  • Hannes
  • Hannes
09 Mar 2026 20:37
Replied by Hannes on topic Strange preview for circular arc (G2/G3)
Category: G&M Codes
BTW: Not having a absolute move before a relative move is probably not anything a CAM software would ever do, but it's also not illegal.
However, a "normal" preview tool not knowing where you machine is could not show you anything in that case.
  • Hannes
  • Hannes
09 Mar 2026 20:22
Category: G&M Codes
I just quickly tested it. That's a bug in gmoccapy. In axis, it works.
In axis, you have to reload the gcode after each other move, so the initial position of the circle is updated.
G2's I and J parameters are relative to the last position:
linuxcnc.org/docs/html/gcode/g-code.html#gcode:g2-g3
Now if you don't have a G0 or G1 command before, the preview in gmoccapy looks funny. I think the preview interpreter is not initialized with the actual position in the UI. The real machine interpreter has no issues afterwards.
For the first command, X,Y and Z has to be specified to work. G0 X0 Y0 is not enough, G0 X0 Y0 Z0 does the trick.
I suggest writing a bug report.
  • Finngineering
  • Finngineering
09 Mar 2026 19:18
Replied by Finngineering on topic XHC WHB04B development?
No, I did not really start a rewrite. I made a small program to communicate with the pendant, but it was more for troubleshooting than planned as the start of a new component. But I did make a new firmware for the dongle, which I have been using without issues so far.
Maybe it was not completely fair to compare it to the xhc-hb04 component. Anyway, I'm glad somebody made this component in the first place, and of course all your bugfixes and improvements are a clear step in the right direction.
I experienced an issue with arc preview just a few weeks ago that I made a post about. I think this may be a bug or limitation in the preview only rather than connected to the issue you mention. But I thought I might as well mention it, since it has some similarities to the issue you mention.
forum.linuxcnc.org/20-g-code/58285-stran...r-circular-arc-g2-g3
  • depronman
  • depronman
09 Mar 2026 19:07 - 09 Mar 2026 19:07
current latest download of LinuxCNC V2.9.8 will not install GRUB on several PC's
Category: Installing LinuxCNC
Many thanks for confirming than I’m not going mad.
The really strange part is the previous iso of LinuxCNC (2.9.7) is also based on debian13 and that installed without any grub issues and no internet access was available
However when trying to update 2.9.7 to 2.9.8 I hit loads of problems with broken packages
I’m in the process of moving all of my CNC machines from parallel ports to mesa cards and have taken the opportunity to update to the latest version and also update the PC’s from circa 2010 hardware to much newer intel NUC’s
As such I’ve installed linuxCNC 2.9.8 on three NUC’s over the last few days and allowed the graphic install to have access to my mobile phones internet connections via the NUC’s built in WiFi card. All three install have gone through perfectly
  • tuxcnc
  • tuxcnc
09 Mar 2026 18:33
Homing not works immediatelly after launch Linuxcnc
Category: EtherCAT
probably is the time to the drivers to reach the op state. in my machine i lock the enable button with the op state from the servos
Thanks.
The problem was more complex, but you drived me to good way.
I found that the lines in my hal file like <net x-modes-of-operation  cia402.0.opmode => lcec.0.X.opmode> not always works, and sometimes op state never changes to "operational".
Fortunatelly I never use other opmodes than 8, and I can set these permanently.
I added to my halfile code as bellow, and it seems work properly.
loadrt logic names=oper-sum personality=0x103
addf oper-sum                 servo-thread
#  Set opmode permanently
setp lcec.0.X.opmode 8
setp lcec.0.Y.opmode 8
setp lcec.0.Z.opmode 8
#  Check lcec operational
net oper-x         lcec.0.X.slave-state-op   =>     oper-sum.in-00
net oper-y         lcec.0.Y.slave-state-op   =>     oper-sum.in-01
net oper-z         lcec.0.Z.slave-state-op   =>     oper-sum.in-02
net oper-sum-out   oper-sum.and              =>     iocontrol.0.emc-enable-in
(It is ability to use more inputs in the logic hal component.)
