  • Pipik
  • Pipik
16 Mar 2026 08:27 - 16 Mar 2026 09:02
Replied by Pipik on topic StepperOnline A6 Servo
Category: EtherCAT
here is my configuration.
It works. I use XYYZ.
Hello.
Just trying to set up simmilar machine configuration asyou have. I am trying to use your configuration, but run into weird problem - at hal, Ethercat to CIA402 driver mapping section, "joint.0.cia-statusword does not exist".
Also joint.0.request-cia-homing, joint.0.start-cia-homing,
What am I missing?
  • grandixximo
  • grandixximo's Avatar
16 Mar 2026 06:31
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
Honestly, waiting for Scott for some direction, he is not been replying any messages, so at the moment everything is stale, I don't really want to touch core functionality, I'm not sure about the uspace work by Sascha, should linuxcnc take that in as well? We would have to build Sasha's ethercat master as well to enable all of that. Not sure what the community needs
  • rodw
  • rodw's Avatar
16 Mar 2026 06:19
Replied by rodw on topic Trouble with XFCE (trixie) timed logouts
Category: Installing LinuxCNC
Its actually very difficult to stop this. Been there done that.
You could try running this script with sudo. It creates some system settings that have been working for me.
#!/bin/bash
set -e
# 1. GLOBAL XFCE SETTINGS (XDG)
# This overrides defaults for ALL users (Live user and installed users)
mkdir -p /etc/xdg/xfce4/xfconf/xfce-perchannel-xml/
# Force Presentation Mode and Disable Sleeping/Blanking
cat <<EOF > /etc/xdg/xfce4/xfconf/xfce-perchannel-xml/xfce4-power-manager.xml
<?xml version="1.0" encoding="UTF-8"?>
<channel name="xfce4-power-manager" version="1.0">
  <property name="xfce4-power-manager" type="empty">
    <property name="presentation-mode" type="bool" value="true"/>
    <property name="lock-screen-suspend-hibernate" type="bool" value="false"/>
    <property name="blank-on-ac" type="int" value="0"/>
    <property name="dpms-on-ac-sleep" type="int" value="0"/>
    <property name="dpms-on-ac-off" type="int" value="0"/>
    <property name="dpms-enabled" type="bool" value="false"/>
  </property>
</channel>
EOF
# Disable Screensaver Globally
cat <<EOF > /etc/xdg/xfce4/xfconf/xfce-perchannel-xml/libxfce4ui.xml
<channel name="libxfce4ui" version="1.0">
  <property name="screensaver" type="empty">
    <property name="enabled" type="bool" value="false"/>
  </property>
</channel>
EOF
# 2. BRUTE FORCE X11 DISABLE
# This ensures that even if XFCE isn't running, the X server itself won't blank
mkdir -p /etc/X11/xorg.conf.d/
cat <<EOF > /etc/X11/xorg.conf.d/10-disable-blanking.conf
Section "ServerFlags"
    Option "BlankTime" "0"
    Option "StandbyTime" "0"
    Option "SuspendTime" "0"
    Option "OffTime" "0"
EndSection
EOF
# 3. SYSTEMD MASKING (The Nuclear Option)
# This prevents the OS from sleeping even if a "suspend" command is sent
systemctl mask suspend.target hibernate.target sleep.target hybrid-sleep.target
  • currinh
  • currinh's Avatar
16 Mar 2026 04:23
Every few years I upgrade something on my stepper controlled knee-mill. I usually get sucked into upgrading linuxcnc at the same time. I just upgraded the stepper motors and put a new controller on. The new controller is using Mesa 5i25 and 7i76 cards with Gecko drivers. I was running linuxcnc 2.9.4 and decided to upgrade to 2.9.8. Rather than upgrade I did a new install with 2.9.8 (Debian trixie).
After install, and working though several problems, I have linuxcnc 2.9.8 working well with a Pncconf configuration. But, I am having great trouble with the computer logging out every 30-60 minutes. A very bad thing for a machine controller. I suspect this is in the XFCE environment but can not find a solution via Internet searching.
I did find, through searching, and have implemented the following changes:
I changed /etc/ligntdm/ligntdm.conf to implement auto login by un-commenting
  autologin-user-[my user name : hugh]
  autologin-user-timeout = 0
In the XFCE settings I disabled Lock Screen [disable "Lock screen when idle"] and disabled Screen Saver.
To prevent logout from /etc/syslogout I put an empty file as "$HOME/.nosyslogout"
In XFCE setting, under Power Management, assured the "Suspend When Inactive for" was set to never.
