  • SwitchWitch
  • SwitchWitch
02 Jun 2026 19:05
Rotary Axis was created by SwitchWitch
Rotary Axis
Looking for some community advice:
I’m planning to add a 4th axis (rotary A-axis) to my milling machine. In principle, that’s not a problem. What I’m wondering is how to best handle situations where the stock isn’t clamped perfectly centered in the chuck/vise.I think it’s unrealistic to expect the workpiece to be mounted absolutely concentric every single time.I’m using the Probe Basic interface. I checked the probing functions to see if I could probe and compensate with G52, but that doesn’t seem to be possible.
How would you approach this? Would you probe the offset somehow, use a different work coordinate system, or handle it another way?I’d appreciate any tips or suggestions!
  • djdelorie
  • djdelorie
02 Jun 2026 19:00
Post-M6 - restore X,Y ? was created by djdelorie
I have a rack-based toolchanger/toolsetter at the back of my CNC router.  My custom M6 gcode saves the X,Y location at the start, and moves back there at the end (at max Z, of course).  Often the next thing that happens is a rapid to a different X,Y.  I'm wondering if there's a safe way to not restore the position after the M6, or if there's some magic to restore it only if the next move is anything other than a G0XnYn move (i.e. G1 or G0Zn)?
  • PCW
  • PCW's Avatar
02 Jun 2026 17:40
Mesa 7i96s with 7i74 and additional pwmgen
Category: Driver Boards
Not sure, works for me:
mesaflash --device 7i96s --addr 10.10.10.10 --write 7i96s2p_7i74d.bin --reload
md5sum 7i96s2p_7i74d.bin
b77b9faf82730e3acf82c2cdcba6e022  7i96s2p_7i74d.bin
mesaflash --device 7i96s --addr 10.10.10.10 --readhmid > 7i96s2p_7i74d.txt
gives me:
File Name: 7i96s2p_7i74d.txt
File Size:7 KB
  • Aciera
  • Aciera's Avatar
02 Jun 2026 17:37 - 02 Jun 2026 17:48
Replied by Aciera on topic potential bug in version 2.9.8
Thanks for reporting.
Given that you could actually run the gcode after getting the 'Radius to end of arc differs from radius to start' message on load would point to a bug in the arc checking done on load which might be connected to a bug fix:
There was a bug that had made the preview use the RS274NGC_STARTUP_CODE in the ini file whenever a new gcode was loaded. This could lead to the preview not matching the currently set machine state. Eg if the gcode did not contain the WCS system (eg G54 or G55) and the controller was currently in, say, G56 but the ini startup_code contained G54 the preview would show the tool path with reference to G54 when the machine would actually run the program with reference to G56 (ie possibly somewhere entirely different).
Could you post your gcode file ?
  • Lennart
  • Lennart
02 Jun 2026 17:21
Replied by Lennart on topic Mesa 7i96s with 7i74 and additional pwmgen
Hello again,Somehow I'm struggling to flash the configuration:
mesaflash --write
returns a success message, but running
--readhmid
afterwards shows absolutely no change.I've tried it with my newly generated bin file (
7i96s2p_7i74d.bin
), but also with various other configurations. I made sure to execute
--reload
and also did several hard power cycles (power resets). I checked the board status using
--verbose
, and it looks like fallback is not active.Does anyone have an idea what could be blocking the update, or what I might be missing?
I attached my terminal outputs.Thanks in advance!
  • depronman
  • depronman
02 Jun 2026 16:27
potential bug in version 2.9.8 was created by depronman
I have recently upgraded both my lathes from 2.8.4 and parallel ports to 2.9.8 and MESA cards
All is running well over the last 6 to 8 weeks and is all stable
However I loaded up a Gcode that I wrote some years ago today and linuxcnc was throwing an error related to the G02 / G03 lines stating that the arc would not meet up or words to that effect
Checking the G03 line all seemed correct, I work in Diameter mode G07 and metric units, the previous X and Z position where correct and a radius of 0.6mm was called for, the finished X was start X + Rx2 and the finished Z was start Z - R
As stated already this Gcode had been written some years ago and used many times without issue
I have amongst others G07 set in the INI files, and as such I do not normall include G07 in my Gcode files (I had always assumed that the INI files would set the machine to G07 and therefore setting G07 in every Gcode was not necessary, I do the same with metric units and never set G21 in my Gcode files as it is set in the INI file)
Running the Gcode all went well appart from the nag message about the ARC but other than that the Gcode ran and produced the correct component, Howerver the graphic on screen display was NOT correct, the white lines (tool path) where drawn at twice the distance from the centre line. When the Gcode was executed the red lines where drawn in the correct place which was NOT over the top of the white lines)
The digital readout on screen was all displayed in Dia mode having the black background and Radius mode the green background
When the Gcode was started the on screen display was moved to show the origin position, this could be moved to show the component being machined.
I found that adding G07 to the start of the Gcode fixed the display problem and the nag message about the ARC
My assumption is that the on screen display is generated from the Gcode file but is NOT utilising the G07 from the INI file
The machine interpeter is using the G07 from the INI files and set the machine to Dia mode and correctly machines the component.