  • Atsu
  • Atsu
09 Mar 2026 18:26
Replied by Atsu on topic Ethercat random jitter fix
Category: EtherCAT
I could share my experience with this issue. Attached is a link to a video showing how the jitter sounds on StepperOnline A6 servos. This is exaggerated by disabling the synchronization. Once synchronization is enabled (syncToRefClock="true" or refClockSyncCycles="-1"), it still happens but much more rarely, just like grandixximo explained at the start of this post. Last week, I upgraded to the latest version of linuxcnc-ethercat, and am currently testing how the changes committed at the end of 2025 affect my machine configuration.
​​​https://imgur.com/a/FXSuvOS
Thank you for the independent testing, if you want a better version
github.com/linuxcnc-ethercat/linuxcnc-et...84ef36b53f0b734eaedf
this I have tested and works well, unfortunately Scott has not been around to merge it, so it is not in the main linuxcnc-ethercat repo yet, but it is a better version
Great, thanks! I'll switch to that version and continue testing.
  • Atsu
  • Atsu
09 Mar 2026 18:19 - 09 Mar 2026 18:23
Category: EtherCAT
After activation of PLL there shouldn't be any random clicks anymore.
Check dmesg if you get any errors there, it can be the network adapter too.
In my case, activation of PLL fixed the issue almost entirely, but the random clunk noises still occur every once in a while, just not nearly as often. After updating to the latest version from the linuxcnc-ethercat repo, I haven't had it occur during motion anymore, which is a good sign. However, I haven't run the machine much yet, so more testing is needed. I will also check the dmesg you pointed out.
  • Hakan
  • Hakan
09 Mar 2026 17:37
Replied by Hakan on topic Ethercat random jitter fix
Category: EtherCAT
Yes, too old. Use a negative number to refClockSyncCycles. That's equivalent to the syncToRefClock="true".
  • fts
  • fts
09 Mar 2026 17:35
I have had the same issue today installing LinuxCNC 2.9.8 onto an OptiPlex 990. I don't have a network and skipped the network config, so my experience matches yours.
There must be something going on with Debian these days because I ran into a similar issue last month installing the latest version of base Debian on a brand new server. Ryzen 9 and 64GB of RAM. I was doing a non-graphical installation without a network connection, and the installation failed every time. It was a (near?) bare minimal installation that didn't include a GUI. There was some package like PostgreSQL or a DBMS portion of some SQL server that failed and killed the package installation process. I gave up and plugged an Ethernet cable into a dummy network, restarted the installation, went through the network portion, and everything worked. This is bad practice on their QA side to allow things like this to happen.
  • andrax
  • andrax's Avatar
09 Mar 2026 17:13
Replied by andrax on topic Ethercat random jitter fix
Category: EtherCAT
I cannot activate syncToRefClock="true". I get ‘invalid master attribute’. My EtherCAT version 1.6.8.g2543cc5-1+27.2 is probably too old, even though I installed it last autumn.
  • Muecke
  • Muecke's Avatar
09 Mar 2026 16:10 - 09 Mar 2026 16:11
400V Servo (51 Nm) mit EtherCAT / CiA402 in LinuxCNC – bezahlbarer Drive gesucht
Category: Deutsch
Ganz so schlimm ist es nicht ?
Ein Haus drehe ich damit nicht – aber es geht um eine Achse, auf der im Worst Case bis zu 11,5 t Achslast stehen können.
Wenn sauber verteilt wären es 5,75 t pro Rad, aber da die Lastverteilung nicht immer ideal ist, rechne ich konservativ mit ~7 t.
Der Motor selbst hat 51 Nm Nennmoment, dahinter sitzt ein 140:1 Getriebe.
