  • Nikita
  • Nikita
27 Jun 2026 03:09
Lenze ECSxM via EMF2192IB (EtherCAT): CiA402 compatibility and configuration iss
Hi everyone,I'm looking for some help from the community with configuring a Lenze drive setup to work with LinuxCNC via the
linuxcnc-ethercat
(lcnc-ethercat) driver.The Hardware:
  • Axis module: Lenze ECSxM
  • Communication module: Lenze EMF2192IB (EtherCAT)
The Issue: I am trying to configure the axis module control using the standard CiA402 profile. However, during diagnostics, I ran into some mapping issues:
  1. When running the
    ethercat pdos
    command, the core CiA402 profile indices like
    0x6060
    (Modes of Operation) and
    0x6061
    (Modes of Operation Display) are missing. From what I’ve gathered in the Lenze documentation, these parameters seem to be strictly hardcoded into SDOs.
  2. When running
    ethercat sdos
    , the master only returns unnamed indices strictly within the
    0x2000
    to
    0x5801
    range. Nothing above this pool is visible (objects from
    0x6000
    onwards are missing entirely).
Given this situation, I have a few questions for the experts here:
  1. Is it actually possible to get the ECSxM + EMF2192IB combo running properly under the standard CiA402 profile in LinuxCNC? Does a native driver/component for
    ethercat-cia402
    support this particular hardware?
  2. If the standard profile isn't supported out of the box due to Lenze's proprietary layout, what is the best way to handle the control? Do I need to manually map the Lenze-specific SDOs/PDOs (from the
    0x2000
    0x5000
    range) into HAL, or should I write a custom XML config to handle PDO Mapping via SDO download?
  3. If anyone has successfully configured this or has a working
    ethercat-conf.xml
    example for this generation of Lenze inverters, could you please share it?
Any advice, pointers, or examples would be greatly appreciated!Cheers!
  • rodw
  • rodw's Avatar
27 Jun 2026 00:30
Replied by rodw on topic EtherCat - CATIO module Help
Category: EtherCAT
Have you tried running RS485 through this module? I just can't seem to get it to work.
I got it going once in a test config but then never again after I built a full config. I suspect you need to set higher timeout on the serial port but have not played again.
  • PCW
  • PCW's Avatar
26 Jun 2026 22:23 - 26 Jun 2026 22:27
Replied by PCW on topic I can't reverse the spindle rotation.
Category: Basic Configuration
Honestly it sounds like you should be using a Darlington OPTO in place
of the low CTR PC817, say a LTV-815 or similar.
( PC817 mas a minimum CTR of 50% vs the LTV-815's 600% minimum )
  • PCW
  • PCW's Avatar
26 Jun 2026 22:08
Replied by PCW on topic G33.1 synchronized tapping problem
Yes! that is a win, especially if combined with the new G28 that allows rehoming
a single axis. That would really simplify combined axis/spindle operations.
  • Ismacr63
  • Ismacr63
26 Jun 2026 21:18
Replied by Ismacr63 on topic I can't reverse the spindle rotation.
Alright, bit of progress. I did some testing and managed to get the PC817 module working — at least for now.
The module has a 302Ω resistor on both the input and output side. When the LED turned on, the output voltage only dropped to about 21V, so the servo driver wasn't seeing it as a proper low signal.
I tried putting another resistor in parallel with the one already on the output side, and bingo — reverse works. With a 3k resistor in parallel, the output drops to around 14V. With a 1.5k, it drops to about 10V. Both values make the servo reverse properly.
So my question now is, what's a safe resistor value to leave in there permanently? I don't want to damage anything, but I need it to work reliably. What would you guys recommend?
26 Jun 2026 16:58
H100 communications for speed reference using mb2hal modbus
Hal files are loaded in sequence as listed in the ini file, is the ordering there set correctly?
Check for typos in the pin names.
Check the ordering of hal files as if you call on a pin that has not yet been loaded, it will fail.
