck Table
Category: QtPyVCP
That is a loooong post, thank you.
15 Oct 2026 04:42
Replied by tommylight on topic Hermle auswahl Mesa Karten
Category: Deutsch
Sind die servos analog oder step/dir ?
Wen geld kein problem ist, nem das von Mesa:
7i96S - 5 step/dir venig IO, spindle mit encoder
7i83 - analog ausgange fuhr analog +-10V servos - nur wen diene servos analog eingang habben
7i85 - 4 encoder eingange und 4 sserial
wen mehr IO braughs
7i70 - 48 eingange uber sserial
7i71 - 48 ausgange uber sserial
oder nur
7i84 - 32 eingange und 16 ausgange
das ist die beste combo fuhr ale moglihkeiten, und kan finden im Deutchland sein beim www.welectron.com
Normaleweise wen finden an, die 7i95T ist ales beim eine platte fuhr step/dir und encoder, und die 7i97T ist AIO fuhr die analog servo und encoder.
15 Oct 2026 04:33
following error: use bus value instead of internal calculation
Category: EtherCAT
Moved to "EtherCAT" section.
From what i read here, EtherCAT has issues with position feedback to the point i was convinced it is useless, but i might be wrong or something might have improved by now.
Since i have no experience with it, i will retreat, for now.
15 Oct 2026 04:30
Replied by tommylight on topic JMC Servo Drive Bricked!
Does the diagnostic software still communicate with the drive?
15 Oct 2026 04:28
Tornos deco 2000/20 ROBOBAR SSF 226 how to progam barfeeder?
Category: CNC Machines
Any luck with this?
And you do not mention if it is running LinuxCNC, from your writing it seems it is not.
15 Oct 2026 04:26
Replied by tommylight on topic general setup question - standard cnc process
Category: Basic Configuration
What exact errors are you getting?
Attach the pictures/logs here so we can have a look.
15 Oct 2026 04:24
Replied by tommylight on topic Z-axis doesn’t move
Z-axis doesn’t move
Category: Flex GUI
Attach the hal and ini files here so we can have a look.
15 Oct 2026 01:08
Replied by tommylight on topic stepper motor does not move
@geebee
Make a new config, start over.
  • bassti
  • bassti
14 Oct 2026 21:55
Replied by bassti on topic Hermle auswahl Mesa Karten
Category: Deutsch
Welche servodrives hast du genau ?
Gruß bassti
  • PCW
  • PCW's Avatar
14 Oct 2026 21:22
Replied by PCW on topic stepper motor does not move
You have:
FF1 = 0
in your ini file
This should always be 1
14 Oct 2026 19:58
LinuxCNC is very good at pointing out failures, so if you are not getting latency warnings while using it, it is not a latency issue.
When i replied about the low current, i was going to add that to much current can also do that, but it has to be way over the rated motor current to cause such issues.
In general,
-if the motor gets warm in 3 minutes, or hot in 5 minutes of being on = way to much current
-if it gets hot in 15-30 minutes = all should be good
-warm is if you can keep your palm on the motor
-hot is when you can keep your finger on it, but not the palm
-to hot is if you skin remains on the motor = the motor is cooked
keep in mind that current ratings on cheap drives are "peak", while on good expensive drives it is "RMS", but lately cheap drives have both ratings written on them, so use the "peak" values while testing, then decide if you need to add more current if the motor skips.
Always use lower current if not sure.
  • tuxcnc
  • tuxcnc
14 Oct 2026 19:24
Replied by tuxcnc on topic stepper motor does not move
The stepper motor withstands temperatures of 120 degrees Celsius.
This is, of course, the maximum parameter and during normal operation it should be cooler.
On the other hand, if the motor is cold, it means that the current is too low, resulting in less shaft torque.
Without a thermometer, this can be assessed by stating that the engine should be hot, but should be able to be touched by hand.
  • geebee
  • geebee
14 Oct 2026 17:58
Replied by geebee on topic stepper motor does not move
Sörry for eventually annoying anyone. Some reading I certainly did, it is just a lot of stuff. I have used several motors both of the same and different types and two different drivers. I can limit current at the tb6600 and certainly did. The cs-d508 does not provide any switch to do so. Its datasheet mentions overvoltage and overcurrent protection. Apparently the current nevertheless is too high, not too low. The motors heat up quickly when not moving. I lost a second one even though I have become more careful after the first one burned. I certainly do know how to wire a 2 phase stepper. Mistakes might happen, but I will not repeat them every time I reconnect the stuff. I have been working with steppers and arduino but not yet on a professional basis.
So at the moment, I suggest its more likely a latency issue. It is gonna take me a while to go through the stuff pcw has told me. After that, I will let you know what I did and what were the results.
Cheers
Displaying 271 - 285 out of 11531 results.
Time to create page: 0.470 seconds
