  • Aciera
  • Aciera's Avatar
28 Jun 2026 17:35
XYYZ Kinematics: G2/G3 Arc Direction Inverted in LinuxCNC
You have setup your machine as a left handed coordinate system instead of the standard right handed system:
Some people get confused by the machine Y only moving in the negative direction from home but that is irrelevant since the actual work is going to be referenced to a work coordinate system (ie G54 ... G59) which can be setup anywhere.
  • Estley
  • Estley
28 Jun 2026 17:11
Actually, i can't get fusions axis to match my machine, if i change the direction of Y (which is the issue right now, either x or Z will also flip)
  • Estley
  • Estley
28 Jun 2026 16:24 - 28 Jun 2026 17:10
I had to use Claude to help me write the post since i'm new at this so please excuse me, I'm attaching my .ini and .hal files, thanks in advance!!:
File Name: LinuxCNC_m...ne_2.ini
File Size:5 KB
File Name: LinuxCNC_m...ne_2.hal
File Size:19 KB
Diagnosis: With corrected Fusion360 machine definition (Z up, X right, Y forward), linear motion executes correctly. However, G2 (clockwise) and G3 (counter-clockwise) commands execute in opposite directions.Tested: Triangle draws correctly. Circle with G3 (counter-clockwise) draws clockwise.Question: Is there a XYYZ kinematics setting or HAL configuration that controls arc direction in LinuxCNC?I'm also atteching a picture of my machine:
  • Fr3nzy
  • Fr3nzy
28 Jun 2026 14:48 - 28 Jun 2026 14:52
Replied by Fr3nzy on topic Installing ethercat repositories
Category: EtherCAT
Hello dear,
mokutil --sb-state says that EFI variables are not supported on this system. And it doesnt want to install linuxcnc-ethercat. The same dpkg error is shown. I do not know what to do...
  • Miller Turner
  • Miller Turner
28 Jun 2026 14:05
Replied by Miller Turner on topic ECAM 5 POST Processors
Category: Post Processors
Hi All,
Have you been using E-CAM for mill or lathe?
  • Aciera
  • Aciera's Avatar
28 Jun 2026 13:31
Replied by Aciera on topic Rotary axis in Qtdragon_hd
Category: Qtvcp
@deltafox24
A gcode example would help us test things.
@cmorley I guess he means a preview of rotray tool paths like this:
  • cmorley
  • cmorley
28 Jun 2026 13:04
Replied by cmorley on topic Rotary axis in Qtdragon_hd
Category: Qtvcp
I don't think we understand exactly what you are expecting.
Are you talking about have a rotary table as A sitting on top of the mill?
  • Ul
  • Ul
28 Jun 2026 12:56 - 28 Jun 2026 13:09
Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
Mach bitte ein Bild von der Karte. Die Chinesen haben Verschiedene. Sie haben auch verschiedene Baidu Links. Welchen hast du bekommen?
Ich habe die Dateien damals mit dem Baidu Downloader oder so heruntergeladen. Weiß leider nicht mehr, ob es eine Website war, oder ob ich ein Programm dazu installieren musste, aber es hat ohne Account funktioniert.
Letzte Woche habe ich meine mit dem Multimeter vermessen und die Pinzuordnung für Xilinx ISE gemacht. Konnte erfolgreich Bitfiles für meine machen. Ich kann eine Anleitung schreiben, was man machen muss. Du musst dich dazu bei AMD registrieren und Xilinx ISE herunterladen. Die Registrierung hat bei mir erst nach mehreren Versuchen geklappt. Einfach immer wieder abschicken, bis es funktioniert.
Ganz wichtig: NICHT versuchen Original Bitfiles für 7i98 zu flashen!!! Deine Karte läuft vermutlich mit modifizierter 7i92 Firmware, die eine andere Belegung zwischen dem FPGA und dem Netzwerkchip hat, daher wird die Karte anschließend nicht ansprechbar sein und kann nur noch über JTAG wiederbelebt werden. Wenn du soweit bist, testen wir das Flashen zusammen, so dass du nix falsch machst.