I did try, I believe, disabling the Display Power Management toggle in the setting menu. This caused a broken system. When a login was done the machine thought awhile then returned to the login screen. I could not figure out how to fix this via the terminal so had to re-install linuxcnc. I re-installed once without re-formatting the /home directory but the login loop was still present. Another re-install with re-formatting all partitions brought me back to zero. I'm trying to not repeat this error.
The computer now starts up without requiring a  login, that's fine. It works for 30-60 minutes and then logs me out. The result of the logout was a new login screen (user: & password). After the above changes, auto login, it automatically logs me back in. But for both of these, any running applications, like linuxcnc, are killed with the logout/login.
What am I missing? Is there a simple fix or should I step back to linuxcnc 2.9.4 and see if it still works?
I am surprised by this problem. I'd think a linuxcnc ISO should be set up for no screen saver and certainly no timed logout. This seems like death to a machine controller where a complicated program could run for a couple of hours. This tends to convince me I've done something wrong with this new clean install.
Thank you for any help you can provide.
  • timo
  • timo
16 Mar 2026 03:25
Replied by timo on topic Inaccurate milling - what could it be?
Category: Basic Configuration
The question is how far are you off dimension?
Are we talking about 0.005 mm? Or mor like 0.2 mm? :-)
On the video it looks like your endmill sticks out "far too" long.
You probably can put it further up into the holder.
Follow suggestions of #344316, finish pass.
  • rodw
  • rodw's Avatar
16 Mar 2026 03:04
Replied by rodw on topic Ethercat random jitter fix
Category: EtherCAT
Take care with merging Sasha's code. The master linuxcnc-ethercat driver is now Scott Lairds repo github.com/linuxcnc-ethercat as it has a workflow that pushes the driver when built across to etherlabs repo on gitlab so we can get the driver with sudo apt install
  • rodw
  • rodw's Avatar
16 Mar 2026 02:53
Installing Linuxcnc on new pc Using Debian 12.13 and Linuxcnc 2.9.8 mesa 7i76eu
thank you Peter,
That got rid of the error there but it points now to an error on Hal line 25: empty variable name. I don't know how lines are counted no matter how many ways I counted them it did not make sense to me.
I so very much appreciate your help, I have spending days with AI trying to get this figured out to no avail, you forum experts know this stuff!!!!
Grorge
If you open the file with geany which is part of the linuxcnc ISO. the  editor will show line numbers.
  • Marcos DC
  • Marcos DC's Avatar
16 Mar 2026 02:15
Replied by Marcos DC on topic El5101 Config
El5101 Config
Category: EtherCAT
It may be less a case of “no results” and more a case of “the pieces exist, but there does not seem to be a complete worked example showing how to tie them together in LinuxCNC.”
If you already get the Z/C event, then it sounds like the remaining issue is LinuxCNC integration rather than the EL5101 itself.
Using the EL5101 for A/B and a separate optical sensor for Z into an EL1008 sounds like a practical workaround if you are looking for a known working threading setup to base yours on.
16 Mar 2026 02:03
In your hal file, under the addf it has
setp [HMOY] hm2_7i76e.0.stepgen.timer-number 1
setp [HMOT] hm2_7i76e.0.dpll.01.timer-us -100.
Notice the HMOY should be HMOT
Editing config files at random never ever ends good.
  • kello711
  • kello711's Avatar
16 Mar 2026 01:28
Probe Basic offset direction not seeming to work
Category: QtPyVCP
I am trying to load up a 1" wood surfacing bit. I wanted to use the tool offset direction in the probing but it doesn't seem to work. I didn't find anything in the documentation to explain how. I added the diameter to the tool table to no avail. Also on the probing menu, what do "User Params" 1 and 2 do?
  • kello711
  • kello711's Avatar
16 Mar 2026 01:22
Probe Basic Errors after successfully probing
Category: QtPyVCP
I'm not sure how to remedy the errors (also attached).
Invalid params in linear command
 Linear move on line 5 would exceed joint 3's positive limit
This occurs after running a surfacing from the conversational tab. I ran the gcode and stopped it to make adjustments to the positions and then run again. The only remedy seemed to re-probe with 3d touch probe and then reload the cutting tool. This seems excessive and not sure how to fix for the future.
  • georgio
  • georgio
16 Mar 2026 01:20
thank you Peter,
Grorge
  • rock861261
  • rock861261
16 Mar 2026 01:08
Replied by rock861261 on topic El5101 Config
El5101 Config
Category: EtherCAT
Can I use the El5101 for the a/b and use an optical sensor for the z with an input to EL1008
Displaying 5701 - 5715 out of 12544 results.
Time to create page: 0.342 seconds