Rein rechnerisch komme ich damit natürlich auf sehr hohe Haltemomente – aber das bedeutet nicht, dass ich permanent 7000 Nm fahre.
Ich habe bewusst eher „zu groß“ dimensioniert, weil:
* hohe Massenträgheit wirkt auf Motor und Getriebe
* Lastverteilung nicht konstant ist
* reproduzierbare Positionierung im mm-Bereich erforderlich ist
* Bewegung in beide Richtungen notwendig ist
* Sicherheitsreserve einkalkuliert wurde
Sollte sich im Prototyp später zeigen, dass deutlich Reserve vorhanden ist (über reale Drehmomentmessung), würde ich das System in einer späteren Ausbaustufe kleiner dimensionieren.
Was mich aktuell technisch mehr beschäftigt, ist der Drive selbst.
Wenn ich nach Servodrives schaue, finde ich fast nie eine explizite Drehzahlbegrenzung im Datenblatt.
4500 rpm sind bei mir die rechnerische Obergrenze, real erwarte ich eher 2200–3000 rpm.
Woran erkenne ich eigentlich, ob ein Drive diese Drehzahl sauber kann?
Ist das primär begrenzt durch:
* Zwischenkreisspannung / Back-EMF des Motors?
* maximale elektrische Frequenz des Drives?
* Encoder-Auswertefrequenz?
* interne Regelzykluszeit?
Oder ist bei der 400-V-Klasse eher Strom bzw. Leistung der limitierende Faktor und nicht die Drehzahl?
Falls jemand hier bereits 400-V-EtherCAT-Drives (CiA402) im Bereich 15–25 kW mit LinuxCNC (IgH + cia402.comp) im Einsatz hat, wären konkrete Erfahrungswerte sehr hilfreich.
Und ganz unabhängig davon:
Wer Interesse an dem Projekt hat – ich sitze im Großraum Stuttgart (nördlich).
Ihr seid herzlich eingeladen, auf ein Bier oder einen Tee vorbeizukommen, Euch meinen Mini-Prototypen anzuschauen und mit mir über mögliche Umsetzungen, Verbesserungen oder auch meine Denkfehler zu diskutieren.
Ich freue mich über jeden, der Lust und Zeit hat, sich das live anzusehen.
Viele Grüße
Mücke
09 Mar 2026 15:04
Replied by tommylight on topic Forum Fehler, ... :-(
Category: Deutsch
Könntest du das Thema eventuell wieder zurückverschieben?
Done.
  • DerKlotz
  • DerKlotz
09 Mar 2026 12:48 - 17 Mar 2026 10:11
Verdrahtung Leadshine DM856 Ena+ und - bei Mesa 7i76e
Category: Deutsch
Im Moment ist ENA bei mir auch nicht verdrahtet und die Treiber sind ständig an... mich nervt dieses Motorgefiepe wenn die Maschine nicht aktiv arbeitet. Das ist im Moment noch häufig der Fall, weil ich Einstellungen/GUI/Probe Basic teste. Ein bischen mehr Sicherheit ist ja auch ganz gut.
Danke für deine Antwort
Meine Verdrahtung nun im Anhang
  • timo
  • timo
09 Mar 2026 12:24 - 09 Mar 2026 12:29
Category: Deutsch
Ich habe die Enable Eingänge an den Motoren einfach frei gelassen :-) die Maschine muss (eh) "festgehalten" werden, wenn der jeweilige Motor sich nicht dreht.
Bei meinem DM860H (noname), geht der Motorstrom aus, wenn ENA+ (5V) und ENA- (GND).
Das funktioniert also prima ohne Enable, ist aber wahrscheinlich so, wie Mücke schreibt.
  • tiagounderground
  • tiagounderground
09 Mar 2026 11:57
Replied by tiagounderground on topic Homing not works immediatelly after launch Linuxcnc
Category: EtherCAT
Displaying 5971 - 5985 out of 12546 results.
Time to create page: 0.762 seconds
