  • MarkoPolo
  • MarkoPolo
03 Jul 2026 18:26
Replied by MarkoPolo on topic qtvismach, a axis toolpath
Category: Qtvcp
Returning to the topic of Vismach navigation, there are several issues that make navigating the Vismach window less than pleasant.
When panning the scene left, right, or up and down, the zoom level isn't taken into account, and at greater zoom levels, it's difficult to move the object.
When zooming in, near maximum zoom, there's a very unpleasant effect: many mouse wheel rotations and little zoom effect.
Panning the scene is done with the middle mouse button, while the left mouse button rotates on two axes. This is difficult to master because in the qtdragon preview window, panning is done with the left mouse button. It would be nice to have the same solution in Vismach.
I have a file, qt_vismach.py, that fixes all these issues.
The question is, do you see the problem and the need to improve these things?
  • dbrija
  • dbrija
03 Jul 2026 15:35
Missing archive for 2.9.9 update was created by dbrija
Category: Installing LinuxCNC
Ran the usual sudo apt update/upgrade to get latest 2.9.9 and seems to be missing the uspace files
  • Nikita
  • Nikita
03 Jul 2026 12:53
Lenze ECSxM via EMF2192IB (EtherCAT): CiA402 compatibility and configuration iss
debian@debian:~$ ethercat slaves -v
=== Master 0, Slave 0 ===
Device: Main
State: PREOP
Flag: +
Identity:
Vendor Id: 0x0000003b
Product code: 0x014e7bc0
Revision number: 0x00000001
Serial number: 0x00000000
DL information:
FMMU bit operation: no
Distributed clocks: yes, 64 bit
DC system time transmission delay: 0 ns
Port Type Link Loop Signal NextSlave RxTime [ns] Diff [ns] NextDc [ns]
0* MII up open yes - 459143642 0 0
1 MII down closed no - - - -
2 N/A down closed no - - - -
3 N/A down closed no - - - -
Mailboxes:
Bootstrap RX: 0x1000/244, TX: 0x10f4/244
Standard RX: 0x1000/256, TX: 0x1100/256
Supported protocols: CoE, FoE
General:
Group: Drives
Image name:
Order number: Servo ECSxM CiA 402
Device name: Servo ECSxM CiA 402
CoE details:
Enable SDO: yes
Enable SDO Info: yes
Enable PDO Assign: no
Enable PDO Configuration: no
Enable Upload at startup: no
Enable SDO complete access: yes
Flags:
Enable SafeOp: no
Enable notLRW: no
Current consumption: 0 mA
debian@debian:~$ ethercat sdos
SDO 0x1000, "Device type"
0x1000:00, r-r-r-, uint32, 32 bit, "Device type"
SDO 0x1008, "Device name"
0x1008:00, r-r-r-, string, 176 bit, "Device name"
SDO 0x1009, "Hardware version"
0x1009:00, r-r-r-, string, 16 bit, "Hardware version"
SDO 0x100a, "Software version"
0x100a:00, r-r-r-, string, 88 bit, "Software version"
SDO 0x1018, "Identity"
0x1018:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
0x1018:01, r-r-r-, uint32, 32 bit, "Vendor ID"
0x1018:02, rwrwrw, uint32, 32 bit, "Product code"
0x1018:03, r-r-r-, uint32, 32 bit, "Revision"
0x1018:04, r-r-r-, uint32, 32 bit, "Serial number"
SDO 0x1600, "IO Outputs"
0x1600:00, rwr-r-, uint8, 8 bit, "SubIndex 000"