As stated previous versions, at least 2.8.4, did not work like this, and if I'm honest this feels like a bug in 2.9.8
There is a work around to add the G07 to each and every Gcode file but in my eyes this should not be required as it is already set to G07 in the INI file
lower left hand bottom corner of Gmoccapy screen shows active G code and G7 is there even without the G07 in the Gcode
its very repeatable, remove the G07 from the Gcode and save the Gcode and the ARC error message is displayed, add the G07 to the Gcode and save the file and no ARC message
MY lathe is a slant bed, tooling on the back of the machines just in case that could be relavent
Whats your thoughts
  • eraserhd
  • eraserhd
02 Jun 2026 14:56
Replied by eraserhd on topic Remora for RP2040
Remora for RP2040
Nice!
I did get PIO working and made a pull request . I hadn't announced it yet because I want to stress the heck out of it, and I just ordered a PCB that will form a hardware test harness for it. It seems like it will work well, but I want to make sure that when six axes are chugging along full speed, the scheduling doesn't slip or lock up.
It theoretically should be capable of 200KHz stepping, but again, I haven't stressed it yet.
I bought the WIZNet RP2350 board as well. One of my pull requests should in fact work on it, but I haven't tried it.   I'll check out this code soon!
Hey @scotta , any chance we can get some of the other PRs merged?  They are starting to stack.  #12, #14, #15, and #17 should all be good to merge, and #11 could be closed if #15 is merged.  (The forum won't let me link the PRs.)
  • meister
  • meister
02 Jun 2026 07:40
Replied by meister on topic Jog speed
Jog speed
Category: AXIS
a usefull commandline to check changes in hal
# halcmd show | grep -v "time\|period\|,\|ready$" > /tmp/t1 ; while sleep .1; do halcmd show | grep -v "time\|period\|,\|ready$" > /tmp/t2; diff /tmp/t1 /tmp/t2 | grep "^>\s*[1-9]" | sort -u ; mv /tmp/t2 /tmp/t1 ; done
>     23  float OUT                  3.97  halui.feed-override.value
>     23  float OUT                  4.71  halui.feed-override.value
>     23  float OUT                     5  halui.feed-override.value
>     23  float OUT                  0.57  halui.rapid-override.value
>     23  float OUT                  0.38  halui.rapid-override.value
>     23  float OUT                  0.15  halui.rapid-override.value
  • meister
  • meister
02 Jun 2026 07:30
Jog speed
Category: AXIS
You can read the values for any of these controls, except for the jog speed control. :(
  • RMJ fabrication
  • RMJ fabrication
02 Jun 2026 07:02
Ethernet connection to Mesa 7i76e disconnecting on its own after one minute
Category: Plasmac
I just ordered two Mesa 7I76EUs, two Mesa THCAD2s, two Hp elitedesk 800 G1 USDT with i5 2.9ghz 16gb ram 512gb ssd, and two cat 8 ethernet cables. So I really want to keep trying until I have a working system. This is my third attempt at trying to achieve a working plasma table and so far I have only got to use my machine for five minutes at a time at most. I really appreciate the amazing support from you all
  • grossm5000
  • grossm5000
02 Jun 2026 00:44
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
i am full speed ahead on the dell optiplex 5050...i will mess with the Asus later, probably with a different machine, Right now, I just need this thing to be operational to boost morale a bit :)
I am thinking ill probably get another 7i77 because i already have a 6i25 and I am eyeing up a fadal VMC40
  • ALS
  • ALS
01 Jun 2026 22:13
Jog speed was created by ALS
Jog speed
Category: AXIS
Hi guys, I'd like to know how to read the value of the jog speed component as shown in the attached image.
  • rodw
  • rodw's Avatar
01 Jun 2026 19:56
LinuxCNC 2.9 / Debian 12 RT – EtherCAT Master Setup für 750W Servo gesucht
Category: Deutsch
Hi Rodw,
Your link to the page is gone.
Wasn't me. Search for @MrRodW on youtube
  • justincase79
  • justincase79
01 Jun 2026 16:26
Kollmorgen AKD option code was created by justincase79
Category: EtherCAT
Hi all
I have found a Kollmorgen servo drive with ethercat that seems to match my requirements, the part number is AKD-P00606-NBEC-0051. But I am not able to find any info on the option code -0051, anyone knows?
  • spumco
  • spumco
01 Jun 2026 15:36
Setting up the Stepperonline A6 battery encoder cable
Category: EtherCAT
@andrax,
Thank you for posting the A6 encoder and homing information - very helpful.
If you don't mind, I have a few questions directly related to your post:
  • Step 6 - I assume you mean trigger the drive's internal homing routine, yes?
    • If so, what homing method (of the 33 available) did you select?
      • Reviewing your HAL file, it appears you have a home switch connected to one of the drive's built-in input pins - is that what you used to home the servo?
      • How did you trigger the drive's homing routine?
    • If not, can you clarify "perform a reference run"
  • Step 7 - do you mean adjust HAL and INI files as you've described in your post, or some other adjustment?
    • Maybe once the servo is homed, you calculate the joint/axis max & min limits and put that in the INI file?
  • XML file - can you post your xml file please?
    • That would help me, and perhaps others, understand the various lcec pins in your HAL file
Again, thanks very much for assisting the LCNC community.
Displaying 3316 - 3330 out of 12541 results.
Time to create page: 2.246 seconds
