  • cmorley
  • cmorley
25 Sep 2026 17:23
Replied by cmorley on topic Flex GUI 2.1.0 OpenGL 3.3
Category: Flex GUI
As for guis there is good and bad on both sides of having code in and out of the main project.
Linuxcnc is lucky, it has both options.
25 Sep 2026 16:00
Replied by tommylight on topic LinuxCNC-Branded USB Drives
Very nice idea, thank you.
  • andypugh
  • andypugh's Avatar
25 Sep 2026 14:59 - 25 Sep 2026 15:03
LinuxCNC-Branded USB Drives was created by andypugh
I have had occasions at events like EMF Camp and Maker Central that I have wished that I had a USB drive with LinuxCNC on it to hand out, like a sort of business-card for the project. It would lower the barrier for entry, and also serve as a reminder of the conversation when they got home.
However, I don't want to spend my own money on this. So the plan I hatched was to sell a decently-sized version of the USB key at a slight premium, each of which funds a smaller, cheaper giveaway version.
So this is what I have done. £25 gets you a 128GB LinuxCNC stick with both USB-A and USB-C plugs, and also buys an 8GB one with LinuxCNC on it, for a stranger who is not yet aware of the joys of LinuxCNC.
www.ebay.co.uk/itm/117429761717
  • tietouwa
  • tietouwa's Avatar
25 Sep 2026 13:48
J1900 L2 sibling: pin Qt HMI to CPUs 0-1, keep the 1 ms EtherCAT thread on CPU3
Category: EtherCAT
Thanks rodw. I'm not using ec_generic. The EtherCAT port runs on IgH's native ec_r8169 driver, which is polled from the RT thread on CPU3, so there is no NIC IRQ to pin. What I pinned: the 1 ms thread on CPU3 (SCHED_FIFO 80), and the Qt HMI threads on CPUs 0-1 via taskset. Isolating CPU2 is a good idea. I'll try it next.
  • Japoo_Ness
  • Japoo_Ness
25 Sep 2026 11:10
Retrofitting a 3-axis VMC with DC servos - guidance needed
Category: Driver Boards
Hi everyone, I'm experiencing noisy/fluctuating readings on my axes. They are currently ungrounded as I just wanted to verify basic readings first. My main star ground is in the main electrical cabinet, but my Mesa 7I97T is mounted remotely in the old display/controller enclosure. I'm considering the grounding scheme shown in the attached diagram. Is this a good approach for logic signals, or will the extra connection points make it more prone to noise and ground loops?
  • JB-Motoring
  • JB-Motoring
25 Sep 2026 10:59
Exchange Simodrive 610 to new components was created by JB-Motoring
Hello guys,
I am running Linuxcnc on my Chiron FZ12S for almost 10 years now.
The machine is equipped with Siemens hardware ( 1FT5 Motors and Simodrive 610 +/-10V).
What I notice, is that the Simodrive is getting old... It starts with random Joint following errors, then cutting out, Errors ect.
There are days, where you have to switch on and off like 50 times to get the machine homing without error...That's just frustrating. But yeah, the drives are almost 35 years old, so quite okay for that age.
I am thinking quite long about this project, but today pissed me so off, that I really want to move on.
For me, it's no option in buying "refreshed" hardware, because that stuff is expensive and also 30+ years old....
So my wish would be, to completely throw the Simodrive away and replace it by new hardware, that doesn't cost as much as the Siemens stuff.
I am running this right now on the 7I77 hardware, but for sure can switch to another board.
Motors XYZ, 4th axis are: Siemens 1FT5064- 1.6 kW @ 4000 RPM
Spindle: Siemens 1FT5076- 7.5 kW @ 7100 RPM
The motors are equipped with Tachos and ROD encoders.
Are there any drives, that could work with these? I would really like to keep the motors, as they are really good and not worn out.
I am happy over any input!
Thank you guys!
  • Aciera
  • Aciera's Avatar
25 Sep 2026 10:42
Replied by Aciera on topic Notifications
Notifications
Category: Show Your Stuff
Thanks for sharing it!
  • Aciera
  • Aciera's Avatar
25 Sep 2026 10:41
Replied by Aciera on topic qtvismach, a axis toolpath
Category: Qtvcp
If anyone uses Vismach and would like to test this out, please let me know.
I'd be _very_ interested indeed. Do you have a repo?