0x1600:01, rwr-r-, uint32, 32 bit, "SubIndex 001"
0x1600:02, rwr-r-, uint32, 32 bit, "SubIndex 002"
0x1600:03, rwr-r-, uint32, 32 bit, "SubIndex 003"
0x1600:04, rwr-r-, uint32, 32 bit, "SubIndex 004"
0x1600:05, rwr-r-, uint32, 32 bit, "SubIndex 005"
0x1600:06, rwr-r-, uint32, 32 bit, "SubIndex 006"
0x1600:07, rwr-r-, uint32, 32 bit, "SubIndex 007"
0x1600:08, rwr-r-, uint32, 32 bit, "SubIndex 008"
0x1600:09, rwr-r-, uint32, 32 bit, "SubIndex 009"
0x1600:0a, rwr-r-, uint32, 32 bit, "SubIndex 010"
0x1600:0b, rwr-r-, uint32, 32 bit, "SubIndex 011"
0x1600:0c, rwr-r-, uint32, 32 bit, "SubIndex 012"
SDO 0x1800, "IO Inputs"
0x1800:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
0x1800:01,
, type 0000, 0 bit, "SubIndex 001"
0x1800:02,
, type 0000, 0 bit, "SubIndex 002"
0x1800:03,
, type 0000, 0 bit, "SubIndex 003"
0x1800:04,
, type 0000, 0 bit, "SubIndex 004"
0x1800:05,
, type 0000, 0 bit, "SubIndex 005"
0x1800:06,
, type 0000, 0 bit, "SubIndex 006"
0x1800:07, r-r-r-, bool, 1 bit, "TxPDO State"
0x1800:08,
, type 0000, 0 bit, "SubIndex 008"
0x1800:09, r-r-r-, bool, 1 bit, "TxPDO Toggle"
SDO 0x1a00, "IO Inputs"
0x1a00:00, rwr-r-, uint8, 8 bit, "SubIndex 000"
0x1a00:01, rwr-r-, uint32, 32 bit, "SubIndex 001"
0x1a00:02, rwr-r-, uint32, 32 bit, "SubIndex 002"
0x1a00:03, rwr-r-, uint32, 32 bit, "SubIndex 003"
0x1a00:04, rwr-r-, uint32, 32 bit, "SubIndex 004"
0x1a00:05, rwr-r-, uint32, 32 bit, "SubIndex 005"
0x1a00:06, rwr-r-, uint32, 32 bit, "SubIndex 006"
0x1a00:07, rwr-r-, uint32, 32 bit, "SubIndex 007"
0x1a00:08, rwr-r-, uint32, 32 bit, "SubIndex 008"
0x1a00:09, rwr-r-, uint32, 32 bit, "SubIndex 009"
0x1a00:0a, rwr-r-, uint32, 32 bit, "SubIndex 010"
0x1a00:0b, rwr-r-, uint32, 32 bit, "SubIndex 011"
0x1a00:0c, rwr-r-, uint32, 32 bit, "SubIndex 012"
0x1a00:0d, rwr-r-, uint32, 32 bit, "SubIndex 013"
0x1a00:0e, rwr-r-, uint32, 32 bit, "SubIndex 014"
0x1a00:0f, rwr-r-, uint32, 32 bit, "SubIndex 015"
SDO 0x1c00, "Sync manager type"
0x1c00:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
0x1c00:01, r-r-r-, uint8, 8 bit, "SubIndex 001"
0x1c00:02, r-r-r-, uint8, 8 bit, "SubIndex 002"
0x1c00:03, r-r-r-, uint8, 8 bit, "SubIndex 003"
0x1c00:04, r-r-r-, uint8, 8 bit, "SubIndex 004"
SDO 0x1c12, "RxPDO assign"
0x1c12:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
0x1c12:01, r-r-r-, uint16, 16 bit, "SubIndex 001"
SDO 0x1c13, "TxPDO assign"
0x1c13:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
0x1c13:01, r-r-r-, uint16, 16 bit, "SubIndex 001"
SDO 0x1c32, "SM output parameter"
0x1c32:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
0x1c32:01, rwrwrw, uint16, 16 bit, "Synchronization Type"
0x1c32:02, rwrwrw, uint32, 32 bit, "Cycle Time"
0x1c32:03, r-r-r-, uint32, 32 bit, "Shift Time"
0x1c32:04, r-r-r-, uint16, 16 bit, "Synchronization Types supported"
0x1c32:05, r-r-r-, uint32, 32 bit, "Minimum Cycle Time"
0x1c32:06, r-r-r-, uint32, 32 bit, "Calc and Copy Time"