  • JT
  • JT's Avatar
28 Jun 2026 09:42
Replied by JT on topic Mesa suppliers located in UK
I'm not in the UK but I ship to the UK and have both the 7i96 and 7i96S in stock. Shipping from the USA to the UK via the USPS is the most cost effective way.
JT
  • NWE
  • NWE's Avatar
28 Jun 2026 05:05 - 28 Jun 2026 05:06
H100 communications for speed reference using mb2hal modbus
I would suggest commenting out the offending line till you can get LinuxCNC to load. Then check what pins mb2hal created. I question whether mb2hal actually creates mb2hal.spindle-set-speed, usually I see pins something like mb2hal.0.1 where the first number is the transaction number and the second is the element number.
Or am I missing something? Is there a method to have mb2hal create labeled pins?
28 Jun 2026 01:40
Replied by tommylight on topic Mesa suppliers located in UK
Not aware of any Mesa suppliers in UK, but these i used a lot:
Portugal: www.eusurplus.com
Germany: www.welectron.com
  • rodw
  • rodw's Avatar
28 Jun 2026 00:12
Lenze ECSxM via EMF2192IB (EtherCAT): CiA402 compatibility and configuration iss
Not all drives are cia402 compatible. Yours probably isn't.
you need to share more info eg.
ethercat pdos > pdos.txt
ethercat sdos > sdos.txt
and also try using lcec_configgen > configgen.xml (but there are some optional command line switches) It may create your XML for you.
  • akb1212
  • akb1212
27 Jun 2026 23:48
Dual PID loops and appropriate pins for feedback to the Trajectory Planner et al
Thanks for sharing! This is great stuff. My mill is from the same time period, so same problems as yours I guess. It's a 1989 Maho MH600E.
One thing though, would you mind sharing your actual config files? That whould be the absolute best way to help us others who are also trying to wotk out how to make this work. And since my machine have much the same issues as yours I'm hoping to be able to have a closer look at a config file which is actually working, and have solved this problem.
Thanks for sharing! I hope you see this and are willing to share your config files too!
Cheers
  • Becksvill
  • Becksvill
27 Jun 2026 04:03
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
just want to say that i am following closely on this as i am thinking of doing the same retro in the coming years on a mill turn like the intergrex. very interesting. i have 7 big cnc machines all 5ton plus machines running in my machine shop and love it. pretty keen to get into mill turn at some stage but don't really want to use the old controllers. they keep dying and i seem to have so much more machine once its got linuxcnc on it. but a mill turn is a big job!
if you want to swap notes on messenger or something hit me up probably best from my website beckcnc.co.nz.
i would love to chat this looks awesome
cheers
  • Becksvill
  • Becksvill
27 Jun 2026 03:56
hey guys
just wanted to report back on this dual feedback thread
I have a large cnc with 0.1mm backlash on the z axis.  so i put a scale on it and the results are awesome
i have accuracy within 0.002mm (compared to the scale accuracy at least assuming that is  good)
i tried both 1 PID loop and 2 PID loops that have the outputs summed together.
with the single loop i had the velocity PID input coming from the motor rotary encoder and the final position from the linear encoder.  and it worked but was really rough and kept bouncing back and forth with the 0.1mm backlash
the two summed loops are really smooth and awesome  the trick is the first loop has the high resolution encoder on servo drive and that has really good performance and of course no backlash.  and I can change all the normal PID values except Integral  and the 2nd PID loop only has the linear encoder input.  and only PID setting is Integral.  so i get nice and smooth motor but still backlash from first loop and then once the axis gets close the Integral moves the last 0.1mm over a second or so.
so by the time i am cutting the machine is perfectly where it should be.  this is probably not so good for high speed surfacing stuff for that you need to remove the physical backlash.  but for a slightly slower machine its awesome.
have a look at this thread where i show some more photos of it.  its working most days now and running hard in production.
forum.linuxcnc.org/show-your-stuff/58689...ing-running-linuxcnc
cheers
Displaying 2836 - 2850 out of 12539 results.
Time to create page: 0.272 seconds