  • Aciera
  • Aciera's Avatar
25 Sep 2026 10:38
EGECOBOT - 6 Axis Industrial Robot with LinuxCNC & EtherCAT
You might be interested in testing the currently ongoing work on multi axis features:
github.com/LinuxCNC/linuxcnc/pull/4374
  • emresensoy
  • emresensoy
  • michaeln
  • michaeln
25 Sep 2026 08:21
Nice project.
But the wrong name? That a robot and not a cobot?
  • muddiver
  • muddiver
25 Sep 2026 07:32
No chance to use outputs on P1 MESA 7i92 help needed.
Hi LuxCNC, Hi Rod!
thanks for your hints!
setp hm2_7i92.0.gpio.019.is_output 1 did the trick for me!
Honestly, i thought i was through with the obvious starter-issues, but as i learned, not by far!
Thanks for the hint with inverting the pwm, i will have a look at it!.
Also the "spindle-rpm-reached" will be part of the ongoing process!
Greets, Tom
  • Unlogic
  • Unlogic
25 Sep 2026 05:44
Replied by Unlogic on topic Optimum Optimill MH50V CNC conversion
Category: Milling Machines
And here is how it looks with the enclosure mounted on the table.
With all the mechanical bits in place I wrote a short spindle run-in program that increased the spindle rpm in increments of 500 up to 6000 and ran for 10 minutes at each increment.
Everything worked well until I reached 5000 rpm when the spindle servo threw a fault. Turned out I had the max allowed rpm set to 4500 in the servo drive since my old spindle couldn't go that high.
Fixed that and immediately ran into the next issue, the default rpm limit for the encoder speed in the servo drive also had to be increased. In the end I had to bump up quite a few parameters including tweaking the inertia to get the full 6000 rpm range enabled in the drive.
The next issue I ran into was that the rpm would not go above 5610 when commanded from LinuxCNC. Turned out that I had to adjust the settings in LinuxCNC regarding how many steps (pulses) per seconds that could be sent to the spindle. Just as with the drive I had set these value quite low for my old spindle when I did the configuration years ago.
With all that sorted I could finally finish the run-in program. But when the program stopped after running the final increment at 6000 rpm I ran into the next issue. The drive threw a fault regarding an overheated regenerative braking resistor.
Going from 3500 to 6000 rpm along with the increased the inertia from the larger spindle overwhelmed the built in regenerative braking resistor in the spindle drive when coming to a full stop from 6000 rpm. I managed to get it somewhat working for now by increasing the time for the spindle ramp down by a few seconds.
But if I stop the spindle a few times in successions from full rpm I still get the fault. So I ended up ordering an external 800W braking resistor which should be here early next week.
If I managed to follow the formulas in the Delta B3 manual correctly a 550W resistor should be enough for my setup. So hopefully 800W will give me plenty of headroom.
However after all the troubleshooting I was still very satisfied at the end of the day when I removed the BT40 tool holder which had been in the spindle all day running at various rpm's. It was essentially the same temperature as when I had picked it up from the tool shelf in the morning.
The new spindle is running significantly cooler compared to the old one. This can also be seen on the idle load.
With the old spindle I would have an idle load of 17-20% on the 2kw spindle servo just running idle at 3500 rpm. The new spindle sits between 1-6% depending on rpm, at 6000 the load is just 1-2% which is very promising.
  • emresensoy
  • emresensoy
25 Sep 2026 03:47 - 25 Sep 2026 03:53
Hi everyone,
I’m building EgeCobot, a custom 6-axis collaborative robot arm powered by LinuxCNC and EtherCAT.
I’m writing my own custom kinematics component for LinuxCNC to handle trajectory planning and joint control for this 6-DOF setup.
Here is the first video introducing the project and mechanical layoutlanned Tech Stack:
* 6-DOF articulated cobot design
* Custom LinuxCNC kinematics module
* EtherCAT fieldbus for real-time joint control
I’d love to hear your feedback and suggestions on EtherCAT setup and HAL integration!
Best regards,
Emre
25 Sep 2026 01:48
Z axis torch initially going up instead of down when clicking cycle start
Category: Plasmac
I wonder what the cause is. Part of me thinks people have moved on to laser since it's become more affordable.
Yes, exactly, here the government payed 15K Euro to china for everyone working with metal that applied for the grant to buy a laser and they added the rest, so basically killed off my business completely.
Not the only business, so i was not worried ... till the PC market went bananas with prices skyrocketing, so no more PC builds for now, and in the near future by the looks of it.
3D printing business was not that active, but occasionally it would bring nice revenue from people with bitcoin miners that needed cooling adapters...
I am ranting again ... sorry.
Displaying 676 - 690 out of 11520 results.
Time to create page: 0.529 seconds