0x1c32:07, r-r-r-, type 0000, 0 bit, "Minimum fast cycle time"
0x1c32:08, r-r-r-, uint16, 16 bit, "Get Cycle Time"
0x1c32:09, r-r-r-, uint32, 32 bit, "Delay Time"
0x1c32:0a, r-r-r-, uint32, 32 bit, "Sync0 Cycle Time"
0x1c32:0b, r-r-r-, uint32, 32 bit, "Cycle Time Too Small"
0x1c32:0c, r-r-r-, uint32, 32 bit, "SM-Event missed"
0x1c32:0d, r-r-r-, uint32, 32 bit, "Shift Time Too Short"
0x1c32:0e, r-r-r-, uint32, 32 bit, "RxPDO Toggle Failed"
0x1c32:0f, r-r-r-, type 0000, 0 bit, "Minimum Cycle Distance"
0x1c32:10, r-r-r-, type 0000, 0 bit, "Maximum Cycle Distance"
0x1c32:11, r-r-r-, type 0000, 0 bit, "Minimum SM SYNC Distance"
0x1c32:12, r-r-r-, type 0000, 0 bit, "Maximum SM SYNC Distance"
0x1c32:13, r-r-r-, type 0000, 0 bit, "SubIndex 019"
0x1c32:14, r-r-r-, type 0000, 0 bit, "SubIndex 020"
0x1c32:15, r-r-r-, type 0000, 0 bit, "SubIndex 021"
0x1c32:16, r-r-r-, type 0000, 0 bit, "SubIndex 022"
0x1c32:17, r-r-r-, type 0000, 0 bit, "SubIndex 023"
0x1c32:18, r-r-r-, type 0000, 0 bit, "SubIndex 024"
0x1c32:19, r-r-r-, type 0000, 0 bit, "SubIndex 025"
0x1c32:1a, r-r-r-, type 0000, 0 bit, "SubIndex 026"
0x1c32:1b, r-r-r-, type 0000, 0 bit, "SubIndex 027"
0x1c32:1c, r-r-r-, type 0000, 0 bit, "SubIndex 028"
0x1c32:1d, r-r-r-, type 0000, 0 bit, "SubIndex 029"
0x1c32:1e, r-r-r-, type 0000, 0 bit, "SubIndex 030"
0x1c32:1f, r-r-r-, type 0000, 0 bit, "SubIndex 031"
0x1c32:20, r-r-r-, bool, 1 bit, "Sync Error"
SDO 0x1c33, "SM input parameter"
0x1c33:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
0x1c33:01, rwrwrw, uint16, 16 bit, "Synchronization Type"
0x1c33:02, rwrwrw, uint32, 32 bit, "Cycle Time"
0x1c33:03, r-r-r-, uint32, 32 bit, "Shift Time"
0x1c33:04, r-r-r-, uint16, 16 bit, "Synchronization Types supported"
0x1c33:05, r-r-r-, uint32, 32 bit, "Minimum Cycle Time"
0x1c33:06, r-r-r-, uint32, 32 bit, "Calc and Copy Time"
0x1c33:07, r-r-r-, type 0000, 0 bit, "Minimum fast cycle time"
0x1c33:08, r-r-r-, uint16, 16 bit, "Get Cycle Time"
0x1c33:09, r-r-r-, uint32, 32 bit, "Delay Time"
0x1c33:0a, r-r-r-, uint32, 32 bit, "Sync0 Cycle Time"
0x1c33:0b, r-r-r-, uint32, 32 bit, "Cycle Time Too Small"
0x1c33:0c, r-r-r-, uint32, 32 bit, "SM-Event missed"
0x1c33:0d, r-r-r-, uint32, 32 bit, "Shift Time Too Short"
0x1c33:0e, r-r-r-, uint32, 32 bit, "RxPDO Toggle Failed"
0x1c33:0f, r-r-r-, type 0000, 0 bit, "Minimum Cycle Distance"
0x1c33:10, r-r-r-, type 0000, 0 bit, "Maximum Cycle Distance"
0x1c33:11, r-r-r-, type 0000, 0 bit, "Minimum SM SYNC Distance"
0x1c33:12, r-r-r-, type 0000, 0 bit, "Maximum SM SYNC Distance"
0x1c33:13, r-r-r-, type 0000, 0 bit, "SubIndex 019"
0x1c33:14, r-r-r-, type 0000, 0 bit, "SubIndex 020"
0x1c33:15, r-r-r-, type 0000, 0 bit, "SubIndex 021"
0x1c33:16, r-r-r-, type 0000, 0 bit, "SubIndex 022"
0x1c33:17, r-r-r-, type 0000, 0 bit, "SubIndex 023"
0x1c33:18, r-r-r-, type 0000, 0 bit, "SubIndex 024"
0x1c33:19, r-r-r-, type 0000, 0 bit, "SubIndex 025"
0x1c33:1a, r-r-r-, type 0000, 0 bit, "SubIndex 026"