26 Jun 2026 16:53
Replied by tommylight on topic Joint speed tracking - motion in danger
I started testing this and failed to recreate the issue on a sim, used the parallel port config included with LinuxCNC and while testing life got in the way and had no time to continue testing.
Thank you for reporting back.
  • karlhe
  • karlhe
26 Jun 2026 16:34
Replied by karlhe on topic Maschine faehrt Endschlter nicht an
Hallo timo,
vielen Dank für Deine Info. Ich habe die Endschalter auch in der ini abgeschatet.,
nach Anweisung von ACIERA..
Damit kann ich erst mal arbeiten.
viele Grüße Karlhe
  • davmer42
  • davmer42's Avatar
26 Jun 2026 16:30
I am in need of some help. In mb2hal.ini transaction 02, I can not get the set speed working. The crash message states that " mb2hal.spindle-set-speed does not exist ". I have stated it in the custom_postgui.hal file. I am wanting to have the " run speed slider " populate the set speed parameter in the drive.
Transactions 00 and 01 work fine
Any ideas would be appreciated.
  • Studi
  • Studi's Avatar
26 Jun 2026 14:57
NativeCAM auf Linuxcnc 2.9 was created by Studi
Category: Deutsch
 freue mich! Es lebt wieder!  Es geht weiter mit NativeCam.  NativeCAM 2.0b – Python 3- und GTK3-Portierung für LinuxCNC 2.9 / Debian 13 Trixie
NativeCAM
Damit wird Linuxcnc zu einer Steuerungssoftware mit Inkludiertem CAM... ja nicht ganz, aber fast.
Ich würde es eher Prototypen Teile Fertigungssteuerung nennen. Ähnlich der ProtoTrak oder Heidenhein-Dialog oder so.
Möcht auf die schnelle eine Rechtecktasche Fräsen und dafür nicht den CAD Rechner anstupsen. Auch nicht von Hand G-Code schreiben.
Das geht mit NativeCam!
Was denkt Ihr dazu?
Braucht Ihr das?
  • spumco
  • spumco
26 Jun 2026 14:06
Replied by spumco on topic G33.1 synchronized tapping problem
@grandixximo -
That would be a huge win if your fix works.
Now, if you can figure out the non-deterministic threading/tapping...
github.com/LinuxCNC/linuxcnc/issues/3455
  • muddiver
  • muddiver
26 Jun 2026 13:54 - 26 Jun 2026 14:29
Replied by muddiver on topic Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
Hallo zusammen,
ich hab den Fehler gemacht und mir so eine F7198 in der Version 1.1 geholt, auslesen kann ich sie, aber da muss ein Bitfile drauf.. Aktuell sind alles nur ein oder Ausgänge.. DerVerkäufer hat mir auch einen baidu-Link geschickt, aber ich bekomme die Files einfach nicht runtergeladen, vielleicht liegt auch an meinen fehlenden Chinsischkenntnissen? kann mir dabei einer helfen oder die Bitfiles für die F7198 V1.1 zur Verfügung stellen?  Vielen Dank schonmal! Gruß, Thomas
  • grandixximo
  • grandixximo's Avatar
26 Jun 2026 13:49
  • endian
  • endian's Avatar
26 Jun 2026 11:27
Replied by endian on topic Joint speed tracking - motion in danger
Hello,
I was in touch with Luca and there was a bug in the Gcode ..  first was the tolerance(I thought I am working G21)and then was the unit system(G20) which take higher tolerance and creaty the clingy movement ... it my fault to too much truct to CAM postprocessor
thank you for testing
  • Todd Zuercher
  • Todd Zuercher's Avatar
26 Jun 2026 11:02
Replied by Todd Zuercher on topic Joint speed tracking - motion in danger
In fact give this a try. Set your G64 setting to G64 P0.1 Q0.001. I think you may like the results.
Displaying 2851 - 2865 out of 12539 results.
Time to create page: 0.457 seconds