0x1c33:1b, r-r-r-, type 0000, 0 bit, "SubIndex 027"
0x1c33:1c, r-r-r-, type 0000, 0 bit, "SubIndex 028"
0x1c33:1d, r-r-r-, type 0000, 0 bit, "SubIndex 029"
0x1c33:1e, r-r-r-, type 0000, 0 bit, "SubIndex 030"
0x1c33:1f, r-r-r-, type 0000, 0 bit, "SubIndex 031"
0x1c33:20, r-r-r-, bool, 1 bit, "Sync Error"
SDO 0x58a4, "(C1883) Process data monitoring time"
0x58a4:00, rwrwrw, uint32, 32 bit, "(C1883) Process data monitoring time"
SDO 0x58a5, "(C1882) Process data monitoring reaction"
0x58a5:00, rwrwrw, uint32, 32 bit, "(C1882) Process data monitoring reaction"
SDO 0x58c5, "(C1850) Station alias"
0x58c5:00, rwrwrw, uint32, 32 bit, "(C1850) Station alias"
SDO 0x58d9, "(C1830) EtherCAT bus state"
0x58d9:00, r-r-r-, uint32, 32 bit, "(C1830) EtherCAT bus state"
SDO 0x58df, "(C1825) Outputs (32 Bit values)"
0x58df:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
0x58df:01, r-r-r-, uint32, 32 bit, "SubIndex 001"
0x58df:02, r-r-r-, uint32, 32 bit, "SubIndex 002"
0x58df:03, r-r-r-, uint32, 32 bit, "SubIndex 003"
0x58df:04, r-r-r-, uint32, 32 bit, "SubIndex 004"
0x58df:05, r-r-r-, uint32, 32 bit, "SubIndex 005"
0x58df:06, r-r-r-, uint32, 32 bit, "SubIndex 006"
0x58df:07, r-r-r-, uint32, 32 bit, "SubIndex 007"
0x58df:08, r-r-r-, uint32, 32 bit, "SubIndex 008"
0x58df:09, r-r-r-, uint32, 32 bit, "SubIndex 009"
0x58df:0a, r-r-r-, uint32, 32 bit, "SubIndex 010"
0x58df:0b, r-r-r-, uint32, 32 bit, "SubIndex 011"
SDO 0x58de, "(C1824) Inputs (32 Bit values)"
0x58de:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
0x58de:01, r-r-r-, uint32, 32 bit, "SubIndex 001"
0x58de:02, r-r-r-, uint32, 32 bit, "SubIndex 002"
0x58de:03, r-r-r-, uint32, 32 bit, "SubIndex 003"
0x58de:04, r-r-r-, uint32, 32 bit, "SubIndex 004"
0x58de:05, r-r-r-, uint32, 32 bit, "SubIndex 005"
0x58de:06, r-r-r-, uint32, 32 bit, "SubIndex 006"
0x58de:07, r-r-r-, uint32, 32 bit, "SubIndex 007"
0x58de:08, r-r-r-, uint32, 32 bit, "SubIndex 008"
0x58de:09, r-r-r-, uint32, 32 bit, "SubIndex 009"
0x58de:0a, r-r-r-, uint32, 32 bit, "SubIndex 010"
0x58de:0b, r-r-r-, uint32, 32 bit, "SubIndex 011"
SDO 0x58e1, "(C1823) Outputs"
0x58e1:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
0x58e1:01, r-r-r-, uint16, 16 bit, "SubIndex 001"
0x58e1:02, r-r-r-, uint16, 16 bit, "SubIndex 002"
0x58e1:03, r-r-r-, uint16, 16 bit, "SubIndex 003"
0x58e1:04, r-r-r-, uint16, 16 bit, "SubIndex 004"
0x58e1:05, r-r-r-, uint16, 16 bit, "SubIndex 005"
0x58e1:06, r-r-r-, uint16, 16 bit, "SubIndex 006"
0x58e1:07, r-r-r-, uint16, 16 bit, "SubIndex 007"
0x58e1:08, r-r-r-, uint16, 16 bit, "SubIndex 008"
0x58e1:09, r-r-r-, uint16, 16 bit, "SubIndex 009"
0x58e1:0a, r-r-r-, uint16, 16 bit, "SubIndex 010"
0x58e1:0b, r-r-r-, uint16, 16 bit, "SubIndex 011"
0x58e1:0c, r-r-r-, uint16, 16 bit, "SubIndex 012"
SDO 0x58e0, "(C1822) Inputs"
0x58e0:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
0x58e0:01, r-r-r-, uint16, 16 bit, "SubIndex 001"
0x58e0:02, r-r-r-, uint16, 16 bit, "SubIndex 002"
0x58e0:03, r-r-r-, uint16, 16 bit, "SubIndex 003"
0x58e0:04, r-r-r-, uint16, 16 bit, "SubIndex 004"
0x58e0:05, r-r-r-, uint16, 16 bit, "SubIndex 005"
0x58e0:06, r-r-r-, uint16, 16 bit, "SubIndex 006"
0x58e0:07, r-r-r-, uint16, 16 bit, "SubIndex 007"
0x58e0:08, r-r-r-, uint16, 16 bit, "SubIndex 008"
0x58e0:09, r-r-r-, uint16, 16 bit, "SubIndex 009"
0x58e0:0a, r-r-r-, uint16, 16 bit, "SubIndex 010"
0x58e0:0b, r-r-r-, uint16, 16 bit, "SubIndex 011"
0x58e0:0c, r-r-r-, uint16, 16 bit, "SubIndex 012"
SDO 0x58ec, "(C1811) Software creation date"
0x58ec:00, r-r-r-, string, 136 bit, "(C1811) Software creation date"
SDO 0x58ed, "(C1810) Software identification code"
0x58ed:00, r-r-r-, string, 112 bit, "(C1810) Software identification code"
debian@debian:~$ ethercat pdos
SM0: PhysAddr 0x1000, DefaultSize 256, ControlRegister 0x26, Enable 1
SM1: PhysAddr 0x1100, DefaultSize 256, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1200, DefaultSize 24, ControlRegister 0x24, Enable 1
RxPDO 0x1600 "IO Outputs"
PDO entry 0x6040:00, 16 bit, "Control word"
PDO entry 0x60b8:00, 16 bit, "TP Function"
PDO entry 0x607a:00, 32 bit, "Target position"
PDO entry 0x60ff:00, 32 bit, "Target velocity"
PDO entry 0x58e1:07, 16 bit, "SubIndex 007"
PDO entry 0x58e1:08, 16 bit, "SubIndex 008"
PDO entry 0x58e1:09, 16 bit, "SubIndex 009"
PDO entry 0x58e1:0a, 16 bit, "SubIndex 010"
PDO entry 0x58e1:0b, 16 bit, "SubIndex 011"
PDO entry 0x58e1:0c, 16 bit, "SubIndex 012"
SM3: PhysAddr 0x1900, DefaultSize 26, ControlRegister 0x20, Enable 1
TxPDO 0x1a00 "IO Inputs"
PDO entry 0x0000:00, 14 bit, ""
PDO entry 0x1800:09, 1 bit, "TxPDO Toggle"
PDO entry 0x1800:07, 1 bit, "TxPDO State"
PDO entry 0x6041:00, 16 bit, "Status word"
PDO entry 0x60b9:00, 16 bit, "TP Status"
PDO entry 0x6064:00, 32 bit, "Position actual value"
PDO entry 0x60ba:00, 32 bit, "TP Pos1 pos value"
PDO entry 0x60bb:00, 32 bit, "TP Pos1 neg value"
PDO entry 0x58e0:09, 16 bit, "SubIndex 009"
PDO entry 0x58e0:0a, 16 bit, "SubIndex 010"
PDO entry 0x58e0:0b, 16 bit, "SubIndex 011"
PDO entry 0x58e0:0c, 16 bit, "SubIndex 012"
debian@debian:~$ sudo ethercat upload -p 0 0x1A00 00 -t uint8
0x0f 15
debian@debian:~$ sudo ethercat upload -p 0 0x1A00 01 -t uint32
0x0000000e 14
debian@debian:~$ sudo ethercat upload -p 0 0x1A00 0x02 -t uint32
0x18000901 402655489
debian@debian:~$ sudo ethercat upload -p 0 0x1A00 0x03 -t uint32
0x18000701 402654977
debian@debian:~$ sudo ethercat upload -p 0 0x1A00 0x04 -t uint32
0x58e00110 1491075344
debian@debian:~$ sudo ethercat upload -p 0 0x1A00 0x05 -t uint32
0x58e00210 1491075600
debian@debian:~$ sudo ethercat upload -p 0 0x1A00 0x06 -t uint32
0x58e00310 1491075856
debian@debian:~$ sudo ethercat upload -p 0 0x1A00 0x07 -t uint32
0x58e00410 1491076112
debian@debian:~$ sudo ethercat upload -p 0 0x1A00 0x08 -t uint32
0x58e00510 1491076368
debian@debian:~$ sudo ethercat upload -p 0 0x1A00 0x09 -t uint32
0x58e00610 1491076624
debian@debian:~$ sudo ethercat upload -p 0 0x1A00 0x0a -t uint32
0x58e00710 1491076880
debian@debian:~$
debian@debian:~$
debian@debian:~$
debian@debian:~$
debian@debian:~$ sudo ethercat upload -p 0 0x6064 00 -t uint32
0xfffd1990 4294777232
0xfffdabd2 4294814674
0xfffeab25 4294880037
0x000001a6 422
0x0000569c 22172
0x0000ac55 44117
I want to share some critical findings regarding the integration of the Lenze ECSxM multi-axis servo drive equipped with the EMF2192IB EtherCAT communication module into LhntxBNB (uring linuxcnc-ethercat / lcec). This setup has a very specific architectural layout that completely misleads standard auto-configuration tools.Here is the exact breakdown of the contradictions and hidden traps we discovered under the hood:1. The Core Issue: SDO Mapping vs. Live PDO RealityThe Live Test: When I manually switch the drive to the PREOP + state using the ethercat CLI tool and manually turn the motor shaft by hand, I can see the encoder ticks updating live in the 0x6064 (Position Actual Value) register. This confirms that the CiA 402 profile layer is working inside the drive.The SDO Mapping Contradiction: However, when I look at the actual SDO mapping data for 0x1A00, the sub-indexes point to Lenze's internal, proprietary AIF registers (like 0x58E0) rather than the standard CiA 402 objects.2. Hidden Technical Padding at the Very BeginningWe discovered that the drive forces a fixed bit layout that starts with technical data instead of the control/status registers. Specifically, there is a hidden padding at the very beginning of the TxPDO stream:The first 14 bits are completely occupied by the internal AIF interface system flags (0x0000:00).The next 2 bits contain the drive's internal state/toggle register (0x1800:09).Only after these initial 16 bits does the standard CiA 402 0x6041 Statusword actually begin.3. No Distributed Clocks (Strictly Free Run Mode)By uploading the synchronization manager parameters directly from the drive via CoE, we checked indexes 0x1C32:01 and 0x1C33:01. Both returned 0x0000 (0).This explicitly proves that Distributed Clocks (DC) hardware synchronization is disabled in the drive firmware. The device operates strictly in Free Run mode. Any attempt by the master to force a strict DC cycle or reference clock sync results in frame timeouts and connection drops.4. Why Automatic Configuration (lcec) Crashes ImmediatelyWhen running automatic configuration tools (such as ethercat config > ... or standard generic driver discovery), the master relies strictly on the statib SDN lapphnf tables reported by the drive.As a result:It generates an XML file filled with internal AIF indexes instead of CiA 402 objects.It completely misses the 14-bit hidden padding at the very beginning of the stream. Because of this, the entire data stream shifts by 14 bits, the parser reads garbage, and lcec crashes immediately.It tries to initialize DC synchronization which the drive rejects.
03 Jul 2026 12:28
Replied by tommylight on topic Keyboard Jogging Problems!!!.
Enjoy your vacation.
  • Japoo_Ness
  • Japoo_Ness
03 Jul 2026 11:17
Retrofitting a 3-axis VMC with DC servos - guidance needed
Category: Driver Boards
Btw I am looking for the datasheet, connection diagrams, or pinout details for a Fanuc AC Spindle Drive Unit
Drive Model: A06B-6060-H003
Control PCB (Top Card): A16B-1100-0261/08B
I am specifically trying to trace the control signals and feedback interfaces (CN1, CN2). Since Fanuc doesn't publish individual datasheets for these part numbers, I am having trouble finding the exact schematics or the correct manual code that covers this specific board revision.
Note: I have attached an image showing how this drive is wired according to the machine's original electrical diagram. However, I want to verify it to be absolutely sure. It caught my attention that, in this original setup, there is no feedback loop going back to the old controller, which seems a bit unusual and is part of why I want to double-check the actual pinout.
Thanks in advance!
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • timo
  • timo
03 Jul 2026 04:31 - 03 Jul 2026 04:32
Replied by timo on topic Do NOT update working machines!!!
What do you mean with secure? There is a PC and it runs linux. The IT risk with my machine is a) lightning strike b) harddrive failure.
a) fixed by backup machine b) fixed with spare harddrive. ... Done!
If someone steals the PC it is also gone ...
p.s. Never change a running system, never run a changing system!
  • Todd Zuercher
  • Todd Zuercher's Avatar
03 Jul 2026 02:40
Replied by Todd Zuercher on topic Keyboard Jogging Problems!!!.
Not soon. I'm on vacation with the family for the next week. I'll try to remember to do some testing when I get back.
  • PCW
  • PCW's Avatar
03 Jul 2026 00:38
Motherboard asrock n100dc-itx no connection with 7i90hd
Did you try turning off epp_wide mode?
(man hm2_7i90)
I guess some other possibilities are:
Bad parallel port
Wrong base or high address (sometimes the high address is not at the standard 0x400 above the base address)
Bad EPP implementation (this has been seen on some PCI parallel port chips)
You could also  set debug_epp true and see if you get any clues from that
and also check if the parallel port works as expected
  • Japoo_Ness
  • Japoo_Ness
03 Jul 2026 00:16
Its okay if i make the config file with mesa ct?
And i need to make a simple config to test all or how is the correct procedure?
bw I test the ping for 60s and came with 0% of package loss.
  • rhscdn
  • rhscdn
03 Jul 2026 00:15
Replied by rhscdn on topic largest NC file
largest NC file
I often do 3d wood carving and run the occasional wooden sign. Depending on the size and detail, the files can get very large. And yes, the stock screen preview can be problematic with these files.
  • telmoram
  • telmoram
02 Jul 2026 21:37
Thanks, Cable (20cm length) and board test with other motherboard and run ok, with the asrock motherboard dont run.
  • PCW
  • PCW's Avatar
02 Jul 2026 21:22
Is the 7I90  "BOOT" jumper (W3) set to P?
How long is the parallel cable?
  • rodw
  • rodw's Avatar
02 Jul 2026 21:03
Have you tried it? It should work but you need to share sdos, pdos and configgen xml
  • telmoram
  • telmoram
02 Jul 2026 20:55
Hi, i have motherboard asrock n100dc-itx, setup Parallel port to ecp+epp v1.9 but start lunuxcnc i get error invalid cookie, got 0xffffffff, expected 0x55aacafe, please help me. Thanks.
Displaying 2731 - 2745 out of 12539 results.
Time to create page: 0.338 seconds
